[GRASS-SVN] r38520 - in grass/trunk: include lib/raster
svn_grass at osgeo.org
Sat Jul 25 06:26:30 EDT 2009
Author: glynn
Date: 2009-07-25 06:26:29 -0400 (Sat, 25 Jul 2009)
New Revision: 38520
grass/trunk/include/rasterdefs.h
grass/trunk/lib/raster/R.h
grass/trunk/lib/raster/gdal.c
grass/trunk/lib/raster/get_row.c
grass/trunk/lib/raster/init.c
grass/trunk/lib/raster/opencell.c
grass/trunk/lib/raster/put_row.c
grass/trunk/lib/raster/set_window.c
grass/trunk/lib/raster/window_map.c
Remove R__.window[_set], Rast__init_window
Modified: grass/trunk/include/rasterdefs.h
--- grass/trunk/include/rasterdefs.h 2009-07-24 11:18:42 UTC (rev 38519)
+++ grass/trunk/include/rasterdefs.h 2009-07-25 10:26:29 UTC (rev 38520)
@@ -503,7 +503,6 @@
int Rast_set_window(struct Cell_head *);
/* window_map.c */
-void Rast__init_window(void);
void Rast__create_window_mapping(int);
int Rast_row_repeat_nomask(int, int);
Modified: grass/trunk/lib/raster/R.h
--- grass/trunk/lib/raster/R.h 2009-07-24 11:18:42 UTC (rev 38519)
+++ grass/trunk/lib/raster/R.h 2009-07-25 10:26:29 UTC (rev 38520)
@@ -73,8 +73,6 @@
struct R__ /* Structure of library globals */
RASTER_MAP_TYPE fp_type; /* type for writing floating maps */
- struct Cell_head window; /* Contains the current window */
- int window_set; /* Flag: window set? */
int mask_fd; /* File descriptor for automatic mask */
int auto_mask; /* Flag denoting automatic masking */
int want_histogram;
Modified: grass/trunk/lib/raster/gdal.c
--- grass/trunk/lib/raster/gdal.c 2009-07-24 11:18:42 UTC (rev 38519)
+++ grass/trunk/lib/raster/gdal.c 2009-07-25 10:26:29 UTC (rev 38520)
@@ -8,6 +8,7 @@
#include <grass/raster.h>
#include <grass/glocale.h>
+#include "../gis/G.h"
#include "R.h"
#ifndef HAVE_GDAL
@@ -418,8 +419,8 @@
/* Does driver support GDALCreate ? */
if ((*pGDALGetMetadataItem) (driver, GDAL_DCAP_CREATE, NULL)) {
gdal->data =
- (*pGDALCreate) (driver, gdal->filename, R__.window.cols,
- R__.window.rows, 1, gdal->type, st->opts.options);
+ (*pGDALCreate) (driver, gdal->filename, G__.window.cols,
+ G__.window.rows, 1, gdal->type, st->opts.options);
if (!gdal->data)
G_fatal_error(_("Unable to create <%s> dataset using <%s> driver"),
name, st->opts.format);
@@ -438,7 +439,7 @@
G_fatal_error(_("Unable to get in-memory raster driver"));
gdal->data =
- (*pGDALCreate) (mem_driver, "", R__.window.cols, R__.window.rows,
+ (*pGDALCreate) (mem_driver, "", G__.window.cols, G__.window.rows,
if (!gdal->data)
G_fatal_error(_("Unable to create <%s> dataset using memory driver"),
@@ -453,12 +454,12 @@
(*pGDALSetRasterNoDataValue) (gdal->band, gdal->null_val);
/* Set Geo Transform */
- transform[0] = R__.window.west;
- transform[1] = R__.window.ew_res;
+ transform[0] = G__.window.west;
+ transform[1] = G__.window.ew_res;
transform[2] = 0.0;
- transform[3] = R__.window.north;
+ transform[3] = G__.window.north;
transform[4] = 0.0;
- transform[5] = -R__.window.ns_res;
+ transform[5] = -G__.window.ns_res;
if ((*pGDALSetGeoTransform) (gdal->data, transform) >= CE_Failure)
G_warning(_("Unable to set geo transform"));
Modified: grass/trunk/lib/raster/get_row.c
--- grass/trunk/lib/raster/get_row.c 2009-07-24 11:18:42 UTC (rev 38519)
+++ grass/trunk/lib/raster/get_row.c 2009-07-25 10:26:29 UTC (rev 38520)
@@ -22,6 +22,7 @@
#include "R.h"
#define NULL_FILE "null"
@@ -35,7 +36,7 @@
int r;
/* check for row in window */
- if (row < 0 || row >= R__.window.rows) {
+ if (row < 0 || row >= G__.window.rows) {
G_warning(_("Reading raster map <%s@%s> request for row %d is outside region"),
fcb->name, fcb->mapset, row);
@@ -65,7 +66,7 @@
CELL max = fcb->reclass.max;
int i;
- for (i = 0; i < R__.window.cols; i++) {
+ for (i = 0; i < G__.window.cols; i++) {
if (Rast_is_c_null_value(&c[i])) {
if (null_is_zero)
c[i] = 0;
@@ -487,23 +488,23 @@
if (fcb->gdal)
(gdal_values_type[fcb->map_type]) (fd, fcb->data, fcb->col_map,
fcb->cur_nbytes, cell,
- R__.window.cols);
+ G__.window.cols);
else
#endif
(cell_values_type[fcb->map_type]) (fd, fcb->data, fcb->col_map,
- R__.window.cols);
+ G__.window.cols);
static void transfer_to_cell_fi(int fd, void *cell)
struct fileinfo *fcb = &R__.fileinfo[fd];
- FCELL *work_buf = G__alloca(R__.window.cols * sizeof(FCELL));
+ FCELL *work_buf = G__alloca(G__.window.cols * sizeof(FCELL));
int i;
transfer_to_cell_XX(fd, work_buf);
((CELL *) cell)[i] = (fcb->col_map[i] == 0)
? 0 : Rast_quant_get_cell_value(&fcb->quant, work_buf[i]);
@@ -513,12 +514,12 @@
static void transfer_to_cell_di(int fd, void *cell)
- DCELL *work_buf = G__alloca(R__.window.cols * sizeof(DCELL));
+ DCELL *work_buf = G__alloca(G__.window.cols * sizeof(DCELL));
int i;
@@ -527,12 +528,12 @@
static void transfer_to_cell_if(int fd, void *cell)
- CELL *work_buf = G__alloca(R__.window.cols * sizeof(CELL));
+ CELL *work_buf = G__alloca(G__.window.cols * sizeof(CELL));
int i;
((FCELL *) cell)[i] = work_buf[i];
G__freea(work_buf);
@@ -540,12 +541,12 @@
static void transfer_to_cell_df(int fd, void *cell)
int i;
G__freea(work_buf);
@@ -553,12 +554,12 @@
static void transfer_to_cell_id(int fd, void *cell)
int i;
((DCELL *) cell)[i] = work_buf[i];
G__freea(work_buf);
@@ -566,12 +567,12 @@
static void transfer_to_cell_fd(int fd, void *cell)
int i;
G__freea(work_buf);
@@ -657,7 +658,7 @@
int i;
if (fcb->reclass_flag && data_type != CELL_TYPE) {
- temp_buf = G__alloca(R__.window.cols * sizeof(CELL));
+ temp_buf = G__alloca(G__.window.cols * sizeof(CELL));
buf = temp_buf;
type = CELL_TYPE;
@@ -685,7 +686,7 @@
if (data_type == CELL_TYPE)
return 1;
Rast_set_c_value(rast, temp_buf[i], data_type);
rast = G_incr_void_ptr(rast, size);
@@ -971,7 +972,7 @@
int i, j, null_fd;
- if (row > R__.window.rows || row < 0) {
+ if (row > G__.window.rows || row < 0) {
@@ -992,8 +993,8 @@
null_fd = open_null_read(fd);
for (i = 0; i < NULL_ROWS_INMEM; i++) {
- /* R__.window.rows doesn't have to be a multiple of NULL_ROWS_INMEM */
- if (i + fcb->min_null_row >= R__.window.rows)
+ /* G__.window.rows doesn't have to be a multiple of NULL_ROWS_INMEM */
+ if (i + fcb->min_null_row >= G__.window.rows)
break;
if (read_null_bits(null_fd, null_work_buf,
@@ -1002,11 +1003,11 @@
if (fcb->map_type == CELL_TYPE) {
/* If can't read null row, assume that all map 0's are nulls */
CELL *mask_buf =
- G__alloca(R__.window.cols * sizeof(CELL));
+ G__alloca(G__.window.cols * sizeof(CELL));
get_map_row_nomask(fd, mask_buf, i + fcb->min_null_row,
CELL_TYPE);
- for (j = 0; j < R__.window.cols; j++)
+ for (j = 0; j < G__.window.cols; j++)
flags[j] = (mask_buf[j] == 0);
G__freea(mask_buf);
@@ -1014,15 +1015,15 @@
else { /* fp map */
/* if can't read null row, assume that all data is valid */
- G_zero(flags, sizeof(char) * R__.window.cols);
+ G_zero(flags, sizeof(char) * G__.window.cols);
/* the flags row is ready now */
} /*if no null file */
else {
/* copy null row to flags row translated by window column mapping */
- /* the fcb->NULL_ROWS[row-fcb->min_null_row] has R__.window.cols bits, */
+ /* the fcb->NULL_ROWS[row-fcb->min_null_row] has G__.window.cols bits, */
/* the null_work_buf has size fcb->cellhd.cols */
- for (j = 0; j < R__.window.cols; j++) {
+ for (j = 0; j < G__.window.cols; j++) {
if (!fcb->col_map[j])
flags[j] = 1;
else
@@ -1036,15 +1037,12 @@
/*bf-We should take of the size - or we get
zeros running on their own after flags convertions -A.Sh. */
fcb->NULL_ROWS[i] = G_realloc(fcb->NULL_ROWS[i],
- Rast__null_bitstream_size(R__.
- window.
- cols) +
- 1);
+ Rast__null_bitstream_size(G__.window.cols) +1);
if (fcb->NULL_ROWS[i] == NULL)
G_fatal_error("get_null_value_row_nomask: %s",
_("Unable to realloc buffer"));
- Rast__convert_01_flags(flags, fcb->NULL_ROWS[i], R__.window.cols);
+ Rast__convert_01_flags(flags, fcb->NULL_ROWS[i], G__.window.cols);
} /* for loop */
@@ -1055,9 +1053,9 @@
} /* row is not in memory */
/* copy null file data translated by column mapping to user null row */
- /* the user requested flags row is of size R__.window.cols */
+ /* the user requested flags row is of size G__.window.cols */
Rast__convert_flags_01(flags, fcb->NULL_ROWS[row - fcb->min_null_row],
- R__.window.cols);
+ G__.window.cols);
@@ -1071,12 +1069,12 @@
int i;
if (get_map_row_nomask(fd, tmp_buf, row, DCELL_TYPE) <= 0) {
- memset(flags, 1, R__.window.cols);
+ memset(flags, 1, G__.window.cols);
G_free(tmp_buf);
return;
/* note: using == won't work if the null value is NaN */
flags[i] =
memcmp(&tmp_buf[i], &fcb->gdal->null_val, sizeof(DCELL)) == 0;
@@ -1092,7 +1090,7 @@
static void embed_mask(char *flags, int row)
- CELL *mask_buf = G__alloca(R__.window.cols * sizeof(CELL));
+ CELL *mask_buf = G__alloca(G__.window.cols * sizeof(CELL));
int i;
if (R__.auto_mask <= 0)
@@ -1106,7 +1104,7 @@
if (R__.fileinfo[R__.mask_fd].reclass_flag)
do_reclass_int(R__.mask_fd, mask_buf, 1);
if (mask_buf[i] == 0)
flags[i] = 1;
@@ -1141,11 +1139,11 @@
&& (R__.auto_mask <= 0 || !with_mask))
return 1;
- null_buf = G__alloca(R__.window.cols);
+ null_buf = G__alloca(G__.window.cols);
get_null_value_row(fd, null_buf, row, with_mask);
/* also check for nulls which might be already embedded by quant
rules in case of fp map. */
if (null_buf[i] || Rast_is_null_value(buf, map_type)) {
Modified: grass/trunk/lib/raster/init.c
--- grass/trunk/lib/raster/init.c 2009-07-24 11:18:42 UTC (rev 38519)
+++ grass/trunk/lib/raster/init.c 2009-07-25 10:26:29 UTC (rev 38520)
@@ -73,6 +73,8 @@
static int init(void)
+ G__init_window();
/* no histograms */
R__.want_histogram = 0;
Modified: grass/trunk/lib/raster/opencell.c
--- grass/trunk/lib/raster/opencell.c 2009-07-24 11:18:42 UTC (rev 38519)
+++ grass/trunk/lib/raster/opencell.c 2009-07-25 10:26:29 UTC (rev 38520)
@@ -25,6 +25,7 @@
#include "R.h"
#define FORMAT_FILE "f_format"
@@ -170,9 +171,6 @@
Rast__init();
- /* make sure window is set */
- Rast__init_window();
G__unqualified_name(name, mapset, xname, xmapset);
name = xname;
mapset = xmapset;
@@ -224,16 +222,16 @@
- if (cellhd.proj != R__.window.proj) {
+ if (cellhd.proj != G__.window.proj) {
G_warning(_("Raster map <%s@%s> is in different projection than current region. "
"Found raster map <%s@%s>, should be <%s>."), name, mapset,
name, G__projection_name(cellhd.proj),
- G__projection_name(R__.window.proj));
+ G__projection_name(G__.window.proj));
return -1;
- if (cellhd.zone != R__.window.zone) {
+ if (cellhd.zone != G__.window.zone) {
G_warning(_("Raster map <%s@%s> is in different zone (%d) than current region (%d)"),
- name, mapset, cellhd.zone, R__.window.zone);
+ name, mapset, cellhd.zone, G__.window.zone);
return -1;
@@ -289,7 +287,7 @@
/* allocate null bitstream buffers for reading null rows */
- fcb->NULL_ROWS[i] = Rast__allocate_null_bits(R__.window.cols);
+ fcb->NULL_ROWS[i] = Rast__allocate_null_bits(G__.window.cols);
/* initialize : no NULL rows in memory */
fcb->min_null_row = (-1) * NULL_ROWS_INMEM;
@@ -512,12 +510,12 @@
if (!fcb->gdal)
return -1;
- fcb->cellhd = R__.window;
+ fcb->cellhd = G__.window;
fcb->cellhd.compressed = 0;
fcb->nbytes = Rast_cell_size(fcb->map_type);
- /* for writing fcb->data is allocated to be R__.window.cols *
+ /* for writing fcb->data is allocated to be G__.window.cols *
sizeof(CELL or DCELL or FCELL) */
- fcb->data = G_calloc(R__.window.cols, fcb->nbytes);
+ fcb->data = G_calloc(G__.window.cols, fcb->nbytes);
fcb->name = map;
fcb->mapset = mapset;
@@ -598,9 +596,6 @@
return -1;
#ifdef HAVE_GDAL
if (G_find_file2("", "GDAL", G_mapset()))
return G__open_raster_new_gdal(map, mapset, map_type);
@@ -629,9 +624,9 @@
fcb->open_mode = -1;
fcb->gdal = NULL;
- fcb->data = (unsigned char *)G_calloc(R__.window.cols,
+ fcb->data = (unsigned char *)G_calloc(G__.window.cols,
Rast_cell_size(fcb->map_type));
@@ -640,7 +635,7 @@
* for compressed writing
* allocate space to hold the row address array
- G_copy((char *)&fcb->cellhd, (char *)&R__.window, sizeof(fcb->cellhd));
+ G_copy((char *)&fcb->cellhd, (char *)&G__.window, sizeof(fcb->cellhd));
if (open_mode == OPEN_NEW_COMPRESSED && fcb->map_type == CELL_TYPE) {
fcb->row_ptr = G_calloc(fcb->cellhd.rows + 1, sizeof(off_t));
Modified: grass/trunk/lib/raster/put_row.c
--- grass/trunk/lib/raster/put_row.c 2009-07-24 11:18:42 UTC (rev 38519)
+++ grass/trunk/lib/raster/put_row.c 2009-07-25 10:26:29 UTC (rev 38520)
@@ -26,6 +26,7 @@
#include "R.h"
static int put_raster_data(int, char *, const void *, int, int, int,
@@ -278,7 +279,7 @@
if (n <= 0)
return 0;
- work_buf = G__alloca(R__.window.cols * fcb->nbytes + 1);
+ work_buf = G__alloca(G__.window.cols * fcb->nbytes + 1);
if (compressed)
set_file_pointer(fd, row);
@@ -455,7 +456,7 @@
if (n <= 0)
return 0;
- work_buf = G__alloca(R__.window.cols * sizeof(CELL) + 1);
+ work_buf = G__alloca(G__.window.cols * sizeof(CELL) + 1);
wk = work_buf;
if (compressed)
Modified: grass/trunk/lib/raster/set_window.c
--- grass/trunk/lib/raster/set_window.c 2009-07-24 11:18:42 UTC (rev 38519)
+++ grass/trunk/lib/raster/set_window.c 2009-07-25 10:26:29 UTC (rev 38520)
@@ -74,10 +74,8 @@
/* copy the window to the current window */
- G_copy((char *)&R__.window, (char *)window, sizeof(*window));
+ G_set_window(window);
- R__.window_set = 1;
/* now for each possible open cell file, recreate the window mapping */
* also the memory for reading and writing must be reallocated for all opened
@@ -98,7 +96,7 @@
else {
/* opened for writing */
G_free(fcb->data);
map_type));
@@ -106,7 +104,7 @@
/* allocate null bitstream buffers for reading/writing null rows */
for (j = 0; j < NULL_ROWS_INMEM; j++) {
G_free(fcb->NULL_ROWS[j]);
- fcb->NULL_ROWS[j] = (R__.window.cols);
+ fcb->NULL_ROWS[j] = (G__.window.cols);
Modified: grass/trunk/lib/raster/window_map.c
--- grass/trunk/lib/raster/window_map.c 2009-07-24 11:18:42 UTC (rev 38519)
+++ grass/trunk/lib/raster/window_map.c 2009-07-25 10:26:29 UTC (rev 38520)
@@ -15,6 +15,7 @@
#include <grass/gis.h>
#include "R.h"
@@ -39,14 +40,12 @@
double C1, C2;
double west;
if (fcb->open_mode >= 0 && fcb->open_mode != OPEN_OLD) /* open for write? */
return;
if (fcb->open_mode == OPEN_OLD) /* already open ? */
G_free(fcb->col_map);
- col = fcb->col_map = alloc_index(R__.window.cols);
+ col = fcb->col_map = alloc_index(G__.window.cols);
* for each column in the window, go to center of the cell,
@@ -56,18 +55,18 @@
* for lat/lon move window so that west is bigger than
* cellhd west.
- west = R__.window.west;
- if (R__.window.proj == PROJECTION_LL) {
+ west = G__.window.west;
+ if (G__.window.proj == PROJECTION_LL) {
while (west > fcb->cellhd.west + 360.0)
west -= 360.0;
while (west < fcb->cellhd.west)
west += 360.0;
- C1 = R__.window.ew_res / fcb->cellhd.ew_res;
+ C1 = G__.window.ew_res / fcb->cellhd.ew_res;
C2 = (west - fcb->cellhd.west +
- R__.window.ew_res / 2.0) / fcb->cellhd.ew_res;
+ G__.window.ew_res / 2.0) / fcb->cellhd.ew_res;
x = C2;
if (C2 < x) /* adjust for rounding of negatives */
x--;
@@ -78,11 +77,11 @@
/* do wrap around for lat/lon */
col = fcb->col_map;
C2 = (west - 360.0 - fcb->cellhd.west +
x = C2;
x--;
@@ -95,39 +94,21 @@
- G_debug(3, "create window mapping (%d columns)", R__.window.cols);
- /* for (i = 0; i < R__.window.cols; i++)
+ G_debug(3, "create window mapping (%d columns)", G__.window.cols);
+ /* for (i = 0; i < G__.window.cols; i++)
fprintf(stderr, "%s%ld", i % 15 ? " " : "\n", (long)fcb->col_map[i]);
fprintf(stderr, "\n");
/* compute C1,C2 for row window mapping */
- fcb->C1 = R__.window.ns_res / fcb->cellhd.ns_res;
+ fcb->C1 = G__.window.ns_res / fcb->cellhd.ns_res;
fcb->C2 =
- (fcb->cellhd.north - R__.window.north +
- R__.window.ns_res / 2.0) / fcb->cellhd.ns_res;
+ (fcb->cellhd.north - G__.window.north +
+ G__.window.ns_res / 2.0) / fcb->cellhd.ns_res;
- * \brief Initialize window.
- Rast__init();
- if (G_is_initialized(&R__.window_set))
- return;
- G__init_window();
- G_get_window(&R__.window);
- G_initialize_done(&R__.window_set);
* \brief Loops rows until mismatch?.
* This routine works fine if the mask is not set. It may give
@@ -158,7 +139,7 @@
if (f < r1)
r1--;
- while (++row < R__.window.rows) {
+ while (++row < G__.window.rows) {
f = row * fcb->C1 + fcb->C2;
r2 = f;
if (f < r2)
