[GRASS-SVN] r35539 - in grass/branches/develbranch_6: general/g.mapsets include lib/gis
Thu Jan 22 14:01:35 EST 2009
Author: martinl
Date: 2009-01-22 14:01:35 -0500 (Thu, 22 Jan 2009)
New Revision: 35539
   grass/branches/develbranch_6/general/g.mapsets/main_cmd.c
   grass/branches/develbranch_6/include/gisdefs.h
   grass/branches/develbranch_6/lib/gis/mapset_nme.c
attempt to fix trac #379
	(merge from trunk, r35449)
Modified: grass/branches/develbranch_6/general/g.mapsets/main_cmd.c
--- grass/branches/develbranch_6/general/g.mapsets/main_cmd.c	2009-01-21 22:29:44 UTC (rev 35538)
+++ grass/branches/develbranch_6/general/g.mapsets/main_cmd.c	2009-01-22 19:01:35 UTC (rev 35539)
@@ -136,6 +136,10 @@
 	    char *mapset;
 	    mapset = *ptr;
+	    if (G_is_mapset_in_search_path(mapset))
+		continue;
 	    if (G__mapset_permissions(mapset) < 0)
 		G_fatal_error(_("Mapset <%s> not found"), mapset);
 	    else
Modified: grass/branches/develbranch_6/include/gisdefs.h
--- grass/branches/develbranch_6/include/gisdefs.h	2009-01-21 22:29:44 UTC (rev 35538)
+++ grass/branches/develbranch_6/include/gisdefs.h	2009-01-22 19:01:35 UTC (rev 35539)
@@ -812,6 +812,7 @@
 int G_reset_mapsets(void);
 char **G_available_mapsets(void);
 void G_add_mapset_to_search_path(const char *mapset);
+int G_is_mapset_in_search_path(const char *);
 /* mask_info.c */
 char *G_mask_info(void);
Modified: grass/branches/develbranch_6/lib/gis/mapset_nme.c
--- grass/branches/develbranch_6/lib/gis/mapset_nme.c	2009-01-21 22:29:44 UTC (rev 35538)
+++ grass/branches/develbranch_6/lib/gis/mapset_nme.c	2009-01-22 19:01:35 UTC (rev 35539)
@@ -218,11 +218,25 @@
+    if (!G_is_mapset_in_search_path(mapset))
+	new_mapset(mapset);
+  \brief Check if given mapset is in search path
+  \param mapset mapset name
+  \return 1 mapset found in search path
+  \return 0 mapset not found
+int G_is_mapset_in_search_path(const char *mapset)
     int i;
     for (i = 0; i < nmapset; i++) {
 	if (strcmp(mapset_name[i], mapset) == 0)
-	    return;
+	    return 1;
-    new_mapset(mapset);
+    return 0;
