[GRASS-SVN] r38298 - grass/branches/develbranch_6/vector/v.to.3d
svn_grass at osgeo.org
Tue Jul 7 15:39:35 EDT 2009
Author: martinl
Date: 2009-07-07 15:39:35 -0400 (Tue, 07 Jul 2009)
New Revision: 38298
grass/branches/develbranch_6/vector/v.to.3d/main.c
grass/branches/develbranch_6/vector/v.to.3d/trans2.c
grass/branches/develbranch_6/vector/v.to.3d/trans3.c
v.to.3d: cleanup if fails, see trac #550
(merge from trunk, r38297)
Modified: grass/branches/develbranch_6/vector/v.to.3d/main.c
--- grass/branches/develbranch_6/vector/v.to.3d/main.c 2009-07-07 19:36:59 UTC (rev 38297)
+++ grass/branches/develbranch_6/vector/v.to.3d/main.c 2009-07-07 19:39:35 UTC (rev 38298)
@@ -29,7 +29,8 @@
struct Map_info In, Out;
BOUND_BOX box;
int field, type;
+ int ret;
G_gisinit(argv[0]);
module = G_define_module();
@@ -100,9 +101,10 @@
G_message(_("Transforming features..."));
+ ret = 0;
if (opt.reverse->answer) {
/* 3d -> 2d */
- trans3d(&In, &Out, type, field, opt.column->answer);
+ ret = trans3d(&In, &Out, type, field, opt.column->answer);
else {
/* 2d -> 3d */
@@ -111,9 +113,16 @@
if (opt.height->answer) {
height = atof(opt.height->answer);
- trans2d(&In, &Out, type, height, field, opt.column->answer);
+ ret = trans2d(&In, &Out, type, height, field, opt.column->answer);
+ if (ret < 0) {
+ Vect_close(&In);
+ Vect_close(&Out);
+ Vect_delete(opt.output->answer);
+ G_fatal_error(_("%s failed"), G_program_name());
if (!opt.reverse->answer && !opt.table->answer) {
G_message(_("Copying attributes..."));
if (Vect_copy_tables(&In, &Out, 0) == -1) {
Modified: grass/branches/develbranch_6/vector/v.to.3d/trans2.c
--- grass/branches/develbranch_6/vector/v.to.3d/trans2.c 2009-07-07 19:36:59 UTC (rev 38297)
+++ grass/branches/develbranch_6/vector/v.to.3d/trans2.c 2009-07-07 19:39:35 UTC (rev 38298)
@@ -16,6 +16,7 @@
\param column attribute column used for height
\return number of writen features
+ \return -1 on error
int trans2d(struct Map_info *In, struct Map_info *Out, int type,
double height, int field, const char *column)
@@ -40,23 +41,29 @@
dbDriver *driver;
Fi = Vect_get_field(In, field);
- if (!Fi)
- G_fatal_error(_("Database connection not defined for layer %d"),
- field);
+ if (!Fi) {
+ G_warning(_("Database connection not defined for layer %d"),
+ field);
+ return -1;
driver = db_start_driver_open_database(Fi->driver, Fi->database);
if (!driver) {
- G_fatal_error(_("Unable to open database <%s> by driver <%s>"),
- Fi->database, Fi->driver);
+ G_warning(_("Unable to open database <%s> by driver <%s>"),
+ Fi->database, Fi->driver);
+ return -1;
/* column type must numeric */
ctype = db_column_Ctype(driver, Fi->table, column);
- if (ctype == -1)
- G_fatal_error(_("Column <%s> not found in table <%s>"),
- column, Fi->table);
+ if (ctype == -1) {
+ G_warning(_("Column <%s> not found in table <%s>"),
+ column, Fi->table);
+ return -1;
if (ctype != DB_C_TYPE_INT && ctype != DB_C_TYPE_DOUBLE) {
- G_fatal_error(_("Column must be numeric"));
+ G_warning(_("Column must be numeric"));
+ return -1;
db_select_CatValArray(driver, Fi->table, Fi->key,
@@ -71,7 +78,8 @@
while (1) {
ltype = Vect_read_next_line(In, Points, Cats);
if (ltype == -1) {
- G_fatal_error(_("Unable to read vector map"));
+ G_warning(_("Unable to read vector map"));
+ return -1;
if (ltype == -2) { /* EOF */
break;
Modified: grass/branches/develbranch_6/vector/v.to.3d/trans3.c
--- grass/branches/develbranch_6/vector/v.to.3d/trans3.c 2009-07-07 19:36:59 UTC (rev 38297)
+++ grass/branches/develbranch_6/vector/v.to.3d/trans3.c 2009-07-07 19:39:35 UTC (rev 38298)
@@ -17,6 +17,7 @@
\param zcolumn attribute column where to store height
int trans3d(struct Map_info *In, struct Map_info *Out, int type,
int field, const char *zcolumn)
@@ -41,23 +42,29 @@
if (zcolumn) {
Fi = Vect_get_field(Out, field);
- if (!Fi)
- field);
+ if (!Fi) {
+ field);
+ return -1;
if (!driver) {
+ return -1;
ctype = db_column_Ctype(driver, Fi->table, zcolumn);
- if (ctype == -1)
- zcolumn, Fi->table);
+ zcolumn, Fi->table);
+ return -1;
+ return -1;
db_begin_transaction(driver);
@@ -71,7 +78,8 @@
while (1) {
if (ltype == -1) {
+ return -1;
break;
