[GRASS-SVN] r38366 - in grass/trunk: general/g.parser
scripts/d.correlate scripts/d.polar scripts/d.rast.edit
scripts/db.dropcolumn scripts/db.droptable scripts/db.in.ogr
scripts/db.out.ogr scripts/db.test scripts/g.extension
scripts/g.manual scripts/i.fusion.brovey
scripts/i.image.mosaic scripts/i.in.spotvgt
scripts/i.landsat.rgb scripts/i.oif scripts/i.spectral
scripts/i.tasscap scripts/m.proj scripts/r.buffer
scripts/r.colors.stddev scripts/r.fillnulls
scripts/r.in.aster scripts/r.in.srtm scripts/r.in.wms
scripts/r.mask scripts/r.out.xyz scripts/r.plane
scripts/r.reclass.area scripts/r.regression.line
scripts/r.shaded.relief scripts/r.tileset scripts/v.centroids
scripts/v.colors scripts/v.convert.all scripts/v.db.addcol
scripts/v.db.addtable scripts/v.db.dropcolumn
scripts/v.db.droptable scripts/v.db.join
scripts/v.db.reconnect.all scripts/v.db.renamecolumn
scripts/v.db.univar scripts/v.db.update scripts/v.dissolve
scripts/v.in.e00 scripts/v.in.geonames scripts/v.in.gns
scripts/v.in.mapgen scripts/v.in.sites.all scripts/v.out.gps
scripts/v.rast.stats scripts/v.report scripts/v.what.vect
svn_grass at osgeo.org
Sat Jul 11 07:53:19 EDT 2009
Author: martinl
Date: 2009-07-11 07:53:18 -0400 (Sat, 11 Jul 2009)
New Revision: 38366
grass/trunk/general/g.parser/main.c
grass/trunk/scripts/d.correlate/d.correlate.py
grass/trunk/scripts/d.polar/d.polar.py
grass/trunk/scripts/d.rast.edit/d.rast.edit.py
grass/trunk/scripts/db.dropcolumn/db.dropcolumn.py
grass/trunk/scripts/db.droptable/db.droptable.py
grass/trunk/scripts/db.in.ogr/db.in.ogr.py
grass/trunk/scripts/db.out.ogr/db.out.ogr.py
grass/trunk/scripts/db.test/db.test.py
grass/trunk/scripts/g.extension/g.extension.py
grass/trunk/scripts/g.manual/g.manual.py
grass/trunk/scripts/i.fusion.brovey/i.fusion.brovey.py
grass/trunk/scripts/i.image.mosaic/i.image.mosaic.py
grass/trunk/scripts/i.in.spotvgt/i.in.spotvgt.py
grass/trunk/scripts/i.landsat.rgb/i.landsat.rgb.py
grass/trunk/scripts/i.oif/i.oif.py
grass/trunk/scripts/i.spectral/i.spectral.py
grass/trunk/scripts/i.tasscap/i.tasscap.py
grass/trunk/scripts/m.proj/m.proj.py
grass/trunk/scripts/r.buffer/r.buffer.py
grass/trunk/scripts/r.colors.stddev/r.colors.stddev.py
grass/trunk/scripts/r.fillnulls/r.fillnulls.py
grass/trunk/scripts/r.in.aster/r.in.aster.py
grass/trunk/scripts/r.in.srtm/r.in.srtm.py
grass/trunk/scripts/r.in.wms/r.in.gdalwarp.py
grass/trunk/scripts/r.in.wms/r.in.wms.py
grass/trunk/scripts/r.mask/r.mask.py
grass/trunk/scripts/r.out.xyz/r.out.xyz.py
grass/trunk/scripts/r.plane/r.plane.py
grass/trunk/scripts/r.reclass.area/r.reclass.area.py
grass/trunk/scripts/r.regression.line/r.regression.line.py
grass/trunk/scripts/r.shaded.relief/r.shaded.relief.py
grass/trunk/scripts/r.tileset/r.tileset.py
grass/trunk/scripts/v.centroids/v.centroids.py
grass/trunk/scripts/v.colors/v.colors.py
grass/trunk/scripts/v.convert.all/v.convert.all.py
grass/trunk/scripts/v.db.addcol/v.db.addcol.py
grass/trunk/scripts/v.db.addtable/v.db.addtable.py
grass/trunk/scripts/v.db.dropcolumn/v.db.dropcolumn.py
grass/trunk/scripts/v.db.droptable/v.db.droptable.py
grass/trunk/scripts/v.db.join/v.db.join.py
grass/trunk/scripts/v.db.reconnect.all/v.db.reconnect.all.py
grass/trunk/scripts/v.db.renamecolumn/v.db.renamecolumn.py
grass/trunk/scripts/v.db.univar/v.db.univar.py
grass/trunk/scripts/v.db.update/v.db.update.py
grass/trunk/scripts/v.dissolve/v.dissolve.py
grass/trunk/scripts/v.in.e00/v.in.e00.py
grass/trunk/scripts/v.in.geonames/v.in.geonames.py
grass/trunk/scripts/v.in.gns/v.in.gns.py
grass/trunk/scripts/v.in.mapgen/v.in.mapgen.py
grass/trunk/scripts/v.in.sites.all/v.in.sites.all.py
grass/trunk/scripts/v.out.gps/v.out.gps.py
grass/trunk/scripts/v.rast.stats/v.rast.stats.py
grass/trunk/scripts/v.report/v.report.py
grass/trunk/scripts/v.what.vect/v.what.vect.py
split keywords also in scripts (to avoid duplicated translations)
Modified: grass/trunk/general/g.parser/main.c
--- grass/trunk/general/g.parser/main.c 2009-07-11 09:30:52 UTC (rev 38365)
+++ grass/trunk/general/g.parser/main.c 2009-07-11 11:53:18 UTC (rev 38366)
@@ -102,7 +102,7 @@
if (strcasecmp(cmd, "keywords") == 0) {
- G_set_keywords(translate(strdup(arg)));
+ G_add_keyword(translate(strdup(arg)));
return;
Modified: grass/trunk/scripts/d.correlate/d.correlate.py
--- grass/trunk/scripts/d.correlate/d.correlate.py 2009-07-11 09:30:52 UTC (rev 38365)
+++ grass/trunk/scripts/d.correlate/d.correlate.py 2009-07-11 11:53:18 UTC (rev 38366)
@@ -18,7 +18,8 @@
#%Module
#% description: Prints a graph of the correlation between data layers (in pairs).
-#% keywords: display, diagram
+#% keywords: display
+#% keywords: diagram
#%End
#%option
#% key: layers
Modified: grass/trunk/scripts/d.polar/d.polar.py
--- grass/trunk/scripts/d.polar/d.polar.py 2009-07-11 09:30:52 UTC (rev 38365)
+++ grass/trunk/scripts/d.polar/d.polar.py 2009-07-11 11:53:18 UTC (rev 38366)
@@ -20,7 +20,8 @@
#%Module
#% description: Draws polar diagram of angle map such as aspect or flow directions
#%End
#%option
#% key: map
Modified: grass/trunk/scripts/d.rast.edit/d.rast.edit.py
--- grass/trunk/scripts/d.rast.edit/d.rast.edit.py 2009-07-11 09:30:52 UTC (rev 38365)
+++ grass/trunk/scripts/d.rast.edit/d.rast.edit.py 2009-07-11 11:53:18 UTC (rev 38366)
@@ -20,7 +20,8 @@
#%Module
#% description: Interactively edit cell values in a raster map.
-#% keywords: display, raster
+#% keywords: raster
#%End
#%Option
#% key: input
Modified: grass/trunk/scripts/db.dropcolumn/db.dropcolumn.py
--- grass/trunk/scripts/db.dropcolumn/db.dropcolumn.py 2009-07-11 09:30:52 UTC (rev 38365)
+++ grass/trunk/scripts/db.dropcolumn/db.dropcolumn.py 2009-07-11 11:53:18 UTC (rev 38366)
@@ -19,7 +19,8 @@
#%Module
#% description: Drops a column from selected attribute table
-#% keywords: database, attribute table
+#% keywords: database
+#% keywords: attribute table
#%End
#%flag
Modified: grass/trunk/scripts/db.droptable/db.droptable.py
--- grass/trunk/scripts/db.droptable/db.droptable.py 2009-07-11 09:30:52 UTC (rev 38365)
+++ grass/trunk/scripts/db.droptable/db.droptable.py 2009-07-11 11:53:18 UTC (rev 38366)
@@ -17,7 +17,8 @@
#%Module
#% description: Drops an attribute table.
#%End
#%flag
Modified: grass/trunk/scripts/db.in.ogr/db.in.ogr.py
--- grass/trunk/scripts/db.in.ogr/db.in.ogr.py 2009-07-11 09:30:52 UTC (rev 38365)
+++ grass/trunk/scripts/db.in.ogr/db.in.ogr.py 2009-07-11 11:53:18 UTC (rev 38366)
@@ -16,7 +16,8 @@
#%Module
#% description: Imports attribute tables in various formats.
#%End
#%option
Modified: grass/trunk/scripts/db.out.ogr/db.out.ogr.py
--- grass/trunk/scripts/db.out.ogr/db.out.ogr.py 2009-07-11 09:30:52 UTC (rev 38365)
+++ grass/trunk/scripts/db.out.ogr/db.out.ogr.py 2009-07-11 11:53:18 UTC (rev 38366)
@@ -16,7 +16,8 @@
#%Module
#% description: Exports attribute tables into various formats.
#%End
#%option
Modified: grass/trunk/scripts/db.test/db.test.py
--- grass/trunk/scripts/db.test/db.test.py 2009-07-11 09:30:52 UTC (rev 38365)
+++ grass/trunk/scripts/db.test/db.test.py 2009-07-11 11:53:18 UTC (rev 38366)
@@ -15,7 +15,8 @@
#% Module
#% description: Test database driver, database must exist and set by db.connect.
#% End
#% option
#% key: test
Modified: grass/trunk/scripts/g.extension/g.extension.py
--- grass/trunk/scripts/g.extension/g.extension.py 2009-07-11 09:30:52 UTC (rev 38365)
+++ grass/trunk/scripts/g.extension/g.extension.py 2009-07-11 11:53:18 UTC (rev 38366)
@@ -20,7 +20,8 @@
#%module
#% label: Tool to maintain GRASS extensions in local GRASS installation.
#% description: Downloads, installs extensions from GRASS Addons SVN repository into local GRASS installation or removes installed extensions.
-#% keywords: installation, extensions
+#% keywords: installation
+#% keywords: extensions
#%end
#%option
Modified: grass/trunk/scripts/g.manual/g.manual.py
--- grass/trunk/scripts/g.manual/g.manual.py 2009-07-11 09:30:52 UTC (rev 38365)
+++ grass/trunk/scripts/g.manual/g.manual.py 2009-07-11 11:53:18 UTC (rev 38366)
@@ -16,7 +16,9 @@
#%Module
#% description: Display the HTML man pages of GRASS
-#% keywords: general, manual, help
+#% keywords: general
+#% keywords: manual
+#% keywords: help
#%End
#%flag
#% key: i
Modified: grass/trunk/scripts/i.fusion.brovey/i.fusion.brovey.py
--- grass/trunk/scripts/i.fusion.brovey/i.fusion.brovey.py 2009-07-11 09:30:52 UTC (rev 38365)
+++ grass/trunk/scripts/i.fusion.brovey/i.fusion.brovey.py 2009-07-11 11:53:18 UTC (rev 38366)
@@ -29,7 +29,9 @@
#%Module
#% description: Brovey transform to merge multispectral and high-res panchromatic channels
-#% keywords: imagery, fusion, Brovey
+#% keywords: imagery
+#% keywords: fusion
+#% keywords: Brovey
#%End
#%Flag
#% key: l
Modified: grass/trunk/scripts/i.image.mosaic/i.image.mosaic.py
--- grass/trunk/scripts/i.image.mosaic/i.image.mosaic.py 2009-07-11 09:30:52 UTC (rev 38365)
+++ grass/trunk/scripts/i.image.mosaic/i.image.mosaic.py 2009-07-11 11:53:18 UTC (rev 38366)
@@ -24,7 +24,9 @@
#% Module
#% description: Mosaics several images and extends colormap
-#% keywords: raster, imagery, mosaicking
+#% keywords: mosaicking
#% End
#% option
#% key: images
Modified: grass/trunk/scripts/i.in.spotvgt/i.in.spotvgt.py
--- grass/trunk/scripts/i.in.spotvgt/i.in.spotvgt.py 2009-07-11 09:30:52 UTC (rev 38365)
+++ grass/trunk/scripts/i.in.spotvgt/i.in.spotvgt.py 2009-07-11 11:53:18 UTC (rev 38366)
@@ -31,7 +31,9 @@
#%Module
#% description: Import of SPOT VGT NDVI file into a raster map
-#% keywords: raster, imagery, import
+#% keywords: import
#%End
#%flag
#% key: a
Modified: grass/trunk/scripts/i.landsat.rgb/i.landsat.rgb.py
--- grass/trunk/scripts/i.landsat.rgb/i.landsat.rgb.py 2009-07-11 09:30:52 UTC (rev 38365)
+++ grass/trunk/scripts/i.landsat.rgb/i.landsat.rgb.py 2009-07-11 11:53:18 UTC (rev 38366)
@@ -22,7 +22,9 @@
#%Module
#% description: Performs auto-balancing of colors for LANDSAT images.
-#% keywords: raster, imagery, colors
+#% keywords: colors
#%End
#%option
#% key: red
Modified: grass/trunk/scripts/i.oif/i.oif.py
--- grass/trunk/scripts/i.oif/i.oif.py 2009-07-11 09:30:52 UTC (rev 38365)
+++ grass/trunk/scripts/i.oif/i.oif.py 2009-07-11 11:53:18 UTC (rev 38366)
@@ -25,7 +25,9 @@
#% Module
#% description: Calculates Optimum-Index-Factor table for LANDSAT TM bands 1-5, & 7
-#% keywords: raster, imagery, statistics
+#% keywords: statistics
#% End
#% option
#% key: image1
Modified: grass/trunk/scripts/i.spectral/i.spectral.py
--- grass/trunk/scripts/i.spectral/i.spectral.py 2009-07-11 09:30:52 UTC (rev 38365)
+++ grass/trunk/scripts/i.spectral/i.spectral.py 2009-07-11 11:53:18 UTC (rev 38366)
@@ -23,7 +23,9 @@
#%Module
#% description: Displays spectral response at user specified locations in group or images.
-#% keywords: imagery, raster, multispectral
+#% keywords: multispectral
#%End
#%option
#% key: group
Modified: grass/trunk/scripts/i.tasscap/i.tasscap.py
--- grass/trunk/scripts/i.tasscap/i.tasscap.py 2009-07-11 09:30:52 UTC (rev 38365)
+++ grass/trunk/scripts/i.tasscap/i.tasscap.py 2009-07-11 11:53:18 UTC (rev 38366)
@@ -34,7 +34,8 @@
#%Module
#% description: Tasseled Cap (Kauth Thomas) transformation for LANDSAT-TM data
#%End
#%flag
#% key: 4
Modified: grass/trunk/scripts/m.proj/m.proj.py
--- grass/trunk/scripts/m.proj/m.proj.py 2009-07-11 09:30:52 UTC (rev 38365)
+++ grass/trunk/scripts/m.proj/m.proj.py 2009-07-11 11:53:18 UTC (rev 38366)
@@ -26,7 +26,8 @@
#%Module
#% description: Converts coordinates from one projection to another (cs2cs frontend).
-#% keywords: miscellaneous, projection
+#% keywords: miscellaneous
+#% keywords: projection
#%End
#%option
#% key: input
Modified: grass/trunk/scripts/r.buffer/r.buffer.py
--- grass/trunk/scripts/r.buffer/r.buffer.py 2009-07-11 09:30:52 UTC (rev 38365)
+++ grass/trunk/scripts/r.buffer/r.buffer.py 2009-07-11 11:53:18 UTC (rev 38366)
@@ -16,7 +16,8 @@
#%Module
#% description: Creates a raster map layer showing buffer zones surrounding cells that contain non-NULL category values.
-#% keywords: raster, buffer
+#% keywords: buffer
#%End
#%Flag
#% key: z
Modified: grass/trunk/scripts/r.colors.stddev/r.colors.stddev.py
--- grass/trunk/scripts/r.colors.stddev/r.colors.stddev.py 2009-07-11 09:30:52 UTC (rev 38365)
+++ grass/trunk/scripts/r.colors.stddev/r.colors.stddev.py 2009-07-11 11:53:18 UTC (rev 38366)
@@ -16,7 +16,8 @@
#%Module
#% description: Set color rules based on stddev from a map's mean value.
-#% keywords: raster, color table
+#% keywords: color table
#%End
#% option
#% key: input
Modified: grass/trunk/scripts/r.fillnulls/r.fillnulls.py
--- grass/trunk/scripts/r.fillnulls/r.fillnulls.py 2009-07-11 09:30:52 UTC (rev 38365)
+++ grass/trunk/scripts/r.fillnulls/r.fillnulls.py 2009-07-11 11:53:18 UTC (rev 38366)
@@ -22,7 +22,9 @@
#%Module
#% description: Fills no-data areas in raster maps using v.surf.rst splines interpolation
-#% keywords: raster, elevation, interpolation
+#% keywords: elevation
+#% keywords: interpolation
#%End
#%option
#% key: input
Modified: grass/trunk/scripts/r.in.aster/r.in.aster.py
--- grass/trunk/scripts/r.in.aster/r.in.aster.py 2009-07-11 09:30:52 UTC (rev 38365)
+++ grass/trunk/scripts/r.in.aster/r.in.aster.py 2009-07-11 11:53:18 UTC (rev 38366)
@@ -22,7 +22,9 @@
#%Module
#% description: Georeference, rectify, and import Terra-ASTER imagery and relative DEM's using gdalwarp.
#%End
#%option
#% key: input
Modified: grass/trunk/scripts/r.in.srtm/r.in.srtm.py
--- grass/trunk/scripts/r.in.srtm/r.in.srtm.py 2009-07-11 09:30:52 UTC (rev 38365)
+++ grass/trunk/scripts/r.in.srtm/r.in.srtm.py 2009-07-11 11:53:18 UTC (rev 38366)
@@ -45,7 +45,8 @@
#%Module
#% description: Import SRTM HGT files into GRASS
-#% keywords: raster, import
#%End
#%option
#% key: input
Modified: grass/trunk/scripts/r.in.wms/r.in.gdalwarp.py
--- grass/trunk/scripts/r.in.wms/r.in.gdalwarp.py 2009-07-11 09:30:52 UTC (rev 38365)
+++ grass/trunk/scripts/r.in.wms/r.in.gdalwarp.py 2009-07-11 11:53:18 UTC (rev 38366)
@@ -20,7 +20,9 @@
#%module
#% description: Warps and imports GDAL supported raster file complete with correct NULL values
-#% keywords: raster, rotate, reproject
+#% keywords: rotate
+#% keywords: reproject
#%end
#%flag
#% key: p
Modified: grass/trunk/scripts/r.in.wms/r.in.wms.py
--- grass/trunk/scripts/r.in.wms/r.in.wms.py 2009-07-11 09:30:52 UTC (rev 38365)
+++ grass/trunk/scripts/r.in.wms/r.in.wms.py 2009-07-11 11:53:18 UTC (rev 38366)
@@ -20,7 +20,9 @@
#%module
#% description: Downloads and imports data from WMS servers.
-#% keywords: raster, import, wms
+#% keywords: wms
#%end
#%flag
#% key: l
Modified: grass/trunk/scripts/r.mask/r.mask.py
--- grass/trunk/scripts/r.mask/r.mask.py 2009-07-11 09:30:52 UTC (rev 38365)
+++ grass/trunk/scripts/r.mask/r.mask.py 2009-07-11 11:53:18 UTC (rev 38366)
@@ -17,7 +17,8 @@
#%Module
#% description: Create a MASK for limiting raster operation
-#% keywords: raster, mask
+#% keywords: mask
#%End
#%option
#% key: input
Modified: grass/trunk/scripts/r.out.xyz/r.out.xyz.py
--- grass/trunk/scripts/r.out.xyz/r.out.xyz.py 2009-07-11 09:30:52 UTC (rev 38365)
+++ grass/trunk/scripts/r.out.xyz/r.out.xyz.py 2009-07-11 11:53:18 UTC (rev 38366)
@@ -18,7 +18,8 @@
#%Module
#% description: Export a raster map to a text file as x,y,z values based on cell centers.
-#% keywords: raster, export
+#% keywords: export
#%End
#%option
#% key: input
Modified: grass/trunk/scripts/r.plane/r.plane.py
--- grass/trunk/scripts/r.plane/r.plane.py 2009-07-11 09:30:52 UTC (rev 38365)
+++ grass/trunk/scripts/r.plane/r.plane.py 2009-07-11 11:53:18 UTC (rev 38366)
@@ -18,7 +18,8 @@
#%Module
#% description: Creates raster plane map given dip (inclination), aspect (azimuth) and one point.
#%End
#%option
#% key: name
Modified: grass/trunk/scripts/r.reclass.area/r.reclass.area.py
--- grass/trunk/scripts/r.reclass.area/r.reclass.area.py 2009-07-11 09:30:52 UTC (rev 38365)
+++ grass/trunk/scripts/r.reclass.area/r.reclass.area.py 2009-07-11 11:53:18 UTC (rev 38366)
@@ -22,7 +22,9 @@
#%Module
#% description: Reclasses a raster map greater or less than user specified area size (in hectares).
-#% keywords: raster, statistics, aggregation
+#% keywords: aggregation
#%End
#%option
Modified: grass/trunk/scripts/r.regression.line/r.regression.line.py
--- grass/trunk/scripts/r.regression.line/r.regression.line.py 2009-07-11 09:30:52 UTC (rev 38365)
+++ grass/trunk/scripts/r.regression.line/r.regression.line.py 2009-07-11 11:53:18 UTC (rev 38366)
@@ -18,7 +18,8 @@
#%Module
#% description: Calculates linear regression from two raster maps: y = a + b*x
#%End
#%flag
#% key: g
Modified: grass/trunk/scripts/r.shaded.relief/r.shaded.relief.py
--- grass/trunk/scripts/r.shaded.relief/r.shaded.relief.py 2009-07-11 09:30:52 UTC (rev 38365)
+++ grass/trunk/scripts/r.shaded.relief/r.shaded.relief.py 2009-07-11 11:53:18 UTC (rev 38366)
@@ -50,7 +50,8 @@
#% Module
#% description: Creates shaded relief map from an elevation map (DEM).
#% End
#% option
#% key: input
Modified: grass/trunk/scripts/r.tileset/r.tileset.py
--- grass/trunk/scripts/r.tileset/r.tileset.py 2009-07-11 09:30:52 UTC (rev 38365)
+++ grass/trunk/scripts/r.tileset/r.tileset.py 2009-07-11 11:53:18 UTC (rev 38366)
@@ -37,7 +37,8 @@
#%Module
#% description: Produces tilings of the source projection for use in the destination region and projection.
-#% keywords: raster, tiling
+#% keywords: tiling
#%End
#%flag
#% key: g
Modified: grass/trunk/scripts/v.centroids/v.centroids.py
--- grass/trunk/scripts/v.centroids/v.centroids.py 2009-07-11 09:30:52 UTC (rev 38365)
+++ grass/trunk/scripts/v.centroids/v.centroids.py 2009-07-11 11:53:18 UTC (rev 38366)
@@ -13,7 +13,9 @@
#%Module
#% description: Adds missing centroids to closed boundaries.
-#% keywords: vector, centroid, area
+#% keywords: vector
+#% keywords: centroid
+#% keywords: area
#%End
#%option
Modified: grass/trunk/scripts/v.colors/v.colors.py
--- grass/trunk/scripts/v.colors/v.colors.py 2009-07-11 09:30:52 UTC (rev 38365)
+++ grass/trunk/scripts/v.colors/v.colors.py 2009-07-11 11:53:18 UTC (rev 38366)
@@ -17,7 +17,8 @@
#%Module
#% description: Set color rules for features in a vector using a numeric attribute column.
-#% keywords: vector, color table
#%End
#% option
#% key: map
Modified: grass/trunk/scripts/v.convert.all/v.convert.all.py
--- grass/trunk/scripts/v.convert.all/v.convert.all.py 2009-07-11 09:30:52 UTC (rev 38365)
+++ grass/trunk/scripts/v.convert.all/v.convert.all.py 2009-07-11 11:53:18 UTC (rev 38366)
@@ -16,7 +16,8 @@
#%Module
#% description: Convert all old GRASS < Ver5.7 vector maps in current mapset to current format
-#% keywords: vector, import
#%end
import sys
Modified: grass/trunk/scripts/v.db.addcol/v.db.addcol.py
--- grass/trunk/scripts/v.db.addcol/v.db.addcol.py 2009-07-11 09:30:52 UTC (rev 38365)
+++ grass/trunk/scripts/v.db.addcol/v.db.addcol.py 2009-07-11 11:53:18 UTC (rev 38366)
@@ -18,7 +18,9 @@
#%Module
#% description: Adds one or more columns to the attribute table connected to a given vector map.
-#% keywords: vector, database, attribute table
#%End
#%option
Modified: grass/trunk/scripts/v.db.addtable/v.db.addtable.py
--- grass/trunk/scripts/v.db.addtable/v.db.addtable.py 2009-07-11 09:30:52 UTC (rev 38365)
+++ grass/trunk/scripts/v.db.addtable/v.db.addtable.py 2009-07-11 11:53:18 UTC (rev 38366)
@@ -16,7 +16,9 @@
#%Module
#% description: Creates and adds a new attribute table to a given layer of an existing vector map.
#%End
#%option
#% key: map
Modified: grass/trunk/scripts/v.db.dropcolumn/v.db.dropcolumn.py
--- grass/trunk/scripts/v.db.dropcolumn/v.db.dropcolumn.py 2009-07-11 09:30:52 UTC (rev 38365)
+++ grass/trunk/scripts/v.db.dropcolumn/v.db.dropcolumn.py 2009-07-11 11:53:18 UTC (rev 38366)
@@ -20,7 +20,9 @@
#%Module
#% description: Drops a column from the attribute table connected to a given vector map.
#%End
#%option
Modified: grass/trunk/scripts/v.db.droptable/v.db.droptable.py
--- grass/trunk/scripts/v.db.droptable/v.db.droptable.py 2009-07-11 09:30:52 UTC (rev 38365)
+++ grass/trunk/scripts/v.db.droptable/v.db.droptable.py 2009-07-11 11:53:18 UTC (rev 38366)
@@ -17,7 +17,9 @@
#%Module
#% description: Removes existing attribute table of a vector map.
#%End
#%flag
#% key: f
Modified: grass/trunk/scripts/v.db.join/v.db.join.py
--- grass/trunk/scripts/v.db.join/v.db.join.py 2009-07-11 09:30:52 UTC (rev 38365)
+++ grass/trunk/scripts/v.db.join/v.db.join.py 2009-07-11 11:53:18 UTC (rev 38366)
@@ -16,7 +16,9 @@
#%Module
#% description: Allows to join a table to a vector map table.
#%End
#%option
Modified: grass/trunk/scripts/v.db.reconnect.all/v.db.reconnect.all.py
--- grass/trunk/scripts/v.db.reconnect.all/v.db.reconnect.all.py 2009-07-11 09:30:52 UTC (rev 38365)
+++ grass/trunk/scripts/v.db.reconnect.all/v.db.reconnect.all.py 2009-07-11 11:53:18 UTC (rev 38366)
@@ -15,7 +15,9 @@
#%Module
#% description: Reconnects vectors to a new database.
#%End
#%option
#% key: old_database
Modified: grass/trunk/scripts/v.db.renamecolumn/v.db.renamecolumn.py
--- grass/trunk/scripts/v.db.renamecolumn/v.db.renamecolumn.py 2009-07-11 09:30:52 UTC (rev 38365)
+++ grass/trunk/scripts/v.db.renamecolumn/v.db.renamecolumn.py 2009-07-11 11:53:18 UTC (rev 38366)
@@ -22,7 +22,9 @@
#%Module
#% description: Renames a column in the attribute table connected to a given vector map.
#%End
#%option
#% key: map
Modified: grass/trunk/scripts/v.db.univar/v.db.univar.py
--- grass/trunk/scripts/v.db.univar/v.db.univar.py 2009-07-11 09:30:52 UTC (rev 38365)
+++ grass/trunk/scripts/v.db.univar/v.db.univar.py 2009-07-11 11:53:18 UTC (rev 38366)
@@ -17,7 +17,8 @@
#%Module
#% description: Calculates univariate statistics on selected table column for a GRASS vector map.
-#% keywords: vector, statistics
#%End
#%flag
#% key: e
Modified: grass/trunk/scripts/v.db.update/v.db.update.py
--- grass/trunk/scripts/v.db.update/v.db.update.py 2009-07-11 09:30:52 UTC (rev 38365)
+++ grass/trunk/scripts/v.db.update/v.db.update.py 2009-07-11 11:53:18 UTC (rev 38366)
@@ -17,7 +17,9 @@
#%Module
#% description: Allows to update a column in the attribute table connected to a vector map.
#%End
#%option
#% key: map
Modified: grass/trunk/scripts/v.dissolve/v.dissolve.py
--- grass/trunk/scripts/v.dissolve/v.dissolve.py 2009-07-11 09:30:52 UTC (rev 38365)
+++ grass/trunk/scripts/v.dissolve/v.dissolve.py 2009-07-11 11:53:18 UTC (rev 38366)
@@ -17,7 +17,9 @@
#%Module
#% description: Dissolves boundaries between adjacent areas sharing a common category number or attribute.
-#% keywords: vector, area, dissolve
+#% keywords: area
+#% keywords: dissolve
#%End
#%option
#% key: input
Modified: grass/trunk/scripts/v.in.e00/v.in.e00.py
--- grass/trunk/scripts/v.in.e00/v.in.e00.py 2009-07-11 09:30:52 UTC (rev 38365)
+++ grass/trunk/scripts/v.in.e00/v.in.e00.py 2009-07-11 11:53:18 UTC (rev 38366)
@@ -23,7 +23,8 @@
#%Module
#% description: Import E00 file into a vector map.
#%End
#%flag
#% key: v
Modified: grass/trunk/scripts/v.in.geonames/v.in.geonames.py
--- grass/trunk/scripts/v.in.geonames/v.in.geonames.py 2009-07-11 09:30:52 UTC (rev 38365)
+++ grass/trunk/scripts/v.in.geonames/v.in.geonames.py 2009-07-11 11:53:18 UTC (rev 38366)
@@ -24,7 +24,9 @@
#%Module
#% description: Imports geonames.org country files into a GRASS vector points map.
-#% keywords: vector, import, gazetteer
+#% keywords: gazetteer
#%End
#%option
#% key: input
Modified: grass/trunk/scripts/v.in.gns/v.in.gns.py
--- grass/trunk/scripts/v.in.gns/v.in.gns.py 2009-07-11 09:30:52 UTC (rev 38365)
+++ grass/trunk/scripts/v.in.gns/v.in.gns.py 2009-07-11 11:53:18 UTC (rev 38366)
@@ -26,7 +26,9 @@
#%Module
#% description: Imports US-NGA GEOnet Names Server (GNS) country files into a GRASS vector points map.
#%End
#%option
#% key: file
Modified: grass/trunk/scripts/v.in.mapgen/v.in.mapgen.py
--- grass/trunk/scripts/v.in.mapgen/v.in.mapgen.py 2009-07-11 09:30:52 UTC (rev 38365)
+++ grass/trunk/scripts/v.in.mapgen/v.in.mapgen.py 2009-07-11 11:53:18 UTC (rev 38366)
@@ -27,7 +27,8 @@
#%Module
#% description: Import Mapgen or Matlab vector maps into GRASS.
#%End
#%flag
#% key: f
Modified: grass/trunk/scripts/v.in.sites.all/v.in.sites.all.py
--- grass/trunk/scripts/v.in.sites.all/v.in.sites.all.py 2009-07-11 09:30:52 UTC (rev 38365)
+++ grass/trunk/scripts/v.in.sites.all/v.in.sites.all.py 2009-07-11 11:53:18 UTC (rev 38366)
@@ -15,7 +15,9 @@
#%Module
#% description: Converts all old GRASS < Ver5.7 sites maps in current mapset to vector maps.
-#% keywords: sites, vector, import
+#% keywords: sites
#%End
import sys
Modified: grass/trunk/scripts/v.out.gps/v.out.gps.py
--- grass/trunk/scripts/v.out.gps/v.out.gps.py 2009-07-11 09:30:52 UTC (rev 38365)
+++ grass/trunk/scripts/v.out.gps/v.out.gps.py 2009-07-11 11:53:18 UTC (rev 38366)
@@ -34,7 +34,9 @@
#%Module
#% description: Exports a vector map to a GPS receiver or file format supported by GpsBabel.
-#% keywords: vector, export, GPS
+#% keywords: GPS
#%End
#%flag
#% key: w
Modified: grass/trunk/scripts/v.rast.stats/v.rast.stats.py
--- grass/trunk/scripts/v.rast.stats/v.rast.stats.py 2009-07-11 09:30:52 UTC (rev 38365)
+++ grass/trunk/scripts/v.rast.stats/v.rast.stats.py 2009-07-11 11:53:18 UTC (rev 38366)
@@ -17,7 +17,9 @@
#%Module
#% description: Calculates univariate statistics from a GRASS raster map based on vector polygons and uploads statistics to new attribute columns.
-#% keywords: vector, raster, statistics
#%End
#%flag
#% key: c
Modified: grass/trunk/scripts/v.report/v.report.py
--- grass/trunk/scripts/v.report/v.report.py 2009-07-11 09:30:52 UTC (rev 38365)
+++ grass/trunk/scripts/v.report/v.report.py 2009-07-11 11:53:18 UTC (rev 38366)
@@ -15,7 +15,9 @@
#%Module
#% description: Reports geometry statistics for vectors.
-#% keywords: vector, report, statistics
+#% keywords: report
#%End
#%Flag
#% key: r
Modified: grass/trunk/scripts/v.what.vect/v.what.vect.py
--- grass/trunk/scripts/v.what.vect/v.what.vect.py 2009-07-11 09:30:52 UTC (rev 38365)
+++ grass/trunk/scripts/v.what.vect/v.what.vect.py 2009-07-11 11:53:18 UTC (rev 38366)
@@ -15,7 +15,9 @@
#%Module
#% description: Uploads vector values at positions of vector points to the table.
#%End
#%option
