[GRASS-SVN] r35523 - grass/trunk/swig/python/examples
svn_grass at osgeo.org
Tue Jan 20 16:10:55 EST 2009
Author: neteler
Date: 2009-01-20 16:10:55 -0500 (Tue, 20 Jan 2009)
New Revision: 35523
grass/trunk/swig/python/examples/vectoraccess.py
updated to current API
Modified: grass/trunk/swig/python/examples/vectoraccess.py
--- grass/trunk/swig/python/examples/vectoraccess.py 2009-01-20 20:52:54 UTC (rev 35522)
+++ grass/trunk/swig/python/examples/vectoraccess.py 2009-01-20 21:10:55 UTC (rev 35523)
@@ -3,7 +3,8 @@
# run within GRASS Spearfish session
import os, sys
-import python_grass7 as g7lib
+import swig.grass as grasslib
+import swig.vector as grassvect
if not os.environ.has_key("GISBASE"):
print "You must be in GRASS GIS to run this program."
@@ -17,31 +18,32 @@
mapset = 'PERMANENT'
# initialize
-g7lib.G_gisinit('')
+grasslib.G_gisinit('')
# define map structure
-map = g7lib.Map_info()
+map = grassvect.Map_info()
# define open level (level 2: topology)
-g7lib.Vect_set_open_level (2)
+grassvect.Vect_set_open_level (2)
# open existing map
-g7lib.Vect_open_old(map, input, mapset)
+grassvect.Vect_open_old(map, input, mapset)
# query
print 'Vect map: ', input
-print 'Vect is 3D: ', g7lib.Vect_is_3d (map)
-print 'Vect DB links: ', g7lib.Vect_get_num_dblinks(map)
-print 'Map Scale: 1:', g7lib.Vect_get_scale(map)
+print 'Vect is 3D: ', grassvect.Vect_is_3d (map)
+print 'Vect DB links: ', grassvect.Vect_get_num_dblinks(map)
+print 'Map Scale: 1:', grassvect.Vect_get_scale(map)
# misleading:
-# print 'Number of lines:', g7lib.Vect_get_num_lines(map)
-print 'Number of points: ', g7lib.Vect_get_num_primitives(map,g7lib.GV_POINT)
+# print 'Number of lines:', grassvect.Vect_get_num_lines(map)
+# how to access GV_POINT?
+# print 'Number of points: ', grassvect.Vect_get_num_primitives(map,GV_POINT)
# confusing:
-#print 'Number of lines: ', g7lib.Vect_get_num_primitives(map,g7lib.GV_LINE)
-#print 'Number of areas:', g7lib.Vect_get_num_primitives(map,g7lib.GV_AREA)
-print 'Number of areas:', g7lib.Vect_get_num_areas(map)
+#print 'Number of lines: ', Vect_get_num_primitives(map,GV_LINE)
+#print 'Number of areas:', Vect_get_num_primitives(map,GV_AREA)
+print 'Number of areas:', grassvect.Vect_get_num_areas(map)
# close map
-g7lib.Vect_close(map)
+grassvect.Vect_close(map)
## end of the python script
