[GRASS-SVN] r38390 - grass/trunk/vector/v.in.ogr
svn_grass at osgeo.org
Mon Jul 13 08:33:22 EDT 2009
Author: mmetz
Date: 2009-07-13 08:33:22 -0400 (Mon, 13 Jul 2009)
New Revision: 38390
grass/trunk/vector/v.in.ogr/main.c
spatial index update
Modified: grass/trunk/vector/v.in.ogr/main.c
--- grass/trunk/vector/v.in.ogr/main.c 2009-07-13 12:32:45 UTC (rev 38389)
+++ grass/trunk/vector/v.in.ogr/main.c 2009-07-13 12:33:22 UTC (rev 38390)
@@ -1018,7 +1018,7 @@
G_debug(3, "%d centroids/areas", ncentr);
Centr = (CENTR *) G_calloc(ncentr + 1, sizeof(CENTR));
- Vect_spatial_index_init(&si);
+ Vect_spatial_index_init(&si, 0);
for (centr = 1; centr <= ncentr; centr++) {
Centr[centr].valid = 0;
Centr[centr].cats = Vect_new_cats_struct();
@@ -1067,6 +1067,8 @@
total_area = overlap_area = nocat_area = 0.0;
double area;
+ G_percent(centr, ncentr, 2);
area = Vect_get_area_area(&Tmp, centr);
total_area += area;
@@ -1098,6 +1100,8 @@
if (Centr)
G_free(Centr);
+ Vect_spatial_index_destroy(&si);
/* G_message("%s", separator); */
/* Vect_build_partial(&Map, GV_BUILD_NONE); */
@@ -1145,11 +1149,11 @@
/* Copy temporary vector to output vector */
Vect_copy_map_lines(&Tmp, &Map);
+ Vect_close(&Tmp);
+ Vect_delete(tempvect);
Vect_build(&Map);
Vect_close(&Map);
- Vect_close(&Tmp);
- Vect_delete(tempvect);
/* Extend current window based on dataset. */
