[GRASS-SVN] r38380 - grass/trunk/lib/vector/diglib
svn_grass at osgeo.org
Mon Jul 13 02:57:23 EDT 2009
Author: mmetz
Date: 2009-07-13 02:57:23 -0400 (Mon, 13 Jul 2009)
New Revision: 38380
grass/trunk/lib/vector/diglib/poly.c
topo building algorithm update
Modified: grass/trunk/lib/vector/diglib/poly.c
--- grass/trunk/lib/vector/diglib/poly.c 2009-07-13 06:51:45 UTC (rev 38379)
+++ grass/trunk/lib/vector/diglib/poly.c 2009-07-13 06:57:23 UTC (rev 38380)
@@ -120,6 +120,11 @@
tot_area += y[i] * (x[i + 1] - x[i - 1]);
+ /* tot_area = 0.0;
+ for (i = 1; i < Points->n_points; i++) {
+ tot_area += (x[i] - x[i - 1]) * (y[i] + y[i - 1]);
*totalarea = 0.5 * tot_area;
return (0);
@@ -127,7 +132,9 @@
* find orientation of polygon (clockwise or counterclockwise)
- * faster than signed area for > 4 vertices
+ * in theory faster than signed area for > 4 vertices, but is not robust
+ * against special cases
+ * use dog_find_area_poly instead
* points must be closed polygon with first point = last point
@@ -135,8 +142,8 @@
* (C) 2000 softSurfer (www.softsurfer.com)
* (C) 2006 Refractions Research Inc.
- * and now copes with partially collapsed boundaries
- * the code is long but fast
+ * copes with partially collapsed boundaries and 8-shaped isles
+ * the code is long and not much faster than dig_find_area_poly
* it can be written much shorter, but that comes with speed penalty
* returns orientation, positive for CW, negative for CCW, 0 for degenerate
@@ -157,6 +164,11 @@
else if (y[pnext] == y[pcur]) { /* just as high */
if (x[pnext] > x[pcur]) /* but to the right */
continue;
+ if (x[pnext] == x[pcur]) { /* duplicate point, self-intersecting polygon ? */
+ pprev = (pcur == 0 ? lastpoint - 1 : pcur - 1);
+ if (y[pnext - 1] < y[pprev])
+ continue;
pcur = pnext; /* a new leftmost highest vertex */
@@ -198,6 +210,11 @@
if (x[pnext] < x[pcur]) /* but to the left */
continue;
+ continue;
pcur = pnext; /* a new rightmost highest vertex */
@@ -239,6 +256,11 @@
else if (y[pnext] == y[pcur]) { /* just as low */
continue;
+ if (y[pnext - 1] > y[pprev])
+ continue;
pcur = pnext; /* a new leftmost lowest vertex */
@@ -280,6 +302,11 @@
continue;
+ continue;
pcur = pnext; /* a new rightmost lowest vertex */
