[GRASS-SVN] r38251 - grass/branches/develbranch_6/vector/v.select
Sun Jul 5 09:13:51 EDT 2009
Author: martinl
Date: 2009-07-05 09:13:50 -0400 (Sun, 05 Jul 2009)
New Revision: 38251
   grass/branches/develbranch_6/vector/v.select/main.c
v.select: for disjoint use reverse intersect (todo: change module's algorithm)
	  (merge from trunk, r38250)
Modified: grass/branches/develbranch_6/vector/v.select/main.c
--- grass/branches/develbranch_6/vector/v.select/main.c	2009-07-05 13:09:26 UTC (rev 38250)
+++ grass/branches/develbranch_6/vector/v.select/main.c	2009-07-05 13:13:50 UTC (rev 38251)
@@ -60,8 +60,11 @@
     if (parm.operator->answer[0] == 'e')
 	operator = OP_EQUALS;
-    else if (parm.operator->answer[0] == 'd')
-	operator = OP_DISJOINT;
+    else if (parm.operator->answer[0] == 'd') {
+	/* operator = OP_DISJOINT; */
+	operator = OP_INTERSECTS;
+	flag.reverse->answer = YES;
     else if (parm.operator->answer[0] == 'i')
     else if (parm.operator->answer[0] == 't')
