[GRASS-SVN] r38438 - grass-addons/vector/v.krige
svn_grass at osgeo.org
Thu Jul 16 11:45:46 EDT 2009
Author: aghisla
Date: 2009-07-16 11:45:46 -0400 (Thu, 16 Jul 2009)
New Revision: 38438
grass-addons/vector/v.krige/v.krige.py
hidden widgets for block size parameter (block kriging) until I get block kriging run
Modified: grass-addons/vector/v.krige/v.krige.py
--- grass-addons/vector/v.krige/v.krige.py 2009-07-16 14:52:49 UTC (rev 38437)
+++ grass-addons/vector/v.krige/v.krige.py 2009-07-16 15:45:46 UTC (rev 38438)
@@ -61,6 +61,14 @@
#% required: no
#%end
#%option
+#% key: block
+#% type: integer
+#% multiple: no
+#% label: Block size (square block)
+#% description: Block size. Used by block kriging.
+#% required: no
+#%end
+#%option
#% key: range
#% type: integer
#% label: Range value
@@ -154,9 +162,17 @@
proj4string=robjects.r.CRS(robjects.r.proj4string(inputdata)))
return GridPredicted
- def ComposeFormula(self, column):
+ def ComposeFormula(self, column, block, inputdata):
# will change when the formula will need to be more complex. Not yet.
- Formula = robjects.r['as.formula'](robjects.r.paste(column, "~ 1"))
+ Formula = robjects.RFormula('y ~ x')
+ Env = Formula.getenvironment()
+ Env['y'] = column
+ if block is not None:
+ #@FIXME does not catch what the formula wants. Nor do I.
+ #Env['x'] = 'x+y'
+ pass
+ else:
+ Env['x'] = 1
return Formula
def FitVariogram(self, formula, inputdata, model = '', sill=0, nugget=0, range=0):
@@ -179,7 +195,7 @@
def DoKriging(self, formula, inputdata, grid, model, block):
DottedParams = {'debug.level': -1} # let krige() print percentage status
- if block:
DottedParams['block'] = block
KrigingResult = robjects.r.krige(formula, inputdata, grid, model, **DottedParams)
return KrigingResult
@@ -187,7 +203,8 @@
def ExportMap(self, map, column, name, overwrite):
robjects.r.writeRAST6(map, vname = name, zcol = column, overwrite = overwrite)
- def Run(self, input, column, output, package, sill, nugget, range, logger, overwrite, model = '', **kwargs):
+ def Run(self, input, column, output, package, sill, nugget, range, logger, \
+ overwrite, model = '', block = None, **kwargs):
""" Wrapper for all functions above. """
# Get data and create grid
logger.message(_("Importing data..."))
@@ -197,7 +214,7 @@
# Fit Variogram
logger.message(_("Fitting variogram..."))
- Formula = self.ComposeFormula(column)
+ Formula = self.ComposeFormula(column, block, InputData)
Variogram = self.FitVariogram(Formula,
InputData,
model = model,
@@ -208,7 +225,7 @@
# Krige
logger.message(_("Kriging..."))
- KrigingResult = self.DoKriging(Formula, InputData, GridPredicted, Variogram)
+ KrigingResult = self.DoKriging(Formula, InputData, GridPredicted, Variogram, block)
logger.message(_("Kriging performed."))
# Export map
@@ -402,7 +419,7 @@
def __init__(self, parent, *args, **kwargs):
wx.Panel.__init__(self, parent, *args, **kwargs)
- KrigingList = ["Ordinary kriging", "Block kriging"]#, "Universal kriging"] #@FIXME: i18n on the list?
+ KrigingList = ["Ordinary kriging"]#, "Block kriging", "Universal kriging"] #@FIXME: i18n on the list?
KrigingRadioBox = wx.RadioBox(self, id=wx.ID_ANY, label=_("Kriging techniques"),
pos=wx.DefaultPosition, size=wx.DefaultSize,
choices=KrigingList, majorDimension=1, style=wx.RA_SPECIFY_COLS)
@@ -424,12 +441,12 @@
#self.ParametersSizer.Add(wx.Button(self, id=wx.ID_ANY, label=_("Interactive variogram fit")))
# block kriging parameters. Size.
- BlockLabel = wx.StaticText(self, id= wx.ID_ANY, label = _("Block size:"))
- self.BlockSpinBox = wx.SpinCtrl(self, id = wx.ID_ANY, max=sys.maxint)
- self.BlockSpinBox.Enable(False) # default choice is Ordinary kriging
+ #BlockLabel = wx.StaticText(self, id= wx.ID_ANY, label = _("Block size:"))
+ #self.BlockSpinBox = wx.SpinCtrl(self, id = wx.ID_ANY, min=1, max=sys.maxint)
+ #self.BlockSpinBox.Enable(False) # default choice is Ordinary kriging
- self.ParametersSizer.Add(BlockLabel, flag=wx.EXPAND | wx.ALIGN_CENTER_VERTICAL | wx.ALL, border=3)
- self.ParametersSizer.Add(self.BlockSpinBox, flag=wx.EXPAND | wx.ALIGN_CENTER_VERTICAL | wx.ALL, border=3)
+ #self.ParametersSizer.Add(BlockLabel, flag=wx.EXPAND | wx.ALIGN_CENTER_VERTICAL | wx.ALL, border=3)
+ #self.ParametersSizer.Add(self.BlockSpinBox, flag=wx.EXPAND | wx.ALIGN_CENTER_VERTICAL | wx.ALL, border=3)
self.VariogramSizer.Add(self.ParametersSizer, proportion=0, flag=wx.EXPAND | wx.ALL, border=3)
@@ -519,6 +536,9 @@
robjects.r.require("automap")
except ImportError, e:
grass.fatal(_("R package automap is missing, no variogram autofit available."))
+ if options['block'] is not '':
+ grass.fatal(_("Block kriging implementation in progress. Re-run without block parameter."))
controller = Controller()
controller.Run(input = options['input'],
