[GRASS-SVN] r35662 - grass/branches/releasebranch_6_4/raster/r.sun2
svn_grass at osgeo.org
Tue Jan 27 15:37:54 EST 2009
Author: neteler
Date: 2009-01-27 15:37:54 -0500 (Tue, 27 Jan 2009)
New Revision: 35662
grass/branches/releasebranch_6_4/raster/r.sun2/main.c
i18n; reduced vertical space in code
Modified: grass/branches/releasebranch_6_4/raster/r.sun2/main.c
--- grass/branches/releasebranch_6_4/raster/r.sun2/main.c 2009-01-27 20:37:39 UTC (rev 35661)
+++ grass/branches/releasebranch_6_4/raster/r.sun2/main.c 2009-01-27 20:37:54 UTC (rev 35662)
@@ -191,8 +191,6 @@
int main(int argc, char *argv[])
double singleSlope;
@@ -742,8 +740,9 @@
ll_correction = 1;
+ G_debug(3, "calculate starts...");
calculate(singleSlope, singleAspect, singleAlbedo, singleLinke, gridGeom);
+ G_debug(3, "OUTGR starts...");
OUTGR();
return 1;
@@ -789,10 +788,7 @@
if ((mapset = G_find_cell(elevin, "")) == NULL)
- G_fatal_error("Elevation raster file not found");
+ G_fatal_error(_("Raster map <%s> not found"),elevin);
fd1 = G_open_cell_old(elevin, mapset);
if (slopein != NULL) {
@@ -803,7 +799,6 @@
for (l = 0; l < numRows; l++) {
s[l] = (float *)G_malloc(sizeof(float) * (n));
if ((mapset = G_find_cell(slopein, "")) == NULL)
G_fatal_error(_("Raster map <%s> not found"),slopein);
@@ -828,7 +823,6 @@
if (linkein != NULL) {
cell4 = G_allocate_f_raster_buf();
if (li == NULL) {
@@ -839,7 +833,6 @@
if ((mapset = G_find_cell(linkein, "")) == NULL)
G_fatal_error(_("Raster map <%s> not found"),linkein);
fd4 = G_open_cell_old(linkein, mapset);
@@ -852,7 +845,6 @@
if ((mapset = G_find_cell(albedo, "")) == NULL)
G_fatal_error(_("Raster map <%s> not found"),albedo);
fd5 = G_open_cell_old(albedo, mapset);
@@ -865,7 +857,6 @@
if ((mapset = G_find_cell(latin, "")) == NULL)
G_fatal_error(_("Raster map <%s> not found"),latin);
fd6 = G_open_cell_old(latin, mapset);
@@ -877,15 +868,11 @@
if ((mapset = G_find_cell(longin, "")) == NULL)
G_fatal_error(_("Raster map <%s> not found"),longin);
fd7 = G_open_cell_old(longin, mapset);
if (coefbh != NULL) {
rast1 = G_allocate_f_raster_buf();
if (cbhr == NULL) {
cbhr = (float **)G_malloc(sizeof(float *) * (numRows));
@@ -893,7 +880,6 @@
if ((mapset = G_find_cell(coefbh, "")) == NULL)
G_fatal_error(_("Raster map <%s> not found"),coefbh);
fr1 = G_open_cell_old(coefbh, mapset);
@@ -906,13 +892,9 @@
if ((mapset = G_find_cell(coefdh, "")) == NULL)
G_fatal_error(_("Raster map <%s> not found"),coefdh);
fr2 = G_open_cell_old(coefdh, mapset);
if (useHorizonData()) {
if (horizonarray == NULL) {
horizonarray =
@@ -943,7 +925,6 @@
sprintf(shad_filename, formatString, horizon, i);
if ((mapset = G_find_cell(shad_filename, "")) == NULL)
G_fatal_error(_("Horizon file no. %d <%s> not found"), i, shad_filename);
fd_shad[i] = G_open_cell_old(shad_filename, mapset);
@@ -953,7 +934,6 @@
for (i = 0; i < arrayNumInt; i++) {
for (row = m - offset - 1; row >= finalRow; row--) {
@@ -967,7 +947,6 @@
AMIN1(horizonbuf[i][j],
256 * invScale)));
horizonpointer += arrayNumInt;
@@ -976,7 +955,6 @@
G_get_f_raster_row(fd1, cell1, row);
if (aspin != NULL)
@@ -996,8 +974,6 @@
if (coefdh != NULL)
G_get_f_raster_row(fr2, rast2, row);
row_rev = m - row - 1;
rowrevoffset = row_rev - offset;
@@ -1061,11 +1037,6 @@
else
cdhr[rowrevoffset][j] = UNDEFZ;
@@ -1231,7 +1202,6 @@
G_set_f_null_value(cell8 + j, 1);
else
cell8[j] = (FCELL) beam[i][j];
G_put_f_raster_row(fd8, cell8);
@@ -1242,7 +1212,6 @@
G_set_f_null_value(cell12 + j, 1);
else
cell12[j] = (FCELL) globrad[i][j];
G_put_f_raster_row(fd12, cell12);
@@ -1309,41 +1278,9 @@
return 1;
-/* min(), max() are unused
- * int min(arg1, arg2)
- * int arg1;
- * int arg2;
- * int res;
- * if (arg1 <= arg2) {
- * res = arg1;
- * else {
- * res = arg2;
- * return res;
- * int max(arg1, arg2)
- * int arg1;
- * int arg2;
- * int res;
- * if (arg1 >= arg2) {
- * res = arg1;
- * else {
- * res = arg2;
- * return res;
void joules2(struct SunGeometryConstDay *sunGeom,
struct SunGeometryVarDay *sunVarGeom,
struct SunGeometryVarSlope *sunSlopeGeom,
@@ -1411,16 +1348,12 @@
firstAngle = (firstTime - 12) * HOURANGLE;
lastAngle = (sunGeom->sunset_time - 12) * HOURANGLE;
dfr_rad = step * HOURANGLE;
sunGeom->timeAngle = firstAngle;
varCount_global = 0;
dfr = step;
while (ss == 1) {
@@ -1469,8 +1402,6 @@
* void where_is_point(void)
@@ -1814,7 +1745,6 @@
numRows = m / numPartitions;
if (useCivilTime()) {
/* We need to calculate the deviation of the local solar time from the
* "local clock time". */
@@ -1829,11 +1759,8 @@
else {
setTimeOffset(0.);
for (j = 0; j < m; j++) {
G_percent(j, m - 1, 2);
@@ -1852,11 +1779,9 @@
longitTime = -longitArray[arrayOffset][i] / 15.;
gridGeom.xg0 = gridGeom.xx0 = (double)i *gridGeom.stepx;
gridGeom.yg0 = gridGeom.yy0 = (double)j *gridGeom.stepy;
gridGeom.xp = xmin + gridGeom.xx0;
gridGeom.yp = ymin + gridGeom.yy0;
