[GRASS-SVN] r35664 - grass/trunk/scripts/r.in.wms
svn_grass at osgeo.org
Tue Jan 27 21:05:57 EST 2009
Author: hamish
Date: 2009-01-27 21:05:57 -0500 (Tue, 27 Jan 2009)
New Revision: 35664
grass/trunk/scripts/r.in.wms/r.in.wms
grass/trunk/scripts/r.in.wms/wms.download
msg cosmetics, check if r.support worked (merge from devbr6)
Modified: grass/trunk/scripts/r.in.wms/r.in.wms
--- grass/trunk/scripts/r.in.wms/r.in.wms 2009-01-28 02:03:51 UTC (rev 35663)
+++ grass/trunk/scripts/r.in.wms/r.in.wms 2009-01-28 02:05:57 UTC (rev 35664)
@@ -561,13 +561,18 @@
message 1 "r.in.gdalwarp $GDALWARP"
eval "r.in.gdalwarp $GDALWARP"
if [ $? -ne 0 ] ; then
+ g.message -e message="r.in.gdalwarp failed"
exit 1
fi
r.support map="$GIS_OPT_OUTPUT" title="WMS Download" history="" \
source1=`echo "$GIS_OPT_MAPSERVER" | cut -c-70` \
source2=`echo "$GIS_OPT_MAPSERVER" | cut -c71-140`
+if [ $? -ne 0 ] ; then
+ g.message -e message="r.support failed"
+ exit 1
+fi
LAY_LEN="echo "$GIS_OPT_LAYERS" | wc -c"
r.support map="$GIS_OPT_OUTPUT" history="layers: $GIS_OPT_LAYERS"
@@ -582,6 +587,7 @@
r.support map="$GIS_OPT_OUTPUT" description="generated by r.in.wms" history=""
r.support map="$GIS_OPT_OUTPUT" history="$CMDLINE"
g.message -v message="Map <${GIS_OPT_OUTPUT}> written"
# Clean up:
Modified: grass/trunk/scripts/r.in.wms/wms.download
--- grass/trunk/scripts/r.in.wms/wms.download 2009-01-28 02:03:51 UTC (rev 35663)
+++ grass/trunk/scripts/r.in.wms/wms.download 2009-01-28 02:05:57 UTC (rev 35664)
@@ -155,7 +155,7 @@
#Get the data from the WMS server
GetData() {
g.message "Downloading data"
- g.message -v message="Requesting Data from <${SERVER}:>"
+ g.message -v message="Requesting Data from <${SERVER}>:"
g.message -v message="$STRING"
if [ "$POST_DATA_OK" -eq 1 ] ; then
