[GRASS-SVN] r38393 - grass-addons/vector/v.krige
svn_grass at osgeo.org
Mon Jul 13 11:00:42 EDT 2009
Author: aghisla
Date: 2009-07-13 11:00:42 -0400 (Mon, 13 Jul 2009)
New Revision: 38393
grass-addons/vector/v.krige/v.krige.py
added Refresh button for list of layers, cleanup, moved grass.region() into Controller::CreateGrid() to allow resolution change after interface load
Modified: grass-addons/vector/v.krige/v.krige.py
--- grass-addons/vector/v.krige/v.krige.py 2009-07-13 13:18:02 UTC (rev 38392)
+++ grass-addons/vector/v.krige/v.krige.py 2009-07-13 15:00:42 UTC (rev 38393)
@@ -133,7 +133,6 @@
#global variables
gisenv = grass.gisenv()
-Region = grass.region()
# model list should come from gstat::vgm(), hardwired here.
ModelList = ['Exp','Sph','Gau','Mat','Lin']
@@ -146,6 +145,7 @@
return robjects.r.readVECT6(map, type= 'point')
def CreateGrid(self, inputdata):
+ Region = grass.region()
Grid = robjects.r.gmeta2grd()
GridPredicted = robjects.r.SpatialGridDataFrame(Grid,
data=robjects.r['data.frame']
@@ -229,7 +229,7 @@
InputBoxSizer = wx.StaticBoxSizer(wx.StaticBox(self, id=wx.ID_ANY, label=_("Input Data")),
orient=wx.HORIZONTAL)
- flexSizer = wx.FlexGridSizer(cols=2, hgap=5, vgap=5)
+ flexSizer = wx.FlexGridSizer(cols=3, hgap=5, vgap=5)
flexSizer.AddGrowableCol(1)
flexSizer.Add(item = wx.StaticText(self, id=wx.ID_ANY, label=_("Point dataset:")),
@@ -238,7 +238,12 @@
ftype = 'points',
updateOnPopup = False)
self.InputDataMap.SetFocus()
- flexSizer.Add(item = self.InputDataMap)
+ flexSizer.Add(item = self.InputDataMap, flag = wx.ALIGN_CENTER_VERTICAL)
+ RefreshButton = wx.Button(self, id=wx.ID_REFRESH)
+ RefreshButton.Bind(wx.EVT_BUTTON, self.OnButtonRefresh)
+ flexSizer.Add(item = RefreshButton, flag = wx.ALIGN_CENTER_VERTICAL)
flexSizer.Add(item = wx.StaticText(self, id=wx.ID_ANY, label=_("Column:")),
flag=wx.ALIGN_CENTER_VERTICAL)
self.InputDataColumn = gselect.ColumnSelect(self, id=wx.ID_ANY)
@@ -306,6 +311,9 @@
Sizer.Add(OutputSizer, proportion=0, flag=wx.EXPAND | wx.ALL, border=self.border)
Sizer.Add(ButtonSizer, proportion=0, flag=wx.ALIGN_RIGHT | wx.ALL, border=self.border)
self.SetSizerAndFit(Sizer)
+ # last action of __init__: update imput data list.
+ # it's performed in the few seconds gap while user examines interface before clicking anything.
self.InputDataMap.GetElementList()
def CreatePage(self, package):
@@ -316,6 +324,15 @@
getattr(self, "RBook"+package+"Panel")
self.RPackagesBook.AddPage(page=getattr(self, "RBook"+package+"Panel"), text=package)
+ def OnButtonRefresh(self, event):
+ """ Forces refresh of list of available layers. """
+ self.InputDataMap.GetElementList()
+ def OnCloseWindow(self, event):
+ """ Cancel button pressed"""
+ self.parent.Close()
+ event.Skip()
def OnInputDataChanged(self, event):
""" Refreshes list of columns and fills output map name TextCtrl """
MapName = event.GetString()
@@ -343,11 +360,6 @@
nugget = SelectedPanel.NuggetCtrl.GetValue(),
range = SelectedPanel.RangeCtrl.GetValue(),
logger = self.parent.log)
- def OnCloseWindow(self, event):
- """ Cancel button pressed"""
- self.parent.Close()
- event.Skip()
class KrigingModule(wx.Frame):
""" Kriging module for GRASS GIS. Depends on R and its packages gstat and geoR. """
@@ -433,7 +445,6 @@
getattr(self, n+"Ctrl").Enable(not event.IsChecked())
#@FIXME: was for n in self.ParametersSizer.GetChildren(): n.Enable(False) but doesn't work
class RBookgeoRPanel(RBookPanel):
""" Subclass of RBookPanel, with specific geoR options and kriging functions. """
def __init__(self, parent, *args, **kwargs):
