[GRASS-SVN] r35654 - grass-addons/vector/v.in.gshhs
svn_grass at osgeo.org
Tue Jan 27 03:48:21 EST 2009
Author: mmetz
Date: 2009-01-27 03:48:20 -0500 (Tue, 27 Jan 2009)
New Revision: 35654
grass-addons/vector/v.in.gshhs/description.html
grass-addons/vector/v.in.gshhs/gshhs.h
grass-addons/vector/v.in.gshhs/main.c
code reformatted
Modified: grass-addons/vector/v.in.gshhs/description.html
--- grass-addons/vector/v.in.gshhs/description.html 2009-01-27 01:40:03 UTC (rev 35653)
+++ grass-addons/vector/v.in.gshhs/description.html 2009-01-27 08:48:20 UTC (rev 35654)
@@ -68,4 +68,4 @@
The original version of v.in.gshhs was written by Bob Covill based on gshhstograss.<br>
Modifications and updates by Markus Neteler and Markus Metz.
<p>
-<i>Last changed: $Date: 2009-01-26 18:43:35 +0200 (Mon, 26 Jan 2009) $</i>
+<i>Last changed: $Date$</i>
Property changes on: grass-addons/vector/v.in.gshhs/description.html
___________________________________________________________________
+ Date
Modified: grass-addons/vector/v.in.gshhs/gshhs.h
--- grass-addons/vector/v.in.gshhs/gshhs.h 2009-01-27 01:40:03 UTC (rev 35653)
+++ grass-addons/vector/v.in.gshhs/gshhs.h 2009-01-27 08:48:20 UTC (rev 35654)
@@ -1,77 +1,78 @@
-/* $Id: gshhs.h,v 1.17 2008/01/23 03:22:49 guru Exp $
- * Include file defining structures used in gshhs.c
- * Paul Wessel, SOEST
- * Copyright (c) 1996-2008 by P. Wessel and W. H. F. Smith
- * See COPYING file for copying and redistribution conditions.
- * This program is free software; you can redistribute it and/or modify
- * it under the terms of the GNU General Public License as published by
- * the Free Software Foundation; version 2 of the License.
- * This program is distributed in the hope that it will be useful,
- * but WITHOUT ANY WARRANTY; without even the implied warranty of
- * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
- * GNU General Public License for more details.
- * Contact info: www.soest.hawaii.edu/pwessel
- * 14-SEP-2004. PW: Version 1.3. Header is now n * 8 bytes (n = 5)
- * For use with version 1.3 of GSHHS
- * 2-MAY-2006. PW: Version 1.4. Header is now 32 bytes (all int 4)
- * For use with version 1.4 of GSHHS
- * 31-MAR-2007. PW: Version 1.5. no format change
- * For use with version 1.5 of GSHHS
- * 28-AUG-2007. PW: Version 1.6. no format change
- * For use with version 1.6 of GSHHS which now has WDBII
- * borders and rivers.
- * may need updating for new GSHHS versions
-#ifndef _GSHHS
-#define _GSHHS
-#define _POSIX_SOURCE 1 /* GSHHS code is POSIX compliant */
-#include <stdio.h>
-#include <stdlib.h>
-#include <math.h>
-#ifndef M_PI
-#define M_PI 3.14159265358979323846
-#endif
-#ifndef SEEK_CUR /* For really ancient systems */
-#define SEEK_CUR 1
-#endif
-#define GSHHS_DATA_VERSION 6 /* For v1.5 data set */
-#define GSHHS_PROG_VERSION "1.9"
-#define GSHHS_SCL 1.0e-6 /* COnvert micro-degrees to degrees */
-/* For byte swapping on little-endian systems (GSHHS is defined to be bigendian) */
-#define swabi4(i4) (((i4) >> 24) + (((i4) >> 8) & 65280) + (((i4) & 65280) << 8) + (((i4) & 255) << 24))
-struct GSHHS { /* Global Self-consistent Hierarchical High-resolution Shorelines */
- int id; /* Unique polygon id number, starting at 0 */
- int n; /* Number of points in this polygon */
- int flag; /* = level + version << 8 + greenwich << 16 + source << 24 */
- /* flag contains 4 items, one in each byte, as follows:
- * low byte: level = flag & 255: Values: 1 land, 2 lake, 3 island_in_lake, 4 pond_in_island_in_lake
- * 2nd byte: version = (flag >> 8) & 255: Values: Should be 4 for GSHHS version 1.4
- * 3rd byte: greenwich = (flag >> 16) & 255: Values: Greenwich is 1 if Greenwich is crossed
- * 4th byte: source = (flag >> 24) & 255: Values: 0 = CIA WDBII, 1 = WVS
- int west, east, south, north; /* min/max extent in micro-degrees */
- int area; /* Area of polygon in 1/10 km^2 */
-struct GSHHS_POINT { /* Each lon, lat pair is stored in micro-degrees in 4-byte integer format */
- int x;
- int y;
-#endif /* _GSHHS */
+/* $Id: gshhs.h,v 1.17 2008/01/23 03:22:49 guru Exp $
+ * Include file defining structures used in gshhs.c
+ * Paul Wessel, SOEST
+ * Copyright (c) 1996-2008 by P. Wessel and W. H. F. Smith
+ * See COPYING file for copying and redistribution conditions.
+ * This program is free software; you can redistribute it and/or modify
+ * it under the terms of the GNU General Public License as published by
+ * the Free Software Foundation; version 2 of the License.
+ * This program is distributed in the hope that it will be useful,
+ * but WITHOUT ANY WARRANTY; without even the implied warranty of
+ * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
+ * GNU General Public License for more details.
+ * Contact info: www.soest.hawaii.edu/pwessel
+ * 14-SEP-2004. PW: Version 1.3. Header is now n * 8 bytes (n = 5)
+ * For use with version 1.3 of GSHHS
+ * 2-MAY-2006. PW: Version 1.4. Header is now 32 bytes (all int 4)
+ * For use with version 1.4 of GSHHS
+ * 31-MAR-2007. PW: Version 1.5. no format change
+ * For use with version 1.5 of GSHHS
+ * 28-AUG-2007. PW: Version 1.6. no format change
+ * For use with version 1.6 of GSHHS which now has WDBII
+ * borders and rivers.
+ * may need updating for new GSHHS versions
+#ifndef _GSHHS
+#define _GSHHS
+#define _POSIX_SOURCE 1 /* GSHHS code is POSIX compliant */
+#include <stdio.h>
+#include <stdlib.h>
+#include <math.h>
+#ifndef M_PI
+#define M_PI 3.14159265358979323846
+#endif
+#ifndef SEEK_CUR /* For really ancient systems */
+#define SEEK_CUR 1
+#endif
+#define GSHHS_DATA_VERSION 6 /* For v1.5 data set */
+#define GSHHS_PROG_VERSION "1.9"
+#define GSHHS_SCL 1.0e-6 /* COnvert micro-degrees to degrees */
+/* For byte swapping on little-endian systems (GSHHS is defined to be bigendian) */
+#define swabi4(i4) (((i4) >> 24) + (((i4) >> 8) & 65280) + (((i4) & 65280) << 8) + (((i4) & 255) << 24))
+struct GSHHS { /* Global Self-consistent Hierarchical High-resolution Shorelines */
+ int id; /* Unique polygon id number, starting at 0 */
+ int n; /* Number of points in this polygon */
+ int flag; /* = level + version << 8 + greenwich << 16 + source << 24 */
+ /* flag contains 4 items, one in each byte, as follows:
+ * low byte: level = flag & 255: Values: 1 land, 2 lake, 3 island_in_lake, 4 pond_in_island_in_lake
+ * 2nd byte: version = (flag >> 8) & 255: Values: Should be 4 for GSHHS version 1.4
+ * 3rd byte: greenwich = (flag >> 16) & 255: Values: Greenwich is 1 if Greenwich is crossed
+ * 4th byte: source = (flag >> 24) & 255: Values: 0 = CIA WDBII, 1 = WVS
+ int west, east, south, north; /* min/max extent in micro-degrees */
+ int area; /* Area of polygon in 1/10 km^2 */
+struct GSHHS_POINT { /* Each lon, lat pair is stored in micro-degrees in 4-byte integer format */
+ int x;
+ int y;
+#endif /* _GSHHS */
Modified: grass-addons/vector/v.in.gshhs/main.c
--- grass-addons/vector/v.in.gshhs/main.c 2009-01-27 01:40:03 UTC (rev 35653)
+++ grass-addons/vector/v.in.gshhs/main.c 2009-01-27 08:48:20 UTC (rev 35654)
@@ -1,745 +1,454 @@
- * MODULE: v.in.gshhs (based on gshhstograss.c)
- * AUTHORS: Simon Cox (simon at ned.dem.csiro.au) & (gshhstograss.c)
- * Paul Wessel (wessel at soest.hawaii.edu) & (gshhstograss.c)
- * Bob Covill <bcovill at tekmap.ns.ca> (v.in.gshhs)
- * Markus Metz <markus.metz.giswork googlemail.com> (v.in.gshhs for grass 6.4)
- * PURPOSE: To extract GRASS binary vector data from binary gshhs
- * shoreline data as described in
- * Wessel, P., and W.H.F. Smith. A Global Self-consistent,
- * Hierarchical, High-resolution Shoreline Database,
- * J. Geophys. Res., 101(B4), 8741-8743, 1996.
- * http://www.soest.hawaii.edu/wessel/hshhs/gshhs.html
- * LICENSE: This program is free software under the
- * GNU General Public License (>=v2).
- * Read the file COPYING that comes with GRASS
- * for details.
-#include <unistd.h>
-#include <string.h>
-#include <time.h>
-#include <grass/gis.h>
-#include <grass/dbmi.h>
-#include <grass/Vect.h>
-#include <grass/gprojects.h>
-#include <grass/glocale.h>
- /* updating to a newer GSHHS version can be as easy as replacing gshhs.h
- * if not too many changes were introduced */
-#include "gshhs.h"
-int main(int argc, char **argv)
-double w, e, s, n, area, lon, lat;
+ * MODULE: v.in.gshhs (based on gshhstograss.c)
+ * AUTHORS: Simon Cox (simon at ned.dem.csiro.au) & (gshhstograss.c)
+ * Paul Wessel (wessel at soest.hawaii.edu) & (gshhstograss.c)
+ * Bob Covill <bcovill at tekmap.ns.ca> (v.in.gshhs)
+ * Markus Metz <markus.metz.giswork googlemail.com> (v.in.gshhs for grass 6.4)
+ * PURPOSE: To extract GRASS binary vector data from binary gshhs
+ * shoreline data as described in
+ * Wessel, P., and W.H.F. Smith. A Global Self-consistent,
+ * Hierarchical, High-resolution Shoreline Database,
+ * J. Geophys. Res., 101(B4), 8741-8743, 1996.
+ * http://www.soest.hawaii.edu/wessel/hshhs/gshhs.html
+ * LICENSE: This program is free software under the
+ * GNU General Public License (>=v2).
+ * Read the file COPYING that comes with GRASS
+ * for details.
-double minx = -180., maxx = 180., miny = -90., maxy = 90.;
+#include <unistd.h>
+#include <string.h>
+#include <time.h>
-char *dataname, *outname;
+#include <grass/gis.h>
+#include <grass/dbmi.h>
+#include <grass/Vect.h>
+#include <grass/gprojects.h>
+#include <grass/glocale.h>
+/* updating to a newer GSHHS version can be as easy as replacing gshhs.h
+ * if not too many changes were introduced */
+#include "gshhs.h"
-char buf[2000], source;
-static char *slevel[] =
- { "shore", "land", "lake", "island in lake",
-"pond in island in lake" };
-int shore_levels = 5;
+int main(int argc, char **argv)
+ double w, e, s, n, area, lon, lat;
+ double minx = -180., maxx = 180., miny = -90., maxy = 90.;
+ char *dataname, *outname;
+ char buf[2000], source;
+ static char *slevel[] = { "shore", "land", "lake", "island in lake",
+ "pond in island in lake"
+ int shore_levels = 5;
+ FILE *fp;
+ int k, i, n_read, flip, level, version, greenwich, src;
+ int max_east = 180000000; /* max_east = 270000000: confuses GRASS */
+ int cnt = 1;
+ struct GSHHS_POINT p; /* renamed to avoid conflict */
+ struct GSHHS h;
+ struct pj_info info_in;
+ struct pj_info info_out;
+ struct Key_Value *out_proj_keys, *out_unit_keys;
+ int type, zone;
+ struct Cell_head region;
+ struct Map_info VectMap;
+ struct line_pnts *Points;
+ struct line_cats *Cats;
+ double lat_nw, lon_nw, lat_ne, lon_ne;
+ double lat_sw, lon_sw, lat_se, lon_se;
+ struct
+ struct Option *input, *output, *n, *s, *e, *w;
+ } parm;
+ struct
+ struct Flag *g, *topo, *a;
+ } flag;
+ struct GModule *module;
-FILE * fp;
-int k, i, n_read, flip, level, version, greenwich, src;
+ /* attribute table */
+ struct field_info *Fi;
+ dbDriver *driver;
+ dbString sql, strval;
+ char *cat_col_name = "cat";
-int max_east = 180000000; /* max_east = 270000000: confuses GRASS */
+ G_gisinit(argv[0]);
-int cnt = 1;
+ /* Set description */
+ module = G_define_module();
+ module->description = ""
+ "Imports Global Self-consistent Hierarchical High-resolution Shoreline (GSHHS) vector data";
-struct GSHHS_POINT p; /* renamed to avoid conflict */
+ parm.input = G_define_option();
+ parm.input->key = "input";
+ parm.input->type = TYPE_STRING;
+ parm.input->required = YES;
+ parm.input->gisprompt = "old_file,file,gshhs";
+ parm.input->description =
+ "Name of GSHHS shoreline file: gshhs_[f|h|i|l|c].b";
-struct GSHHS h;
+ parm.output = G_define_standard_option(G_OPT_V_OUTPUT);
-struct pj_info info_in;
+ parm.n = G_define_option();
+ parm.n->key = "n";
+ parm.n->type = TYPE_DOUBLE;
+ parm.n->required = NO;
+ parm.n->description = "North limit in units of location projection";
-struct pj_info info_out;
+ parm.s = G_define_option();
+ parm.s->key = "s";
+ parm.s->type = TYPE_DOUBLE;
+ parm.s->required = NO;
+ parm.s->description = "South limit in units of location projection";
-struct Key_Value *out_proj_keys, *out_unit_keys;
+ parm.e = G_define_option();
+ parm.e->key = "e";
+ parm.e->type = TYPE_DOUBLE;
+ parm.e->required = NO;
+ parm.e->description = "East limit in units of location projection";
-int type, zone;
+ parm.w = G_define_option();
+ parm.w->key = "w";
+ parm.w->type = TYPE_DOUBLE;
+ parm.w->required = NO;
+ parm.w->description = "West limit in units of location projection";
-struct Cell_head region;
+ flag.g = G_define_flag();
+ flag.g->key = 'g';
+ flag.g->description = "Get coordinates from current GRASS region";
-struct Map_info VectMap;
+ flag.topo = G_define_flag();
+ flag.topo->key = 't';
+ flag.topo->description = "Do not build topology for output vector";
-struct line_pnts *Points;
+ /* Importing as boundary causes problems with subregions, incorrect boundaries */
+ /* flag.a = G_define_flag();
+ flag.a->key = 'a';
+ flag.a->description =
+ "Import shoreline as type line (default = boundary)";
-struct line_cats *Cats;
+ if (G_parser(argc, argv))
+ exit(1);
-double lat_nw, lon_nw, lat_ne, lon_ne;
+ /* get parameters */
+ dataname = parm.input->answer;
+ outname = parm.output->answer;
-double lat_sw, lon_sw, lat_se, lon_se;
+ G_get_window(®ion);
+ zone = region.zone;
-struct
-struct Option *input, *output, *n, *s, *e, *w;
-} parm;
+ /* Out Info */
+ out_proj_keys = G_get_projinfo();
+ out_unit_keys = G_get_projunits();
-struct
-struct Flag *g, *topo, *a;
-} flag;
+ if (pj_get_kv(&info_out, out_proj_keys, out_unit_keys) < 0) {
+ exit(0);
+ G_free_key_value(out_proj_keys);
+ G_free_key_value(out_unit_keys);
-struct GModule *module;
+ /* In Info */
+ /* N.B. GSHHS data is not referenced to any ellipsoid or datum. This
+ * limits its precision to several hundred metres. Hence it does not
+ * matter which ellipsoid we use in the input projection keys as the
+ * precision of the data is less than the maximum error that could be
+ * caused by projecting using the 'wrong' ellipsoid.
+ * Anyone who understands this better than me feel free to change it.
+ * PK March 2003 */
- /* attribute table */
- struct field_info *Fi;
+ /* GSHHS spatial reference
+ * GSHHS is a combination of WVS and WDBII
+ * The WVS dataset uses WGS84 according to
+ * http://shoreline.noaa.gov/data/datasheets/wvs.html
+ * The WDBII dataset may have used wgs72 but is inaccurate anyway
+ * Safest would be to always use wgs84
+ * MM Jan 2009 */
-dbDriver * driver;
-dbString sql, strval;
-char *cat_col_name = "cat";
+ /* set input projection to lat/long w/ same ellipsoid as output */
+ /* TODO: use wgs84 datum and ellipsoid */
+ info_in.zone = 0;
+ info_in.meters = 1.;
+ sprintf(info_in.proj, "ll");
+ if ((info_in.pj = pj_latlong_from_proj(info_out.pj)) == NULL)
+ G_fatal_error("Unable to set up lat/long projection parameters");
-G_gisinit(argv[0]);
- /* Set description */
- module = G_define_module();
-module->description = ""
- "Imports Global Self-consistent Hierarchical High-resolution Shoreline (GSHHS) vector data";
-parm.input = G_define_option();
-parm.input->key = "input";
-parm.input->type = TYPE_STRING;
-parm.input->required = YES;
-parm.input->gisprompt = "old_file,file,gshhs";
-parm.input->description =
- "Name of GSHHS shoreline file: gshhs_[f|h|i|l|c].b";
-parm.output = G_define_standard_option(G_OPT_V_OUTPUT);
-parm.n = G_define_option();
-parm.n->key = "n";
-parm.n->type = TYPE_DOUBLE;
-parm.n->required = NO;
-parm.n->description = "North limit in units of location projection";
-parm.s = G_define_option();
-parm.s->key = "s";
-parm.s->type = TYPE_DOUBLE;
-parm.s->required = NO;
-parm.s->description = "South limit in units of location projection";
-parm.e = G_define_option();
-parm.e->key = "e";
-parm.e->type = TYPE_DOUBLE;
-parm.e->required = NO;
-parm.e->description = "East limit in units of location projection";
-parm.w = G_define_option();
-parm.w->key = "w";
-parm.w->type = TYPE_DOUBLE;
-parm.w->required = NO;
-parm.w->description = "West limit in units of location projection";
-flag.g = G_define_flag();
-flag.g->key = 'g';
-flag.g->description = "Get coordinates from current GRASS region";
-flag.topo = G_define_flag();
-flag.topo->key = 't';
-flag.topo->description =
-"Do not build topology for output vector";
- /* Importing as boundary causes problems with subregions, incorrect boundaries */
- /* flag.a = G_define_flag();
- flag.a->key = 'a';
- flag.a->description =
- "Import shoreline as type line (default = boundary)";
-if (G_parser(argc, argv))
-exit(1);
- /* get parameters */
- dataname = parm.input->answer;
-outname = parm.output->answer;
-G_get_window(®ion);
-zone = region.zone;
- /* Out Info */
- out_proj_keys = G_get_projinfo();
-out_unit_keys = G_get_projunits();
-if (pj_get_kv(&info_out, out_proj_keys, out_unit_keys) < 0) {
-exit(0);
-G_free_key_value(out_proj_keys);
-G_free_key_value(out_unit_keys);
- /* In Info */
- /* N.B. GSHHS data is not referenced to any ellipsoid or datum. This
- * limits its precision to several hundred metres. Hence it does not
- * matter which ellipsoid we use in the input projection keys as the
- * precision of the data is less than the maximum error that could be
- * caused by projecting using the 'wrong' ellipsoid.
- * Anyone who understands this better than me feel free to change it.
- * PK March 2003 */
- /* GSHHS spatial reference
- * GSHHS is a combination of WVS and WDBII
- * The WVS dataset uses WGS84 according to
- * http://shoreline.noaa.gov/data/datasheets/wvs.html
- * The WDBII dataset may have used wgs72 but is inaccurate anyway
- * Safest would be to always use wgs84
- * MM Jan 2009 */
- /* set input projection to lat/long w/ same ellipsoid as output */
- /* TODO: use wgs84 datum and ellipsoid */
- info_in.zone = 0;
-info_in.meters = 1.;
-sprintf(info_in.proj, "ll");
-if ((info_in.pj = pj_latlong_from_proj(info_out.pj)) == NULL)
-G_fatal_error("Unable to set up lat/long projection parameters");
-if (flag.g->answer) {
- /* get coordinates from current region */
- minx = region.west;
-maxx = region.east;
-miny = region.south;
-maxy = region.north;
+ if (flag.g->answer) {
+ /* get coordinates from current region */
+ minx = region.west;
+ maxx = region.east;
+ miny = region.south;
+ maxy = region.north;
else {
- /* get coordinates from command line */
- if (!parm.w->answer || !parm.e->answer || !parm.s->answer
- ||!parm.n->answer) {
-G_fatal_error
+ /* get coordinates from command line */
+ if (!parm.w->answer || !parm.e->answer || !parm.s->answer
+ || !parm.n->answer) {
+ G_fatal_error
("Missing region parameters: you must supply n, s, e, w values or use '-g' flag");
-sscanf(parm.w->answer, "%lf", &minx);
-sscanf(parm.e->answer, "%lf", &maxx);
-sscanf(parm.s->answer, "%lf", &miny);
-sscanf(parm.n->answer, "%lf", &maxy);
-if (maxx < minx)
-G_fatal_error("East must be east of West");
-if (maxy < miny)
-G_fatal_error("North must be north of South");
-if (G_projection() != PROJECTION_LL) {
- /* convert to latlon and print bounds */
- /* NW */
- lon_nw = minx;
-lat_nw = maxy;
-if (pj_do_proj(&lon_nw, &lat_nw, &info_out, &info_in) < 0) {
-G_fatal_error
+ sscanf(parm.w->answer, "%lf", &minx);
+ sscanf(parm.e->answer, "%lf", &maxx);
+ sscanf(parm.s->answer, "%lf", &miny);
+ sscanf(parm.n->answer, "%lf", &maxy);
+ if (maxx < minx)
+ G_fatal_error("East must be east of West");
+ if (maxy < miny)
+ G_fatal_error("North must be north of South");
+ if (G_projection() != PROJECTION_LL) {
+ /* convert to latlon and print bounds */
+ /* NW */
+ lon_nw = minx;
+ lat_nw = maxy;
+ if (pj_do_proj(&lon_nw, &lat_nw, &info_out, &info_in) < 0) {
+ G_fatal_error
("Error in coordinate transformation for north west corner");
- /* NE */
- lon_ne = maxx;
-lat_ne = maxy;
-if (pj_do_proj(&lon_ne, &lat_ne, &info_out, &info_in) < 0) {
-G_fatal_error
+ /* NE */
+ lon_ne = maxx;
+ lat_ne = maxy;
+ if (pj_do_proj(&lon_ne, &lat_ne, &info_out, &info_in) < 0) {
+ G_fatal_error
("Error in coordinate transformation for north east corner");
- /* SE */
- lon_se = maxx;
-lat_se = miny;
-if (pj_do_proj(&lon_se, &lat_se, &info_out, &info_in) < 0) {
-G_fatal_error
+ /* SE */
+ lon_se = maxx;
+ lat_se = miny;
+ if (pj_do_proj(&lon_se, &lat_se, &info_out, &info_in) < 0) {
+ G_fatal_error
("Error in coordinate transformation for south eest corner");
- /* SW */
- lon_sw = minx;
-lat_sw = miny;
-if (pj_do_proj(&lon_sw, &lat_sw, &info_out, &info_in) < 0) {
-G_fatal_error
+ /* SW */
+ lon_sw = minx;
+ lat_sw = miny;
+ if (pj_do_proj(&lon_sw, &lat_sw, &info_out, &info_in) < 0) {
+ G_fatal_error
("Error in coordinate transformation for south west corner");
- /* get north max */
- maxy = lat_nw > lat_ne ? lat_nw : lat_ne;
- /* get south min */
- miny = lat_sw < lat_se ? lat_sw : lat_se;
- /* get east max */
- maxx = lon_ne > lon_se ? lon_ne : lon_se;
- /* get west min */
- minx = lon_nw < lon_sw ? lon_nw : lon_sw;
- /* check coordinate accuracy */
- if (maxx < minx) {
-G_fatal_error(_("maxx %f < minx %f."), maxx, minx);
-if (maxy < miny) {
-G_fatal_error(_("maxy %f < miny %f."), maxy, miny);
-G_message(_("Using lat/lon bounds N=%f S=%f E=%f W=%f\n"), maxy, miny,
- maxx,
-minx);
- /* open GSHHS shoreline for reading */
- if ((fp = fopen(dataname, "rb")) == NULL) {
-G_fatal_error(_("Could not find file %s."), dataname);
- /* Open new vector */
- if (0 > Vect_open_new(&VectMap, outname, 0)) {
-G_fatal_error(_("Cannot open new vector %s"), outname);
- /* set vector line type to GV_LINE, boundaries can cause problems */
- type = GV_LINE;
- /* Initialize vector line struct */
- Points = Vect_new_line_struct();
- /* Initialize vector category struct */
- Cats = Vect_new_cats_struct();
- /* read header from GSHHS database */
- n_read =
- fread((void *)&h, (size_t) sizeof(struct GSHHS), (size_t) 1, fp);
-version = (h.flag >> 8) & 255;
-flip = (version < 6); /* Take as sign that byte-swapping is needed */
-if (flip) {
-version = swabi4((unsigned int)h.flag);
-version = (version >> 8) & 255;
- /* read lines from GSHHS database */
- while (n_read == 1) {
-if (flip) {
-h.id = swabi4((unsigned int)h.id);
-h.n = swabi4((unsigned int)h.n);
-h.west = swabi4((unsigned int)h.west);
-h.east = swabi4((unsigned int)h.east);
-h.south = swabi4((unsigned int)h.south);
-h.north = swabi4((unsigned int)h.north);
-h.area = swabi4((unsigned int)h.area);
-h.flag = swabi4((unsigned int)h.flag);
-level = h.flag & 255;
- /* version = (h.flag >> 8) & 255; */
- greenwich = (h.flag >> 16) & 255;
-src = (h.flag >> 24) & 255;
-w = h.west * GSHHS_SCL; /* Convert from microdegrees to degrees */
-e = h.east * GSHHS_SCL;
-s = h.south * GSHHS_SCL;
-n = h.north * GSHHS_SCL;
- /* skip WDBII data because they are too inacurate? */
- source = (src == 1) ? 'W' : 'C'; /* Either WVS or CIA (WDBII) pedigree */
-area = 0.1 * h.area; /* Now im km^2 */
-if (h.west > max_east)
+ /* get north max */
+ maxy = lat_nw > lat_ne ? lat_nw : lat_ne;
+ /* get south min */
+ miny = lat_sw < lat_se ? lat_sw : lat_se;
+ /* get east max */
+ maxx = lon_ne > lon_se ? lon_ne : lon_se;
+ /* get west min */
+ minx = lon_nw < lon_sw ? lon_nw : lon_sw;
+ /* check coordinate accuracy */
+ if (maxx < minx) {
+ G_fatal_error(_("maxx %f < minx %f."), maxx, minx);
+ if (maxy < miny) {
+ G_fatal_error(_("maxy %f < miny %f."), maxy, miny);
+ G_message(_("Using lat/lon bounds N=%f S=%f E=%f W=%f\n"), maxy, miny,
+ maxx, minx);
+ /* open GSHHS shoreline for reading */
+ if ((fp = fopen(dataname, "rb")) == NULL) {
+ G_fatal_error(_("Could not find file %s."), dataname);
+ /* Open new vector */
+ if (0 > Vect_open_new(&VectMap, outname, 0)) {
+ G_fatal_error(_("Cannot open new vector %s"), outname);
+ /* set vector line type to GV_LINE, boundaries can cause problems */
+ type = GV_LINE;
+ /* Initialize vector line struct */
+ Points = Vect_new_line_struct();
+ /* Initialize vector category struct */
+ Cats = Vect_new_cats_struct();
+ /* read header from GSHHS database */
+ n_read = fread((void *)&h, (size_t) sizeof(struct GSHHS), (size_t) 1, fp);
+ version = (h.flag >> 8) & 255;
+ flip = (version < 6); /* Take as sign that byte-swapping is needed */
+ if (flip) {
+ version = swabi4((unsigned int)h.flag);
+ version = (version >> 8) & 255;
+ /* read lines from GSHHS database */
+ while (n_read == 1) {
+ if (flip) {
+ h.id = swabi4((unsigned int)h.id);
+ h.n = swabi4((unsigned int)h.n);
+ h.west = swabi4((unsigned int)h.west);
+ h.east = swabi4((unsigned int)h.east);
+ h.south = swabi4((unsigned int)h.south);
+ h.north = swabi4((unsigned int)h.north);
+ h.area = swabi4((unsigned int)h.area);
+ h.flag = swabi4((unsigned int)h.flag);
+ level = h.flag & 255;
+ /* version = (h.flag >> 8) & 255; */
+ greenwich = (h.flag >> 16) & 255;
+ src = (h.flag >> 24) & 255;
+ w = h.west * GSHHS_SCL; /* Convert from microdegrees to degrees */
+ e = h.east * GSHHS_SCL;
+ s = h.south * GSHHS_SCL;
+ n = h.north * GSHHS_SCL;
+ /* skip WDBII data because they are too inacurate? */
+ source = (src == 1) ? 'W' : 'C'; /* Either WVS or CIA (WDBII) pedigree */
+ area = 0.1 * h.area; /* Now im km^2 */
+ if (h.west > max_east)
w -= 360.0;
-if (h.east > max_east)
+ if (h.east > max_east)
e -= 360.0;
- /* got line header now read in points if line box overlaps with region */
- if ((w <= maxx && e >= minx) && (s <= maxy && n >= miny)) {
-Vect_reset_line(Points);
-Vect_reset_cats(Cats);
-for (k = 0; k < h.n; k++) {
-if (fread
- ((void *)&p, (size_t) sizeof(struct GSHHS_POINT),
- (size_t) 1,
-fp) != 1)
-G_fatal_error("Error reading data.");
-if (flip) {
-p.x = swabi4((unsigned int)p.x);
-p.y = swabi4((unsigned int)p.y);
-lon = p.x * GSHHS_SCL;
-if (p.x > max_east)
+ /* got line header now read in points if line box overlaps with region */
+ if ((w <= maxx && e >= minx) && (s <= maxy && n >= miny)) {
+ Vect_reset_line(Points);
+ Vect_reset_cats(Cats);
+ for (k = 0; k < h.n; k++) {
+ if (fread
+ ((void *)&p, (size_t) sizeof(struct GSHHS_POINT),
+ (size_t) 1, fp) != 1)
+ G_fatal_error("Error reading data.");
+ if (flip) {
+ p.x = swabi4((unsigned int)p.x);
+ p.y = swabi4((unsigned int)p.y);
+ lon = p.x * GSHHS_SCL;
+ if (p.x > max_east)
lon -= 360.0;
-lat = p.y * GSHHS_SCL;
-if (pj_do_proj(&lon, &lat, &info_in, &info_out) < 0) {
-G_fatal_error("Error in coordinate transformation");
-Vect_append_point(Points, lon, lat, 0.);
-} /* done with line */
-if (k) {
- /* simple table and cats for layer 1: not unique, just per slevel */
- Vect_cat_set(Cats, 1, level);
- /* cats for layer 2 are unique ID, same like GSHHS ID */
- Vect_cat_set(Cats, 2, h.id);
-Vect_write_line(&VectMap, type, Points, Cats);
-cnt++;
+ lat = p.y * GSHHS_SCL;
+ if (pj_do_proj(&lon, &lat, &info_in, &info_out) < 0) {
+ G_fatal_error("Error in coordinate transformation");
+ Vect_append_point(Points, lon, lat, 0.);
+ } /* done with line */
+ if (k) {
+ /* simple table and cats for layer 1: not unique, just per slevel */
+ Vect_cat_set(Cats, 1, level);
+ /* cats for layer 2 are unique ID, same like GSHHS ID */
+ Vect_cat_set(Cats, 2, h.id);
+ Vect_write_line(&VectMap, type, Points, Cats);
+ cnt++;
else {
-G_debug(1,
- "skipped line box west: %f, east: %f, north: %f, south: %f",
- w, e, n, s);
-fseek(fp, (long)(h.n * sizeof(struct GSHHS_POINT)), SEEK_CUR);
- /* max_east = 180000000; *//* Only Eurasiafrica needs 270 */
-n_read =
+ G_debug(1,
+ "skipped line box west: %f, east: %f, north: %f, south: %f",
+ w, e, n, s);
+ fseek(fp, (long)(h.n * sizeof(struct GSHHS_POINT)), SEEK_CUR);
+ /* max_east = 180000000; *//* Only Eurasiafrica needs 270 */
+ n_read =
- /* done with gshhs file */
- fclose(fp);
-Vect_destroy_line_struct(Points);
-Vect_destroy_cats_struct(Cats);
- /* write out vect header info */
- Vect_set_scale(&VectMap, 100000);
-sprintf(buf, "GSHHS shorelines version %d imported by v.in.gshhs",
- version);
-Vect_set_comment(&VectMap, buf);
- /* create table and link new vector to table, code taken from v.in.ogr */
-db_init_string(&sql);
-db_init_string(&strval);
-Fi = Vect_default_field_info(&VectMap, 1, NULL, GV_1TABLE);
-Vect_map_add_dblink(&VectMap, 1, NULL, Fi->table,
-cat_col_name,
- Fi->database, Fi->driver);
-sprintf(buf, "create table %s (%s integer, type varchar(25))",
- Fi->table,
-cat_col_name);
-db_set_string(&sql, buf);
-driver =
+ /* done with gshhs file */
+ fclose(fp);
+ Vect_destroy_line_struct(Points);
+ Vect_destroy_cats_struct(Cats);
+ /* write out vect header info */
+ Vect_set_scale(&VectMap, 100000);
+ sprintf(buf, "GSHHS shorelines version %d imported by v.in.gshhs",
+ version);
+ Vect_set_comment(&VectMap, buf);
+ /* create table and link new vector to table, code taken from v.in.ogr */
+ db_init_string(&sql);
+ db_init_string(&strval);
+ Fi = Vect_default_field_info(&VectMap, 1, NULL, GV_1TABLE);
+ Vect_map_add_dblink(&VectMap, 1, NULL, Fi->table,
+ cat_col_name, Fi->database, Fi->driver);
+ sprintf(buf, "create table %s (%s integer, type varchar(25))",
+ Fi->table, cat_col_name);
+ db_set_string(&sql, buf);
+ driver =
db_start_driver_open_database(Fi->driver,
-Vect_subst_var(Fi->database,
- &VectMap));
-if (driver == NULL) {
-G_fatal_error(_("Cannot open database %s by driver %s"),
-Vect_subst_var(Fi->database, &VectMap), Fi->driver);
-G_debug(1, "table: %s", Fi->table);
-G_debug(1, "driver: %s", Fi->driver);
-G_debug(1, "database: %s", Fi->database);
-if (db_execute_immediate(driver, &sql) != DB_OK) {
-db_close_database(driver);
-db_shutdown_driver(driver);
-G_fatal_error(_("Cannot create table: %s"),
-db_get_string(&sql));
-if (db_create_index2(driver, Fi->table, cat_col_name) != DB_OK)
-G_warning(_("Cannot create index"));
-if (db_grant_on_table
- (driver, Fi->table, DB_PRIV_SELECT,
-DB_GROUP | DB_PUBLIC) != DB_OK)
-G_fatal_error(_("Cannot grant privileges on table %s"), Fi->table);
-db_begin_transaction(driver);
-for (i = 0; i < shore_levels; i++) {
-sprintf(buf, "insert into %s values ( %d, \'%s\')", Fi->table, i + 1,
- slevel[i]);
-G_fatal_error(_("Cannot insert new row: %s"),
-db_commit_transaction(driver);
-db_close_database_shutdown_driver(driver);
-if (flag.topo->answer) {
-G_message(_("Run \"v.build map=%s option=build\" to build topology"),
- outname);
+ Vect_subst_var(Fi->database, &VectMap));
+ if (driver == NULL) {
+ G_fatal_error(_("Cannot open database %s by driver %s"),
+ Vect_subst_var(Fi->database, &VectMap), Fi->driver);
+ G_debug(1, "table: %s", Fi->table);
+ G_debug(1, "driver: %s", Fi->driver);
+ G_debug(1, "database: %s", Fi->database);
+ if (db_execute_immediate(driver, &sql) != DB_OK) {
+ db_close_database(driver);
+ db_shutdown_driver(driver);
+ G_fatal_error(_("Cannot create table: %s"), db_get_string(&sql));
+ if (db_create_index2(driver, Fi->table, cat_col_name) != DB_OK)
+ G_warning(_("Cannot create index"));
+ if (db_grant_on_table
+ (driver, Fi->table, DB_PRIV_SELECT, DB_GROUP | DB_PUBLIC) != DB_OK)
+ G_fatal_error(_("Cannot grant privileges on table %s"), Fi->table);
+ db_begin_transaction(driver);
+ for (i = 0; i < shore_levels; i++) {
+ sprintf(buf, "insert into %s values ( %d, \'%s\')", Fi->table, i + 1,
+ slevel[i]);
+ G_fatal_error(_("Cannot insert new row: %s"),
+ db_get_string(&sql));
+ db_commit_transaction(driver);
+ db_close_database_shutdown_driver(driver);
+ if (flag.topo->answer) {
+ G_message(_("Run \"v.build map=%s option=build\" to build topology"),
+ outname);
else {
-Vect_build(&VectMap);
-Vect_close(&VectMap);
-G_message(_("GSHHS shoreline version %d import complete"), version);
-exit(EXIT_SUCCESS);
+ Vect_build(&VectMap);
+ Vect_close(&VectMap);
+ G_message(_("GSHHS shoreline version %d import complete"), version);
+ exit(EXIT_SUCCESS);
