[GRASS-SVN] r38447 - grass-addons/vector/v.krige
svn_grass at osgeo.org
Fri Jul 17 09:14:05 EDT 2009
Author: aghisla
Date: 2009-07-17 09:14:05 -0400 (Fri, 17 Jul 2009)
New Revision: 38447
grass-addons/vector/v.krige/v.krige.py
added block kriging option
Modified: grass-addons/vector/v.krige/v.krige.py
--- grass-addons/vector/v.krige/v.krige.py 2009-07-17 04:37:09 UTC (rev 38446)
+++ grass-addons/vector/v.krige/v.krige.py 2009-07-17 13:14:05 UTC (rev 38447)
@@ -107,6 +107,7 @@
# rpy2
try:
+ import rpy2.rinterface as rinterface
import rpy2.robjects as robjects
haveRpy2 = True
except ImportError:
@@ -151,29 +152,44 @@
""" Executes analysis. For the moment, only with gstat functions."""
def ImportMap(self, map):
- return robjects.r.readVECT6(map, type= 'point')
+ inputmap = robjects.r.readVECT6(map, type= 'point')
+ coordinatesDF = robjects.r['as.data.frame'](robjects.r.coordinates(inputmap))
+ data=robjects.r['data.frame'](x=coordinatesDF.r['coords.x1'][0],
+ y=coordinatesDF.r['coords.x2'][0])
+ rsSP = robjects.r.SpatialPoints(robjects.r.coordinates(inputmap),
+ proj4string=robjects.r.CRS(robjects.r.proj4string(inputmap)))
+ rsflatDF = robjects.r['as.data.frame'](inputmap)
+ DottedParams = {'by.x': 'row.names', 'by.y': 'row.names'}
+ rsData = robjects.r.merge(data, rsflatDF, **DottedParams)
+ rsSPDF = robjects.r.SpatialPointsDataFrame(rsSP, rsData,
+ print robjects.r.proj4string(rsSPDF)
+ return rsSPDF
def CreateGrid(self, inputdata):
Region = grass.region()
Grid = robjects.r.gmeta2grd()
+ ## addition of coordinates columns into dataframe.
+ coordinatesDF = robjects.r['as.data.frame'](robjects.r.coordinates(Grid))
+ data=robjects.r['data.frame'](x=coordinatesDF.r['s1'][0],
+ y=coordinatesDF.r['s2'][0])
GridPredicted = robjects.r.SpatialGridDataFrame(Grid,
- data=robjects.r['data.frame']
- (k=robjects.r.rep(1,Region['cols']*Region['rows'])),
- proj4string=robjects.r.CRS(robjects.r.proj4string(inputdata)))
+ data,
+ proj4string= robjects.r.CRS(robjects.r.proj4string(inputdata)))
+ print robjects.r.proj4string(GridPredicted)
return GridPredicted
def ComposeFormula(self, column, block, inputdata):
- # will change when the formula will need to be more complex. Not yet.
- Formula = robjects.RFormula('y ~ x')
- Env = Formula.getenvironment()
- Env['y'] = column
if block is not None:
- #@FIXME does not catch what the formula wants. Nor do I.
- #Env['x'] = 'x+y'
- pass
+ predictor = 'x+y'
else:
- Env['x'] = 1
- return Formula
+ predictor = 1
+ return robjects.r['as.formula'](robjects.r.paste(column, "~", predictor))
def FitVariogram(self, formula, inputdata, model = '', sill=0, nugget=0, range=0):
if model is '':
@@ -181,7 +197,7 @@
VariogramModel = robjects.r.autofitVariogram(formula, inputdata)
return VariogramModel.r['var_model'][0]
else:
- DataVariogram = robjects.r.variogram(formula, inputdata)
+ DataVariogram = robjects.r['variogram'](formula, inputdata)
VariogramModel = robjects.r['fit.variogram'](DataVariogram,
model = robjects.r.vgm(psill = sill,
model = model,
@@ -197,6 +213,7 @@
DottedParams = {'debug.level': -1} # let krige() print percentage status
DottedParams['block'] = block
+ print DottedParams
KrigingResult = robjects.r.krige(formula, inputdata, grid, model, **DottedParams)
return KrigingResult
@@ -209,6 +226,7 @@
# Get data and create grid
logger.message(_("Importing data..."))
InputData = self.ImportMap(input)
+ print(robjects.r.slot(InputData, 'data').names)
logger.message("Imported.")
GridPredicted = self.CreateGrid(InputData)
@@ -419,7 +437,7 @@
def __init__(self, parent, *args, **kwargs):
wx.Panel.__init__(self, parent, *args, **kwargs)
- KrigingList = ["Ordinary kriging"]#, "Block kriging", "Universal kriging"] #@FIXME: i18n on the list?
+ KrigingList = ["Ordinary kriging", "Block kriging"]#, "Universal kriging"] #@FIXME: i18n on the list?
KrigingRadioBox = wx.RadioBox(self, id=wx.ID_ANY, label=_("Kriging techniques"),
pos=wx.DefaultPosition, size=wx.DefaultSize,
choices=KrigingList, majorDimension=1, style=wx.RA_SPECIFY_COLS)
@@ -441,12 +459,12 @@
#self.ParametersSizer.Add(wx.Button(self, id=wx.ID_ANY, label=_("Interactive variogram fit")))
# block kriging parameters. Size.
- #BlockLabel = wx.StaticText(self, id= wx.ID_ANY, label = _("Block size:"))
- #self.BlockSpinBox = wx.SpinCtrl(self, id = wx.ID_ANY, min=1, max=sys.maxint)
- #self.BlockSpinBox.Enable(False) # default choice is Ordinary kriging
+ BlockLabel = wx.StaticText(self, id= wx.ID_ANY, label = _("Block size:"))
+ self.BlockSpinBox = wx.SpinCtrl(self, id = wx.ID_ANY, min=1, max=sys.maxint)
+ self.BlockSpinBox.Enable(False) # default choice is Ordinary kriging
- #self.ParametersSizer.Add(BlockLabel, flag=wx.EXPAND | wx.ALIGN_CENTER_VERTICAL | wx.ALL, border=3)
- #self.ParametersSizer.Add(self.BlockSpinBox, flag=wx.EXPAND | wx.ALIGN_CENTER_VERTICAL | wx.ALL, border=3)
+ self.ParametersSizer.Add(BlockLabel, flag=wx.EXPAND | wx.ALIGN_CENTER_VERTICAL | wx.ALL, border=3)
+ self.ParametersSizer.Add(self.BlockSpinBox, flag=wx.EXPAND | wx.ALIGN_CENTER_VERTICAL | wx.ALL, border=3)
self.VariogramSizer.Add(self.ParametersSizer, proportion=0, flag=wx.EXPAND | wx.ALL, border=3)
@@ -537,8 +555,8 @@
except ImportError, e:
grass.fatal(_("R package automap is missing, no variogram autofit available."))
- if options['block'] is not '':
- grass.fatal(_("Block kriging implementation in progress. Re-run without block parameter."))
+ #if options['block'] is not '': #remove when block kriging will be ready
+ # grass.fatal(_("Block kriging implementation in progress. Re-run without block parameter."))
controller = Controller()
controller.Run(input = options['input'],
