[GRASS-SVN] r38206 -
grass/branches/develbranch_6/gui/wxpython/gui_modules
svn_grass at osgeo.org
Sat Jul 4 11:31:17 EDT 2009
Author: martinl
Date: 2009-07-04 11:31:17 -0400 (Sat, 04 Jul 2009)
New Revision: 38206
grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp.py
grass/branches/develbranch_6/gui/wxpython/gui_modules/utils.py
wxGUI: fix statusbar proj info (on failure)
(merge from trunk, r38202)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp.py 2009-07-04 15:26:10 UTC (rev 38205)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp.py 2009-07-04 15:31:17 UTC (rev 38206)
@@ -556,6 +556,7 @@
key='projection',
subkey='proj4'),
flags = 'd')
if coord:
e, n = coord
if proj in ('ll', 'latlong', 'longlat'):
@@ -563,7 +564,7 @@
else:
self.statusbar.SetStatusText("%.2f; %.2f" % (e, n), 0)
else:
- self.statusbar.SetStatusText(_("Error in projection"), 0)
+ self.statusbar.SetStatusText(_("Error in projection (check the settings)"), 0)
else:
if self.Map.projinfo['proj'] == 'll':
self.statusbar.SetStatusText("%s" % utils.Deg2DMS(e, n), 0)
@@ -914,7 +915,7 @@
self.statusbar.SetStatusText("%.2f - %.2f, %.2f - %.2f (%.2f, %.2f)" %
(w, e, s, n, ewres, nsres), 0)
else:
else:
w, s = utils.Deg2DMS(region["w"], region["s"],
@@ -1029,7 +1030,7 @@
self.statusbarWin['goto'].SetValue("%.2f; %.2f" % (coord[0],
coord[1]))
else:
else:
self.statusbarWin['goto'].SetValue("%s" % utils.Deg2DMS(region['center_easting'],
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/utils.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/utils.py 2009-07-04 15:26:10 UTC (rev 38205)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/utils.py 2009-07-04 15:31:17 UTC (rev 38206)
@@ -508,6 +508,9 @@
if proj in ('ll', 'latlong', 'longlat') and 'd' not in flags:
return (proj, (e, n))
else:
- return (proj, (float(e), float(n)))
+ try:
+ return (proj, (float(e), float(n)))
+ except ValueError:
+ return (None, None)
return (None, None)
