[GRASS-SVN] r38409 - grass-addons/vector/v.strahler
svn_grass at osgeo.org
Tue Jul 14 04:33:20 EDT 2009
Author: hamish
Date: 2009-07-14 04:33:19 -0400 (Tue, 14 Jul 2009)
New Revision: 38409
grass-addons/vector/v.strahler/v.mainchannel
some cleanup
Modified: grass-addons/vector/v.strahler/v.mainchannel
--- grass-addons/vector/v.strahler/v.mainchannel 2009-07-14 05:59:49 UTC (rev 38408)
+++ grass-addons/vector/v.strahler/v.mainchannel 2009-07-14 08:33:19 UTC (rev 38409)
@@ -1,6 +1,6 @@
#!/bin/sh
# MODULE: v.mainchannel
# AUTHOR(S): Annalisa Minelli, Ivan Marchesini
@@ -11,6 +11,7 @@
# License (>=v2). Read the file COPYING that comes with GRASS
# for details.
#%Module
#% description: Find the main channel of a vector stream network (useful to compare with a network ordered by Horton-Strahler)
#% keywords: strahler, main_channel, vector
@@ -55,7 +56,13 @@
#% description: Name of the main_channel vector map
#% required : yes
#%END
+#%flag
+#% key: d
+#% label: Display results
+#% description: Plot the result of elaboration in relation to the strahler ordered stream network
+#%end
if [ -z "$GISBASE" ] ; then
echo "You must be in GRASS GIS to run this program." >&2
exit 1
@@ -65,12 +72,12 @@
exec g.parser "$0" "$@"
fi
-dem=$GIS_OPT_DEM
-xcoor=$GIS_OPT_XCOOR
-ycoor=$GIS_OPT_YCOOR
-cost=$GIS_OPT_COST
-input=$GIS_OPT_INPUT
-output=$GIS_OPT_OUTPUT
+dem="$GIS_OPT_DEM"
+xcoor="$GIS_OPT_XCOOR"
+ycoor="$GIS_OPT_YCOOR"
+cost="$GIS_OPT_COST"
+input="$GIS_OPT_INPUT"
+output="$GIS_OPT_OUTPUT"
### setup enviro vars ###
eval `g.gisenv`
@@ -79,35 +86,64 @@
g.remove vect=end_basin,out_1del,out_1add,out_basin,out_isodistance,out_2,out_2del,out_2points,out_2addp,out_3D,out_path
echo "$xcoor|$ycoor|1" | v.in.ascii out=end_basin
thr=`g.region -p | grep nsres | cut -f2 -d':' | tr -d ' '`
thresh=`echo "$thr*1.5" | bc -l | cut -f1 -d'.'`
+#### setup temporary files
+TMP="`g.tempfile pid=$$`"
+if [ $? -ne 0 ] || [ -z "$TMP" ] ; then
+ g.message -e "Unable to create temporary files"
+ exit 1
+fi
v.category input=$input output=out_1del type=line option=del cat=1 layer=1 step=1
v.category input=out_1del output=out_1add type=line option=add cat=1 layer=1 step=1
-v.net input=out_1add points=end_basin output=out_basin operation=connect alayer=1 nlayer=2 thresh="$thresh"
-v.net.iso input=out_basin output=out_isodistance type=line alayer=1 nlayer=2 ccats=1-99999999 costs=$cost
-v.category input=out_isodistance opt=report -g > temp1
-cat temp1 | grep line | cut -f5 -d ' ' > temp2
-v.extract input=out_isodistance output=out_2 type=line layer=1 new=-1 file=temp2
-v.category input=out_2 output=out_2del type=point,line,boundary,centroid,area option=del cat=1 layer=1 step=1
+v.net input=out_1add points=end_basin output=out_basin operation=connect \
+ alayer=1 nlayer=2 thresh="$thresh"
+v.net.iso input=out_basin output=out_isodistance type=line \
+ alayer=1 nlayer=2 ccats=1-99999999 costs=$cost
+v.category input=out_isodistance opt=report -g > "$TMP.1"
+grep 'line' "$TMP.1" | cut -f5 -d ' ' > "$TMP.2"
+v.extract input=out_isodistance output=out_2 type=line layer=1 new=-1 file="$TMP.2"
+v.category input=out_2 output=out_2del option=del \
+ type=point,line,boundary,centroid,area cat=1 layer=1 step=1
v.net input=out_2del output=out_2points operation=nodes alayer=1 nlayer=2
-v.category input=out_2points output=out_2addp type=point option=add cat=1 layer=2 step=1
+v.category input=out_2points output=out_2addp type=point option=add \
+ cat=1 layer=2 step=1
v.drape input=out_2addp type=point,line rast=$dem method=nearest output=out_3D
-v.db.addtable map=out_3D table=tab_coord layer=2 'columns=cat integer, x double precision, y double precision, z double precision'
+v.db.addtable map=out_3D table=tab_coord layer=2 \
+ 'columns=cat integer, x double precision, y double precision, z double precision'
v.to.db map=out_3D type=point layer=2 qlayer=1 option=coor units=meters 'column=x, y, z'
-v.univar -g map=out_3D type=point column=z layer=2 percentile=90 > temp
-max=`cat temp | grep max | cut -f2 -d'='`
+v.univar -g map=out_3D type=point column=z layer=2 percentile=90 > "$TMP.3"
+max=`cat "$TMP.3" | grep max | cut -f2 -d'='`
db_driver=`db.connect -p | grep driver | cut -f2 -d':'`
db_database=`db.connect -p | grep database | cut -f2 -d':'`
x_max=`db.select -c table=tab_coord database=$db_database driver=$db_driver 'sql=select x from tab_coord where z='$max''`
y_max=`db.select -c table=tab_coord database=$db_databese driver=$db_driver 'sql=select y from tab_coord where z='$max''`
-echo "1 $x_max $y_max $xcoor $ycoor" | v.net.path input=out_isodistance output=$output type=line alayer=1 nlayer=2
-#plot the result of elaboration in relation to the strahler ordered stream network
-d.mon stop=x0
-d.mon start=x0
-d.vect $input display=shape,cat
-d.vect map=$output color=255:0:0 lcolor=0:0:0 fcolor=170:170:170 display=shape type=line icon=basic/x size=5 width=2 layer=1 lsize=8
-d.barscale tcolor=0:0:0 bcolor=255:255:255 at=2,2
+echo "1 $x_max $y_max $xcoor $ycoor" | v.net.path input=out_isodistance \
+ output=$output type=line alayer=1 nlayer=2
+if [ "$GIS_FLAG_DISPLAY" -eq 1 ] ; then
+ #plot the result of elaboration in relation to the strahler ordered stream network
+ #d.mon stop=x0
+ d.mon start=x0
+ d.vect "$input" display=shape,cat
+ d.vect map="$output" color=red lcolor=black fcolor=170:170:170 \
+ display=shape type=line icon=basic/x size=5 width=2 layer=1 lsize=8
+ d.barscale tcolor=black bcolor=white at=2,2
+fi
g.remove vect=end_basin,out_1del,out_1add,out_basin,out_2,out_2del,out_2points,out_2addp,out_3D
+\rm "$TMP" "$TMP".[1-3]
#you can modify the "cost" distances in order to have main channel including the max_ordered channel
Property changes on: grass-addons/vector/v.strahler/v.mainchannel
___________________________________________________________________
Added: svn:mime-type
+ text/x-sh
Added: svn:eol-style
+ native
