[GRASS-SVN] r35513 - grass/trunk/gui/wxpython/gui_modules
Tue Jan 20 15:14:14 EST 2009
Author: martinl
Date: 2009-01-20 15:14:14 -0500 (Tue, 20 Jan 2009)
New Revision: 35513
   grass/trunk/gui/wxpython/gui_modules/mapdisp.py
   grass/trunk/gui/wxpython/gui_modules/nviz_mapdisp.py
more p.mon-related fixes
Modified: grass/trunk/gui/wxpython/gui_modules/mapdisp.py
--- grass/trunk/gui/wxpython/gui_modules/mapdisp.py	2009-01-20 20:04:40 UTC (rev 35512)
+++ grass/trunk/gui/wxpython/gui_modules/mapdisp.py	2009-01-20 20:14:14 UTC (rev 35513)
@@ -285,9 +285,13 @@
                               CloseButton(False).Layer(2))
         # vector digitizer
         elif name == "vdigit":
+            if self.gismanager:
+                log = self.gismanager.goutput
+            else:
+                log = None
             self.toolbars['vdigit'] = toolbars.VDigitToolbar(parent=self, map=self.Map,
                                                              layerTree=self.tree,
-                                                             log=self.gismanager.goutput)
+                                                             log=log)
             for toolRow in range(0, self.toolbars['vdigit'].numOfRows):
                 self._mgr.AddPane(self.toolbars['vdigit'].toolbar[toolRow],
@@ -345,7 +349,8 @@
             # update layer tree (-> enable 3d-rasters)
-            self.tree.EnableItemType(type='3d-raster', enable=True)
+            if self.tree:
+                self.tree.EnableItemType(type='3d-raster', enable=True)
             # update status bar
@@ -436,7 +441,8 @@
             # update layer tree (-> disable 3d-rasters)
-            self.tree.EnableItemType(type='3d-raster', enable=False)
+            if self.tree:
+                self.tree.EnableItemType(type='3d-raster', enable=False)
         self.toolbars['map'].combo.SetValue (_("2D view"))
         self.toolbars['map'].Enable2D(True)
@@ -573,7 +579,7 @@
             else: # moveLine, deleteLine
                 self.MapWindow.mouse['box'] = 'box'
-        elif self.gismanager.georectifying:
+        elif self.gismanager and self.gismanager.georectifying:
             self.MapWindow.SetCursor(self.cursors["cross"])
         else:
@@ -1638,7 +1644,8 @@
         else:
             Map = None
-        self.mapFrm = MapFrame(parent=None, id=wx.ID_ANY, Map=Map, size=(640,480))
+        self.mapFrm = MapFrame(parent=None, id=wx.ID_ANY, Map=Map,
+                               size=globalvar.MAP_WINDOW_SIZE)
         #self.SetTopWindow(Map)
         self.mapFrm.Show()
@@ -1685,8 +1692,10 @@
     gm_map = MapApp(0)
     # set title
-    gm_map.mapFrm.SetTitle ("GRASS GIS - Map Display: " + title + " - Location: " + \
-                                grass.gisenv()['LOCATION_NAME'])
+    gm_map.mapFrm.SetTitle(_("GRASS GIS Map Display: " +
+                             title +
+                             " - Location: " + grass.gisenv()["LOCATION_NAME"]))
     gm_map.MainLoop()
     os.remove(cmdfilename)
Modified: grass/trunk/gui/wxpython/gui_modules/nviz_mapdisp.py
--- grass/trunk/gui/wxpython/gui_modules/nviz_mapdisp.py	2009-01-20 20:04:40 UTC (rev 35512)
+++ grass/trunk/gui/wxpython/gui_modules/nviz_mapdisp.py	2009-01-20 20:14:14 UTC (rev 35513)
@@ -97,9 +97,14 @@
         # create nviz instance
-        self.nvizThread = NvizThread(self.gismgr.goutput.cmd_stderr,
+        if self.gismgr:
+            logerr = self.gismgr.goutput.cmd_stderr
+            logmsg = self.gismgr.goutput.cmd_output
+        else:
+            logerr = logmsg = None
+        self.nvizThread = NvizThread(logerr,
                                      self.parent.onRenderGauge,
-                                     self.gismgr.goutput.cmd_output)
+                                     logmsg)
         self.nvizThread.start()
         time.sleep(.1)
         self.nvizClass =  self.nvizThread.nvizClass
@@ -338,6 +343,9 @@
         @todo volumes
+        if not self.tree:
+            return
         listOfItems = []
         item = self.tree.GetFirstChild(self.tree.root)[0]
         self._GetDataLayers(item, listOfItems)
