[GRASS-SVN] r38502 - grass-addons/vector/v.in.postgis
svn_grass at osgeo.org
Tue Jul 21 10:10:37 EDT 2009
Author: mathieug
Date: 2009-07-21 10:10:37 -0400 (Tue, 21 Jul 2009)
New Revision: 38502
grass-addons/vector/v.in.postgis/v.in.postgis.py
modified cleanup on error + command execution
Modified: grass-addons/vector/v.in.postgis/v.in.postgis.py
--- grass-addons/vector/v.in.postgis/v.in.postgis.py 2009-07-21 04:30:20 UTC (rev 38501)
+++ grass-addons/vector/v.in.postgis/v.in.postgis.py 2009-07-21 14:10:37 UTC (rev 38502)
@@ -5,7 +5,7 @@
# MODULE: v.in.postgis
# AUTHOR(S): Mathieu Grelier, 2009 (greliermathieu at gmail.com)
-# PURPOSE: GRASS layer creation from arbitrary PostGIS sql queries
+# PURPOSE: GRASS layer creation from arbitrary PostGIS sql queries
# COPYRIGHT: (C) 2009 Mathieu Grelier
# This program is free software under the GNU General Public
@@ -118,7 +118,7 @@
host = grass.parse_key_val(dbElems[0], sep = '=')['host']
db = grass.parse_key_val(dbElems[1], sep = '=')['dbname']
loginLine = self.executeCommand('sed -n "/pg ' + dbElems[0] + ','\
- + dbElems[1] + ' /p" ' + self.grassloginfile, redirect = False, shell = True)
+ + dbElems[1] + ' /p" ' + self.grassloginfile, toLog = False, shell = True)
p = re.compile(' ')
loginElems = p.split(loginLine)
user = loginElems[-2].strip()
@@ -132,12 +132,16 @@
"""Command execution method using Popen in two modes : shell mode or not."""
p = None
shell = True if 'shell' in kwargs and kwargs['shell'] is True else False
- redirection = True if 'redirect' in kwargs and kwargs['redirect'] is True else False
+ toLog = True if 'toLog' in kwargs and kwargs['toLog'] is True \
+ and self.logOutput is True else False
+ ##now remove this key as it is not expected by grass.start_command
+ if 'toLog' in kwargs:
+ del kwargs['toLog']
command = args[0]
if shell is True:
- if redirection is True and self.logOutput is not False:
+ if toLog is True:
command = command + ' >> ' + self.logfile
- ##use redirection on stdout only
+ ##always use redirection on stdout only
command = command + " 2>&1"
p = Popen(command, shell = shell, stdout = PIPE)
else:
@@ -145,16 +149,19 @@
kwargs['stderr'] = PIPE
p = grass.start_command(*args, **kwargs)
retcode = p.wait()
- com = p.communicate()
message = ''
- r = re.compile('\n')
- for std in com:
- if std is not None:
- lines = r.split(std)
- for elem in lines:
- message += str(elem).strip() + "\n"
- if self.logOutput is not False and shell is False:
- self.__writeLog(message)
+ if shell is True and toLog is True:
+ message = 'Read logfile for details.'
+ else:
+ com = p.communicate()
+ r = re.compile('\n')
+ for std in com:
+ if std is not None:
+ lines = r.split(std)
+ for elem in lines:
+ message += str(elem).strip() + "\n"
+ if toLog is True:
+ self.__writeLog(message)
if retcode == 0:
return message
else:
@@ -359,25 +366,36 @@
layername = output
##we use the shell mode to be able to follow v.in.ogr progress in log file
cmd = self.executeCommand('v.in.ogr' + flags + ' dsn="' + dsn + '" output=' + output + \
- ' layer=' + layername + ' --o', shell = True, redirect = True)
+ ' layer=' + layername + ' --o', shell = True, toLog = True)
if toDbf is True:
grass.run_command("db.connect", driver = 'pg', database = 'host=' + self.dbparams['host'] + \
",dbname=" + self.dbparams['db'])
- self.cursor.execute('DROP TABLE ' + output)
+ #self.cursor.execute('DROP TABLE ' + output)
+ self.removeImportData(True, False)
##else we work directly with postgis so the connection between imported grass layer
##and postgres attribute table must be explicit
else:
##can cause segfaults if mapset name is too long:
- cmd = self.executeCommand("v.db.connect", map = output, table = output, flags = 'o')
+ cmd = self.executeCommand("v.db.connect", map = output, table = output, flags = 'o', \
+ toLog = self.logOutput)
##delete temporary data in geometry_columns table
- self.cursor.execute("DELETE FROM geometry_columns WHERE f_table_name = '" + output + "'")
+ #self.cursor.execute("DELETE FROM geometry_columns WHERE f_table_name = '" + output + "'")
+ self.removeImportData(False, True)
pass
def commitChanges(self):
"""Commit current transaction."""
self.db.commit()
+ def removeImportData(self, removeTable = True, removeGeometryColumnsRecord = True):
+ """Cleanup method"""
+ if removeTable is True:
+ self.cursor.execute('DROP TABLE ' + self.output)
+ if removeGeometryColumnsRecord is True:
+ self.cursor.execute("DELETE FROM geometry_columns WHERE f_table_name = '" + self.output + "'")
+ self.commitChanges()
def makeSqlImport(self):
"""GrassPostGisImporter main sequence."""
##1)check layers before starting
@@ -391,11 +409,12 @@
geoparams = self.getGeometryInfo(self.output, self.geometryfield)
##5)new geometry
self.addGeometry(self.output, self.geometryfield, geoparams, self.gistindexFlag)
+ ##we must commit before connecting to new table for import
##6)v.in.ogr
self.importToGrass(self.output, self.geometryfield, geoparams, toDbf = self.dbfFlag, \
- overrideProj = self.overrideprojFlag)
- ##7)post-import operations
+ overrideProj = self.overrideprojFlag)
+ ##process is ok
class GrassPostGisImporterError(Exception):
@@ -413,12 +432,14 @@
postgisImporter.makeSqlImport()
except GrassPostGisImporterError, e1:
postgisImporter.printMessage(e1.message, type = 'error')
+ postgisImporter.removeImportData()
exitStatus = 1
except:
exceptionType, exceptionValue, exceptionTraceback = sys.exc_info()
errorMessage = "Unexpected error \n:" + \
repr(traceback.format_exception(exceptionType, exceptionValue, exceptionTraceback))
postgisImporter.printMessage(errorMessage, type = 'error')
exitStatus = 1
else:
postgisImporter.printMessage("Done", type = 'info')
