[GRASS-SVN] r38454 - grass/branches/releasebranch_6_4/swig/python/examples
Fri Jul 17 18:54:25 EDT 2009
Author: neteler
Date: 2009-07-17 18:54:24 -0400 (Fri, 17 Jul 2009)
New Revision: 38454
   grass/branches/releasebranch_6_4/swig/python/examples/rasteraccess.py
   grass/branches/releasebranch_6_4/swig/python/examples/vectoraccess.py
version fix in comment
Modified: grass/branches/releasebranch_6_4/swig/python/examples/rasteraccess.py
--- grass/branches/releasebranch_6_4/swig/python/examples/rasteraccess.py	2009-07-17 22:50:37 UTC (rev 38453)
+++ grass/branches/releasebranch_6_4/swig/python/examples/rasteraccess.py	2009-07-17 22:54:24 UTC (rev 38454)
@@ -5,14 +5,14 @@
 Run this before starting python to append module search path:
 @code
-export PYTHONPATH=/usr/src/grass70/swig/python
+export PYTHONPATH=/usr/src/grass64/swig/python
 @endcode
 Check with "import sys; sys.path"
 or:
 @code
-sys.path.append("/usr/src/grass70/swig/python")
+sys.path.append("/usr/src/grass64/swig/python")
 @endcode
 \todo install the grass bindings in $GISBASE/lib/ ?
Modified: grass/branches/releasebranch_6_4/swig/python/examples/vectoraccess.py
--- grass/branches/releasebranch_6_4/swig/python/examples/vectoraccess.py	2009-07-17 22:50:37 UTC (rev 38453)
+++ grass/branches/releasebranch_6_4/swig/python/examples/vectoraccess.py	2009-07-17 22:54:24 UTC (rev 38454)
@@ -2,10 +2,10 @@
 # run within GRASS Spearfish session
 # run this before starting python to append module search path:
-#   export PYTHONPATH=/usr/src/grass70/swig/python
+#   export PYTHONPATH=/usr/src/grass64/swig/python
 #   check with "import sys; sys.path"
 # or:
-#   sys.path.append("/usr/src/grass70/swig/python")
+#   sys.path.append("/usr/src/grass64/swig/python")
 # FIXME: install the grass bindings in $GISBASE/lib/ ?
 import os, sys
