[GRASS-SVN] r38193 - grass-addons/vector/v.autokrige
Fri Jul 3 12:44:22 EDT 2009
Author: mathieug
Date: 2009-07-03 12:44:22 -0400 (Fri, 03 Jul 2009)
New Revision: 38193
Added:
   grass-addons/vector/v.autokrige/v.autokrige.py
Removed:
   grass-addons/vector/v.autokrige/v_autokrige.py
corrected region flag inversion
Added: grass-addons/vector/v.autokrige/v.autokrige.py
--- grass-addons/vector/v.autokrige/v.autokrige.py	                        (rev 0)
+++ grass-addons/vector/v.autokrige/v.autokrige.py	2009-07-03 16:44:22 UTC (rev 38193)
@@ -0,0 +1,452 @@
+#!/usr/bin/python
+#-*- coding: utf-8 -*-
+# MODULE:       v.autokrige.py
+# AUTHOR(S):	Mathieu Grelier (greliermathieu at gmail.com)
+# PURPOSE:	automatic kriging interpolation from vector point data
+# REQUIREMENTS:
+#   - statistical software : R (http://www.r-project.org/)
+#   - R packages :
+#       - spgrass6 (http://cran.r-project.org/web/packages/spgrass6/index.html)
+#       - automap (http://intamap.geo.uu.nl/~paul/Downloads.html) packages
+#   - optional :
+#       - imagemagick : convert program
+# COPYRIGHT:	(C) 2009 Mathieu Grelier
+#		This program is free software under the GNU General Public
+#		License (>=v2). Read the file COPYING that comes with GRASS
+#		for details.
+#%Module
+#%  description: automatic ordinary kriging interpolation from vector point data with R automap package.
+#%  keywords: kriging, automap, R
+#%End
+#%option
+#% key: input
+#% type: string
+#% gisprompt: old,vector,vector
+#% description: Name of the vector containing values to interpolate (must not contain any null values)
+#% required : yes
+#%end
+#%option
+#% key: column
+#% type: string
+#% description: Attribute column to interpolate (must be numeric)
+#% required : yes
+#%end
+#%option
+#% key: nbcell
+#% type: integer
+#% answer: 100
+#% description: number of cell of the created grid. If set, GRASS region is affected
+#% required : no
+#%end
+#%option
+#% key: models
+#% type: string
+#% options: Exp,Sph,Gau,Mat
+#% multiple : yes
+#% answer:
+#% description: List of variogram models to be automatically tested. Select only one to fix the model
+#% required : no
+#%end
+#%option
+#% key: range
+#% type: integer
+#% description: Range value. Automatically fixed if not set
+#% required : no
+#%end
+#%option
+#% key: nugget
+#% type: double
+#% description: Nugget value. Automatically fixed if not set
+#% required : no
+#%end
+#%option
+#% key: sill
+#% type: double
+#% description: Sill value. Automatically fixed if not set
+#% required : no
+#%end
+#%option
+#% key: nmax
+#% type: double
+#% description: Local kriging. Number of nearest observations that should be used for a kriging prediction (default : all observations are used)
+#% required : no
+#%end
+#%option
+#% key: maxdist
+#% type: double
+#% description: Local kriging. Maximum distance for observations from the prediction location to be included for prediction (default : no limitation)
+#% required : no
+#%end
+#%option
+#% key: output
+#% type: string
+#% answer: autokrige
+#% description: Name of the raster to produce
+#% required : yes
+#%end
+#%option
+#% key: colormap
+#% type: string
+#% answer: bcyor
+#% description: Colormap file to use to colorize the raster
+#% required : no
+#%end
+#%flag
+#% key: v
+#% description: Create variance raster also
+#%end
+#%flag
+#% key: r
+#% description: Don't set region from sites extent. Region would have been previously set in grass
+#%end
+#%flag
+#% key: l
+#% description: Log R output to v_autokrige.py.log
+#%end
+import sys
+import os
+import re
+from subprocess import Popen, call, PIPE
+import traceback
+##see http://trac.osgeo.org/grass/browser/grass/trunk/lib/python
+from grass import core as grass
+##only needed to use debugger with Komodo IDE. See http://aspn.activestate.com/ASPN/Downloads/Komodo/RemoteDebugging
+#from dbgp.client import brk
+class AutoKrige():
+    def __init__(self, options, flags):
+        ##options
+        self.input = options['input']
+        self.column = options['column']
+        self.nbcell = options['nbcell'] if options['nbcell'].strip() != '' else None
+        self.models = options['models'] if options['models'].strip() != '' else None
+        self.range = options['range'] if options['range'].strip() != '' else 'NA'
+        self.nugget = options['nugget'] if options['nugget'].strip() != '' else 'NA'
+        self.sill = options['sill'] if options['sill'].strip() != '' else 'NA'
+        self.nmax = options['nmax'] if options['nmax'].strip() != '' else 'Inf'
+        self.maxdist = options['maxdist'] if options['maxdist'].strip() != '' else 'Inf'
+        self.output = options['output']
+        self.colormap = options['colormap'] if options['colormap'].strip() != '' else 'bcyor'
+        ##flags
+        self.varianceFlag = True if flags['v'] is True else False
+        self.regionFlag = False if flags['r'] is True else True
+        self.logROutput = True if flags['l'] is True else False
+        ##others
+        self.RscriptFile = None
+        logfilename = 'v.autokrige.py.log'
+        self.logfile = os.path.join(os.getenv('LOGDIR'),logfilename) if os.getenv('LOGDIR') else logfilename
+        grass.try_remove(self.logfile)
+    def __prepareRModelsString(self, models=None):
+        """Create the R argument as expected in the R script.
+        Used to avoid string manipulations with R."""
+        modelsString = ''
+        if models is None:
+            ##it is important not to have any space between commas and following slashes
+            modelsString = 'c(\\"Sph\\",\\"Exp\\",\\"Gau\\",\\"Mat\\")'
+        else:
+            ##conversion to R arguments in the expected format, starting from model1,model2...
+            ##add c(" at the beginning and add ") at the end
+            RargumentsDict['models'] = 'c(\\"' + models + '\\")'
+            ##replace commas by \",\"
+            p = re.compile(',')
+            modelsString = p.sub('\\",\\"',RargumentsDict['models'])
+        return modelsString
+    def __writeRScript(self):
+        """Create the R script for automap."""
+        RscriptFile = grass.tempfile()
+        fileHandle = open(RscriptFile, 'a')
+        script = """
+        options(echo = FALSE)
+        args <- commandArgs()
+        ##start at index 5 because first arguments are R options
+        cat("arguments:","\n")
+        sitesG <- args[5]
+        column <- args[6]
+        rastername <- args[7]
+        cellsize <- as.numeric(args[8])
+        models <- args[9]
+        modelslist <- eval(parse(text = models))
+        range <- as.numeric(args[10])
+        if(args[11] == "NA") {nugget = NA} else {nugget <- as.numeric(args[11])}
+        if(args[12] == "NA") {sill = NA} else {sill <- as.numeric(args[12])}
+        if(args[13] == "Inf") {nobsmax = Inf} else {nobsmax <- as.numeric(args[13])}
+        if(args[14] == "Inf") {maxdistance = Inf} else {maxdistance <- as.numeric(args[14])}
+        writevarrast <- as.logical(args[15])
+        ##preparing UK implementation
+        predictors <- as.character(args[16])
+        ##print arguments
+        cat("sitesG:",sitesG,"\n")
+        cat("column:",column,"\n")
+        cat("rastername:",rastername,"\n")
+        cat("cellsize:",cellsize,"\n")
+        cat("modelslist:",modelslist,"\n")
+        cat("range:",range,"\n")
+        cat("nugget:",nugget,"\n")
+        cat("sill:",sill,"\n")
+        cat("nobsmax:",nobsmax,"\n")
+        cat("maxdistance:",maxdistance,"\n")
+        cat("writevarrast:",writevarrast,"\n")
+        cat("predictors:",predictors,"\n")
+        ##variogram plot function
+        plot.autoKrigeVariogramAndFittedModel = function(x, sp.layout = NULL, ...)
+        ##Function adapted from plot.autoKrige in automap package.
+        ##Prints only the variogram and model as we already have the map output in GRASS.
+            library(lattice)
+            shift = 0.03
+            labels = as.character(x$exp_var$np)
+            vario = xyplot(gamma ~ dist, data = x$exp_var, panel = automap:::autokrige.vgm.panel,
+                        labels = labels, shift = shift, model = x$var_model,# subscripts = TRUE,
+                        direction = c(x$exp_var$dir.hor[1], x$exp_var$dir.ver[1]),
+                        ylim = c(min(0, 1.04 * min(x$exp_var$gamma)), 1.04 * max(x$exp_var$gamma)),
+                        xlim = c(0, 1.04 * max(x$exp_var$dist)), xlab = "Distance", ylab = "Semi-variance",
+                        main = "Experimental variogram and fitted variogram model", mode = "direct",...)
+            print(vario, position = c(0,0,1,1))
+        ##autokrige script
+        tryCatch({
+            ##libraries
+            library(spgrass6)
+            library(automap)
+            ##retrieve sites in a SpatialPointsDataFrame object
+            cat("retrieve sites from GRASS","\n")
+            sitesR <- readVECT6(sitesG, ignore.stderr = F)
+            cat("retrieve metadata","\n")
+            G <- gmeta6()
+            cat("GridTopology creation","\n")
+            grd <- gmeta2grd()
+            ##this is necessary to ensure that we have square cells
+            ##the more this number is small, the more the kriged map resolution is high
+            slot(grd, "cellsize") <- c(cellsize, cellsize)
+            ##creation of another grid object: SpatialGridDataFrame
+            ##this is a matrix whose values receive spatial coordinates associated to interpolated values
+            ##matrix size must be equal to the number of GridTopology cells
+            ##we create first a classical data.frame
+            data <- data.frame(list(k=rep(1,(floor(G$cols)*floor(G$rows)))))
+            cat("SpatialGridDataFrame creation","\n")
+            mask_SG <- SpatialGridDataFrame(grd, data=data, CRS(G$proj4))
+            ##add coordinates system
+            attr(sitesR, "proj4string") <-CRS(G$proj4)
+            cat("ordinary kriging","\n")
+            kriging_result = autoKrige(as.formula(paste(column,"~",predictors)), sitesR[column], mask_SG, model = modelslist, fix.values = c(nugget,range,sill), debug.level=-1, verbose=TRUE, nmax=nobsmax, maxdist=maxdistance)
+            cat("send raster to GRASS","\n")
+            writeRAST6(kriging_result$krige_output,rastername,zcol=1,NODATA=0)
+            cat("Generated",rastername," "); cat("", sep="\n")
+            if(writevarrast == T) {
+                varrastername = paste(rastername, "_var", sep = "")
+                writeRAST6(kriging_result$krige_output,varrastername,zcol=2,NODATA=0)
+                cat("Generated",varrastername," "); cat("", sep="\n")
+            ##plot experimental and model variogram
+            cat("plot kriging results","\n")
+            ##see R FAQ 7.19. Plotting to png can produce errors if R version < 2.7
+            ##we use the pdf driver then we will convert to png
+            options(device="pdf")
+            try(plot.autoKrigeVariogramAndFittedModel(kriging_result))
+            cat("R script done","\n")
+            quit(status = 0)
+        }, interrupt = function(ex) {
+            cat("An interrupt was detected while executing R script.\n")
+            cat(conditionMessage(ex), "\n")
+            quit(status = 4)
+            error = function(ex) {
+            cat("\n");
+            cat("Error while executing R script\n")
+            quit(status = 5)
+        ) ## tryCatch()
+        fileHandle.write(script)
+        fileHandle.close()
+        return RscriptFile
+    def __execRCommand(self, command, logFile = False):
+        """R command execution method using Popen in shell mode."""
+        if logFile is not False:
+            command = command + ' >> ' +  logFile
+        ##use redirection on stdout only
+        command = command + " 2>&1"
+        p = Popen(command, shell = True, stdout = PIPE)
+        retcode = p.wait()
+        com = p.communicate()
+        if retcode == 0:
+            return retcode
+        else:
+            lines = None
+                logHandle = open(logFile,"r")
+                lines = logHandle.readlines()
+            else:
+                r = re.compile('\n')
+                lines = r.split(com[0])
+            out = lines[-2].strip() + ":" + lines[-1].strip()
+            raise AutoKrigeError(out)
+    def printMessage(self, message, type = 'info'):
+        """Call grass message function corresponding to type."""
+        if type == 'error':
+            grass.error(message)
+        elif type == 'warning':
+            grass.warning(message)
+        elif type == 'info' and grass.gisenv()['GRASS_VERBOSE'] > 0:
+            grass.info(message)
+    def checkLayers(self, input, output, testVarianceRast = False):
+        """Preliminary checks before starting kriging.
+        Note : for this to work with grass6.3, in find_file function from core.py,
+        command should be (n flag removed because 6.4 specific):
+        s = read_command("g.findfile", element = element, file = name, mapset = mapset)
+        ##Test for input vector map.
+        testInput = grass.find_file(input, element = 'vector')
+        if testInput['fullname'] == '':
+            raise AutoKrigeError("vector map " + input + " not found in mapset search path.")
+        ##Test if output raster map already exists.
+        testOutput = grass.find_file(output, element = 'cell')
+        if testOutput['fullname'] != '':
+            if not grass.overwrite() is True:
+                raise AutoKrigeError("raster map " + output + " already exists in mapset search path. \n \
+Use the --o flag to overwrite.")
+            else:
+                self.printMessage("raster map " + output + " will be overwritten.", type = 'warning')
+        ##Test also variance raster.
+        if testVarianceRast is True:
+            testVarOutput = grass.find_file(output + '_var', element = 'cell')
+            if testVarOutput['fullname'] != '':
+                else:
+                    self.printMessage("raster map " + output + '_var' + " will be overwritten.", type = 'warning')
+    def getGridCellSize(self, input, nbcell, adjustRegionToSites = True):
+        """Define kriged grid cell size.
+        Raster resolution but also computation time depends on it.
+        We take region resolution as cell size but we can fix this resolution with the nbcell parameter.
+        Only one value is needed because the R script use square cells."""
+        if adjustRegionToSites is True:
+            grass.run_command("g.region", vect = input)
+        if nbcell is not None:
+            self.fixRegionResFromNumberOfCells(nbcell)
+        regionParams = grass.region()
+        cellsize = float(regionParams['nsres']) if float(regionParams['nsres']) > float(regionParams['ewres']) \
+        else float(regionParams['ewres'])
+        return cellsize
+    def fixRegionResFromNumberOfCells(self, nbcell=100):
+        """Adjust one of the two region dimensions so that we have a maximum of 'nbcell' cells in both."""
+        nsResForGivenNbCell = (float(regionParams['n'])- float(regionParams['s'])) / float(nbcell)
+        ewResForGivenNbCell = (float(regionParams['e'])- float(regionParams['w'])) / float(nbcell)
+        tmpRegionRes = nsResForGivenNbCell if nsResForGivenNbCell > ewResForGivenNbCell else ewResForGivenNbCell
+        grass.use_temp_region
+        grass.run_command("g.region", res = tmpRegionRes)
+    def finalizeOutput(self):
+        """Final operations after successful kriging.
+        We don't want to stop execution if an error occurs here.
+        try:
+            ##convert plot to png
+            call('convert -alpha off Rplots.pdf autokrige_result.png', shell = True)
+            grass.try_remove('Rplots.pdf')
+            ##apply colormap
+            grass.run_command("r.colors", map = self.output, rules = self.colormap, quiet = True)
+            if self.varianceFlag is True:
+                grass.run_command("r.colors", map = self.output + '_var', rules = self.colormap, quiet = True)
+        except:
+            pass
+    def runAutoKrige(self):
+        """Performs kriging process."""
+        ##1)Necessary checks
+        self.checkLayers(self.input, self.output, self.varianceFlag)
+        ##2)Adjust interpolation resolution
+        cellsize = self.getGridCellSize(self.input, self.nbcell, self.regionFlag)
+        ##3)Execute R from GRASS
+        self.RscriptFile = self.__writeRScript()
+        ##spgrass6 cause : column name in R has only the 10 first characters of the original column name
+        ##may change with future versions of spgrass6
+        Rcolumnname = self.column[0:10]
+        writeVarRast = 'T' if self.varianceFlag is True else 'F'
+        self.printMessage("RGrass is working...", type = 'info')
+        #print "RGrass is working..."
+        ##ordinary kriging for now
+        predictors = '1'
+        autoKrigeCommand = 'R --vanilla --slave --args ' + self.input + ' ' + Rcolumnname + ' ' + \
+                        self.output + ' ' + str(cellsize) + ' "' + self.__prepareRModelsString() + '" ' + \
+                        self.range + ' ' +  self.nugget + ' ' + self.sill \
+                        + ' ' + self.nmax + ' ' + self.maxdist + ' ' \
+                        + writeVarRast + ' ' + predictors + ' < "' + self.RscriptFile + '"'
+        logFileArg = self.logfile if self.logROutput is True else False
+        self.__execRCommand(autoKrigeCommand, logFile=logFileArg)
+        ##4)Final steps
+        self.finalizeOutput()
+class AutoKrigeError(Exception):
+    """Errors specific to Autokrige class."""
+    def __init__(self, message=''):
+        self.details = '\nDetails:\n'
+        exceptionType, exceptionValue, exceptionTraceback = sys.exc_info()
+        self.details += repr(traceback.format_exception(exceptionType, exceptionValue, exceptionTraceback))
+        self.message = message + "\n" + self.details
+def main():
+    exitStatus = 0
+    try:
+        autoKrige = AutoKrige(options, flags)
+        autoKrige.runAutoKrige()
+    except AutoKrigeError, e1:
+        autoKrige.printMessage(e1.message, type = 'error')
+        exitStatus = 1
+    except:
+        errorMessage = "Unexpected error \n:" + \
+                       repr(traceback.format_exception(exceptionType, exceptionValue, exceptionTraceback))
+        autoKrige.printMessage(errorMessage, type = 'error')
+        exitStatus = 1
+    else:
+        autoKrige.printMessage("Done", type = 'info')
+    finally:
+        grass.try_remove(autoKrige.RscriptFile)
+        sys.exit(exitStatus)
+if __name__ == "__main__":
+    ### DEBUG : uncomment to start local debugging session
+    #brk(host="localhost", port=9000)
+    if grass.find_program('R'):
+        options, flags = grass.parser()
+        main()
+    else:
+        print "R required, please install R first"
Property changes on: grass-addons/vector/v.autokrige/v.autokrige.py
___________________________________________________________________
Added: svn:executable
Deleted: grass-addons/vector/v.autokrige/v_autokrige.py
--- grass-addons/vector/v.autokrige/v_autokrige.py	2009-07-03 16:27:43 UTC (rev 38192)
+++ grass-addons/vector/v.autokrige/v_autokrige.py	2009-07-03 16:44:22 UTC (rev 38193)
@@ -1,455 +0,0 @@
-#!/usr/bin/python
-#-*- coding: utf-8 -*-
-# MODULE:       v_autokrige.py
-# AUTHOR(S):	Mathieu Grelier (greliermathieu at gmail.com)
-# PURPOSE:	automatic kriging interpolation from vector point data
-# REQUIREMENTS:
-#   - statistical software : R (http://www.r-project.org/)
-#   - R packages :
-#       - spgrass6 (http://cran.r-project.org/web/packages/spgrass6/index.html)
-#       - automap (http://intamap.geo.uu.nl/~paul/Downloads.html) packages
-#   - optional :
-#       - imagemagick : convert program
-# COPYRIGHT:	(C) 2009 Mathieu Grelier
-#		This program is free software under the GNU General Public
-#		License (>=v2). Read the file COPYING that comes with GRASS
-#		for details.
-#%Module
-#%  description: automatic ordinary kriging interpolation from vector point data with R automap package.
-#%  keywords: kriging, automap, R
-#%End
-#%option
-#% key: input
-#% type: string
-#% gisprompt: old,vector,vector
-#% description: Name of the vector containing values to interpolate (must not contain any null values)
-#% required : yes
-#%end
-#%option
-#% key: column
-#% type: string
-#% description: Attribute column to interpolate (must be numeric)
-#% required : yes
-#%end
-#%option
-#% key: nbcell
-#% type: integer
-#% answer: 100
-#% description: number of cell of the created grid. If set, GRASS region is affected
-#% required : no
-#%end
-#%option
-#% key: models
-#% type: string
-#% options: Exp,Sph,Gau,Mat
-#% multiple : yes
-#% answer:
-#% description: List of variogram models to be automatically tested. Select only one to fix the model
-#% required : no
-#%end
-#%option
-#% key: range
-#% type: integer
-#% description: Range value. Automatically fixed if not set
-#% required : no
-#%end
-#%option
-#% key: nugget
-#% type: double
-#% description: Nugget value. Automatically fixed if not set
-#% required : no
-#%end
-#%option
-#% key: sill
-#% type: double
-#% description: Sill value. Automatically fixed if not set
-#% required : no
-#%end
-#%option
-#% key: nmax
-#% type: double
-#% description: Local kriging. Number of nearest observations that should be used for a kriging prediction (default : all observations are used)
-#% required : no
-#%end
-#%option
-#% key: maxdist
-#% type: double
-#% description: Local kriging. Maximum distance for observations from the prediction location to be included for prediction (default : no limitation)
-#% required : no
-#%end
-#%option
-#% key: output
-#% type: string
-#% answer: autokrige
-#% description: Name of the raster to produce
-#% required : yes
-#%end
-#%option
-#% key: colormap
-#% type: string
-#% answer: bcyor
-#% description: Colormap file to use to colorize the raster
-#% required : no
-#%end
-#%flag
-#% key: v
-#% description: Create variance raster also
-#%end
-#%flag
-#% key: r
-#% description: Don't set region from sites extent. Region would have been previously set in grass
-#%end
-#%flag
-#% key: l
-#% description: Log R output to v_autokrige.py.log
-#%end
-import sys
-import os
-import re
-from subprocess import Popen, call, PIPE
-import traceback
-##see http://trac.osgeo.org/grass/browser/grass/trunk/lib/python
-from grass import core as grass
-##only needed to use debugger. See http://aspn.activestate.com/ASPN/Downloads/Komodo/RemoteDebugging
-from dbgp.client import brk
-class AutoKrige():
-    def __init__(self, options, flags):
-        ##options
-        self.input = options['input']
-        self.column = options['column']
-        self.nbcell = options['nbcell'] if options['nbcell'].strip() != '' else None
-        self.models = options['models'] if options['models'].strip() != '' else None
-        self.range = options['range'] if options['range'].strip() != '' else 'NA'
-        self.nugget = options['nugget'] if options['nugget'].strip() != '' else 'NA'
-        self.sill = options['sill'] if options['sill'].strip() != '' else 'NA'
-        self.nmax = options['nmax'] if options['nmax'].strip() != '' else 'Inf'
-        self.maxdist = options['maxdist'] if options['maxdist'].strip() != '' else 'Inf'
-        self.output = options['output']
-        self.colormap = options['colormap'] if options['colormap'].strip() != '' else 'bcyor'
-        ##flags
-        self.varianceFlag = True if flags['v'] is True else False
-        self.regionFlag = True if flags['r'] is True else False
-        self.logROutput = True if flags['l'] is True else False
-        ##others
-        self.RscriptFile = None
-        logfilename = 'v_autokrige.py.log'
-        self.logfile = os.path.join(os.getenv('LOGDIR'),logfilename) if os.getenv('LOGDIR') else logfilename
-        grass.try_remove(self.logfile)
-    def __prepareRModelsString(self, models=None):
-        """!Create the R argument as expected in the R script,
-        to avoid string manipulations with R."""
-        modelsString = ''
-        if models is None:
-            ##it is important not to have any space between commas and following slashes
-            modelsString = 'c(\\"Sph\\",\\"Exp\\",\\"Gau\\",\\"Mat\\")'
-        else:
-            ##conversion to R arguments in the expected format, starting from model1,model2...
-            ##add c(" at the beginning and add ") at the end
-            RargumentsDict['models'] = 'c(\\"' + models + '\\")'
-            ##replace commas by \",\"
-            p = re.compile(',')
-            modelsString = p.sub('\\",\\"',RargumentsDict['models'])
-        return modelsString
-    def __writeRScript(self):
-        """!Create the R script for automap"""
-        RscriptFile = grass.tempfile()
-        fileHandle = open(RscriptFile, 'a')
-        script = """
-        options(echo = FALSE)
-        args <- commandArgs()
-        ##start at index 5 because first arguments are R options
-        cat("arguments:","\n")
-        sitesG <- args[5]
-        column <- args[6]
-        rastername <- args[7]
-        cellsize <- as.numeric(args[8])
-        models <- args[9]
-        modelslist <- eval(parse(text = models))
-        range <- as.numeric(args[10])
-        if(args[11] == "NA") {nugget = NA} else {nugget <- as.numeric(args[11])}
-        if(args[12] == "NA") {sill = NA} else {sill <- as.numeric(args[12])}
-        if(args[13] == "Inf") {nobsmax = Inf} else {nobsmax <- as.numeric(args[13])}
-        if(args[14] == "Inf") {maxdistance = Inf} else {maxdistance <- as.numeric(args[14])}
-        writevarrast <- as.logical(args[15])
-        ##preparing UK implementation
-        predictors <- as.character(args[16])
-        ##print arguments
-        cat("sitesG:",sitesG,"\n")
-        cat("column:",column,"\n")
-        cat("rastername:",rastername,"\n")
-        cat("cellsize:",cellsize,"\n")
-        cat("modelslist:",modelslist,"\n")
-        cat("range:",range,"\n")
-        cat("nugget:",nugget,"\n")
-        cat("sill:",sill,"\n")
-        cat("nobsmax:",nobsmax,"\n")
-        cat("maxdistance:",maxdistance,"\n")
-        cat("writevarrast:",writevarrast,"\n")
-        cat("predictors:",predictors,"\n")
-        ##variogram plot function
-        plot.autoKrigeVariogramAndFittedModel = function(x, sp.layout = NULL, ...)
-        ##Function adapted from plot.autoKrige in automap package.
-        ##Prints only the variogram and model as we already have the map output in GRASS.
-            library(lattice)
-            shift = 0.03
-            labels = as.character(x$exp_var$np)
-            vario = xyplot(gamma ~ dist, data = x$exp_var, panel = automap:::autokrige.vgm.panel,
-                        labels = labels, shift = shift, model = x$var_model,# subscripts = TRUE,
-                        direction = c(x$exp_var$dir.hor[1], x$exp_var$dir.ver[1]),
-                        ylim = c(min(0, 1.04 * min(x$exp_var$gamma)), 1.04 * max(x$exp_var$gamma)),
-                        xlim = c(0, 1.04 * max(x$exp_var$dist)), xlab = "Distance", ylab = "Semi-variance",
-                        main = "Experimental variogram and fitted variogram model", mode = "direct",...)
-            print(vario, position = c(0,0,1,1))
-        ##autokrige script
-        tryCatch({
-            ##libraries
-            library(spgrass6)
-            library(automap)
-            ##retrieve sites in a SpatialPointsDataFrame object
-            cat("retrieve sites from GRASS","\n")
-            sitesR <- readVECT6(sitesG, ignore.stderr = F)
-            cat("retrieve metadata","\n")
-            G <- gmeta6()
-            cat("GridTopology creation","\n")
-            grd <- gmeta2grd()
-            ##this is necessary to ensure that we have square cells
-            ##the more this number is small, the more the kriged map resolution is high
-            slot(grd, "cellsize") <- c(cellsize, cellsize)
-            ##creation of another grid object: SpatialGridDataFrame
-            ##this is a matrix whose values receive spatial coordinates associated to interpolated values
-            ##matrix size must be equal to the number of GridTopology cells
-            ##we create first a classical data.frame
-            data <- data.frame(list(k=rep(1,(floor(G$cols)*floor(G$rows)))))
-            cat("SpatialGridDataFrame creation","\n")
-            mask_SG <- SpatialGridDataFrame(grd, data=data, CRS(G$proj4))
-            ##add coordinates system
-            attr(sitesR, "proj4string") <-CRS(G$proj4)
-            cat("ordinary kriging","\n")
-            kriging_result = autoKrige(as.formula(paste(column,"~",predictors)), sitesR[column], mask_SG, model = modelslist, fix.values = c(nugget,range,sill), debug.level=-1, verbose=TRUE, nmax=nobsmax, maxdist=maxdistance)
-            cat("send raster to GRASS","\n")
-            writeRAST6(kriging_result$krige_output,rastername,zcol=1,NODATA=0)
-            cat("Generated",rastername," "); cat("", sep="\n")
-            if(writevarrast == T) {
-                varrastername = paste(rastername, "_var", sep = "")
-                writeRAST6(kriging_result$krige_output,varrastername,zcol=2,NODATA=0)
-                cat("Generated",varrastername," "); cat("", sep="\n")
-            ##plot experimental and model variogram
-            cat("plot kriging results","\n")
-            ##see R FAQ 7.19. Plotting to png can produce errors if R version < 2.7
-            ##we use the pdf driver then we will convert to png
-            options(device="pdf")
-            try(plot.autoKrigeVariogramAndFittedModel(kriging_result))
-            cat("R script done","\n")
-            quit(status = 0)
-        }, interrupt = function(ex) {
-            cat("An interrupt was detected while executing R script.\n")
-            cat(conditionMessage(ex), "\n")
-            quit(status = 4)
-            error = function(ex) {
-            cat("\n");
-            cat("Error while executing R script\n")
-            quit(status = 5)
-        ) ## tryCatch()
-        fileHandle.write(script)
-        fileHandle.close()
-        return RscriptFile
-    def __execRCommand(self, command, logFile = False):
-        """!R command execution method using Popen in shell mode"""
-        if logFile is not False:
-            command = command + ' >> ' +  logFile
-        ##use redirection on stdout only
-        command = command + " 2>&1"
-        p = Popen(command, shell = True, stdout = PIPE)
-        retcode = p.wait()
-        com = p.communicate()
-        if retcode == 0:
-            return retcode
-        else:
-            lines = None
-                logHandle = open(logFile,"r")
-                lines = logHandle.readlines()
-            else:
-                r = re.compile('\n')
-                lines = r.split(com[0])
-            out = lines[-2].strip() + ":" + lines[-1].strip()
-            raise AutoKrigeError(out)
-    def printMessage(self, message, type = 'info'):
-        if type == 'error':
-            grass.error(message)
-        elif type == 'warning':
-            grass.warning(message)
-        elif type == 'info' and grass.verbosity > 0:
-            grass.info(message)
-    def checkLayers(self, input, output, testVarianceRast = False):
-        !Preliminary checks before starting kriging.
-        Note : for this to work with grass6.3, in find_file function from core.py,
-        command should be (n flag removed because 6.4 specific):
-        s = read_command("g.findfile", element = element, file = name, mapset = mapset)
-        ##Test for input vector map.
-        testInput = grass.find_file(input, element = 'vector')
-        if testInput['fullname'] == '':
-            raise AutoKrigeError("vector map " + input + " not found in mapset search path.")
-        ##Test if output raster map already exists.
-        testOutput = grass.find_file(output, element = 'cell')
-        if testOutput['fullname'] != '':
-            if not grass.overwrite() is True:
-                raise AutoKrigeError("raster map " + output + " already exists in mapset search path. \n \
-Use the --o flag to overwrite.")
-            else:
-                self.printMessage("raster map " + output + " will be overwritten.", type = 'warning')
-                #print "Warning: raster map " + output + " will be overwritten."
-        ##Test also variance raster.
-        if testVarianceRast is True:
-            testVarOutput = grass.find_file(output + '_var', element = 'cell')
-            if testVarOutput['fullname'] != '':
-                else:
-                    self.printMessage("raster map " + output + '_var' + " will be overwritten.", type = 'warning')
-                    #print "Warning: raster map " + output + '_var' + " will be overwritten."
-    def getGridCellSize(self, input, nbcell, adjustRegionToSites = True):
-        """!Define kriged grid cell size.
-        Raster resolution but also computation time depends on it.
-        We take region resolution as cell size but we can fix this resolution with the nbcell parameter.
-        Only one value is needed because the R script use square cells."""
-        if adjustRegionToSites is True:
-            grass.run_command("g.region", vect = input)
-        if nbcell is not None:
-            self.fixRegionResFromNumberOfCells(nbcell)
-        regionParams = grass.region()
-        cellsize = float(regionParams['nsres']) if float(regionParams['nsres']) > float(regionParams['ewres']) \
-        else float(regionParams['ewres'])
-        return cellsize
-    def fixRegionResFromNumberOfCells(self, nbcell=100):
-        """!Adjust one of the two region dimensions so that we have a maximum of 'nbcell' cells in both."""
-        nsResForGivenNbCell = (float(regionParams['n'])- float(regionParams['s'])) / float(nbcell)
-        ewResForGivenNbCell = (float(regionParams['e'])- float(regionParams['w'])) / float(nbcell)
-        tmpRegionRes = nsResForGivenNbCell if nsResForGivenNbCell > ewResForGivenNbCell else ewResForGivenNbCell
-        grass.use_temp_region
-        grass.run_command("g.region", res = tmpRegionRes)
-    def finalizeOutput(self):
-        """!Final operations after successful kriging.
-        We don't want to stop execution if an error occurs here.
-        try:
-            ##convert plot to png
-            call('convert -alpha off Rplots.pdf autokrige_result.png', shell = True)
-            grass.try_remove('Rplots.pdf')
-            ##apply colormap
-            grass.run_command("r.colors", map = self.output, rules = self.colormap, quiet = True)
-            if self.varianceFlag is True:
-                grass.run_command("r.colors", map = self.output + '_var', rules = self.colormap, quiet = True)
-        except:
-            pass
-    def runAutoKrige(self):
-        """!Performs kriging process"""
-        ##1)Necessary checks
-        self.checkLayers(self.input, self.output, self.varianceFlag)
-        ##2)Adjust interpolation resolution
-        cellsize = self.getGridCellSize(self.input, self.nbcell, self.regionFlag)
-        ##3)Execute R from GRASS
-        self.RscriptFile = self.__writeRScript()
-        ##spgrass6 cause : column name in R has only the 10 first characters of the original column name
-        ##may change with future versions of spgrass6
-        Rcolumnname = self.column[0:10]
-        writeVarRast = 'T' if self.varianceFlag is True else 'F'
-        self.printMessage("RGrass is working...", type = 'info')
-        #print "RGrass is working..."
-        ##ordinary kriging for now
-        predictors = '1'
-        autoKrigeCommand = 'R --vanilla --slave --args ' + self.input + ' ' + Rcolumnname + ' ' + \
-                        self.output + ' ' + str(cellsize) + ' "' + self.__prepareRModelsString() + '" ' + \
-                        self.range + ' ' +  self.nugget + ' ' + self.sill \
-                        + ' ' + self.nmax + ' ' + self.maxdist + ' ' \
-                        + writeVarRast + ' ' + predictors + ' < "' + self.RscriptFile + '"'
-        logFileArg = self.logfile if self.logROutput is True else False
-        self.__execRCommand(autoKrigeCommand, logFile=logFileArg)
-        ##4)Final steps
-        self.finalizeOutput()
-class AutoKrigeError(Exception):
-    """Errors specific to Autokrige class"""
-    def __init__(self, message=''):
-        self.details = '\nDetails:\n'
-        exceptionType, exceptionValue, exceptionTraceback = sys.exc_info()
-        self.details += repr(traceback.format_exception(exceptionType, exceptionValue, exceptionTraceback))
-        self.message = message + "\n" + self.details
-def main():
-    exitStatus = 0
-    try:
-        autoKrige = AutoKrige(options, flags)
-        autoKrige.runAutoKrige()
-    except AutoKrigeError, e1:
-        autoKrige.printMessage(e1.message, type = 'error')
-        exitStatus = 1
-    except:
-        errorMessage = "Unexpected error \n:" + \
-                       repr(traceback.format_exception(exceptionType, exceptionValue, exceptionTraceback))
-        autoKrige.printMessage(errorMessage, type = 'error')
-        exitStatus = 1
-    else:
-        autoKrige.printMessage("Done", type = 'info')
-    finally:
-        grass.try_remove(autoKrige.RscriptFile)
-        sys.exit(exitStatus)
-if __name__ == "__main__":
-    ### DEBUG : uncomment to start local debugging session
-    #brk(host="localhost", port=9000)
-    if grass.find_program('R'):
-        options, flags = grass.parser()
-        main()
-    else:
-        print "R required, please install R first"
