[GRASS-SVN] r38443 - grass/trunk/general/g.proj
svn_grass at osgeo.org
Thu Jul 16 17:16:28 EDT 2009
Author: martinl
Date: 2009-07-16 17:16:28 -0400 (Thu, 16 Jul 2009)
New Revision: 38443
grass/trunk/general/g.proj/main.c
g.proj: cosmetics in guisection, i18n
(merge from devbr6, r38441)
Modified: grass/trunk/general/g.proj/main.c
--- grass/trunk/general/g.proj/main.c 2009-07-16 21:03:05 UTC (rev 38442)
+++ grass/trunk/general/g.proj/main.c 2009-07-16 21:16:28 UTC (rev 38443)
@@ -58,36 +58,39 @@
module = G_define_module();
G_add_keyword(_("general"));
- module->description =
+ G_add_keyword(_("projection"));
#ifdef HAVE_OGR
+ module->label =
_("Converts co-ordinate system descriptions (i.e. projection "
- "information) between various formats (including GRASS format). "
- "Can also be used to create GRASS locations.");
+ "information) between various formats (including GRASS format).");
+ module->description =
+ _("Can also be used to create GRASS locations.");
#else
_("Prints and manipulates GRASS projection information files.");
#endif
printinfo = G_define_flag();
printinfo->key = 'p';
- printinfo->guisection = "Printed_Output";
+ printinfo->guisection = _("Print");
printinfo->description =
_("Print projection information (in conventional GRASS format)");
datuminfo = G_define_flag();
datuminfo->key = 'd';
- datuminfo->guisection = "Printed_Output";
+ datuminfo->guisection = _("Print");
datuminfo->description =
_("Verify datum information and print transformation parameters");
printproj4 = G_define_flag();
printproj4->key = 'j';
- printproj4->guisection = "Printed_Output";
+ printproj4->guisection = _("Print");
printproj4->description =
_("Print projection information in PROJ.4 format");
dontprettify = G_define_flag();
dontprettify->key = 'f';
- dontprettify->guisection = "Printed_Output";
+ dontprettify->guisection = _("Print");
dontprettify->description =
_("Print 'flat' output with no linebreaks (applies to "
#ifdef HAVE_OGR
@@ -98,21 +101,21 @@
#ifdef HAVE_OGR
printwkt = G_define_flag();
printwkt->key = 'w';
- printwkt->guisection = "Printed_Output";
+ printwkt->guisection = _("Print");
printwkt->description = _("Print projection information in WKT format");
esristyle = G_define_flag();
esristyle->key = 'e';
- esristyle->guisection = "Printed_Output";
+ esristyle->guisection = _("Print");
esristyle->description =
_("Use ESRI-style format (applies to WKT output only)");
ingeo = G_define_option();
ingeo->key = "georef";
ingeo->type = TYPE_STRING;
ingeo->key_desc = "file";
ingeo->required = NO;
- ingeo->guisection = "Input";
+ ingeo->guisection = _("Input");
ingeo->description = _("Georeferenced data file to read projection "
"information from");
@@ -121,7 +124,7 @@
inwkt->type = TYPE_STRING;
inwkt->key_desc = "file";
inwkt->required = NO;
- inwkt->guisection = "Input";
+ inwkt->guisection = _("Input");
inwkt->description = _("ASCII file containing a WKT projection "
"description (- for stdin)");
@@ -130,7 +133,7 @@
inproj4->type = TYPE_STRING;
inproj4->key_desc = "params";
inproj4->required = NO;
- inproj4->guisection = "Input";
+ inproj4->guisection = _("Input");
inproj4->description = _("PROJ.4 projection description (- for stdin)");
inepsg = G_define_option();
@@ -138,7 +141,7 @@
inepsg->type = TYPE_INTEGER;
inepsg->required = NO;
inepsg->options = "1-1000000";
- inepsg->guisection = "Input";
+ inepsg->guisection = _("Input");
inepsg->description = _("EPSG projection code");
#endif
@@ -148,21 +151,21 @@
dtrans->required = NO;
dtrans->options = "-1-100";
dtrans->answer = "0";
- dtrans->guisection = "Datum_Trans";
- dtrans->description =
- _("Index number of datum transform parameters, \"0\" "
- "for unspecified or \"-1\" to list and exit");
+ dtrans->guisection = _("Datum");
+ dtrans->label =
+ _("Index number of datum transform parameters");
+ dtrans->description = ("\"0\" for unspecified or \"-1\" to list and exit");
forcedatumtrans = G_define_flag();
forcedatumtrans->key = 't';
- forcedatumtrans->guisection = "Datum_Trans";
+ forcedatumtrans->guisection = _("Datum");
forcedatumtrans->description =
_("Force override of datum transformation information in input "
"co-ordinate system");
create = G_define_flag();
create->key = 'c';
- create->guisection = "Create/Edit_Locations";
+ create->guisection = _("Create/Edit");
create->description = _("Create new projection files (modifies current "
"location unless 'location' option specified)");
@@ -171,9 +174,9 @@
location->type = TYPE_STRING;
location->key_desc = "name";
location->required = NO;
- location->guisection = "Create/Edit_Locations";
+ location->guisection = _("Create/Edit");
location->description = _("Name of new location to create");
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
