[GRASS-SVN] r35639 - grass/trunk/lib/display
svn_grass at osgeo.org
Sun Jan 25 20:00:48 EST 2009
Author: hamish
Date: 2009-01-25 20:00:48 -0500 (Sun, 25 Jan 2009)
New Revision: 35639
grass/trunk/lib/display/cnversions.c
grass/trunk/lib/display/setup.c
Doxygen
Modified: grass/trunk/lib/display/cnversions.c
--- grass/trunk/lib/display/cnversions.c 2009-01-26 00:49:32 UTC (rev 35638)
+++ grass/trunk/lib/display/cnversions.c 2009-01-26 01:00:48 UTC (rev 35639)
@@ -51,22 +51,6 @@
/* others */
static int is_lat_lon;
- * \brief initialize conversions
- * The relationship between the
- * earth <b>region</b> and the <b>top, bottom, left</b>, and <b>right</b>
- * screen coordinates is established, which then allows conversions between all
- * three coordinate systems to be performed.
- * Note this routine is called by <i>D_setup.</i>
- * \param region
- * \param top
- * \param bottom
- * \param left
- * \param right
- * \return int
static void calc_size(struct rect *rect)
@@ -150,6 +134,21 @@
U_to_D_conv.x, U_to_D_conv.y);
+ * \brief initialize conversions
+ * The relationship between the earth <b>region</b> and the <b>top, bottom,
+ * left</b>, and <b>right</b> screen coordinates is established, which then
+ * allows conversions between all three coordinate systems to be performed.
+ * Note this routine is called by <i>D_setup</i>.
+ * \param region
+ * \param top
+ * \param bottom
+ * \param left
+ * \param right
+ * \return none
void D_do_conversions(const struct Cell_head *window,
double t, double b, double l, double r)
@@ -162,6 +161,7 @@
#endif /* DEBUG */
int D_is_lat_lon(void) { return (is_lat_lon); }
double D_get_d_to_a_xconv(void) { return (D_to_A_conv.x); }
@@ -211,6 +211,18 @@
calc_size(&U);
+ * \brief returns frame bounds in source coordinate system
+ * D_get_src() returns the frame bounds in the source coordinate system
+ * (used by D_* functions)
+ * \param top
+ * \param bottom
+ * \param left
+ * \param right
+ * \return void
void D_get_src(double *t, double *b, double *l, double *r)
*t = U.north;
@@ -245,6 +257,20 @@
calc_size(&D);
+ * \brief returns frame bounds in destination coordinate system
+ * D_get_dst() returns the frame bounds in the destination coordinate system
+ * (used by R_* commands).
+ * The various D_setup() commands all set the destination coordinate
+ * system to the current frame reported by R_get_window().
+ * \param top
+ * \param bottom
+ * \param left
+ * \param right
+ * \return none
void D_get_dst(double *t, double *b, double *l, double *r)
*t = D.north;
Modified: grass/trunk/lib/display/setup.c
--- grass/trunk/lib/display/setup.c 2009-01-26 00:49:32 UTC (rev 35638)
+++ grass/trunk/lib/display/setup.c 2009-01-26 01:00:48 UTC (rev 35639)
@@ -3,15 +3,6 @@
* This is a high level D call.
* It does a full setup for the current graphics frame.
- * 1. Makes sure there is a current graphics frame
- * (will create a full-screen one, if not
- * 2. Sets the region coordinates so that the graphics frame
- * and the active program region agree
- * (may change active program region to do this).
- * 3. Performs graphic frame/region coordinate conversion intialization
- * Returns: 0 if ok. Exits with error message if failure.
* Note: Connection to driver must already be made.
* clear values:
@@ -23,22 +14,27 @@
#include <grass/display.h>
#include <grass/raster.h>
* \brief graphics frame setup
- * Performs a full setup
- * for the current graphics frame: 1) Makes sure there is a current graphics
- * frame (will create a full-screen one, if not); 2) Sets the region coordinates
- * so that the graphics frame and the active module region agree (may change
- * active module region to do this); and 3) performs graphic frame/region
- * coordinate conversion initialization.
+ * D_setup() sets the source coordinate system to the current region, and
+ * adjusts the destination coordinate system to preserve the aspect
+ * ratio.
+ * Performs a full setup for the current graphics frame:
+ * 1) Makes sure there is a current graphics frame (will create a full-screen
+ * one, if not);
+ * 2) Sets the region coordinates so that the graphics frame and the active
+ * module region agree (may change active module region to do this); and
+ * 3) Performs graphic frame/region coordinate conversion initialization.
* If <b>clear</b> is true, the frame is cleared (same as running
- * <i>d.erase.</i>) Otherwise, it is not cleared.
+ * <i>d.erase</i>.) Otherwise, it is not cleared.
* \param clear
- * \return int
+ * \return none
void D_setup(int clear)
struct Cell_head region;
@@ -56,6 +52,20 @@
D_erase(DEFAULT_BG_COLOR);
+ * \brief
+ * D_setup_unity() sets the source coordinate system to match the
+ * destination coordinate system, so that D_* functions use the same
+ * coordinate system as R_* functions.
+ * If <b>clear</b> is true, the frame is cleared (same as running
+ * \param clear
+ * \return none
void D_setup_unity(int clear)
double dt, db, dl, dr;
@@ -71,6 +81,25 @@
+ * \brief
+ * D_setup2() sets the source coordinate system to its arguments, and if
+ * the <b>fit</b> argument is non-zero, adjusts the destination coordinate
+ * system to preserve the aspect ratio.
+ * \param clear
+ * \param fit
+ * \param s_top
+ * \param s_bottom
+ * \param s_left
+ * \param s_right
+ * \return none
void D_setup2(int clear, int fit, double st, double sb, double sl, double sr)
@@ -88,4 +117,3 @@
if (clear)
