[GRASS-SVN] r35694 - in grass/trunk: . general/g.cairocomp
include/Make
svn_grass at osgeo.org
Sat Jan 31 22:01:09 EST 2009
Author: glynn
Date: 2009-01-31 22:01:08 -0500 (Sat, 31 Jan 2009)
New Revision: 35694
grass/trunk/configure
grass/trunk/configure.in
grass/trunk/general/g.cairocomp/Makefile
grass/trunk/include/Make/Platform.make.in
Add cairo-ft to configure checks
Add, use configure check for cairo_xlib_surface_create_with_xrender_format()
Modified: grass/trunk/configure
--- grass/trunk/configure 2009-02-01 01:12:20 UTC (rev 35693)
+++ grass/trunk/configure 2009-02-01 03:01:08 UTC (rev 35694)
@@ -13394,10 +13394,9 @@
if test -n "$USE_CAIRO"; then
+cairo="cairo cairo-ft"
if test -n "$USE_X11"; then
- cairo=cairo\ cairo-xlib-xrender
-else
- cairo=cairo
+ cairo="$cairo cairo-xlib-xrender"
fi
# With Cairo includes directory
@@ -13406,7 +13405,7 @@
echo $ac_n "checking for location of cairo includes""... $ac_c" 1>&6
-echo "configure:13410: checking for location of cairo includes" >&5
+echo "configure:13409: checking for location of cairo includes" >&5
case "$with_cairo_includes" in
y | ye | yes | n | no)
{ echo "configure: error: *** You must supply a directory to --with-cairo-includes." 1>&2; exit 1; }
@@ -13432,15 +13431,15 @@
do
ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:13436: checking for $ac_hdr" >&5
+echo "configure:13435: checking for $ac_hdr" >&5
cat > conftest.$ac_ext <<EOF
-#line 13439 "configure"
+#line 13438 "configure"
#include "confdefs.h"
#include <$ac_hdr>
EOF
ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:13444: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13443: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
if test -z "$ac_err"; then
rm -rf conftest*
@@ -13476,7 +13475,7 @@
echo $ac_n "checking for location of cairo library""... $ac_c" 1>&6
-echo "configure:13480: checking for location of cairo library" >&5
+echo "configure:13479: checking for location of cairo library" >&5
case "$with_cairo_libs" in
{ echo "configure: error: *** You must supply a directory to --with-cairo-libs." 1>&2; exit 1; }
@@ -13496,7 +13495,7 @@
echo $ac_n "checking for cairo linking flags""... $ac_c" 1>&6
-echo "configure:13500: checking for cairo linking flags" >&5
+echo "configure:13499: checking for cairo linking flags" >&5
case "$with_cairo_ldflags" in
{ echo "configure: error: *** You must supply a directory to --with-cairo-ldflags." 1>&2; exit 1; }
@@ -13512,10 +13511,10 @@
LIBS=" $CAIROLIB $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for cairo_create""... $ac_c" 1>&6
-echo "configure:13516: checking for cairo_create" >&5
+echo "configure:13515: checking for cairo_create" >&5
-#line 13519 "configure"
+#line 13518 "configure"
/* System header to define __stub macros and hopefully few prototypes,
which can conflict with char cairo_create(); below. */
@@ -13538,7 +13537,7 @@
; return 0; }
EOF
-if { (eval echo configure:13542: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13541: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_cairo_create=yes"
else
@@ -13567,6 +13566,65 @@
LDFLAGS=${ac_save_ldflags}
+ac_save_libs="$LIBS"
+ac_save_ldflags="$LDFLAGS"
+LIBS=" $CAIROLIB $LIBS"
+LDFLAGS=" $LDFLAGS"
+echo $ac_n "checking for cairo_xlib_surface_create_with_xrender_format""... $ac_c" 1>&6
+echo "configure:13575: checking for cairo_xlib_surface_create_with_xrender_format" >&5
+cat > conftest.$ac_ext <<EOF
+#line 13578 "configure"
+#include "confdefs.h"
+/* System header to define __stub macros and hopefully few prototypes,
+ which can conflict with char cairo_xlib_surface_create_with_xrender_format(); below. */
+#include <assert.h>
+/* Override any gcc2 internal prototype to avoid an error. */
+/* We use char because int might match the return type of a gcc2
+ builtin and then its argument prototype would still apply. */
+char cairo_xlib_surface_create_with_xrender_format();
+int main() {
+/* The GNU C library defines this for functions which it implements
+ to always fail with ENOSYS. Some functions are actually named
+ something starting with __ and the normal name is an alias. */
+#if defined (__stub_cairo_xlib_surface_create_with_xrender_format) || defined (__stub___cairo_xlib_surface_create_with_xrender_format)
+choke me
+#else
+cairo_xlib_surface_create_with_xrender_format();
+#endif
+; return 0; }
+EOF
+if { (eval echo configure:13601: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+ rm -rf conftest*
+ eval "ac_cv_func_cairo_xlib_surface_create_with_xrender_format=yes"
+else
+ echo "configure: failed program was:" >&5
+ cat conftest.$ac_ext >&5
+ rm -rf conftest*
+ eval "ac_cv_func_cairo_xlib_surface_create_with_xrender_format=no"
+fi
+rm -f conftest*
+if eval "test \"`echo '$ac_cv_func_'cairo_xlib_surface_create_with_xrender_format`\" = yes"; then
+ echo "$ac_t""yes" 1>&6
+CAIRO_HAS_XRENDER=1
+else
+ echo "$ac_t""no" 1>&6
+CAIRO_HAS_XRENDER=0
+fi
+LIBS=${ac_save_libs}
+LDFLAGS=${ac_save_ldflags}
CAIROLIB="$CAIROLIB $CAIROLDFLAGS"
fi # $USE_CAIRO
@@ -13581,7 +13639,7 @@
echo $ac_n "checking whether to use FreeType""... $ac_c" 1>&6
-echo "configure:13585: checking whether to use FreeType" >&5
+echo "configure:13643: checking whether to use FreeType" >&5
echo "$ac_t"""$with_freetype"" 1>&6
case "$with_freetype" in
"no") USE_FREETYPE= ;;
@@ -13600,7 +13658,7 @@
echo $ac_n "checking for location of FreeType includes""... $ac_c" 1>&6
-echo "configure:13604: checking for location of FreeType includes" >&5
+echo "configure:13662: checking for location of FreeType includes" >&5
case "$with_freetype_includes" in
{ echo "configure: error: *** You must supply a directory to --with-freetype-includes." 1>&2; exit 1; }
@@ -13626,15 +13684,15 @@
do
-echo "configure:13630: checking for $ac_hdr" >&5
+echo "configure:13688: checking for $ac_hdr" >&5
-#line 13633 "configure"
+#line 13691 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:13638: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13696: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -13668,7 +13726,7 @@
echo $ac_n "checking for location of FreeType library""... $ac_c" 1>&6
-echo "configure:13672: checking for location of FreeType library" >&5
+echo "configure:13730: checking for location of FreeType library" >&5
case "$with_freetype_libs" in
{ echo "configure: error: *** You must supply a directory to --with-freetype-libs." 1>&2; exit 1; }
@@ -13693,13 +13751,13 @@
echo $ac_n "checking for FT_Init_FreeType in -lfreetype""... $ac_c" 1>&6
-echo "configure:13697: checking for FT_Init_FreeType in -lfreetype" >&5
+echo "configure:13755: checking for FT_Init_FreeType in -lfreetype" >&5
ac_lib_var=`echo freetype'_'FT_Init_FreeType | sed 'y%./+-%__p_%'`
ac_save_LIBS="$LIBS"
LIBS="-lfreetype $LIBS"
-#line 13703 "configure"
+#line 13761 "configure"
@@ -13710,7 +13768,7 @@
FT_Init_FreeType()
; return 0; }
EOF
-if { (eval echo configure:13714: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13772: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_lib_$ac_lib_var=yes"
else
@@ -13751,7 +13809,7 @@
echo $ac_n "checking whether to use NLS""... $ac_c" 1>&6
-echo "configure:13755: checking whether to use NLS" >&5
+echo "configure:13813: checking whether to use NLS" >&5
echo "$ac_t"""$with_nls"" 1>&6
case "$with_nls" in
"no") USE_NLS= ;;
@@ -13771,10 +13829,10 @@
echo $ac_n "checking for gettext""... $ac_c" 1>&6
-echo "configure:13775: checking for gettext" >&5
+echo "configure:13833: checking for gettext" >&5
-#line 13778 "configure"
+#line 13836 "configure"
which can conflict with char gettext(); below. */
@@ -13797,7 +13855,7 @@
; return 0; }
EOF
-if { (eval echo configure:13801: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13859: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_gettext=yes"
else
@@ -13815,13 +13873,13 @@
echo $ac_n "checking for gettext in -lintl""... $ac_c" 1>&6
-echo "configure:13819: checking for gettext in -lintl" >&5
+echo "configure:13877: checking for gettext in -lintl" >&5
ac_lib_var=`echo intl'_'gettext | sed 'y%./+-%__p_%'`
LIBS="-lintl $LIBS"
-#line 13825 "configure"
+#line 13883 "configure"
@@ -13832,7 +13890,7 @@
gettext()
; return 0; }
EOF
-if { (eval echo configure:13836: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13894: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13867,7 +13925,7 @@
echo $ac_n "checking whether to use C++""... $ac_c" 1>&6
-echo "configure:13871: checking whether to use C++" >&5
+echo "configure:13929: checking whether to use C++" >&5
echo "$ac_t"""$with_cxx"" 1>&6
case "$with_cxx" in
"no") USE_CXX= ;;
@@ -13883,7 +13941,7 @@
# Extract the first word of "$ac_prog", so it can be a program name with args.
set dummy $ac_prog; ac_word=$2
echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:13887: checking for $ac_word" >&5
+echo "configure:13945: checking for $ac_word" >&5
if test -n "$CXX"; then
ac_cv_prog_CXX="$CXX" # Let the user override the test.
@@ -13912,7 +13970,7 @@
echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works""... $ac_c" 1>&6
-echo "configure:13916: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
+echo "configure:13974: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
ac_ext=C
# CXXFLAGS is not in ac_cpp because -g, -O, etc. are not valid cpp options.
@@ -13923,12 +13981,12 @@
cat > conftest.$ac_ext << EOF
-#line 13927 "configure"
+#line 13985 "configure"
int main(){return(0);}
EOF
-if { (eval echo configure:13932: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13990: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
ac_cv_prog_cxx_works=yes
# If we can't run a trivial program, we are probably using a cross compiler.
if (./conftest; exit) 2>/dev/null; then
@@ -13954,19 +14012,19 @@
{ echo "configure: error: installation or configuration problem: C++ compiler cannot create executables." 1>&2; exit 1; }
fi
echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler""... $ac_c" 1>&6
-echo "configure:13958: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
+echo "configure:14016: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
echo "$ac_t""$ac_cv_prog_cxx_cross" 1>&6
cross_compiling=$ac_cv_prog_cxx_cross
echo $ac_n "checking whether we are using GNU C++""... $ac_c" 1>&6
-echo "configure:13963: checking whether we are using GNU C++" >&5
+echo "configure:14021: checking whether we are using GNU C++" >&5
cat > conftest.C <<EOF
#ifdef __GNUC__
yes;
#endif
EOF
-if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:13970: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
+if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:14028: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
ac_cv_prog_gxx=yes
else
ac_cv_prog_gxx=no
@@ -13984,7 +14042,7 @@
ac_save_CXXFLAGS="$CXXFLAGS"
CXXFLAGS=
echo $ac_n "checking whether ${CXX-g++} accepts -g""... $ac_c" 1>&6
-echo "configure:13988: checking whether ${CXX-g++} accepts -g" >&5
+echo "configure:14046: checking whether ${CXX-g++} accepts -g" >&5
echo 'void f(){}' > conftest.cc
if test -z "`${CXX-g++} -g -c conftest.cc 2>&1`"; then
@@ -14025,7 +14083,7 @@
echo $ac_n "checking whether to use openDWG""... $ac_c" 1>&6
-echo "configure:14029: checking whether to use openDWG" >&5
+echo "configure:14087: checking whether to use openDWG" >&5
echo "$ac_t"""$with_opendwg"" 1>&6
case "$with_opendwg" in
"no") USE_OPENDWG= ;;
@@ -14045,7 +14103,7 @@
echo $ac_n "checking for location of openDGW includes""... $ac_c" 1>&6
-echo "configure:14049: checking for location of openDGW includes" >&5
+echo "configure:14107: checking for location of openDGW includes" >&5
case "$with_opendwg_includes" in
{ echo "configure: error: *** You must supply a directory to --with-opendwg-includes." 1>&2; exit 1; }
@@ -14071,15 +14129,15 @@
do
-echo "configure:14075: checking for $ac_hdr" >&5
+echo "configure:14133: checking for $ac_hdr" >&5
-#line 14078 "configure"
+#line 14136 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:14083: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14141: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -14113,7 +14171,7 @@
echo $ac_n "checking for location of openDWG library""... $ac_c" 1>&6
-echo "configure:14117: checking for location of openDWG library" >&5
+echo "configure:14175: checking for location of openDWG library" >&5
case "$with_opendwg_libs" in
{ echo "configure: error: *** You must supply a directory to --with-opendwg-libs." 1>&2; exit 1; }
@@ -14154,7 +14212,7 @@
echo $ac_n "checking whether to use POSIX threads""... $ac_c" 1>&6
-echo "configure:14158: checking whether to use POSIX threads" >&5
+echo "configure:14216: checking whether to use POSIX threads" >&5
echo "$ac_t"""$with_pthread"" 1>&6
case "$with_pthread" in
"no") USE_PTHREAD= ;;
@@ -14174,7 +14232,7 @@
echo $ac_n "checking for location of POSIX threads includes""... $ac_c" 1>&6
-echo "configure:14178: checking for location of POSIX threads includes" >&5
+echo "configure:14236: checking for location of POSIX threads includes" >&5
case "$with_pthread_includes" in
{ echo "configure: error: *** You must supply a directory to --with-pthread-includes." 1>&2; exit 1; }
@@ -14200,15 +14258,15 @@
do
-echo "configure:14204: checking for $ac_hdr" >&5
+echo "configure:14262: checking for $ac_hdr" >&5
-#line 14207 "configure"
+#line 14265 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:14212: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14270: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -14242,7 +14300,7 @@
echo $ac_n "checking for location of POSIX threads library""... $ac_c" 1>&6
-echo "configure:14246: checking for location of POSIX threads library" >&5
+echo "configure:14304: checking for location of POSIX threads library" >&5
case "$with_pthread_libs" in
{ echo "configure: error: *** You must supply a directory to --with-pthread-libs." 1>&2; exit 1; }
@@ -14267,10 +14325,10 @@
LIBS=" $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for pthread_create""... $ac_c" 1>&6
-echo "configure:14271: checking for pthread_create" >&5
+echo "configure:14329: checking for pthread_create" >&5
-#line 14274 "configure"
+#line 14332 "configure"
which can conflict with char pthread_create(); below. */
@@ -14293,7 +14351,7 @@
; return 0; }
EOF
-if { (eval echo configure:14297: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14355: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_pthread_create=yes"
else
@@ -14320,13 +14378,13 @@
echo $ac_n "checking for pthread_create in -lpthread""... $ac_c" 1>&6
-echo "configure:14324: checking for pthread_create in -lpthread" >&5
+echo "configure:14382: checking for pthread_create in -lpthread" >&5
ac_lib_var=`echo pthread'_'pthread_create | sed 'y%./+-%__p_%'`
LIBS="-lpthread $LIBS"
-#line 14330 "configure"
+#line 14388 "configure"
@@ -14337,7 +14395,7 @@
pthread_create()
; return 0; }
EOF
-if { (eval echo configure:14341: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14399: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14393,7 +14451,7 @@
if test "$enable_largefile" = yes; then
echo $ac_n "checking for special C compiler options needed for large files""... $ac_c" 1>&6
-echo "configure:14397: checking for special C compiler options needed for large files" >&5
+echo "configure:14455: checking for special C compiler options needed for large files" >&5
ac_cv_sys_largefile_CC=no
largefile_cc_opt=""
@@ -14401,7 +14459,7 @@
# IRIX 6.2 and later do not support large files by default,
# so use the C compiler's -n32 option if that helps.
-#line 14405 "configure"
+#line 14463 "configure"
#include <sys/types.h>
/* Check that off_t can represent 2**63 - 1 correctly.
@@ -14417,7 +14475,7 @@
; return 0; }
EOF
-if { (eval echo configure:14421: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14479: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
@@ -14426,7 +14484,7 @@
ac_save_CC="${CC-cc}"
CC="$CC -n32"
-#line 14430 "configure"
+#line 14488 "configure"
@@ -14442,7 +14500,7 @@
; return 0; }
EOF
-if { (eval echo configure:14446: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14504: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_largefile_CC=' -n32'
else
@@ -14462,11 +14520,11 @@
fi
echo $ac_n "checking for _FILE_OFFSET_BITS value needed for large files""... $ac_c" 1>&6
-echo "configure:14466: checking for _FILE_OFFSET_BITS value needed for large files" >&5
+echo "configure:14524: checking for _FILE_OFFSET_BITS value needed for large files" >&5
ac_cv_sys_file_offset_bits=no
-#line 14470 "configure"
+#line 14528 "configure"
@@ -14482,14 +14540,14 @@
; return 0; }
EOF
-if { (eval echo configure:14486: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14544: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
rm -rf conftest*
-#line 14493 "configure"
+#line 14551 "configure"
#define _FILE_OFFSET_BITS 64
@@ -14507,7 +14565,7 @@
; return 0; }
EOF
-if { (eval echo configure:14511: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14569: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_file_offset_bits=64
else
@@ -14526,11 +14584,11 @@
fi
echo $ac_n "checking for _LARGE_FILES value needed for large files""... $ac_c" 1>&6
-echo "configure:14530: checking for _LARGE_FILES value needed for large files" >&5
+echo "configure:14588: checking for _LARGE_FILES value needed for large files" >&5
ac_cv_sys_large_files=no
-#line 14534 "configure"
+#line 14592 "configure"
@@ -14546,14 +14604,14 @@
; return 0; }
EOF
-if { (eval echo configure:14550: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14608: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
rm -rf conftest*
-#line 14557 "configure"
+#line 14615 "configure"
#define _LARGE_FILES 1
@@ -14571,7 +14629,7 @@
; return 0; }
EOF
-if { (eval echo configure:14575: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14633: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_large_files=1
else
@@ -14590,25 +14648,25 @@
fi
echo $ac_n "checking for _LARGEFILE_SOURCE value needed for large files""... $ac_c" 1>&6
-echo "configure:14594: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:14652: checking for _LARGEFILE_SOURCE value needed for large files" >&5
ac_cv_sys_largefile_source=no
-#line 14598 "configure"
+#line 14656 "configure"
#include <stdio.h>
int main() {
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:14605: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14663: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
rm -rf conftest*
-#line 14612 "configure"
+#line 14670 "configure"
#define _LARGEFILE_SOURCE 1
#include <stdio.h>
@@ -14617,7 +14675,7 @@
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:14621: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14679: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_largefile_source=1
else
@@ -14638,10 +14696,10 @@
fi
echo $ac_n "checking if system supports Large Files at all""... $ac_c" 1>&6
-echo "configure:14642: checking if system supports Large Files at all" >&5
+echo "configure:14700: checking if system supports Large Files at all" >&5
-#line 14645 "configure"
+#line 14703 "configure"
#include <stdio.h>
@@ -14673,7 +14731,7 @@
#endif
; return 0; }
EOF
-if { (eval echo configure:14677: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14735: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_largefiles=yes
else
@@ -14702,7 +14760,7 @@
# Python check
echo $ac_n "checking whether to use Python""... $ac_c" 1>&6
-echo "configure:14706: checking whether to use Python" >&5
+echo "configure:14764: checking whether to use Python" >&5
PYTHONINC=
PYTHONCFLAGS=
@@ -14722,7 +14780,7 @@
# Extract the first word of "python-config", so it can be a program name with args.
set dummy python-config; ac_word=$2
-echo "configure:14726: checking for $ac_word" >&5
+echo "configure:14784: checking for $ac_word" >&5
case "$PY_CONFIG" in
@@ -14767,15 +14825,15 @@
do
-echo "configure:14771: checking for $ac_hdr" >&5
+echo "configure:14829: checking for $ac_hdr" >&5
-#line 14774 "configure"
+#line 14832 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:14779: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14837: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -14815,7 +14873,7 @@
# Extract the first word of "swig", so it can be a program name with args.
set dummy swig; ac_word=$2
-echo "configure:14819: checking for $ac_word" >&5
+echo "configure:14877: checking for $ac_word" >&5
case "$SWIG" in
@@ -14861,7 +14919,7 @@
# Enable wxWidgets support (for wxGUI)
echo $ac_n "checking whether to use wxWidgets""... $ac_c" 1>&6
-echo "configure:14865: checking whether to use wxWidgets" >&5
+echo "configure:14923: checking whether to use wxWidgets" >&5
WXVERSION=
WXWIDGETSCXXFLAGS=
@@ -14881,7 +14939,7 @@
# Extract the first word of "wx-config", so it can be a program name with args.
set dummy wx-config; ac_word=$2
-echo "configure:14885: checking for $ac_word" >&5
+echo "configure:14943: checking for $ac_word" >&5
case "$WX_CONFIG" in
@@ -14929,7 +14987,7 @@
REQWX="2.8.1"
echo $ac_n "checking wxWidgets version""... $ac_c" 1>&6
-echo "configure:14933: checking wxWidgets version" >&5
+echo "configure:14991: checking wxWidgets version" >&5
if WXVERSION=`"$WX_CONFIG" --version`; then
echo "$ac_t""$WXVERSION" 1>&6
else
@@ -14952,15 +15010,15 @@
do
-echo "configure:14956: checking for $ac_hdr" >&5
+echo "configure:15014: checking for $ac_hdr" >&5
-#line 14959 "configure"
+#line 15017 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:14964: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:15022: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -15245,6 +15303,7 @@
s%@BLASINC@%$BLASINC%g
s%@LAPACKLIB@%$LAPACKLIB%g
s%@LAPACKINC@%$LAPACKINC%g
+s%@CAIRO_HAS_XRENDER@%$CAIRO_HAS_XRENDER%g
s%@CAIROINC@%$CAIROINC%g
s%@CAIROLIB@%$CAIROLIB%g
s%@USE_CAIRO@%$USE_CAIRO%g
Modified: grass/trunk/configure.in
--- grass/trunk/configure.in 2009-02-01 01:12:20 UTC (rev 35693)
+++ grass/trunk/configure.in 2009-02-01 03:01:08 UTC (rev 35694)
@@ -1392,10 +1392,9 @@
-else
- cairo=cairo
fi
@@ -1414,6 +1413,9 @@
LOC_CHECK_LDFLAGS(cairo,cairo,CAIROLIB)
LOC_CHECK_FUNC(cairo_create,,,,,$CAIROLIB,[:])
+LOC_CHECK_FUNC(cairo_xlib_surface_create_with_xrender_format,,,,,$CAIROLIB,
+[CAIRO_HAS_XRENDER=1],[CAIRO_HAS_XRENDER=0])
+AC_SUBST(CAIRO_HAS_XRENDER)
Modified: grass/trunk/general/g.cairocomp/Makefile
--- grass/trunk/general/g.cairocomp/Makefile 2009-02-01 01:12:20 UTC (rev 35693)
+++ grass/trunk/general/g.cairocomp/Makefile 2009-02-01 03:01:08 UTC (rev 35694)
@@ -10,6 +10,8 @@
ifneq ($(USE_CAIRO),)
ifneq ($(USE_X11),)
+ifneq ($(CAIRO_HAS_XRENDER),)
default: cmd
endif
endif
+endif
Modified: grass/trunk/include/Make/Platform.make.in
--- grass/trunk/include/Make/Platform.make.in 2009-02-01 01:12:20 UTC (rev 35693)
+++ grass/trunk/include/Make/Platform.make.in 2009-02-01 03:01:08 UTC (rev 35694)
@@ -210,6 +210,7 @@
CAIROINC = @CAIROINC@
CAIROLIB = @CAIROLIB@
USE_CAIRO = @USE_CAIRO@
+CAIRO_HAS_XRENDER = @CAIRO_HAS_XRENDER@
#Python
PYTHONINC = @PYTHONINC@
