[GRASS-SVN] r38163 - grass-addons/vector/v.in.postgis.sqlquery
svn_grass at osgeo.org
Thu Jul 2 11:30:11 EDT 2009
Author: mathieug
Date: 2009-07-02 11:30:11 -0400 (Thu, 02 Jul 2009)
New Revision: 38163
Removed:
grass-addons/vector/v.in.postgis.sqlquery/v_in_postgis_sqlquery_tests.py
renamed module
Deleted: grass-addons/vector/v.in.postgis.sqlquery/v_in_postgis_sqlquery_tests.py
--- grass-addons/vector/v.in.postgis.sqlquery/v_in_postgis_sqlquery_tests.py 2009-07-02 15:01:35 UTC (rev 38162)
+++ grass-addons/vector/v.in.postgis.sqlquery/v_in_postgis_sqlquery_tests.py 2009-07-02 15:30:11 UTC (rev 38163)
@@ -1,237 +0,0 @@
-#!/usr/bin/python
-#-*- coding: utf-8 -*-
-# MODULE: v_in_postgis_sqlquery_tests.py
-# AUTHOR(S): Mathieu Grelier, 2009 (greliermathieu at gmail.com)
-# PURPOSE: An attempt of a GRASS module unit test
-# COPYRIGHT: (C) 2009 Mathieu Grelier
-# This program is free software under the GNU General Public
-# License (>=v2). Read the file COPYING that comes with GRASS
-# for details.
-import sys
-import os
-##see http://trac.osgeo.org/grass/browser/grass/trunk/lib/python
-from grass import core as grass
-##only needed to use debugger. See http://aspn.activestate.com/ASPN/Downloads/Komodo/RemoteDebugging
-from dbgp.client import brk
-##see http://pyunit.sourceforge.net/
-import unittest
-##see http://initd.org/pub/software/psycopg/
-import psycopg2 as dbapi2
-importer = None
-db = None
-cursor = None
-host = None
-dbname = None
-user = None
-pwd = None
-testTableName = None
-queryTableName = None
-geometryField = None
-geoparams = None
-class v_in_postgis_sqlquery_tests(unittest.TestCase):
- def setUp(self):
- grass.run_command("db.connect", driver = 'pg', database = 'host=' + host + ",dbname=" + dbname)
- def tearDown(self):
- cleanUpQueryTable()
- def testGetDbInfos(self):
- Test if the importer is able to retrieve correctly the parameters dictionnary for current connection.
- self.assertEqual(importer.dbparams['host'],host)
- self.assertEqual(importer.dbparams['db'],dbname)
- self.assertEqual(importer.dbparams['user'],user)
- self.assertEqual(importer.dbparams['pwd'],pwd)
- def testCheckLayers(self):
- !Test if overwrite is working correctly
- from v_in_postgis_sqlquery import GrassPostGisImporterError
- os.environ['GRASS_OVERWRITE'] = '0'
- createQueryTable()
- importer.addGeometry(queryTableName, geometryField, geoparams, False)
- importer.commitChanges()
- importer.importToGrass(queryTableName, geometryField, geoparams, toDbf = False, overrideProj = True)
- ##GRASS_OVERWRITE set to False, we can't import again the layer
- self.assertRaises(GrassPostGisImporterError, importer.checkLayers, queryTableName)
- ##now set to True, it should be possible
- os.environ['GRASS_OVERWRITE'] = '1'
- try:
- importer.checkLayers(queryTableName)
- except Exception:
- self.fail("CheckLayers was expected to be successful with --o flag.")
- pass
- def testCheckComment(self):
- !Test that we can't drop a table with the output name if it was not created by the importer.
- ##a table that was not tagged by the importer should not be overwritten
- self.assertRaises(GrassPostGisImporterError, importer.checkComment, testTableName)
- pass
- def testCreateTable(self):
- pass
- def testAddingCategoryWithPgDriverIsNecessary(self):
- """!Test is the cat column addition is working and is still necessary with pg driver import
- cat column is necessary for GRASS to store categories.
- For now, the pg driver for v.in.ogr doesn't doesn't add automatically this
- cat column, whereas the dbf driver does. So the importer has a specific addCategory()
- method, which necessity is tested here.
- ##starting with postgis to dbf import : no need to use the addCategory() method is expected
- importer.importToGrass(queryTableName, geometryField, geoparams, toDbf = True, overrideProj = True)
- cmd = importer.executeCommand("v.univar", map = queryTableName, column = 'value')
- self.assertEqual(cmd['return_code'], 0)
- ##now same operations with pg driver : error is expected when GRASS use the cat column.
- importer.importToGrass(queryTableName, geometryField, geoparams, False, True)
- self.assertNotEqual(cmd['return_code'], 0)
- ##now same operations with pg driver, after adding category column
- ##with the importer : error should not occur.
- importer.addCategory(queryTableName)
- def testGeometryDuplicationIsNecessary(self):
- """!Test that we need to use the postGis' AddGeometryColumn function"""
- self.assertRaises(GrassPostGisImporterError, importer.importToGrass, queryTableName, \
- geometryField, geoparams, False, True)
- ##now addGeometry:
- try:
- except Exception:
- self.fail("Both operations are for now expected to be necessary.")
- pass
-def createQueryTable():
- importer.createPostgresTableFromQuery(queryTableName, 'select * from ' + testTableName + ' where id=1')
-def cleanUpQueryTable():
- db.rollback()
- try:
- importer.executeCommand("g.remove", vect = queryTableName, quiet = True)
- cursor.execute('DROP TABLE ' + queryTableName)
- except:
- pass
- try:
- cursor.execute("DELETE FROM geometry_columns WHERE f_table_name = '" + queryTableName + "'")
- except:
- pass
- db.commit()
-def cleanUp():
- db.rollback()
- try:
- importer.executeCommand("g.remove", vect = testTableName, quiet = True)
- cursor.execute('DROP TABLE ' + testTableName)
- except:
- pass
- try:
- cursor.execute("DELETE FROM geometry_columns WHERE f_table_name = '" + testTableName + "'")
- except:
- pass
- db.commit()
-def suite():
- alltests = unittest.TestSuite()
- alltests.addTest(unittest.findTestCases(module))
- return alltests
-if __name__ == '__main__':
- ### DEBUG : uncomment to start local debugging session
- #brk(host="localhost", port=9000)
- currentDirectory = os.path.split(__file__)[0]
- sys.path.append(currentDirectory)
- ##test configuration
- options = {'sqlquery':'', 'geometryfield':'', 'output':''}
- flags = {'d':0, 'z':0, 'o':0, 'g':0, 'l':0}
- importer = GrassPostGisImporter(options, flags)
- module = __import__('v_in_postgis_sqlquery_tests')
- host = 'localhost'
- dbname = 'yourdb'
- user = 'postgres'
- pwd = 'yourpwd'
- db = dbapi2.connect(host=host, database=dbname, user=user, password=pwd)
- cursor = db.cursor()
- testTableName = 'test_grass_import'
- queryTableName = 'test_query'
- geometryField = 'the_geom'
- geoparams = {'type':'POLYGON', 'ndims':'2', 'srid':'-1'}
- ##give access to test elements to module
- module.importer = importer
- module.db = db
- module.cursor = cursor
- module.host = host
- module.dbname = dbname
- module.user = user
- module.pwd = pwd
- module.testTableName = testTableName
- module.queryTableName = queryTableName
- module.geometryField = geometryField
- module.geoparams = geoparams
- ##test geo table
- cursor.execute("CREATE TABLE " + testTableName + " ( id int4, label varchar(20), value real )")
- cursor.execute("SELECT AddGeometryColumn('', '" + testTableName + "','" + geometryField + "',-1,'POLYGON',2)")
- cursor.execute("INSERT INTO " + testTableName + " (id, label, value, " + geometryField + ") VALUES (1, 'A Geometry', 10, \
- GeomFromText('POLYGON((0 0, 0 10, 10 10, 10 0, 0 0))', -1))")
- cursor.execute("INSERT INTO " + testTableName + " (id, label, value, " + geometryField + ") VALUES (2, 'Another Geometry', 20, \
- GeomFromText('POLYGON((0 0, 0 20, 20 20, 20 0, 0 0))', -1))")
- cursor.execute("ALTER TABLE " + testTableName + " ADD CONSTRAINT test_pkey " + " PRIMARY KEY (id)")
- db.commit()
- os.environ['GRASS_VERBOSE'] = '0'
- try:
- unittest.main(defaultTest='suite')
- finally:
- module.cleanUp()
- sys.exit(0)
