[GRASS-SVN] r38306 -
grass/branches/releasebranch_6_4/gui/wxpython/gui_modules
svn_grass at osgeo.org
Wed Jul 8 02:42:11 EDT 2009
Author: martinl
Date: 2009-07-08 02:42:11 -0400 (Wed, 08 Jul 2009)
New Revision: 38306
grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/vdigit.py
wxGUI/vdigit: use SpinCTRL for layer instead of Choice
(merge from devbr6, r38304)
Modified: grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/vdigit.py
--- grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/vdigit.py 2009-07-08 06:40:56 UTC (rev 38305)
+++ grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/vdigit.py 2009-07-08 06:42:11 UTC (rev 38306)
@@ -1384,16 +1384,9 @@
settings = ((_("Layer"), 1), (_("Category"), 1), (_("Mode"), _("Next to use")))
# layer
text = wx.StaticText(parent=panel, id=wx.ID_ANY, label=_("Layer"))
- if self.parent.digit.map:
- layers = map(str, self.parent.digit.GetLayers())
- if len(layers) == 0:
- layers = [str(UserSettings.Get(group='vdigit', key="layer", subkey='value')), ]
- else:
- self.layer = wx.Choice(parent=panel, id=wx.ID_ANY, size=(125, -1),
- choices=layers)
- self.layer.SetStringSelection(str(UserSettings.Get(group='vdigit', key="layer", subkey='value')))
+ self.layer = wx.SpinCtrl(parent=panel, id=wx.ID_ANY, size=(125, -1),
+ min = 1, max = 1e3)
+ self.layer.SetValue(int(UserSettings.Get(group='vdigit', key="layer", subkey='value')))
flexSizer.Add(item=text, proportion=0, flag=wx.ALIGN_CENTER_VERTICAL)
flexSizer.Add(item=self.layer, proportion=0,
flag=wx.FIXED_MINSIZE | wx.ALIGN_CENTER_VERTICAL)
@@ -1437,7 +1430,7 @@
# bindings
self.Bind(wx.EVT_CHECKBOX, self.OnChangeAddRecord, self.addRecord)
self.Bind(wx.EVT_CHOICE, self.OnChangeCategoryMode, self.categoryMode)
- self.Bind(wx.EVT_CHOICE, self.OnChangeLayer, self.layer)
+ self.Bind(wx.EVT_SPINCTRL, self.OnChangeLayer, self.layer)
panel.SetSizer(border)
@@ -1486,7 +1479,7 @@
def OnChangeLayer(self, event):
"""Layer changed"""
- layer = int(event.GetString())
+ layer = event.GetInt()
if layer > 0:
UserSettings.Set(group='vdigit', key='layer', subkey='value', value=layer)
self.parent.digit.SetCategory()
@@ -1618,7 +1611,7 @@
UserSettings.Set(group='vdigit', key="addRecord", subkey='enabled',
value=self.addRecord.IsChecked())
UserSettings.Set(group='vdigit', key="layer", subkey='value',
- value=int(self.layer.GetStringSelection()))
+ value=int(self.layer.GetValue()))
UserSettings.Set(group='vdigit', key="category", subkey='value',
value=int(self.category.GetValue()))
UserSettings.Set(group='vdigit', key="categoryMode", subkey='selection',
