[GRASS-SVN] r38344 - grass-addons/vector/v.krige
svn_grass at osgeo.org
Fri Jul 10 07:29:59 EDT 2009
Author: aghisla
Date: 2009-07-10 07:29:59 -0400 (Fri, 10 Jul 2009)
New Revision: 38344
grass-addons/vector/v.krige/v.krige.py
small cleanup, and try to understand why parser ignores flags
Modified: grass-addons/vector/v.krige/v.krige.py
--- grass-addons/vector/v.krige/v.krige.py 2009-07-10 11:03:09 UTC (rev 38343)
+++ grass-addons/vector/v.krige/v.krige.py 2009-07-10 11:29:59 UTC (rev 38344)
@@ -57,7 +57,7 @@
#% options: Exp,Sph,Gau,Mat,Lin
#% multiple: yes
#% label: Variogram model(s)
-#% description: Leave empty to
+#% description: Leave empty to test all models (requires automap)
#% required: no
#%end
#%option
@@ -452,38 +452,37 @@
k.Show()
app.MainLoop()
else:
+ print argv
options, flags = argv
#CLI
#@TODO: Work on verbosity. Sometimes it's too verbose (R), sometimes not enough.
- # check for output map with same name. g.parser can't handle this, afaik.
+ # create output map name, if not specified
if options['output'] is '':
try: # to strip mapset name from fullname. Ugh.
options['input'] = options['input'].split("@")[0]
except:
pass
options['output'] = options['input'] + '_kriging'
- mapname = grass.find_file(options['output'], element = 'cell')['fullname']
- if options['output'] == mapname.split("@")[0]:
+ # check for output map with same name. g.parser can't handle this, afaik.
+ if grass.find_file(options['output'], element = 'cell')['fullname']:
grass.error(_("option: <output>: Raster map already exists."))
sys.exit()
#print options
- #print flags
+ print flags
if options['model'] is '':
try:
robjects.r.require("automap")
except ImportError, e:
grass.fatal(_("R package automap is missing, no variogram autofit available."))
controller = Controller()
controller.Run(input = options['input'],
column = options['column'],
output = options['output'],
- overwrite = flags['o'],
+ overwrite = flags['overwrite'],
package = options['package'],
model = options['model'],
sill = options['sill'],
