[GRASS-SVN] r38546 - grass-addons/vector/v.krige
svn_grass at osgeo.org
Fri Jul 31 07:03:47 EDT 2009
Author: aghisla
Date: 2009-07-31 07:03:47 -0400 (Fri, 31 Jul 2009)
New Revision: 38546
grass-addons/vector/v.krige/v.krige.py
preparing interactive variogram fit frame
Modified: grass-addons/vector/v.krige/v.krige.py
--- grass-addons/vector/v.krige/v.krige.py 2009-07-31 11:02:13 UTC (rev 38545)
+++ grass-addons/vector/v.krige/v.krige.py 2009-07-31 11:03:47 UTC (rev 38546)
@@ -258,7 +258,7 @@
#controller istance
self.Controller = Controller()
-# 1. Input data
+ # 1. Input data
InputBoxSizer = wx.StaticBoxSizer(wx.StaticBox(self, id=wx.ID_ANY, label=_("Input Data")),
orient=wx.HORIZONTAL)
@@ -287,7 +287,7 @@
InputBoxSizer.Add(item = flexSizer)
-# 2. Kriging. In book pages one for each R package. Includes variogram fit.
+ # 2. Kriging. In book pages one for each R package. Includes variogram fit.
KrigingSizer = wx.StaticBoxSizer(wx.StaticBox(self, id=wx.ID_ANY, label=_("Kriging")), wx.HORIZONTAL)
self.RPackagesBook = FN.FlatNotebook(parent=self, id=wx.ID_ANY,
@@ -308,7 +308,7 @@
self.RPackagesBook.SetSelection(0)
KrigingSizer.Add(self.RPackagesBook, proportion=1, flag=wx.EXPAND)
-# 3. Output Parameters.
+ # 3. Output Parameters.
OutputSizer = wx.StaticBoxSizer(wx.StaticBox(self, id=wx.ID_ANY, label=_("Output")), wx.HORIZONTAL)
OutputParameters = wx.GridBagSizer(hgap=5, vgap=5)
@@ -329,7 +329,7 @@
OutputSizer.Add(OutputParameters, proportion=0, flag=wx.EXPAND | wx.ALL, border=3)
-# 4. Run Button and Quit Button
+ # 4. Run Button and Quit Button
ButtonSizer = wx.BoxSizer(wx.HORIZONTAL)
QuitButton = wx.Button(self, id=wx.ID_EXIT)
QuitButton.Bind(wx.EVT_BUTTON, self.OnCloseWindow)
@@ -338,7 +338,7 @@
ButtonSizer.Add(QuitButton, proportion=0, flag=wx.ALIGN_RIGHT | wx.ALL, border=self.border)
ButtonSizer.Add(RunButton, proportion=0, flag=wx.ALIGN_RIGHT | wx.ALL, border=self.border)
-# Main Sizer. Add each child sizer as soon as it is ready.
+ # Main Sizer. Add each child sizer as soon as it is ready.
Sizer = wx.BoxSizer(wx.VERTICAL)
Sizer.Add(InputBoxSizer, proportion=0, flag=wx.EXPAND | wx.ALL, border=self.border)
Sizer.Add(KrigingSizer, proportion=1, flag=wx.EXPAND | wx.ALL, border=self.border)
@@ -462,9 +462,6 @@
self.ParametersSizer.Add(getattr(self, n+"Text"), flag = wx.ALIGN_CENTER_VERTICAL)
self.ParametersSizer.Add(getattr(self, n+"Ctrl"), flag = wx.EXPAND | wx.ALIGN_CENTER_VERTICAL)
self.ParametersSizer.Add(getattr(self, n+"CheckBox"), flag = wx.ALIGN_CENTER_VERTICAL)
- #@TODO: deploy this asap!!
- #self.ParametersSizer.Add(wx.Button(self, id=wx.ID_ANY, label=_("Interactive variogram fit")))
# block kriging parameters. Size.
BlockLabel = wx.StaticText(self, id= wx.ID_ANY, label = _("Block size:"))
@@ -502,7 +499,8 @@
self.VariogramCheckBox.Bind(wx.EVT_CHECKBOX, self.HideOptions)
ModelFactor = robjects.r.vgm().r['long']
- ModelList = robjects.r.levels(ModelFactor[0]) # no other way to let the Python pick it up..
+ ModelList = robjects.r.levels(ModelFactor[0])
+ #@FIXME: no other way to let the Python pick it up..
# and this is te wrong place where to load this list. should be at the very beginning.
self.ModelChoicebox = wx.Choice(self, id=wx.ID_ANY, choices=ModelList)
@@ -517,9 +515,16 @@
id= wx.ID_ANY,
label = _("Variogram model")),
flag = wx.ALIGN_CENTER_VERTICAL | wx.ALL)
- self.ParametersSizer.Insert(before=1, item= self.ModelChoicebox)
- self.ParametersSizer.InsertStretchSpacer(2)
+ self.ParametersSizer.Insert(before=1,
+ item= self.ModelChoicebox,
+ flag = wx.ALIGN_CENTER_VERTICAL | wx.ALL)
+ #@TODO: deploy this asap!!
+ #self.InteractiveVariogramFitButton = wx.Button(self, id=wx.ID_ANY, label=_("Interactive variogram fit"))
+ #self.InteractiveVariogramFitButton.Bind(wx.EVT_BUTTON, self.InteractiveVariogramFit)
+ #self.ParametersSizer.Insert(before=2, item= self.InteractiveVariogramFitButton)
+ self.ParametersSizer.InsertStretchSpacer(2) ## use it until childframe will be ready
self.SetSizerAndFit(self.Sizer)
def HideOptions(self, event):
@@ -527,7 +532,13 @@
for n in ["Sill", "Nugget", "Range"]:
getattr(self, n+"Ctrl").Enable(not event.IsChecked())
getattr(self, n+ "CheckBox").SetValue(not event.IsChecked())
- #@FIXME: was for n in self.ParametersSizer.GetChildren(): n.Enable(False) but doesn't work
+ #@FIXME: was for n in self.ParametersSizer.GetChildren(): n.Enable(False) but doesn't work
+ def InteractiveVariogramFit(self, event):
+ """ Opens the frame with interactive variogram fit. """
+ FitFrame = VariogramDialog(parent = self)
+ FitFrame.Center()
+ FitFrame.Show()
class RBookgeoRPanel(RBookPanel):
""" Subclass of RBookPanel, with specific geoR options and kriging functions. """
@@ -538,6 +549,24 @@
n.Hide()
self.Sizer.Add(wx.StaticText(self, id= wx.ID_ANY, label = _("Work in progress! No functionality provided.")))
+class VariogramDialog(wx.Frame):
+ """ Dialog for interactive variogram fit. """
+ def __init__(self, parent, *args, **kwargs):
+ wx.Frame.__init__(self, parent, *args, **kwargs)
+ # setting properties and all widgettery
+ self.SetTitle(_("Variogram fit"))
+ self.SetIcon(wx.Icon(os.path.join(globalvar.ETCICONDIR, 'grass_dialog.ico'), wx.BITMAP_TYPE_ICO))
+ # set the widgets of the frame
+ # set the methods of the frame
+ # give the parent frame the result of the fit
+ #self.Panel = KrigingPanel(self)
+ #self.SetMinSize(self.GetBestSize())
+ #self.SetSize(self.GetBestSize())
def main(argv=None):
#@FIXME: solve this double ifelse. the control should not be done twice.
