[GRASS-SVN] r38165 - grass-addons/vector/v.in.postgis.sqlquery
svn_grass at osgeo.org
Thu Jul 2 11:32:59 EDT 2009
Author: mathieug
Date: 2009-07-02 11:32:59 -0400 (Thu, 02 Jul 2009)
New Revision: 38165
Removed:
grass-addons/vector/v.in.postgis.sqlquery/v.in.postgis.sqlquery.html
renamed module
Deleted: grass-addons/vector/v.in.postgis.sqlquery/v.in.postgis.sqlquery.html
--- grass-addons/vector/v.in.postgis.sqlquery/v.in.postgis.sqlquery.html 2009-07-02 15:30:31 UTC (rev 38164)
+++ grass-addons/vector/v.in.postgis.sqlquery/v.in.postgis.sqlquery.html 2009-07-02 15:32:59 UTC (rev 38165)
@@ -1,91 +0,0 @@
-<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
-<html>
-<head>
-<title>v.in.postgis.sqlquery</title>
-<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
-<link rel="stylesheet" href="grassdocs.css" type="text/css">
-</head>
-<body bgcolor="white">
-<img src="grass.smlogo.gif" alt="GRASS logo"><hr align=center size=6 noshade>
-<h2>NAME</h2>
-<em><b>v.in.postgis.sqlquery</b></em> - Create a grass layer from any sql query in postgis
-<h2>KEYWORDS</h2>
-postgis, grass layer, sql
-<h2>SYNOPSIS</h2>
-<b>v.in.postgis.sqlquery</b><br>
-<b>v.in.postgis.sqlquery help</b><br>
-<b>v.in.postgis.sqlquery</b> [-<b>dzrg</b>] <b>sqlquery</b>=<em>string</em> <b>geometryfield</b>=<em>string</em> [<b>output</b>=<em>string</em>]
-<h3>Flags:</h3>
-<DL>
-<DT><b>-d</b></DT>
-<DD>import result in grass dbf format (no new table in postgis). If not set, the grass layer will be directly connected to the postgis new table</DD>
-<DT><b>-z</b></DT>
-<DD>use -z for v.in.ogr (create 3D output)</DD>
-<DT><b>-r</b></DT>
-<DD>use -o for v.in.ogr (override dataset projection)</DD>
-<DT><b>-g</b></DT>
-<DD>add a gist index to the imported table in postgis (useless with the d flag)</DD>
-<h3>Parameters:</h3>
-<DL>
-<DT><b>sqlquery</b>=<em>name</em></DT>
-<DD>Arbitrary sql query returning a recordset with geometry for each row </DD>
-<DT><b>geometryfield</b>=<em>name</em></DT>
-<DD>Name of the source geometry field. Usually defaults to the_geom but needed if a geometry function was used (for example, centroid), or if the table has many geometry columns</DD>
-<DT><b>output</b>=<em>name</em></DT>
-<DD>Name of the geographic postgis table where to place the query results. Will be the name of the imported grass layer. If -d flag is set, this table is deleted and replaced by a dbf attribute table. Use a different name than the original. Do not use capital letters </DD>
-</DL>
-<h2>DESCRIPTION</h2>
-<em>v.in.postgis.sqlquery</em> is a shell script to import as a grass layer the result of any sql query returning geometry. There are two main modes : i)grass native format import with attributes in a dbf file. No tables are added in PostGIS ; ii)Grass layer import with attributes directly connected to a temporary table in PostGIS containing the query results.
-Before using the script, db.connect (and eventually db.login) commands must have been called.
-The script has been tested with Linux and WinGrass. However, for winGrass, you should modify the home directory setting at the beginning of the script.
-Logfile is written in the directory specified by the LOGFILE environment variable (default : home directory).
-<h2>EXAMPLES</h2>
-<li><B>PostGIS sql query to grass map </B>(dbf attributes table, no new table in postgis)<BR>
-<div class="code"><pre>
-v.in.postgis.sqlquery -d sqlquery="SELECT * FROM zones, data WHERE zones.zone_id=data.zone_id AND value > 100" output=zones
-</pre></div>
-<li><B>work in Grass directly on a PostGIS table</B> (a new table is added in postgis, create a gist index)<BR>
-v.in.postgis.sqlquery -r -g sqlquery="SELECT value, centroid(geocolumn) AS locations FROM zones, data WHERE zones.zone_id=data.zone_id
-GROUP BY name" geometryfield=locations output=locations
-</pre></div>
-<BR>
-<h2>SEE ALSO</h2>
-<em><a HREF="db.connect.html">db.connect</a></em>,
-<em><a HREF="db.login.html">db.login</a></em>,
-<em><a HREF="v.in.ogr">v.in.ogr</a></em>,
-<h2>AUTHOR</h2>
-Mathieu Grelier, greliermathieu at gmail.com
-<br>
-<p>
-<i>Last changed: $Date: 2007/10/10 12:10:14 $</i>
-<HR>
-<P><a href="index.html">Main index</a> - <a href="vector.html">vector index</a> - <a href="full_index.html">Full index</a></P>
-</body>
-</html>
