[GRASS-SVN] r35688 - in grass/branches/releasebranch_6_4/scripts:
v.db.univar v.univar.sh
svn_grass at osgeo.org
Fri Jan 30 17:04:43 EST 2009
Author: neteler
Date: 2009-01-30 17:04:43 -0500 (Fri, 30 Jan 2009)
New Revision: 35688
grass/branches/releasebranch_6_4/scripts/v.db.univar/v.db.univar
grass/branches/releasebranch_6_4/scripts/v.univar.sh/v.univar.sh
fix potential white space in path bugs (merge from devel6_branch, r35687)
Modified: grass/branches/releasebranch_6_4/scripts/v.db.univar/v.db.univar
--- grass/branches/releasebranch_6_4/scripts/v.db.univar/v.db.univar 2009-01-30 22:04:06 UTC (rev 35687)
+++ grass/branches/releasebranch_6_4/scripts/v.db.univar/v.db.univar 2009-01-30 22:04:43 UTC (rev 35688)
@@ -115,9 +115,9 @@
fi
if [ -z "$GIS_OPT_WHERE" ] ; then
- db.select table="$GIS_OPT_TABLE" $db $drv sql="select $GIS_OPT_COLUMN from $GIS_OPT_TABLE" -c > "$TMP"
+ db.select table="$GIS_OPT_TABLE" ${db} ${drv} sql="select $GIS_OPT_COLUMN from $GIS_OPT_TABLE" -c > "$TMP"
else
- db.select table="$GIS_OPT_TABLE" $db $drv sql="select $GIS_OPT_COLUMN from $GIS_OPT_TABLE WHERE $GIS_OPT_WHERE" -c > "$TMP"
+ db.select table="$GIS_OPT_TABLE" ${db} ${drv} sql="select $GIS_OPT_COLUMN from $GIS_OPT_TABLE WHERE $GIS_OPT_WHERE" -c > "$TMP"
fi
Modified: grass/branches/releasebranch_6_4/scripts/v.univar.sh/v.univar.sh
--- grass/branches/releasebranch_6_4/scripts/v.univar.sh/v.univar.sh 2009-01-30 22:04:06 UTC (rev 35687)
+++ grass/branches/releasebranch_6_4/scripts/v.univar.sh/v.univar.sh 2009-01-30 22:04:43 UTC (rev 35688)
@@ -118,9 +118,9 @@
fi
else
fi
