[GRASS-SVN] r35511 - in grass/trunk/gui/wxpython: gui_modules icons
Tue Jan 20 15:03:08 EST 2009
Author: martinl
Date: 2009-01-20 15:03:08 -0500 (Tue, 20 Jan 2009)
New Revision: 35511
   grass/trunk/gui/wxpython/gui_modules/mapdisp.py
   grass/trunk/gui/wxpython/gui_modules/mapdisp_command.py
   grass/trunk/gui/wxpython/gui_modules/mapdisp_window.py
   grass/trunk/gui/wxpython/icons/icon.py
fix wxGUI to work with p.mon
Modified: grass/trunk/gui/wxpython/gui_modules/mapdisp.py
--- grass/trunk/gui/wxpython/gui_modules/mapdisp.py	2009-01-20 19:48:32 UTC (rev 35510)
+++ grass/trunk/gui/wxpython/gui_modules/mapdisp.py	2009-01-20 20:03:08 UTC (rev 35511)
@@ -32,6 +32,8 @@
 import tempfile
 import copy
+import gui_modules.globalvar as globalvar
+globalvar.CheckForWx()
 import wx
 import wx.aui
@@ -46,6 +48,9 @@
 gmpath = os.path.join(globalvar.ETCWXDIR, "icons")
 sys.path.append(gmpath)
+grassPath = os.path.join(globalvar.ETCDIR, "python")
+sys.path.append(grassPath)
 import render
 import toolbars
 import menuform
@@ -463,7 +468,8 @@
         Change choicebook page to match display.
         Or set display for georectifying
-        if self.gismanager.georectifying:
+        if self.gismanager and \
+                self.gismanager.georectifying:
             # in georectifying session; display used to get get geographic
             # coordinates for GCPs
             self.OnPointer(event)
@@ -959,16 +965,14 @@
         if self.toolbars['nviz']:
             self.toolbars['nviz'].OnExit()
-        if self.page:
+        if not self.gismanager:
+            self.Destroy()
+        elif self.page:
             pgnum = self.layerbook.GetPageIndex(self.page)
             if pgnum > -1:
                 self.layerbook.DeletePage(pgnum)
-        ### self.Destroy()
-        # if event:
-        #    event.Skip() <- causes application crash
     def GetRender(self):
         Returns the current instance of render.Map()
@@ -1641,7 +1645,7 @@
         if __name__ == "__main__":
             # redraw map, if new command appears
             self.redraw = False
-            status = Command(self, Map)
+            status = Command(self, Map, cmdfilename)
             status.start()
             self.timer = wx.PyTimer(self.watcher)
             # check each 0.1s
@@ -1675,9 +1679,9 @@
     cmdfilename = sys.argv[2]
     import gettext
-    gettext.install("gm_map") # replace with the appropriate catalog name
+    gettext.install('grasswxpy', os.path.join(os.getenv("GISBASE"), 'locale'), unicode=True)
-    print "Starting monitor <%s>" % (title)
+    print >> sys.stderr, "\nStarting monitor <%s>...\n" % (title)
     gm_map = MapApp(0)
     # set title
@@ -1688,6 +1692,6 @@
     os.remove(cmdfilename)
     os.system("""g.gisenv set="GRASS_PYCMDFILE" """)
-    print "Stoping monitor <%s>" % (title)
+    print >> sys.stderr, "\nStoping monitor <%s>...\n" % (title)
-    sys.exit()
+    sys.exit(0)
Modified: grass/trunk/gui/wxpython/gui_modules/mapdisp_command.py
--- grass/trunk/gui/wxpython/gui_modules/mapdisp_command.py	2009-01-20 19:48:32 UTC (rev 35510)
+++ grass/trunk/gui/wxpython/gui_modules/mapdisp_command.py	2009-01-20 20:03:08 UTC (rev 35511)
@@ -14,6 +14,9 @@
 @author Jachym Cepicky
+import sys
+import time
 from threading import Thread
 class Command(Thread):
@@ -21,14 +24,14 @@
     Creates thread which will observe the command file and see, if
     there is new command to be executed
-    def __init__ (self, parent, Map):
+    def __init__ (self, parent, Map, cmdfile):
         Thread.__init__(self)
         global cmdfilename
         self.parent = parent
         self.map = Map
-        self.cmdfile = open(cmdfilename, "r")
+        self.cmdfile = open(cmdfile, "r")
     def run(self):
Modified: grass/trunk/gui/wxpython/gui_modules/mapdisp_window.py
--- grass/trunk/gui/wxpython/gui_modules/mapdisp_window.py	2009-01-20 19:48:32 UTC (rev 35510)
+++ grass/trunk/gui/wxpython/gui_modules/mapdisp_window.py	2009-01-20 20:03:08 UTC (rev 35511)
@@ -688,7 +688,8 @@
         if len(self.polycoords) > 0:
             self.DrawLines(self.pdcTmp)
-        if self.parent.gismanager.georectifying:
+        if self.parent.gismanager and \
+                self.parent.gismanager.georectifying:
             # -> georectifier (redraw GCPs)
             if self.parent.toolbars['georect']:
                 coordtype = 'gcpcoord'
Modified: grass/trunk/gui/wxpython/icons/icon.py
--- grass/trunk/gui/wxpython/icons/icon.py	2009-01-20 19:48:32 UTC (rev 35510)
+++ grass/trunk/gui/wxpython/icons/icon.py	2009-01-20 20:03:08 UTC (rev 35511)
@@ -21,8 +21,8 @@
 import os
 import sys
-import wxversion
-wxversion.select('2.8')
 import wx
 gmPath = os.path.join(os.getenv("GISBASE"), "etc", "wxpython", "gui_modules")
