[GRASS-SVN] r38293 - in grass-addons/vector/net.analyze: . netalib v.net.allpairs v.net.centrality v.net.connectivity v.net.distance v.net.flow
Tue Jul 7 09:21:27 EDT 2009
Author: dano
Date: 2009-07-07 09:21:27 -0400 (Tue, 07 Jul 2009)
New Revision: 38293
Added:
   grass-addons/vector/net.analyze/netalib/centrality.c
   grass-addons/vector/net.analyze/netalib/path.c
   grass-addons/vector/net.analyze/v.net.centrality/
   grass-addons/vector/net.analyze/v.net.centrality/Makefile
   grass-addons/vector/net.analyze/v.net.centrality/main.c
   grass-addons/vector/net.analyze/v.net.connectivity/
   grass-addons/vector/net.analyze/v.net.connectivity/Makefile
   grass-addons/vector/net.analyze/v.net.connectivity/main.c
   grass-addons/vector/net.analyze/v.net.distance/
   grass-addons/vector/net.analyze/v.net.distance/Makefile
   grass-addons/vector/net.analyze/v.net.distance/main.c
   grass-addons/vector/net.analyze/Makefile
   grass-addons/vector/net.analyze/netalib/flow.c
   grass-addons/vector/net.analyze/netalib/neta.h
   grass-addons/vector/net.analyze/netalib/utils.c
   grass-addons/vector/net.analyze/v.net.allpairs/main.c
   grass-addons/vector/net.analyze/v.net.flow/main.c
New modules v.net.distance/connectivity/centrality and several bug fixes/updates of other modules as well
Modified: grass-addons/vector/net.analyze/Makefile
--- grass-addons/vector/net.analyze/Makefile	2009-07-07 11:38:23 UTC (rev 38292)
+++ grass-addons/vector/net.analyze/Makefile	2009-07-07 13:21:27 UTC (rev 38293)
@@ -5,7 +5,10 @@
         v.net.bridge \
         v.net.spanningtree \
         v.net.allpairs \
-        v.net.flow
+        v.net.flow \
+        v.net.connectivity \
+        v.net.centrality \
+        v.net.distance
 SUBDIRS = netalib $(SUBDIRS1)
Added: grass-addons/vector/net.analyze/netalib/centrality.c
--- grass-addons/vector/net.analyze/netalib/centrality.c	                        (rev 0)
+++ grass-addons/vector/net.analyze/netalib/centrality.c	2009-07-07 13:21:27 UTC (rev 38293)
@@ -0,0 +1,212 @@
+ * MODULE:     netalib
+ * AUTHOR(S):  Daniel Bundala
+ * PURPOSE:    Centrality measures
+ * COPYRIGHT:  (C) 2002-2005 by the GRASS Development Team
+ *             This program is free software under the
+ *             GNU General Public License (>=v2).
+ *             Read the file COPYING that comes with GRASS
+ *             for details.
+#include <stdio.h>
+#include <stdlib.h>
+#include <grass/gis.h>
+#include <grass/Vect.h>
+#include <grass/glocale.h>
+#include <grass/dgl/graph.h>
+#include <grass/neta.h>
+/* Computes degree centrality measure. Array degree has to be properly initialised to nnodes+1 elements */
+void neta_degree_centrality(dglGraph_s * graph, double *degree)
+    int i;
+    double nnodes = dglGet_NodeCount(graph);
+    for (i = 1; i <= nnodes; i++)
+	degree[i] =
+	    dglNodeGet_OutDegree(graph,
+				 dglGetNode(graph, (dglInt32_t) i)) / nnodes;
+/* Computes eigenvector centrality using edge costs as weights. Returns 0 on success. */
+int neta_eigenvector_centrality(dglGraph_s * graph, int iterations,
+				double error, double *eigenvector)
+    int i, iter, nnodes;
+    double *tmp;
+    nnodes = dglGet_NodeCount(graph);
+    tmp = (double *)G_calloc(nnodes + 1, sizeof(double));
+    if (!tmp) {
+	G_fatal_error(_("Out of memory"));
+	return -1;
+    error *= error;
+	eigenvector[i] = 1;
+    for (iter = 0; iter < iterations; iter++) {
+	    tmp[i] = 0;
+	dglInt32_t *node;
+	dglNodeTraverser_s nt;
+	dglEdgesetTraverser_s et;
+	dglNode_T_Initialize(&nt, graph);
+	for (node = dglNode_T_First(&nt); node; node = dglNode_T_Next(&nt)) {
+	    dglInt32_t node_id = dglNodeGet_Id(graph, node);
+	    double cur_value = eigenvector[node_id];
+	    dglInt32_t *edge;
+	    dglEdgeset_T_Initialize(&et, graph,
+				    dglNodeGet_OutEdgeset(graph, node));
+	    for (edge = dglEdgeset_T_First(&et); edge;
+		 edge = dglEdgeset_T_Next(&et))
+		tmp[dglNodeGet_Id(graph, dglEdgeGet_Tail(graph, edge))] +=
+		    cur_value * dglEdgeGet_Cost(graph, edge);
+	    dglEdgeset_T_Release(&et);
+	dglNode_T_Release(&nt);
+	double cum_error = 0, max_value = tmp[1];
+	for (i = 2; i <= nnodes; i++)
+	    if (tmp[i] > max_value)
+		max_value = tmp[i];
+	for (i = 1; i <= nnodes; i++) {
+	    tmp[i] /= max_value;
+	    cum_error += (tmp[i] - eigenvector[i]) * (tmp[i] - eigenvector[i]);
+	    eigenvector[i] = tmp[i];
+	if (cum_error < error)
+	    break;
+    G_free(tmp);
+    return 0;
+/*computes betweenness and closeness centrality measure using Brandes algorithm.
+ * Edge costs must be nonnegative. If some edge costs are negative then the behaviour of this method is undefined.
+ * Returns 0 on success */
+int neta_betweenness_closeness(dglGraph_s * graph, double *betweenness,
+			       double *closeness)
+    int i, j, nnodes, stack_size;
+    dglInt32_t *dst, *node, *stack, *cnt, *delta;
+    dglHeap_s heap;
+    struct ilist **prev;
+    dst = (dglInt32_t *) G_calloc(nnodes + 1, sizeof(dglInt32_t));
+    prev = (struct ilist **)G_calloc(nnodes + 1, sizeof(struct ilist *));
+    stack = (dglInt32_t *) G_calloc(nnodes, sizeof(dglInt32_t));
+    cnt = (dglInt32_t *) G_calloc(nnodes + 1, sizeof(dglInt32_t));
+    delta = (dglInt32_t *) G_calloc(nnodes + 1, sizeof(dglInt32_t));
+    if (!dst || !prev || !stack || !cnt || !delta) {
+	return -1;
+	prev[i] = Vect_new_list();
+	if (closeness)
+	    closeness[i] = 0;
+	if (betweenness)
+	    betweenness[i] = 0;
+	dglInt32_t s = dglNodeGet_Id(graph, node);
+	dglHeapData_u heap_data;
+	dglHeapNode_s heap_node;
+	stack_size = 0;
+	    Vect_reset_list(prev[i]);
+	    cnt[i] = 0;
+	    dst[i] = -1;
+	dst[s] = 0;
+	cnt[s] = 1;
+	dglHeapInit(&heap);
+	heap_data.ul = s;
+	dglHeapInsertMin(&heap, 0, ' ', heap_data);
+	while (1) {
+	    dglInt32_t v, dist;
+	    if (!dglHeapExtractMin(&heap, &heap_node))
+		break;
+	    v = heap_node.value.ul;
+	    dist = heap_node.key;
+	    if (dst[v] < dist)
+		continue;
+	    stack[stack_size++] = v;
+	    dglInt32_t *edge;
+							  dglGetNode(graph,
+								     v)));
+		 edge = dglEdgeset_T_Next(&et)) {
+		dglInt32_t *to = dglEdgeGet_Tail(graph, edge);
+		dglInt32_t to_id = dglNodeGet_Id(graph, to);
+		dglInt32_t d = dglEdgeGet_Cost(graph, edge);
+		if (dst[to_id] == -1 || dst[to_id] > dist + d) {
+		    dst[to_id] = dist + d;
+		    Vect_reset_list(prev[to_id]);
+		    heap_data.ul = to_id;
+		    dglHeapInsertMin(&heap, dist + d, ' ', heap_data);
+		if (dst[to_id] == dist + d) {
+		    cnt[to_id] += cnt[v];
+		    Vect_list_append(prev[to_id], v);
+	dglHeapFree(&heap, NULL);
+	    delta[i] = 0;
+	for (i = stack_size - 1; i >= 0; i--) {
+	    dglInt32_t w = stack[i];
+	    if (closeness)
+		closeness[s] += dst[w];
+	    for (j = 0; j < prev[w]->n_values; j++) {
+		dglInt32_t v = prev[w]->value[j];
+		delta[v] += (cnt[v] / (double)cnt[w]) * (1.0 + delta[w]);
+	    if (w != s && betweenness)
+		betweenness[w] += delta[w];
+	if (closeness)
+	    closeness[s] /= (double)stack_size;
+	Vect_destroy_list(prev[i]);
+    G_free(delta);
+    G_free(cnt);
+    G_free(stack);
+    G_free(prev);
+    G_free(dst);
+    return 0;
Property changes on: grass-addons/vector/net.analyze/netalib/centrality.c
___________________________________________________________________
Added: svn:executable
Modified: grass-addons/vector/net.analyze/netalib/flow.c
--- grass-addons/vector/net.analyze/netalib/flow.c	2009-07-07 11:38:23 UTC (rev 38292)
+++ grass-addons/vector/net.analyze/netalib/flow.c	2009-07-07 13:21:27 UTC (rev 38293)
@@ -23,6 +23,7 @@
 dglInt32_t sign(dglInt32_t x)
@@ -36,35 +37,46 @@
  * each edge. Negative flow corresponds to a flow in opposite direction
  * The function assumes that the edge costs correspond to edge capacities.
-int neta_flow(dglGraph_s * graph, int source, int sink, int *flow)
+int neta_flow(dglGraph_s * graph, struct ilist *source_list,
+	      struct ilist *sink_list, int *flow)
     int nnodes, nlines, i;
     dglInt32_t *queue;
     dglInt32_t **prev;
+    char *is_source, *is_sink;
     int begin, end, total_flow;
     nlines = dglGet_EdgeCount(graph) / 2;	/*each line corresponds to two edges. One in each direction */
     queue = (dglInt32_t *) G_calloc(nnodes + 3, sizeof(dglInt32_t));
     prev = (dglInt32_t **) G_calloc(nnodes + 3, sizeof(dglInt32_t *));
-    if (!queue || !prev) {
+    is_source = (char *)G_calloc(nnodes + 3, sizeof(char));
+    is_sink = (char *)G_calloc(nnodes + 3, sizeof(char));
+    if (!queue || !prev || !is_source || !is_sink) {
 	return -1;
+    for (i = 0; i < source_list->n_values; i++)
+	is_source[source_list->value[i]] = 1;
+    for (i = 0; i < sink_list->n_values; i++)
+	is_sink[sink_list->value[i]] = 1;
     for (i = 0; i <= nlines; i++)
 	flow[i] = 0;
     total_flow = 0;
     while (1) {
 	dglInt32_t node, edge_id, min_residue;
-	int found = 0;
-	begin = 0;
-	end = 1;
-	queue[0] = source;
+	int found = -1;
+	begin = end = 0;
+	    queue[end++] = source_list->value[i];
 	    prev[i] = NULL;
-	while (begin != end && !found) {
+	while (begin != end && found == -1) {
 	    dglInt32_t vertex = queue[begin++];
 	    dglInt32_t *edge, *node = dglGetNode(graph, vertex);
@@ -75,11 +87,11 @@
 		dglInt32_t id = dglEdgeGet_Id(graph, edge);
 		dglInt32_t to =
 		    dglNodeGet_Id(graph, dglEdgeGet_Tail(graph, edge));
-		if (to != source && prev[to] == NULL &&
+		if (!is_source[to] && prev[to] == NULL &&
 		    cap > sign(id) * flow[abs(id)]) {
 		    prev[to] = edge;
-		    if (to == sink) {
-			found = 1;
+		    if (is_sink[to]) {
+			found = to;
 			break;
 		    queue[end++] = to;
@@ -87,15 +99,15 @@
-	if (!found)
+	if (found == -1)
 	    break;		/*no augmenting path */
 	/*find minimum residual capacity along the augmenting path */
-	node = sink;
+	node = found;
 	edge_id = dglEdgeGet_Id(graph, prev[node]);
 	min_residue =
 			    prev[node]) - sign(edge_id) * flow[abs(edge_id)];
-	while (node != source) {
+	while (!is_source[node]) {
 	    dglInt32_t residue;
 	    residue =
@@ -108,8 +120,8 @@
 	total_flow += min_residue;
 	/*update flow along the augmenting path */
-	node = sink;
+	node = found;
 	    flow[abs(edge_id)] += sign(edge_id) * min_residue;
 	    node = dglNodeGet_Id(graph, dglEdgeGet_Head(graph, prev[node]));
@@ -118,6 +130,141 @@
     G_free(queue);
     G_free(prev);
+    G_free(is_source);
+    G_free(is_sink);
     return total_flow;
+ * This methods calculates minimum cut between source(s) and sink(s) and returns the list of edges (cut).
+ * Flow is the array produced by neta_flow method when called with source_list and sink_list as the input.
+ * The output of this and neta_flow method should be the same.
+int neta_min_cut(dglGraph_s * graph, struct ilist *source_list,
+		 struct ilist *sink_list, int *flow, struct ilist *cut)
+    int nnodes, i;
+    dglInt32_t *queue;
+    char *visited;
+    int begin, end, total_flow;
+    queue = (dglInt32_t *) G_calloc(nnodes + 3, sizeof(dglInt32_t));
+    visited = (char *)G_calloc(nnodes + 3, sizeof(char));
+    if (!queue || !visited) {
+	return -1;
+    total_flow = begin = end = 0;
+	visited[i] = 0;
+    for (i = 0; i < source_list->n_values; i++) {
+	visited[source_list->value[i]] = 1;
+    /* find vertices reachable from source(s) using only non-saturated edges */
+    while (begin != end) {
+	dglInt32_t vertex = queue[begin++];
+	dglInt32_t *edge, *node = dglGetNode(graph, vertex);
+	dglEdgeset_T_Initialize(&et, graph, dglNodeGet_OutEdgeset(graph, node));
+	    dglInt32_t cap = dglEdgeGet_Cost(graph, edge);
+	    dglInt32_t id = dglEdgeGet_Id(graph, edge);
+	    dglInt32_t to = dglNodeGet_Id(graph, dglEdgeGet_Tail(graph, edge));
+	    if (!visited[to] && cap > sign(id) * flow[abs(id)]) {
+		visited[to] = 1;
+		queue[end++] = to;
+    /*saturated edges from reachable vertices to non-reachable ones form a minimum cost */
+    Vect_reset_list(cut);
+	if (!visited[i])
+	    continue;
+	dglInt32_t *node, *edgeset, *edge;
+	node = dglGetNode(graph, i);
+	edgeset = dglNodeGet_OutEdgeset(graph, node);
+	dglEdgeset_T_Initialize(&et, graph, edgeset);
+	    dglInt32_t to, edge_id;
+	    to = dglNodeGet_Id(graph, dglEdgeGet_Tail(graph, edge));
+	    edge_id = abs(dglEdgeGet_Id(graph, edge));
+	    if (!visited[to] && flow[edge_id] != 0) {
+		Vect_list_append(cut, edge_id);
+		total_flow += abs(flow[abs(edge_id)]);
+    G_free(visited);
+    G_free(queue);
+    return total_flow;
+/* The method splits each vertex of in graph into two vertices: in vertex and out vertex. Also, it adds an edge
+ * from an in vertex to the corresponding out vertex (capacity=2) and it adds an edge from out vertex to
+ * in vertex for each edge present in the in graph (forward capacity=1, backward capacity=0). If the
+ * id of a vertex is v then id of in vertex is 2*v-1 and of out vertex 2*v.
+ * Method returns the number of undirected edges in the graph.
+int neta_split_vertices(dglGraph_s * in, dglGraph_s * out, int *node_costs)
+    dglInt32_t opaqueset[16] =
+	{ 360000, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0 };
+    dglInt32_t nnodes, edge_cnt;
+    dglInt32_t *cur_node;
+    nnodes = dglGet_NodeCount(in);
+    dglInitialize(out, (dglByte_t) 1, (dglInt32_t) 0, (dglInt32_t) 0,
+		  opaqueset);
+    dglNode_T_Initialize(&nt, in);
+    edge_cnt = 0;
+    dglInt32_t max_node_cost = 0;
+    for (cur_node = dglNode_T_First(&nt); cur_node;
+	 cur_node = dglNode_T_Next(&nt)) {
+	dglInt32_t v = dglNodeGet_Id(in, cur_node);
+	edge_cnt++;
+	dglInt32_t cost = 1;
+	if (node_costs)
+	    cost = node_costs[v];
+	if (cost > max_node_cost)
+	    max_node_cost = cost;
+	dglAddEdge(out, 2 * v - 1, 2 * v, cost, edge_cnt);
+	dglAddEdge(out, 2 * v, 2 * v - 1, (dglInt32_t) 0, -edge_cnt);
+	dglInt32_t *edge;
+	dglEdgeset_T_Initialize(&et, in, dglNodeGet_OutEdgeset(in, cur_node));
+	    dglInt32_t to;
+	    to = dglNodeGet_Id(in, dglEdgeGet_Tail(in, edge));
+	    edge_cnt++;
+	    dglAddEdge(out, 2 * v, 2 * to - 1, max_node_cost + 1, edge_cnt);
+	    dglAddEdge(out, 2 * to - 1, 2 * v, (dglInt32_t) 0, -edge_cnt);
+    if (dglFlatten(out) < 0)
+	G_fatal_error(_("GngFlatten error"));
+    return edge_cnt;
Modified: grass-addons/vector/net.analyze/netalib/neta.h
--- grass-addons/vector/net.analyze/netalib/neta.h	2009-07-07 11:38:23 UTC (rev 38292)
+++ grass-addons/vector/net.analyze/netalib/neta.h	2009-07-07 13:21:27 UTC (rev 38293)
@@ -23,6 +23,7 @@
 #include <stdlib.h>
+#include <grass/dbmi.h>
@@ -44,5 +45,21 @@
 void neta_add_point_on_node(struct Map_info *In, struct Map_info *Out, int node, struct line_cats *Cats);
 /*neta_flow.c*/
-int neta_flow(dglGraph_s *graph, int source, int sink, int *flow);
+int neta_flow(dglGraph_s * graph, struct ilist *source_list, struct ilist *sink_list, int *flow);
+int neta_min_cut(dglGraph_s *graph, struct ilist *source_list, struct ilist *sink_list, int *flow, struct ilist *cut);
+int neta_split_vertices(dglGraph_s *in, dglGraph_s *out, int *node_costs);
+/*utils.c*/
+void neta_add_point_on_node(struct Map_info *In, struct Map_info *Out, int node,
+			    struct line_cats *Cats);
+void neta_points_to_nodes(struct Map_info *In, struct ilist *point_list);
+int neta_get_node_costs(struct Map_info *In, int layer, char *column, int *node_costs);
+void neta_varray_to_nodes(struct Map_info *map, VARRAY *varray, struct ilist *nodes, int *nodes_to_features);
+/*centrality.c*/
+void neta_degree_centrality(dglGraph_s * graph, double *degree);
+int neta_eigenvector_centrality(dglGraph_s *graph, int iterations, double error, double *eigenvector);
+int neta_betweenness_closeness(dglGraph_s * graph, double *betweenness, double *closeness);
+/*path.c*/
+int neta_distance_from_points(dglGraph_s *graph, struct ilist *from, int *dst, dglInt32_t **prev);
 #endif
Added: grass-addons/vector/net.analyze/netalib/path.c
--- grass-addons/vector/net.analyze/netalib/path.c	                        (rev 0)
+++ grass-addons/vector/net.analyze/netalib/path.c	2009-07-07 13:21:27 UTC (rev 38293)
@@ -0,0 +1,87 @@
+ * MODULE:     netalib
+ * PURPOSE:    Shortest paths from a set of nodes
+ *             for details.
+#include <stdio.h>
+/* Computes shortests paths to every node from  nodes in "from". Array "dst" contains the length of the path
+ * or -1 if the node is not reachable.  Prev contains edges from predecessor along the shortest path */
+int neta_distance_from_points(dglGraph_s * graph, struct ilist *from, int *dst,
+			      dglInt32_t ** prev)
+    int i, nnodes;
+    dglHeap_s heap;
+	dst[i] = -1;
+	prev[i] = NULL;
+    for (i = 0; i < from->n_values; i++) {
+	int v = from->value[i];
+	if (dst[v] == 0)
+	    continue;		/*ingore duplicates */
+	dst[v] = 0;
+	heap_data.ul = v;
+    while (1) {
+	    break;
+	    continue;
+	dglInt32_t *edge;
+						      dglGetNode(graph, v)));
+		prev[to_id] = edge;
+    return 0;
Property changes on: grass-addons/vector/net.analyze/netalib/path.c
Modified: grass-addons/vector/net.analyze/netalib/utils.c
--- grass-addons/vector/net.analyze/netalib/utils.c	2009-07-07 11:38:23 UTC (rev 38292)
+++ grass-addons/vector/net.analyze/netalib/utils.c	2009-07-07 13:21:27 UTC (rev 38293)
@@ -25,6 +25,7 @@
+/* Writes GV_POINT to Out at the position of the node in In */
@@ -37,3 +38,114 @@
     Vect_write_line(Out, GV_POINT, Points, Cats);
     Vect_destroy_line_struct(Points);
+/* Returns the list of all points with the given category and field */
+/*void neta_get_points_by_category(struct Map_info *In, int field, int cat, struct ilist *point_list)
+ * int i, nlines;
+ * struct line_cats *Cats;
+ * Cats = Vect_new_cats_struct();
+ * Vect_get_num_lines(In);
+ * for(i=1;i<=nlines;i++){
+ * int type = Vect_read_line(In, NULL, Cats, i);
+ * if(type!=GV_POINT)continue;
+ * Vect_destroy_cats_struct(Cats);
+/* Finds the node corresponding to each point in the point_list */
+    int i, node;
+    for (i = 0; i < point_list->n_values; i++) {
+	Vect_get_line_nodes(In, point_list->value[i], &node, NULL);
+	point_list->value[i] = node;
+/* For each node in the map, finds the category of the point on it (if there is any) and stores the value
+ * associated with this category in the array node_costs. If there is no point with a category, node_costs=0.
+ * node_costs are multiplied by 1000000 and truncated to integers (as is done in Vect_net_build_graph)
+ * Returns 1 on success, 0 on failure.
+			int *node_costs)
+    int i, nlines, nnodes;
+    dbCatValArray vals;
+    struct line_cats *Cats;
+    struct line_pnts *Points;
+    dbDriver *driver;
+    struct field_info *Fi;
+    Fi = Vect_get_field(In, layer);
+    driver = db_start_driver_open_database(Fi->driver, Fi->database);
+    if (driver == NULL)
+	G_fatal_error(_("Unable to open database <%s> by driver <%s>"),
+		      Fi->database, Fi->driver);
+    nlines = Vect_get_num_lines(In);
+    nnodes = Vect_get_num_nodes(In);
+    Cats = Vect_new_cats_struct();
+    Points = Vect_new_line_struct();
+	node_costs[i] = 0;
+    db_CatValArray_init(&vals);
+    if (db_select_CatValArray(driver, Fi->table, Fi->key, column, NULL, &vals)
+	== -1)
+	return 0;
+    for (i = 1; i <= nlines; i++) {
+	int type = Vect_read_line(In, Points, Cats, i);
+	if (type == GV_POINT) {
+	    int node, cat;
+	    double value;
+	    if (!Vect_cat_get(Cats, layer, &cat))
+		continue;
+	    Vect_get_line_nodes(In, i, &node, NULL);
+	    if (db_CatValArray_get_value_double(&vals, cat, &value) == DB_OK)
+		node_costs[node] = value * 1000000.0;
+    Vect_destroy_cats_struct(Cats);
+    db_CatValArray_free(&vals);
+    db_close_database_shutdown_driver(driver);
+    return 1;
+/*returns the list of all nodes on features selected by varray.
+ * nodes_to_features conains the index of a feature adjecent to each node or -1 if no such feature
+ * specified by varray exists */
+void neta_varray_to_nodes(struct Map_info *map, VARRAY * varray,
+			  struct ilist *nodes, int *nodes_to_features)
+    int nlines, nnodes, i;
+    nlines = Vect_get_num_lines(map);
+    nnodes = Vect_get_num_nodes(map);
+	nodes_to_features[i] = -1;
+	if (varray->c[i]) {
+	    int type = Vect_read_line(map, NULL, NULL, i);
+		int node;
+		Vect_get_line_nodes(map, i, &node, NULL);
+		Vect_list_append(nodes, node);
+		nodes_to_features[node] = i;
+	    else {
+		int node1, node2;
+		Vect_get_line_nodes(map, i, &node1, &node2);
+		Vect_list_append(nodes, node1);
+		Vect_list_append(nodes, node2);
+		nodes_to_features[node1] = nodes_to_features[node2] = i;
Modified: grass-addons/vector/net.analyze/v.net.allpairs/main.c
--- grass-addons/vector/net.analyze/v.net.allpairs/main.c	2009-07-07 11:38:23 UTC (rev 38292)
+++ grass-addons/vector/net.analyze/v.net.allpairs/main.c	2009-07-07 13:21:27 UTC (rev 38293)
@@ -234,7 +234,8 @@
 	    for (j = 1; j <= nnodes; j++)
 		if (cats[j] != -1) {
 		    sprintf(buf, "insert into %s values (%d, %d, %f)",
-			    Fi->table, i, j, dist[i][j] / 1000.0);
+			    Fi->table, i, j,
+			    dist[i][j] / (double)In.cost_multip);
 		    db_set_string(&sql, buf);
 		    G_debug(3, db_get_string(&sql));
Added: grass-addons/vector/net.analyze/v.net.centrality/Makefile
--- grass-addons/vector/net.analyze/v.net.centrality/Makefile	                        (rev 0)
+++ grass-addons/vector/net.analyze/v.net.centrality/Makefile	2009-07-07 13:21:27 UTC (rev 38293)
@@ -0,0 +1,15 @@
+MODULE_TOPDIR = ../../..
+PGM=v.net.centrality
+include ../Netalib.make
+LIBES     = $(NETALIB) $(VECTLIB) $(VECTLIB_REAL) $(DBMILIB) $(GISLIB)
+DEPENDENCIES = $(NETADEP) $(VECTDEP) $(DBMIDEP) $(GISDEP)
+EXTRA_INC = $(VECT_INC)
+EXTRA_CFLAGS = $(VECT_CFLAGS)
+include $(MODULE_TOPDIR)/include/Make/Module.make
+default: cmd
Property changes on: grass-addons/vector/net.analyze/v.net.centrality/Makefile
Added: grass-addons/vector/net.analyze/v.net.centrality/main.c
--- grass-addons/vector/net.analyze/v.net.centrality/main.c	                        (rev 0)
+++ grass-addons/vector/net.analyze/v.net.centrality/main.c	2009-07-07 13:21:27 UTC (rev 38293)
@@ -0,0 +1,297 @@
+ * MODULE:     v.net.centrality
+ * PURPOSE:    This module computes various cetrality measures
+ *             for details.
+#include <stdio.h>
+void update_record(dbDriver * driver, dbString * sql, char *table, char *key,
+		   char *column, double value, int cat)
+    char buf[2000];
+    sprintf(buf, "update %s set %s=%f where %s=%d", table, column, value, key,
+	    cat);
+    db_set_string(sql, buf);
+    G_debug(3, db_get_string(sql));
+    if (db_execute_immediate(driver, sql) != DB_OK) {
+	G_fatal_error(_("Cannot insert new record: %s"), db_get_string(sql));
+int main(int argc, char *argv[])
+    struct Map_info In;
+    char *mapset;
+    struct GModule *module;	/* GRASS module for parsing arguments */
+    struct Option *map_in;
+    struct Option *cat_opt, *field_opt, *where_opt, *abcol, *afcol;
+    struct Option *deg_opt, *close_opt, *betw_opt, *eigen_opt;
+    struct Option *iter_opt, *error_opt;
+    struct Flag *geo_f;
+    int chcat, with_z;
+    int layer, mask_type;
+    VARRAY *varray;
+    dglGraph_s *graph;
+    int i, geo, nnodes, nlines;
+    double *deg, *close, *betw, *eigen;
+    /* Attribute table */
+    dbString sql;
+    dbDriver *driver;
+    /* initialize GIS environment */
+    G_gisinit(argv[0]);		/* reads grass env, stores program name to G_program_name() */
+    /* initialize module */
+    module = G_define_module();
+    module->keywords =
+	_
+	("network, centrality measures, degree, betweeness, closeness, eigenvector");
+    module->description =
+	_
+	("Computes degree, centrality, betweeness, closeness and eigenvector cetrality measures");
+    /* Define the different options as defined in gis.h */
+    map_in = G_define_standard_option(G_OPT_V_INPUT);
+    field_opt = G_define_standard_option(G_OPT_V_FIELD);
+    cat_opt = G_define_standard_option(G_OPT_V_CATS);
+    where_opt = G_define_standard_option(G_OPT_WHERE);
+    afcol = G_define_option();
+    afcol->key = "afcolumn";
+    afcol->type = TYPE_STRING;
+    afcol->required = NO;
+    afcol->description = _("Arc forward/both direction(s) cost column");
+    abcol = G_define_option();
+    abcol->key = "abcolumn";
+    abcol->type = TYPE_STRING;
+    abcol->required = NO;
+    abcol->description = _("Arc backward direction cost column");
+    deg_opt = G_define_option();
+    deg_opt->key = "degree";
+    deg_opt->type = TYPE_STRING;
+    deg_opt->required = NO;
+    deg_opt->description = _("Degree centrality column");
+    close_opt = G_define_option();
+    close_opt->key = "closeness";
+    close_opt->type = TYPE_STRING;
+    close_opt->required = NO;
+    close_opt->description = _("Closeness centrality column");
+    betw_opt = G_define_option();
+    betw_opt->key = "betweenness";
+    betw_opt->type = TYPE_STRING;
+    betw_opt->required = NO;
+    betw_opt->description = _("Betweenness centrality column");
+    eigen_opt = G_define_option();
+    eigen_opt->key = "eigenvector";
+    eigen_opt->type = TYPE_STRING;
+    eigen_opt->required = NO;
+    eigen_opt->description = _("Eigenvector centrality column");
+    iter_opt = G_define_option();
+    iter_opt->key = "iterations";
+    iter_opt->answer = "1000";
+    iter_opt->type = TYPE_INTEGER;
+    iter_opt->required = NO;
+    iter_opt->description =
+	_("Maximum number of iterations to compute eigenvector centrality");
+    error_opt = G_define_option();
+    error_opt->key = "error";
+    error_opt->answer = "0.1";
+    error_opt->type = TYPE_DOUBLE;
+    error_opt->required = NO;
+    error_opt->description =
+	_("Cuumulative error tolerance for eigenvector centrality");
+    geo_f = G_define_flag();
+    geo_f->key = 'g';
+    geo_f->description =
+	_("Use geodesic calculation for longitude-latitude locations");
+    /* options and flags parser */
+    if (G_parser(argc, argv))
+	exit(EXIT_FAILURE);
+    /* TODO: make an option for this */
+    mask_type = GV_LINE | GV_BOUNDARY;
+    if ((mapset = G_find_vector2(map_in->answer, "")) == NULL)
+	G_fatal_error(_("Vector map <%s> not found"), map_in->answer);
+    Vect_set_open_level(2);
+    if (1 > Vect_open_old(&In, map_in->answer, mapset))
+	G_fatal_error(_("Unable to open vector map <%s>"),
+		      G_fully_qualified_name(map_in->answer, mapset));
+    with_z = Vect_is_3d(&In);
+    if (geo_f->answer) {
+	geo = 1;
+	if (G_projection() != PROJECTION_LL)
+	    G_warning(_("The current projection is not longitude-latitude"));
+    else
+	geo = 0;
+    /* parse filter option and select appropriate lines */
+    layer = atoi(field_opt->answer);
+    if (where_opt->answer) {
+	if (layer < 1)
+	    G_fatal_error(_("'%s' must be > 0 for '%s'"), "layer", "where");
+	if (cat_opt->answer)
+	    G_warning(_
+		      ("'where' and 'cats' parameters were supplied, cat will be ignored"));
+	chcat = 1;
+	varray = Vect_new_varray(Vect_get_num_lines(&In));
+	if (Vect_set_varray_from_db
+	    (&In, layer, where_opt->answer, mask_type, 1, varray) == -1) {
+	    G_warning(_("Unable to load data from database"));
+    else if (cat_opt->answer) {
+	if (layer < 1)
+	    G_fatal_error(_("'%s' must be > 0 for '%s'"), "layer", "cat");
+	chcat = 1;
+	if (Vect_set_varray_from_cat_string
+	    (&In, layer, cat_opt->answer, mask_type, 1, varray) == -1) {
+	    G_warning(_("Problem loading category values"));
+    else {
+	chcat = 0;
+	varray = NULL;
+    /* Open database */
+    Fi = Vect_get_field(&In, layer);
+    db_begin_transaction(driver);
+    db_init_string(&sql);
+    Vect_net_build_graph(&In, mask_type, atoi(field_opt->answer), 0,
+			 afcol->answer, abcol->answer, NULL, geo, 0);
+    graph = &(In.graph);
+    deg = close = betw = eigen = NULL;
+    if (deg_opt->answer) {
+	deg = (double *)G_calloc(nnodes + 1, sizeof(double));
+	if (!deg)
+    if (close_opt->answer) {
+	close = (double *)G_calloc(nnodes + 1, sizeof(double));
+	if (!close)
+    if (betw_opt->answer) {
+	betw = (double *)G_calloc(nnodes + 1, sizeof(double));
+	if (!betw)
+    if (eigen_opt->answer) {
+	eigen = (double *)G_calloc(nnodes + 1, sizeof(double));
+	if (!eigen)
+	G_message(_("Computing degree centrality measure"));
+	neta_degree_centrality(graph, deg);
+    if (betw_opt->answer || close_opt->answer) {
+	G_message(_
+		  ("Computing betweenness and/or closeness centrality measure"));
+	neta_betweenness_closeness(graph, betw, close);
+	G_message(_("Computing eigenvector centrality measure"));
+	neta_eigenvector_centrality(graph, atoi(iter_opt->answer),
+				    atof(error_opt->answer), eigen);
+    nlines = Vect_get_num_lines(&In);
+    G_message(_("Writing data into the table..."));
+    G_percent_reset();
+	G_percent(i, nlines, 1);
+	//        if(!varray->c[i])continue;
+	int type = Vect_read_line(&In, NULL, Cats, i);
+	    int cat, node;
+		continue;
+	    Vect_get_line_nodes(&In, i, &node, NULL);
+		update_record(driver, &sql, Fi->table, Fi->key, deg_opt->answer,
+			      deg[node], cat);
+			      close_opt->answer, close[node], cat);
+			      betw_opt->answer, betw[node], cat);
+			      eigen_opt->answer, eigen[node], cat);
+    db_commit_transaction(driver);
+    if (deg)
+	G_free(deg);
+    if (close)
+	G_free(close);
+    if (betw)
+	G_free(betw);
+    if (eigen)
+	G_free(eigen);
+    Vect_close(&In);
+    exit(EXIT_SUCCESS);
Property changes on: grass-addons/vector/net.analyze/v.net.centrality/main.c
Added: grass-addons/vector/net.analyze/v.net.connectivity/Makefile
--- grass-addons/vector/net.analyze/v.net.connectivity/Makefile	                        (rev 0)
+++ grass-addons/vector/net.analyze/v.net.connectivity/Makefile	2009-07-07 13:21:27 UTC (rev 38293)
@@ -0,0 +1,15 @@
+PGM=v.net.connectivity
+default: cmd
Property changes on: grass-addons/vector/net.analyze/v.net.connectivity/Makefile
Added: grass-addons/vector/net.analyze/v.net.connectivity/main.c
--- grass-addons/vector/net.analyze/v.net.connectivity/main.c	                        (rev 0)
+++ grass-addons/vector/net.analyze/v.net.connectivity/main.c	2009-07-07 13:21:27 UTC (rev 38293)
@@ -0,0 +1,221 @@
+ * MODULE:     v.net.connectivity
+ * PURPOSE:    Vertex connectivity between two sets of nodes
+ *             for details.
+#include <stdio.h>
+    struct Map_info In, Out;
+    static struct line_pnts *Points;
+    char *mapset;
+    struct Option *map_in, *map_out;
+    struct Option *cat_opt, *field_opt, *where_opt, *ncol, *set1_opt, *set2_opt;
+    VARRAY *varray;
+    int i, nnodes, nlines, *flow, total_flow, nedges;
+    struct ilist *set1_list, *set2_list, *cut;
+    struct cat_list *set1_cats, *set2_cats;
+    int *node_costs;
+    dglGraph_s vg;
+    module->keywords = _("network, connectivity, vertex connectivity");
+	_("Computes vertex connectivity between two sets of nodes.");
+    map_out = G_define_standard_option(G_OPT_V_OUTPUT);
+    ncol = G_define_option();
+    ncol->key = "ncolumn";
+    ncol->type = TYPE_STRING;
+    ncol->required = NO;
+    ncol->description = _("Node capacity column");
+    set1_opt = G_define_standard_option(G_OPT_V_CATS);
+    set1_opt->key = "set1";
+    set1_opt->required = YES;
+    set1_opt->description = _("Categories of the first set");
+    set2_opt = G_define_standard_option(G_OPT_V_CATS);
+    set2_opt->key = "set2";
+    set2_opt->required = YES;
+    set2_opt->description = _("Categories of the second set");
+    Vect_check_input_output_name(map_in->answer, map_out->answer,
+				 GV_FATAL_EXIT);
+    if (0 > Vect_open_new(&Out, map_out->answer, with_z)) {
+	Vect_close(&In);
+	G_fatal_error(_("Unable to create vector map <%s>"), map_out->answer);
+	if (layer < 1)
+	    G_warning(_
+	chcat = 1;
+	if (layer < 1)
+	chcat = 1;
+    else {
+	chcat = 0;
+	varray = NULL;
+    set1_cats = Vect_new_cat_list();
+    set2_cats = Vect_new_cat_list();
+    Vect_str_to_cat_list(set1_opt->answer, set1_cats);
+    Vect_str_to_cat_list(set2_opt->answer, set2_cats);
+    set1_list = Vect_new_list();
+    set2_list = Vect_new_list();
+    nnodes = Vect_get_num_nodes(&In);
+	int type, cat;
+	type = Vect_read_line(&In, NULL, Cats, i);
+	if (type != GV_POINT)
+	    continue;
+	Vect_cat_get(Cats, layer, &cat);
+	if (Vect_cat_in_cat_list(cat, set1_cats))
+	    Vect_list_append(set1_list, i);
+	if (Vect_cat_in_cat_list(cat, set2_cats))
+	    Vect_list_append(set2_list, i);
+    if (set1_list->n_values == 0)
+	G_fatal_error(_("No points with categories [%s]"), set1_opt->answer);
+    if (set2_list->n_values == 0)
+	G_fatal_error(_("No points with categories [%s]"), set2_opt->answer);
+    neta_points_to_nodes(&In, set1_list);
+    neta_points_to_nodes(&In, set2_list);
+    Vect_copy_head_data(&In, &Out);
+    Vect_hist_copy(&In, &Out);
+    Vect_hist_command(&Out);
+    Vect_net_build_graph(&In, mask_type, 0, atoi(field_opt->answer),
+			 NULL, NULL, NULL, 0, 0);
+    /*build new graph */
+    if (ncol->answer) {
+	node_costs = (int *)G_calloc(nnodes + 1, sizeof(int));
+	if (!node_costs)
+	neta_get_node_costs(&In, layer, ncol->answer, node_costs);
+	nedges = neta_split_vertices(graph, &vg, node_costs);
+	G_free(node_costs);
+    else
+	nedges = neta_split_vertices(graph, &vg, NULL);
+    graph = &vg;
+    for (i = 0; i < set1_list->n_values; i++)
+	set1_list->value[i] = set1_list->value[i] * 2;	/*out vertex */
+    for (i = 0; i < set2_list->n_values; i++)
+	set2_list->value[i] = set2_list->value[i] * 2 - 1;	/*in vertex */
+    flow = (int *)G_calloc(nedges + 1, sizeof(int));
+    if (!flow)
+    total_flow = neta_flow(graph, set1_list, set2_list, flow);
+    G_debug(3, "Connectivity: %d", total_flow);
+    cut = Vect_new_list();
+    total_flow = neta_min_cut(graph, set1_list, set2_list, flow, cut);
+    /*TODO: copy old points */
+    for (i = 0; i < cut->n_values; i++)
+	neta_add_point_on_node(&In, &Out, cut->value[i], Cats);
+    Vect_destroy_list(cut);
+    G_free(flow);
+    Vect_destroy_list(set1_list);
+    Vect_destroy_list(set2_list);
+    Vect_build(&Out);
+    Vect_close(&In);
+    Vect_close(&Out);
Property changes on: grass-addons/vector/net.analyze/v.net.connectivity/main.c
Added: grass-addons/vector/net.analyze/v.net.distance/Makefile
--- grass-addons/vector/net.analyze/v.net.distance/Makefile	                        (rev 0)
+++ grass-addons/vector/net.analyze/v.net.distance/Makefile	2009-07-07 13:21:27 UTC (rev 38293)
@@ -0,0 +1,16 @@
+PGM=v.net.distance
+default: cmd
Property changes on: grass-addons/vector/net.analyze/v.net.distance/Makefile
Added: grass-addons/vector/net.analyze/v.net.distance/main.c
--- grass-addons/vector/net.analyze/v.net.distance/main.c	                        (rev 0)
+++ grass-addons/vector/net.analyze/v.net.distance/main.c	2009-07-07 13:21:27 UTC (rev 38293)
@@ -0,0 +1,308 @@
+ * MODULE:     v.net.distance
+ * PURPOSE:    Computes shortest distance via the network between
+ *             the given sets of features.
+ *             for details.
+#include <stdio.h>
+int initiliase_varray(struct Map_info *In, int layer, int mask_type,
+		      char *where, char *cat, VARRAY ** varray)
+    if (where) {
+	if (layer < 1)
+	if (cat)
+	    G_warning(_
+	*varray = Vect_new_varray(Vect_get_num_lines(In));
+	    (In, layer, where, mask_type, 1, *varray) == -1) {
+	    return 0;
+	return 1;
+    else if (cat) {
+	if (layer < 1)
+	    (In, layer, cat, mask_type, 1, *varray) == -1) {
+	    return 0;
+	return 1;
+    else {
+	G_fatal_error(_("Neither 'where' nor 'cat' were specified"));
+	return 0;
+    char *mapset;
+    struct Option *map_in, *map_out, *abcol, *afcol;
+    struct Option *catf_opt, *fieldf_opt, *wheref_opt;
+    struct Option *catt_opt, *fieldt_opt, *wheret_opt;
+    struct Flag *geo_f, *newpoints_f;
+    int with_z, geo;
+    int mask_type;
+    VARRAY *varrayf, *varrayt;
+    int flayer, tlayer;
+    struct ilist *nodest;
+    int i, nnodes, nlines;
+    int *dst, *nodes_to_features;
+    dglInt32_t **prev;
+    struct line_cats **on_path;
+    char buf[2000];
+    dbString sql;
+    dbDriver *driver;
+    module->keywords = _("network, shortest path");
+	_
+	("Find the shortest paths from a feature 'to' to every feature 'from' and various information about this realtion are uploaded to the attribute table.");
+    fieldf_opt = G_define_standard_option(G_OPT_V_FIELD);
+    fieldf_opt->key = "from_layer";
+    fieldf_opt->description = _("From layer");
+    catf_opt = G_define_standard_option(G_OPT_V_CATS);
+    catf_opt->key = "from_cats";
+    catf_opt->description = _("From category values");
+    wheref_opt = G_define_standard_option(G_OPT_WHERE);
+    wheref_opt->key = "from_where";
+    wheref_opt->description =
+	_("From WHERE conditions of SQL statement without 'where' keyword");
+    fieldt_opt = G_define_standard_option(G_OPT_V_FIELD);
+    fieldt_opt->key = "to_layer";
+    fieldt_opt->description = _("To layer");
+    catt_opt = G_define_standard_option(G_OPT_V_CATS);
+    catt_opt->key = "to_cats";
+    catt_opt->description = _("To category values");
+    wheret_opt = G_define_standard_option(G_OPT_WHERE);
+    wheret_opt->key = "to_where";
+    wheret_opt->description =
+	_("To WHERE conditions of SQL statement without 'where' keyword");
+    geo_f->key = 'g';
+    mask_type = GV_POINT | GV_LINE | GV_BOUNDARY;
+				 GV_FATAL_EXIT);
+	Vect_close(&In);
+	geo = 1;
+    else
+	geo = 0;
+    dst = (int *)G_calloc(nnodes + 1, sizeof(int));
+    prev = (dglInt32_t **) G_calloc(nnodes + 1, sizeof(dglInt32_t *));
+    nodes_to_features = (int *)G_calloc(nnodes + 1, sizeof(int));
+    on_path =
+	(struct line_cats **)G_calloc(nlines + 1, sizeof(struct line_cats *));
+    if (!dst || !prev || !nodes_to_features || !on_path)
+	on_path[i] = Vect_new_cats_struct();
+    /*initialise varrays and nodes list appropriatelly */
+    flayer = atoi(fieldf_opt->answer);
+    tlayer = atoi(fieldt_opt->answer);
+    initiliase_varray(&In, flayer, GV_POINT, wheref_opt->answer,
+		      catf_opt->answer, &varrayf);
+    initiliase_varray(&In, tlayer, mask_type, wheret_opt->answer,
+		      catt_opt->answer, &varrayt);
+    nodest = Vect_new_list();
+    neta_varray_to_nodes(&In, varrayt, nodest, nodes_to_features);
+    Vect_net_build_graph(&In, mask_type, 1, 0, afcol->answer, abcol->answer,
+			 NULL, geo, 0);
+    neta_distance_from_points(graph, nodest, dst, prev);
+    /* Create table */
+    Fi = Vect_default_field_info(&Out, 1, NULL, GV_1TABLE);
+    Vect_map_add_dblink(&Out, 1, NULL, Fi->table, "cat", Fi->database,
+			Fi->driver);
+    sprintf(buf,
+	    "create table %s ( cat integer, tcat integer, dist double precision)",
+	    Fi->table);
+    db_set_string(&sql, buf);
+    G_debug(2, db_get_string(&sql));
+    if (db_execute_immediate(driver, &sql) != DB_OK) {
+	G_fatal_error(_("Unable to create table: '%s'"), db_get_string(&sql));
+    if (db_create_index2(driver, Fi->table, "cat") != DB_OK)
+	G_warning(_("Cannot create index"));
+    if (db_grant_on_table
+	(driver, Fi->table, DB_PRIV_SELECT, DB_GROUP | DB_PUBLIC) != DB_OK)
+	G_fatal_error(_("Cannot grant privileges on table <%s>"), Fi->table);
+	if (varrayf->c[i]) {
+	    int type = Vect_read_line(&In, Points, Cats, i);
+	    int node, tcat, cat;
+	    double cost;
+	    dglInt32_t *vertex, vertex_id;
+	    if (!Vect_cat_get(Cats, flayer, &cat))
+		continue;
+	    Vect_write_line(&Out, type, Points, Cats);
+	    cost = dst[node] / (double)In.cost_multip;
+	    vertex = dglGetNode(graph, node);
+	    vertex_id = node;
+	    while (prev[vertex_id] != NULL) {
+		Vect_cat_set(on_path
+			     [abs(dglEdgeGet_Id(graph, prev[vertex_id]))], 1,
+			     cat);
+		vertex = dglEdgeGet_Head(graph, prev[vertex_id]);
+		vertex_id = dglNodeGet_Id(graph, vertex);
+	    Vect_read_line(&In, NULL, Cats, nodes_to_features[vertex_id]);
+	    if (!Vect_cat_get(Cats, tlayer, &tcat))
+		continue;
+	    sprintf(buf, "insert into %s values (%d, %d, %f)", Fi->table, cat,
+		    tcat, cost);
+	    G_debug(3, db_get_string(&sql));
+			      db_get_string(&sql));
+	if (on_path[i]->n_cats > 0) {
+	    int type = Vect_read_line(&In, Points, NULL, i);
+	    Vect_write_line(&Out, type, Points, on_path[i]);
+    Vect_build(&Out);
+    Vect_close(&In);
+    Vect_close(&Out);
+	Vect_destroy_cats_struct(on_path[i]);
+    G_free(on_path);
+    G_free(nodes_to_features);
+    G_free(dst);
+    G_free(prev);
Property changes on: grass-addons/vector/net.analyze/v.net.distance/main.c
Modified: grass-addons/vector/net.analyze/v.net.flow/main.c
--- grass-addons/vector/net.analyze/v.net.flow/main.c	2009-07-07 11:38:23 UTC (rev 38292)
+++ grass-addons/vector/net.analyze/v.net.flow/main.c	2009-07-07 13:21:27 UTC (rev 38293)
@@ -5,7 +5,7 @@
- * PURPOSE:    Max flow between two nodes
+ * PURPOSE:    Max flow and min cut between two sets of nodes
@@ -27,18 +27,23 @@
-    struct Map_info In, Out;
+    struct Map_info In, Out, cut_map;
     char *mapset;
-    struct Option *map_in, *map_out;
-    struct Option *cat_opt, *field_opt, *where_opt, *abcol, *afcol;
+    struct Option *map_in, *map_out, *cut_out;
+    struct Option *cat_opt, *field_opt, *where_opt, *abcol, *afcol, *source_opt,
+	*sink_opt;
     int chcat, with_z;
     VARRAY *varray;
     dglGraph_s *graph;
     int i, nlines, *flow, total_flow;
+    struct ilist *source_list, *sink_list, *cut;
+    struct cat_list *source_cats, *sink_cats;
+    int find_cut;
     char buf[2000];
@@ -52,12 +57,19 @@
     module->keywords = _("network, max flow");
-    module->description = _("Computes the maximum flow between two nodes.");
+	_("Computes the maximum flow between two sets of nodes.");
+    cut_out = G_define_option();
+    cut_out->type = TYPE_STRING;
+    cut_out->required = YES;
+    cut_out->key = "cut";
+    cut_out->description = _("Name of output map containing a minimum cut");
@@ -74,9 +86,20 @@
     abcol->description = _("Arc backward direction capacity column");
+    source_opt = G_define_standard_option(G_OPT_V_CATS);
+    source_opt->key = "source";
+    source_opt->required = YES;
+    source_opt->description = _("Categories of source(s)");
+    sink_opt = G_define_standard_option(G_OPT_V_CATS);
+    sink_opt->key = "sink";
+    sink_opt->required = YES;
+    sink_opt->description = _("Categories of sink(s)");
 	exit(EXIT_FAILURE);
+    find_cut = (cut_out->answer[0]);
@@ -102,6 +125,12 @@
+    if (find_cut && 0 > Vect_open_new(&cut_map, cut_out->answer, with_z)) {
+	Vect_close(&In);
+	Vect_close(&Out);
+	G_fatal_error(_("Unable to create vector map <%s>"), cut_out->answer);
@@ -161,6 +190,35 @@
+    source_cats = Vect_new_cat_list();
+    sink_cats = Vect_new_cat_list();
+    Vect_str_to_cat_list(source_opt->answer, source_cats);
+    Vect_str_to_cat_list(sink_opt->answer, sink_cats);
+    source_list = Vect_new_list();
+    sink_list = Vect_new_list();
+	int type, cat;
+	    continue;
+	if (Vect_cat_in_cat_list(cat, source_cats))
+	    Vect_list_append(source_list, i);
+	if (Vect_cat_in_cat_list(cat, sink_cats))
+	    Vect_list_append(sink_list, i);
+    if (source_list->n_values == 0)
+	G_fatal_error(_("No points with categories [%s]"), source_opt->answer);
+    if (sink_list->n_values == 0)
+	G_fatal_error(_("No points with categories [%s]"), sink_opt->answer);
+    neta_points_to_nodes(&In, source_list);
+    neta_points_to_nodes(&In, sink_list);
@@ -169,14 +227,18 @@
 			 afcol->answer, abcol->answer, NULL, 0, 0);
-    nlines = Vect_get_num_lines(&In);
     flow = (int *)G_calloc(nlines + 1, sizeof(int));
     if (!flow)
-    total_flow = neta_flow(graph, 215, 219, flow);
+    total_flow = neta_flow(graph, source_list, sink_list, flow);
     G_debug(3, "Max flow: %d", total_flow);
+    if (find_cut) {
+	total_flow = neta_min_cut(graph, source_list, sink_list, flow, cut);
+	G_debug(3, "Min cut: %d", total_flow);
     G_message(_("Writing the output..."));
     G_percent_reset();
@@ -190,7 +252,7 @@
 	    if (cat == -1)
 		continue;	/*TODO: warning? */
 	    sprintf(buf, "insert into %s values (%d, %d)", Fi->table, cat,
-		    flow[i] / 1000);
+		    flow[i] / In.cost_multip);
@@ -201,12 +263,24 @@
-    neta_add_point_on_node(&In, &Out, 215, Cats);
-    neta_add_point_on_node(&In, &Out, 219, Cats);
+    if (find_cut) {
+	for (i = 0; i < cut->n_values; i++) {
+	    int type = Vect_read_line(&In, Points, Cats, cut->value[i]);
+	    Vect_write_line(&cut_map, type, Points, Cats);
+	Vect_build(&cut_map);
+	Vect_close(&cut_map);
     G_free(flow);
+    Vect_destroy_list(source_list);
+    Vect_destroy_list(sink_list);
     Vect_build(&Out);
