[GRASS-SVN] r38544 - grass/trunk/lib/cluster
Fri Jul 31 06:51:49 EDT 2009
Author: martinl
Date: 2009-07-31 06:51:49 -0400 (Fri, 31 Jul 2009)
New Revision: 38544
   grass/trunk/lib/cluster/c_assign.c
   grass/trunk/lib/cluster/c_begin.c
   grass/trunk/lib/cluster/c_clear.c
   grass/trunk/lib/cluster/c_distinct.c
   grass/trunk/lib/cluster/c_exec.c
   grass/trunk/lib/cluster/c_execmem.c
   grass/trunk/lib/cluster/c_means.c
   grass/trunk/lib/cluster/c_merge.c
   grass/trunk/lib/cluster/c_nclasses.c
   grass/trunk/lib/cluster/c_point.c
   grass/trunk/lib/cluster/c_reassign.c
   grass/trunk/lib/cluster/c_reclass.c
   grass/trunk/lib/cluster/c_sep.c
   grass/trunk/lib/cluster/c_sig.c
   grass/trunk/lib/cluster/c_sum2.c
   grass/trunk/lib/cluster/clusterlib.dox
clusterlib doc doxygenized
Modified: grass/trunk/lib/cluster/c_assign.c
--- grass/trunk/lib/cluster/c_assign.c	2009-07-30 23:42:43 UTC (rev 38543)
+++ grass/trunk/lib/cluster/c_assign.c	2009-07-31 10:51:49 UTC (rev 38544)
@@ -1,6 +1,28 @@
+  \file cluster/c_assign.c
+  \brief Cluster library - Assign cluster
+  (C) 2001-2009 by the GRASS Development Team
+  This program is free software under the GNU General Public License
+  (>=v2). Read the file COPYING that comes with GRASS for details.
+  \author Original author CERL
 #include <math.h>
 #include <grass/cluster.h>
+  \brief Assign cluster
+  \param C pointer to Cluster structure
+  \param interrupted ?
+  \return -1 on interrupted
+  \return 0 on success
 int I_cluster_assign(struct Cluster *C, int *interrupted)
     int p, c;
@@ -8,11 +30,9 @@
     double d, q;
     double dmin;
-       fprintf (stderr,"I_cluster_assign(npoints=%d,nclasses=%d,nbands=%d)\n",
-       C->npoints, C->nclasses, C->nbands);
+    G_debug("I_cluster_assign(npoints=%d,nclasses=%d,nbands=%d)",
+	    C->npoints, C->nclasses, C->nbands);
     for (p = 0; p < C->npoints; p++) {
 	if (*interrupted)
 	    return -1;
Modified: grass/trunk/lib/cluster/c_begin.c
--- grass/trunk/lib/cluster/c_begin.c	2009-07-30 23:42:43 UTC (rev 38543)
+++ grass/trunk/lib/cluster/c_begin.c	2009-07-31 10:51:49 UTC (rev 38544)
@@ -1,18 +1,30 @@
+  \file cluster/c_begin.c
+  \brief Cluster library - Begin clusterring
 #include <stdlib.h>
+#include <grass/glocale.h>
- * I_cluster_begin (C,nbands)
- * initialize the cluster routines for nbands
- * returns
- *  0 ok
- * -1 out of memory
- *  1 illegal number of bands
+  \brief Initialize the cluster routines for nbands
+  \param nbands number of bands
+  \return 0 ok
+  \return -1 out of memory
+  \return 1 illegal number of bands
 int I_cluster_begin(struct Cluster *C, int nbands)
     int band;
@@ -42,7 +54,7 @@
     /* prepare the signatures for nbands */
     I_init_signatures(&C->S, nbands);
-    sprintf(C->S.title, "produced by i.cluster");
+    sprintf(C->S.title, _("produced by i.cluster"));
     /* allocate the data (points) arrays */
     C->points = (DCELL **) malloc(C->nbands * sizeof(DCELL *));
Modified: grass/trunk/lib/cluster/c_clear.c
--- grass/trunk/lib/cluster/c_clear.c	2009-07-30 23:42:43 UTC (rev 38543)
+++ grass/trunk/lib/cluster/c_clear.c	2009-07-31 10:51:49 UTC (rev 38544)
@@ -1,4 +1,25 @@
+  \file cluster/c_clear.c
+  \brief Cluster library - Clear structures
+  \brief Clear Cluster structure
+  \return 0
 int I_cluster_clear(struct Cluster *C)
     C->points = NULL;
Modified: grass/trunk/lib/cluster/c_distinct.c
--- grass/trunk/lib/cluster/c_distinct.c	2009-07-30 23:42:43 UTC (rev 38543)
+++ grass/trunk/lib/cluster/c_distinct.c	2009-07-31 10:51:49 UTC (rev 38544)
@@ -1,5 +1,26 @@
+  \file cluster/c_distinct.c
+  \brief Cluster library - Distinct value
+  \brief Get distinct value
+  \param pointer to Cluster structure
+  \param separation separation value
+  \return distiction value
 int I_cluster_distinct(struct Cluster *C, double separation)
     int class1, class2;
Modified: grass/trunk/lib/cluster/c_exec.c
--- grass/trunk/lib/cluster/c_exec.c	2009-07-30 23:42:43 UTC (rev 38543)
+++ grass/trunk/lib/cluster/c_exec.c	2009-07-31 10:51:49 UTC (rev 38544)
@@ -1,25 +1,31 @@
+  \file cluster/c_exec.c
+  \brief Cluster library - Exectute clusterring
- * I_cluster_exec (C, maxclass, iterations,
- *               convergence, separation, min_class_size,
- *               checkpoint, interrupted)
- *  maxclass       maximum number of classes
- *  iterations     maximum number of iterations
- *  convergence    percentage of points stable
- *  separation     minimum distance between class centroids
- *  checkpoint     routine to be called at various steps
- *  interrupted    boolean to check for interrupt
- * returns:
- *   0 ok
- *  -2 interrupted
- *   1 not enough data points
+  \param maxclass maximum number of classes
+  \param iterations maximum number of iterations
+  \param convergence percentage of points stable
+  \param separation minimum distance between class centroids
+  \param checkpoint routine to be called at various steps
+  \param interrupted boolean to check for interrupt
+  \return 0 ok
+  \return -2 interrupted
+  \return 1 not enough data points
 int I_cluster_exec(struct Cluster *C, int maxclass, int iterations,
 		   double convergence,
 		   double separation, int min_class_size,
@@ -32,7 +38,7 @@
     /* check for valid inputs */
     if (C->npoints < 2) {
-	fprintf(stderr, "cluster: not enough data points (%d)\n", C->npoints);
+	G_warning(_("Not enough data points (%d) in cluster"), C->npoints);
 	return 1;
Modified: grass/trunk/lib/cluster/c_execmem.c
--- grass/trunk/lib/cluster/c_execmem.c	2009-07-30 23:42:43 UTC (rev 38543)
+++ grass/trunk/lib/cluster/c_execmem.c	2009-07-31 10:51:49 UTC (rev 38544)
@@ -1,11 +1,31 @@
+  \file cluster/c_execmem.c
+  \brief Cluster library - Allocate cluster
+  \brief Allocate Cluster structure
+  \param C poiter to Cluster structure
+  \return 1 on success
+  \return 0 on error
 int I_cluster_exec_allocate(struct Cluster *C)
-       fprintf(stderr,"I_cluster_exec_allocate(npoints=%d,nclasses=%d,nbands=%d)\n", C->npoints, C->nclasses, C->nbands);
+    G_debug(1, "I_cluster_exec_allocate(npoints=%d,nclasses=%d,nbands=%d)",
     C->class = I_alloc_int(C->npoints);
     C->reclass = I_alloc_int(C->nclasses);
     C->count = I_alloc_int(C->nclasses);
@@ -24,6 +44,13 @@
     return 1;
+  \brief Free allocated Cluster structure
+  \return 0
 int I_cluster_exec_free(struct Cluster *C)
     I_free(C->class);
Modified: grass/trunk/lib/cluster/c_means.c
--- grass/trunk/lib/cluster/c_means.c	2009-07-30 23:42:43 UTC (rev 38543)
+++ grass/trunk/lib/cluster/c_means.c	2009-07-31 10:51:49 UTC (rev 38544)
@@ -1,6 +1,26 @@
+  \file cluster/c_means.c
+  \brief Cluster library - Means value
 #include <math.h>
+  \brief Calculate means value
+  \return 0
 int I_cluster_means(struct Cluster *C)
     int band;
@@ -8,9 +28,9 @@
     double m, v;		/* m=mean, v=variance then std dev */
     double s;
-       fprintf(stderr,"I_cluster_means(nbands=%d,nclasses=%d)\n",C->nbands, C->nclasses);
+    G_debug(3, "I_cluster_means(nbands=%d,nclasses=%d)",
+	    C->nbands, C->nclasses);
     for (band = 0; band < C->nbands; band++) {
 	s = C->band_sum[band];
 	m = s / C->npoints;
Modified: grass/trunk/lib/cluster/c_merge.c
--- grass/trunk/lib/cluster/c_merge.c	2009-07-30 23:42:43 UTC (rev 38543)
+++ grass/trunk/lib/cluster/c_merge.c	2009-07-31 10:51:49 UTC (rev 38544)
@@ -1,5 +1,25 @@
+  \file cluster/c_merge.c
+  \brief Cluster library - Merge
+  \brief ?
+  \return 0
 int I_cluster_merge(struct Cluster *C)
     int band, p;
Modified: grass/trunk/lib/cluster/c_nclasses.c
--- grass/trunk/lib/cluster/c_nclasses.c	2009-07-30 23:42:43 UTC (rev 38543)
+++ grass/trunk/lib/cluster/c_nclasses.c	2009-07-31 10:51:49 UTC (rev 38544)
@@ -1,5 +1,26 @@
+  \file cluster/c_nclasses.c
+  \brief Cluster library - Number of classes
+  \brief Get number of classes
+  \param minsize minimum class size
+  \return number of classes
 int I_cluster_nclasses(struct Cluster *C, int minsize)
     int i, n;
Modified: grass/trunk/lib/cluster/c_point.c
--- grass/trunk/lib/cluster/c_point.c	2009-07-30 23:42:43 UTC (rev 38543)
+++ grass/trunk/lib/cluster/c_point.c	2009-07-31 10:51:49 UTC (rev 38544)
@@ -1,28 +1,34 @@
+  \file cluster/c_point.c
+  \brief Cluster library - Add point
- * I_cluster_point (C,x)
- *     struct Cluster *C;
- *     DCELL *x;
- * adds the point x to the list of data points to be "clustered"
- * returns
- *   0  ok
- *  -1  out of memory, point not added
- *   1  all values are zero, point not added
- * the dimension of x must agree with the number of bands specified
- * in the initializing call to I_cluster_begin()
- * note: if all values in x are zero, the point is rejected
 #include <grass/raster.h>
 static int extend(struct Cluster *, int);
 static int all_zero(struct Cluster *, int);
+  \brief Adds the point x to the list of data points to be "clustered"
+  The dimension of x must agree with the number of bands specified
+  in the initializing call to I_cluster_begin()
+  Note: if all values in x are zero, the point is rejected
+  \return 0 ok
+  \return -1 out of memory, point not added
+  \return 1 all values are null, point not added
 int I_cluster_point(struct Cluster *C, DCELL * x)
     int band;
@@ -53,11 +59,32 @@
     return 0;
+  \brief Begin point set
+  \param n ?
+  \return -1 on error
 int I_cluster_begin_point_set(struct Cluster *C, int n)
     return extend(C, n) ? 0 : -1;
+  \brief ?
+  \param x cell value
+  \param band band number
+  \param n ?
+  \return 0 ok
 int I_cluster_point_part(struct Cluster *C, DCELL x, int band, int n)
     DCELL tmp = x;
@@ -71,6 +98,14 @@
     return 0;
+  \brief ?
+  \param n ?
+  \return number of points
 int I_cluster_end_point_set(struct Cluster *C, int n)
     int band;
Modified: grass/trunk/lib/cluster/c_reassign.c
--- grass/trunk/lib/cluster/c_reassign.c	2009-07-30 23:42:43 UTC (rev 38543)
+++ grass/trunk/lib/cluster/c_reassign.c	2009-07-31 10:51:49 UTC (rev 38544)
@@ -1,6 +1,27 @@
+  \file cluster/c_reassign.c
+  \brief Cluster library - Reassign cluster
 #include <math.h>
+  \brief ?
+  \return number of changes
 int I_cluster_reassign(struct Cluster *C, int *interrupted)
     double min, d, z;
Modified: grass/trunk/lib/cluster/c_reclass.c
--- grass/trunk/lib/cluster/c_reclass.c	2009-07-30 23:42:43 UTC (rev 38543)
+++ grass/trunk/lib/cluster/c_reclass.c	2009-07-31 10:51:49 UTC (rev 38544)
@@ -1,5 +1,27 @@
+  \file cluster/c_reclass.c
+  \brief Cluster library - Reclass data
+  \brief Reclass data
+  \return 1 no change
 int I_cluster_reclass(struct Cluster *C, int minsize)
     int band, c, hole, move, p;
Modified: grass/trunk/lib/cluster/c_sep.c
--- grass/trunk/lib/cluster/c_sep.c	2009-07-30 23:42:43 UTC (rev 38543)
+++ grass/trunk/lib/cluster/c_sep.c	2009-07-31 10:51:49 UTC (rev 38544)
@@ -1,3 +1,16 @@
+  \file cluster/c_sep.c
+  \brief Cluster library - Separation
 #include <math.h>
@@ -3,4 +16,11 @@
 #define FAR ((double) -1.0)
+  \brief ?
+  \param class1 1st class
+  \param class2 2nd class
 double I_cluster_separation(struct Cluster *C, int class1, int class2)
Modified: grass/trunk/lib/cluster/c_sig.c
--- grass/trunk/lib/cluster/c_sig.c	2009-07-30 23:42:43 UTC (rev 38543)
+++ grass/trunk/lib/cluster/c_sig.c	2009-07-31 10:51:49 UTC (rev 38544)
@@ -1,4 +1,25 @@
+  \file cluster/c_sig.c
+  \brief Cluster library - Signatures
+  \brief Create signatures
+  \return 0
 int I_cluster_signatures(struct Cluster *C)
     int c, p, band1, band2;
Modified: grass/trunk/lib/cluster/c_sum2.c
--- grass/trunk/lib/cluster/c_sum2.c	2009-07-30 23:42:43 UTC (rev 38543)
+++ grass/trunk/lib/cluster/c_sum2.c	2009-07-31 10:51:49 UTC (rev 38544)
@@ -1,14 +1,33 @@
+  \file cluster/c_sum2.c
+  \brief Cluster library - Sum of squares
-/* compute sum of squares for each class */
+  \brief Compute sum of squares for each class
+  \return 0
 int I_cluster_sum2(struct Cluster *C)
     int p, band, class;
     double q;
-       fprintf (stderr, "I_cluster_sum2(npoints=%d,nclasses=%d,nbands=%d)\n", C->npoints, C->nclasses, C->nbands);
+    G_debug(3, "I_cluster_sum2(npoints=%d,nclasses=%d,nbands=%d)",
     for (class = 0; class < C->nclasses; class++)
 	    C->sum2[band][class] = 0;
Modified: grass/trunk/lib/cluster/clusterlib.dox
--- grass/trunk/lib/cluster/clusterlib.dox	2009-07-30 23:42:43 UTC (rev 38543)
+++ grass/trunk/lib/cluster/clusterlib.dox	2009-07-31 10:51:49 UTC (rev 38544)
@@ -1,8 +1,86 @@
-/*! \page clusterlib GRASS cluster analysis statistics Library
+/*! \page clusterlib GRASS Cluster analysis statistics Library
-\section clusterintro Introduction to cluster analysis statistics Library
+by GRASS Development Team (http://grass.osgeo.org)
-This library does a k-means style of cluster analysis.
-It is currently only used by i.cluster.
+\section clusterintro Introduction
+This library does a k-means style of cluster analysis. It is currently
+only used by <tt>i.cluster</tt>.
+The library functions are defined in <tt>cluster.h</tt>.
+\code
+#include <grass/cluster.h>
+\endcode
+\section ClusterStruct Cluster structure
+\code
+struct Cluster
+    int nbands;                 /* number of bands */
+    int npoints;                /* number of points */
+    DCELL **points;             /* array of points */
+    int np;
+    double *band_sum;		/* sum over each band */
+    double *band_sum2;		/* sum of squares over each band */
+    int *class;			/* class of each point */
+    int *reclass;		/* for removing empty classes  */
+    int *count;			/* number of points in each class */
+    int *countdiff;		/* change in count */
+    double **sum;		/* sum over band per class */
+    double **sumdiff;		/* change in sum */
+    double **sum2;		/* sum of squares per band per class */
+    double **mean;		/* initial class means */
+    struct Signature S;		/* final signature(s) */
+    int nclasses;               /* number of classes */
+    int merge1, merge2;
+    int iteration;              /* number of iterations */
+    double percent_stable;      /* percentage stable */
+\endcode
+\section listFn List of functions
+ - I_cluster_assign()
+ - I_cluster_begin()
+ - I_cluster_clear()
+ - I_cluster_distinct()
+ - I_cluster_exec()
+ - I_cluster_exec_allocate()
+ - I_cluster_exec_free()
+ - I_cluster_means()
+ - I_cluster_merge()
+ - I_cluster_nclasses()
+ - I_cluster_point()
+ - I_cluster_begin_point_set()
+ - I_cluster_point_part()
+ - I_cluster_end_point_set()
+ - I_cluster_reassign()
+ - I_cluster_reclass()
+ - I_cluster_separation()
+ - I_cluster_signatures()
+ - I_cluster_sum2()
