[GRASS-SVN] r38423 - grass-addons/vector/v.krige
svn_grass at osgeo.org
Wed Jul 15 08:29:37 EDT 2009
Author: aghisla
Date: 2009-07-15 08:29:37 -0400 (Wed, 15 Jul 2009)
New Revision: 38423
grass-addons/vector/v.krige/v.krige.py
redirected output into command output tab - adapted Controller::Run interface to CLI's.
Modified: grass-addons/vector/v.krige/v.krige.py
--- grass-addons/vector/v.krige/v.krige.py 2009-07-15 11:34:56 UTC (rev 38422)
+++ grass-addons/vector/v.krige/v.krige.py 2009-07-15 12:29:37 UTC (rev 38423)
@@ -159,8 +159,8 @@
Formula = robjects.r['as.formula'](robjects.r.paste(column, "~ 1"))
return Formula
- def FitVariogram(self, formula, inputdata, model, autofit, sill=0, nugget=0, range=0):
- if autofit:
+ def FitVariogram(self, formula, inputdata, model = '', sill=0, nugget=0, range=0):
+ if model is '':
robjects.r.require("automap")
VariogramModel = robjects.r.autofitVariogram(formula, inputdata)
return VariogramModel.r['var_model'][0]
@@ -185,7 +185,7 @@
def ExportMap(self, map, column, name, overwrite):
robjects.r.writeRAST6(map, vname = name, zcol = column, overwrite = overwrite)
- def Run(self, input, column, output, package, sill, nugget, range, logger, overwrite, model = None, **kwargs):
+ def Run(self, input, column, output, package, sill, nugget, range, logger, overwrite, model = '', **kwargs):
""" Wrapper for all functions above. """
# Get data and create grid
logger.message(_("Importing data..."))
@@ -198,7 +198,6 @@
Formula = self.ComposeFormula(column)
Variogram = self.FitVariogram(Formula,
InputData,
- autofit = model is None,
model = model,
sill = sill,
nugget = nugget,
@@ -310,7 +309,7 @@
# Main Sizer. Add each child sizer as soon as it is ready.
Sizer = wx.BoxSizer(wx.VERTICAL)
Sizer.Add(InputBoxSizer, proportion=0, flag=wx.EXPAND | wx.ALL, border=self.border)
- Sizer.Add(KrigingSizer, proportion=0, flag=wx.EXPAND | wx.ALL, border=self.border)
+ Sizer.Add(KrigingSizer, proportion=1, flag=wx.EXPAND | wx.ALL, border=self.border)
Sizer.Add(OutputSizer, proportion=0, flag=wx.EXPAND | wx.ALL, border=self.border)
Sizer.Add(ButtonSizer, proportion=0, flag=wx.ALIGN_RIGHT | wx.ALL, border=self.border)
self.SetSizerAndFit(Sizer)
@@ -353,15 +352,30 @@
# pages, but only the selected one will be executed when Run is pressed.
SelectedPanel = self.RPackagesBook.GetCurrentPage()
- # shift focus on Command output, if needed
- if self.RPackagesBook.GetSelection() != self.goutputId:
- self.RPackagesBook.SetSelection(self.goutputId)
# mount command string as it would have been written on CLI
- command = "v.krige.py" + " input=" + self.InputDataMap.GetValue()
+ command = ["v.krige.py", "input=" + self.InputDataMap.GetValue(),
+ "column=" + self.InputDataColumn.GetValue(),
+ "output=" + self.OutputMapName.GetValue(),
+ "package=" + '%s' % self.RPackagesBook.GetPageText(self.RPackagesBook.GetSelection()),
+ "sill=" + '%s' % SelectedPanel.SillCtrl.GetValue(),
+ "nugget=" + '%s' % SelectedPanel.NuggetCtrl.GetValue(),
+ "range=" + '%s' % SelectedPanel.RangeCtrl.GetValue()]
+ if not SelectedPanel.VariogramCheckBox.IsChecked():
+ command.append("model=" + '%s' % SelectedPanel.ModelChoicebox.GetStringSelection().split(" ")[0])
+ if self.OverwriteCheckBox.IsChecked():
+ command.append("--overwrite")
+ print command
# give it to the output console
- self.goutput.RunCmd(command)
+ self.goutput.RunCmd(command, switchPage = True)
+ #self.goutput.RunCmd(['v.krige.py',
+ # self.InputDataMap.GetValue(),
+ # self.InputDataColumn.GetValue()],
+ # switchPage=True)
## TEST - remove before flight
- self.goutput.RunCmd(['g.region', '-p'], switchPage = True)
+ #self.goutput.RunCmd(['g.region', '-p'], switchPage = True)
## old function to port into command =
#self.Controller.Run(input = self.InputDataMap.GetValue(),
# column = self.InputDataColumn.GetValue(),
@@ -510,7 +524,6 @@
output = options['output'],
overwrite = os.getenv("GRASS_OVERWRITE") == 1,
package = options['package'],
- autofit = options['model'] is '',
model = options['model'],
sill = options['sill'],
nugget = options['nugget'],
