[GRASS-SVN] r38552 - in grass/trunk: display/d.extract display/d.thematic.area display/d.vect display/d.zoom general/g.region gui/wxpython/vdigit imagery/i.points include include/vect lib/gis lib/nviz lib/sites lib/vector/Vlib lib/vector/dglib lib/vector/diglib ps/ps.map raster/r.region vector/lidar/lidarlib vector/lidar/v.lidar.correction vector/lidar/v.lidar.edgedetection vector/lidar/v.lidar.growing vector/lidar/v.outlier vector/lidar/v.surf.bspline vector/v.clean vector/v.convert vector/v.db.select vector/v.delaunay vector/v.distance vector/v.edit vector/v.external vector/v.generalize vector/v.hull vector/v.in.dxf vector/v.in.ogr vector/v.info vector/v.kcv vector/v.kernel vector/v.label.sa vector/v.neighbors vector/v.normal vector/v.out.dxf vector/v.out.svg vector/v.patch vector/v.select vector/v.support vector/v.to.3d vector/v.transform vector/v.voronoi vector/v.what.rast visualization/nviz/src
Fri Jul 31 07:46:59 EDT 2009
Author: martinl
Date: 2009-07-31 07:46:59 -0400 (Fri, 31 Jul 2009)
New Revision: 38552
   grass/trunk/display/d.extract/extract.c
   grass/trunk/display/d.thematic.area/area.c
   grass/trunk/display/d.thematic.area/main.c
   grass/trunk/display/d.vect/area.c
   grass/trunk/display/d.vect/main.c
   grass/trunk/display/d.vect/plot1.c
   grass/trunk/display/d.zoom/main.c
   grass/trunk/general/g.region/main.c
   grass/trunk/gui/wxpython/vdigit/driver.cpp
   grass/trunk/gui/wxpython/vdigit/driver.h
   grass/trunk/gui/wxpython/vdigit/driver_draw.cpp
   grass/trunk/gui/wxpython/vdigit/driver_select.cpp
   grass/trunk/gui/wxpython/vdigit/line.cpp
   grass/trunk/imagery/i.points/driver.c
   grass/trunk/include/P_site.h
   grass/trunk/include/cluster.h
   grass/trunk/include/proto_dbmi.h
   grass/trunk/include/std_incs.h
   grass/trunk/include/vect/dig_defines.h
   grass/trunk/include/vect/dig_externs.h
   grass/trunk/include/vect/dig_macros.h
   grass/trunk/include/vect/dig_structs.h
   grass/trunk/include/vector.h
   grass/trunk/lib/gis/Makefile
   grass/trunk/lib/gis/find_file.c
   grass/trunk/lib/gis/find_vect.c
   grass/trunk/lib/gis/legal_name.c
   grass/trunk/lib/gis/open.c
   grass/trunk/lib/gis/zero.c
   grass/trunk/lib/nviz/nvizlib.dox
   grass/trunk/lib/sites/sites.c
   grass/trunk/lib/vector/Vlib/area.c
   grass/trunk/lib/vector/Vlib/array.c
   grass/trunk/lib/vector/Vlib/box.c
   grass/trunk/lib/vector/Vlib/break_lines.c
   grass/trunk/lib/vector/Vlib/build.c
   grass/trunk/lib/vector/Vlib/build_nat.c
   grass/trunk/lib/vector/Vlib/build_ogr.c
   grass/trunk/lib/vector/Vlib/cindex.c
   grass/trunk/lib/vector/Vlib/clean_nodes.c
   grass/trunk/lib/vector/Vlib/close.c
   grass/trunk/lib/vector/Vlib/close_ogr.c
   grass/trunk/lib/vector/Vlib/constraint.c
   grass/trunk/lib/vector/Vlib/dgraph.h
   grass/trunk/lib/vector/Vlib/error.c
   grass/trunk/lib/vector/Vlib/find.c
   grass/trunk/lib/vector/Vlib/geos.c
   grass/trunk/lib/vector/Vlib/graph.c
   grass/trunk/lib/vector/Vlib/header.c
   grass/trunk/lib/vector/Vlib/hist.c
   grass/trunk/lib/vector/Vlib/init_head.c
   grass/trunk/lib/vector/Vlib/level_two.c
   grass/trunk/lib/vector/Vlib/line.c
   grass/trunk/lib/vector/Vlib/map.c
   grass/trunk/lib/vector/Vlib/merge_lines.c
   grass/trunk/lib/vector/Vlib/open.c
   grass/trunk/lib/vector/Vlib/open_nat.c
   grass/trunk/lib/vector/Vlib/open_ogr.c
   grass/trunk/lib/vector/Vlib/poly.c
   grass/trunk/lib/vector/Vlib/read_nat.c
   grass/trunk/lib/vector/Vlib/read_ogr.c
   grass/trunk/lib/vector/Vlib/remove_duplicates.c
   grass/trunk/lib/vector/Vlib/select.c
   grass/trunk/lib/vector/Vlib/sindex.c
   grass/trunk/lib/vector/Vlib/tin.c
   grass/trunk/lib/vector/Vlib/write_nat.c
   grass/trunk/lib/vector/dglib/graph.h
   grass/trunk/lib/vector/dglib/graph_v1.h
   grass/trunk/lib/vector/dglib/graph_v2.h
   grass/trunk/lib/vector/diglib/box.c
   grass/trunk/lib/vector/diglib/cindex.c
   grass/trunk/lib/vector/diglib/cindex_rw.c
   grass/trunk/lib/vector/diglib/file.c
   grass/trunk/lib/vector/diglib/frmt.c
   grass/trunk/lib/vector/diglib/inside.c
   grass/trunk/lib/vector/diglib/plus.c
   grass/trunk/lib/vector/diglib/plus_area.c
   grass/trunk/lib/vector/diglib/plus_line.c
   grass/trunk/lib/vector/diglib/plus_node.c
   grass/trunk/lib/vector/diglib/plus_struct.c
   grass/trunk/lib/vector/diglib/port_init.c
   grass/trunk/lib/vector/diglib/portable.c
   grass/trunk/lib/vector/diglib/spindex.c
   grass/trunk/lib/vector/diglib/spindex_rw.c
   grass/trunk/lib/vector/diglib/struct_alloc.c
   grass/trunk/lib/vector/diglib/test.c
   grass/trunk/ps/ps.map/ps_vareas.c
   grass/trunk/ps/ps.map/ps_vlines.c
   grass/trunk/ps/ps.map/ps_vpoints.c
   grass/trunk/raster/r.region/main.c
   grass/trunk/vector/lidar/lidarlib/PolimiFunct.h
   grass/trunk/vector/lidar/lidarlib/raster.c
   grass/trunk/vector/lidar/lidarlib/zones.c
   grass/trunk/vector/lidar/v.lidar.correction/correction.c
   grass/trunk/vector/lidar/v.lidar.correction/correction.h
   grass/trunk/vector/lidar/v.lidar.correction/main.c
   grass/trunk/vector/lidar/v.lidar.edgedetection/edgedetection.c
   grass/trunk/vector/lidar/v.lidar.edgedetection/edgedetection.h
   grass/trunk/vector/lidar/v.lidar.edgedetection/main.c
   grass/trunk/vector/lidar/v.lidar.growing/main.c
   grass/trunk/vector/lidar/v.outlier/main.c
   grass/trunk/vector/lidar/v.outlier/outlier.c
   grass/trunk/vector/lidar/v.outlier/outlier.h
   grass/trunk/vector/lidar/v.surf.bspline/main.c
   grass/trunk/vector/v.clean/prune.c
   grass/trunk/vector/v.convert/read.c
   grass/trunk/vector/v.db.select/main.c
   grass/trunk/vector/v.delaunay/defs.h
   grass/trunk/vector/v.delaunay/in_out.c
   grass/trunk/vector/v.delaunay/in_out.h
   grass/trunk/vector/v.delaunay/main.c
   grass/trunk/vector/v.distance/main.c
   grass/trunk/vector/v.edit/select.c
   grass/trunk/vector/v.external/main.c
   grass/trunk/vector/v.generalize/displacement.c
   grass/trunk/vector/v.generalize/main.c
   grass/trunk/vector/v.generalize/network.c
   grass/trunk/vector/v.generalize/operators.h
   grass/trunk/vector/v.hull/main.c
   grass/trunk/vector/v.in.dxf/dxf_to_vect.c
   grass/trunk/vector/v.in.ogr/geom.c
   grass/trunk/vector/v.in.ogr/main.c
   grass/trunk/vector/v.info/main.c
   grass/trunk/vector/v.kcv/main.c
   grass/trunk/vector/v.kernel/main.c
   grass/trunk/vector/v.label.sa/labels.c
   grass/trunk/vector/v.label.sa/labels.h
   grass/trunk/vector/v.neighbors/main.c
   grass/trunk/vector/v.normal/main.c
   grass/trunk/vector/v.out.dxf/main.c
   grass/trunk/vector/v.out.svg/main.c
   grass/trunk/vector/v.patch/main.c
   grass/trunk/vector/v.select/main.c
   grass/trunk/vector/v.support/main.c
   grass/trunk/vector/v.to.3d/main.c
   grass/trunk/vector/v.transform/main.c
   grass/trunk/vector/v.voronoi/defs.h
   grass/trunk/vector/v.voronoi/sw_main.c
   grass/trunk/vector/v.what.rast/main.c
   grass/trunk/visualization/nviz/src/site_attr_commands.c
vectorlib:
	* eliminate 'typedef struct'
	* GRASS_VECT renamed to GV_
Modified: grass/trunk/display/d.extract/extract.c
--- grass/trunk/display/d.extract/extract.c	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/display/d.extract/extract.c	2009-07-31 11:46:59 UTC (rev 38552)
@@ -25,7 +25,7 @@
     int screen_x, screen_y, cur_screen_x, cur_screen_y;
     double x1, y1, x2, y2;
     struct ilist *List, *CList;
-    BOUND_BOX box;
+    struct bound_box box;
     struct line_pnts *Points;
     struct line_cats *Cats;
Modified: grass/trunk/display/d.thematic.area/area.c
--- grass/trunk/display/d.thematic.area/area.c	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/display/d.thematic.area/area.c	2009-07-31 11:46:59 UTC (rev 38552)
@@ -38,7 +38,7 @@
     for (area = 1; area <= num; area++) {
 	int i;
-	BOUND_BOX box;
 	G_debug(3, "area = %d", area);
Modified: grass/trunk/display/d.thematic.area/main.c
--- grass/trunk/display/d.thematic.area/main.c	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/display/d.thematic.area/main.c	2009-07-31 11:46:59 UTC (rev 38552)
@@ -64,7 +64,7 @@
     dbHandle handle;
     dbCatValArray cvarr;
     struct Cell_head window;
-    BOUND_BOX box;
     double overlap, *breakpoints, *data = NULL, class_info = 0.0;
     struct GASTATS stats;
     FILE *fd;
Modified: grass/trunk/display/d.vect/area.c
--- grass/trunk/display/d.vect/area.c	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/display/d.vect/area.c	2009-07-31 11:46:59 UTC (rev 38552)
@@ -132,7 +132,7 @@
 	int i;
-	BOUND_BOX box;
@@ -231,7 +231,7 @@
 	/* z height colors */
 	if (z_color_flag && Vect_is_3d(Map)) {
-	    BOUND_BOX box;
 	    double zval;
 	    struct Colors colors;
Modified: grass/trunk/display/d.vect/main.c
--- grass/trunk/display/d.vect/main.c	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/display/d.vect/main.c	2009-07-31 11:46:59 UTC (rev 38552)
@@ -109,7 +109,7 @@
     dbDriver *driver;
     dbHandle handle;
-    BOUND_BOX box;
     double overlap;
     /* Initialize the GIS calls */
Modified: grass/trunk/display/d.vect/plot1.c
--- grass/trunk/display/d.vect/plot1.c	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/display/d.vect/plot1.c	2009-07-31 11:46:59 UTC (rev 38552)
@@ -323,7 +323,7 @@
-	    BOUND_BOX box;
 	    double zval;
Modified: grass/trunk/display/d.zoom/main.c
--- grass/trunk/display/d.zoom/main.c	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/display/d.zoom/main.c	2009-07-31 11:46:59 UTC (rev 38552)
@@ -161,7 +161,7 @@
     if (vect) {
 	struct Map_info Map;
-	BOUND_BOX box;
 	for (i = 0; vect[i]; i++) ;
 	nvects = i;
Modified: grass/trunk/general/g.region/main.c
--- grass/trunk/general/g.region/main.c	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/general/g.region/main.c	2009-07-31 11:46:59 UTC (rev 38552)
@@ -496,7 +496,7 @@
 	vect_ptr = parm.vect->answers;
 	for (; *vect_ptr != NULL; vect_ptr++) {
-	    BOUND_BOX box;
 	    char vect_name[GNAME_MAX];
 	    struct Cell_head map_window;
Modified: grass/trunk/gui/wxpython/vdigit/driver.cpp
--- grass/trunk/gui/wxpython/vdigit/driver.cpp	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/gui/wxpython/vdigit/driver.cpp	2009-07-31 11:46:59 UTC (rev 38552)
@@ -498,7 +498,7 @@
 std::vector<double> DisplayDriver::GetMapBoundingBox()
     std::vector<double> region;
-    BOUND_BOX bbox;
+    struct bound_box bbox;
     if (!mapInfo) {
 	return region;
Modified: grass/trunk/gui/wxpython/vdigit/driver.h
--- grass/trunk/gui/wxpython/vdigit/driver.h	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/gui/wxpython/vdigit/driver.h	2009-07-31 11:46:59 UTC (rev 38552)
@@ -66,7 +66,7 @@
     struct _region {
 	// GRASS region section
-	BOUND_BOX box; // W,E,N,S,T,B
+	struct bound_box box; // W,E,N,S,T,B
 	double ns_res;
 	double ew_res;
 	double center_easting;
Modified: grass/trunk/gui/wxpython/vdigit/driver_draw.cpp
--- grass/trunk/gui/wxpython/vdigit/driver_draw.cpp	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/gui/wxpython/vdigit/driver_draw.cpp	2009-07-31 11:46:59 UTC (rev 38552)
@@ -32,7 +32,7 @@
 	return -1;
     int nlines;
-    BOUND_BOX mapBox;
+    struct bound_box mapBox;
     struct ilist *listLines;
     // ids.clear();
Modified: grass/trunk/gui/wxpython/vdigit/driver_select.cpp
--- grass/trunk/gui/wxpython/vdigit/driver_select.cpp	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/gui/wxpython/vdigit/driver_select.cpp	2009-07-31 11:46:59 UTC (rev 38552)
@@ -489,7 +489,7 @@
-    BOUND_BOX region_box, line_box;
+    struct bound_box region_box, line_box;
     struct ilist *list, *list_tmp;
     list = list_tmp = NULL;
Modified: grass/trunk/gui/wxpython/vdigit/line.cpp
--- grass/trunk/gui/wxpython/vdigit/line.cpp	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/gui/wxpython/vdigit/line.cpp	2009-07-31 11:46:59 UTC (rev 38552)
@@ -962,7 +962,7 @@
     int ret, type, nlines;
     int lineBreak;
-    BOUND_BOX lineBox;
+    struct bound_box lineBox;
     struct ilist *list, *listBreak, *listRef;
     struct line_pnts *points_check, *points;
Modified: grass/trunk/imagery/i.points/driver.c
--- grass/trunk/imagery/i.points/driver.c	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/imagery/i.points/driver.c	2009-07-31 11:46:59 UTC (rev 38552)
@@ -14,7 +14,7 @@
 	MENU("PLOT RASTER", plotcell, &use),
 	MENU("ANALYZE", analyze, &use),
 	INFO("  Input method -> ", &from_flag),
-	OPTION("DIGITIZER", 2, &from_digitizer),
+	/*	OPTION("DIGITIZER", 2, &from_digitizer), */
 	OPTION("KEYBOARD", 2, &from_keyboard),
 	OPTION("SCREEN", 2, &from_screen),
 	OTHER(mark, &use),
Modified: grass/trunk/include/P_site.h
--- grass/trunk/include/P_site.h	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/include/P_site.h	2009-07-31 11:46:59 UTC (rev 38552)
@@ -13,7 +13,7 @@
 int G_site_s_cmp(const void *a, const void *b);
 char *G_site_format(const Site * s, const char *fs, int id);
-/* SITE_ATT * G_sites_get_atts (struct Map_info * ptr, int* cat); */
+/* struct site_att * G_sites_get_atts (struct Map_info * ptr, int* cat); */
 int G_sites_get_fields(struct Map_info *ptr, char ***cnames, int **ctypes,
 		       int **ndx);
 void G_sites_free_fields(int ncols, char **cnames, int *ctypes, int *ndx);
Modified: grass/trunk/include/cluster.h
--- grass/trunk/include/cluster.h	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/include/cluster.h	2009-07-31 11:46:59 UTC (rev 38552)
@@ -6,9 +6,9 @@
 struct Cluster
-    int nbands;
-    int npoints;
-    DCELL **points;
+    int nbands;                 /* number of bands */
+    int npoints;                /* number of points */
+    DCELL **points;             /* array of points */
     int np;
     double *band_sum;		/* sum over each band */
@@ -24,10 +24,10 @@
     double **mean;		/* initial class means */
     struct Signature S;		/* final signature(s) */
-    int nclasses;
+    int nclasses;               /* number of classes */
     int merge1, merge2;
-    int iteration;
-    double percent_stable;
+    int iteration;              /* number of iterations */
+    double percent_stable;      /* percentage stable */
 /* c_assign.c */
Modified: grass/trunk/include/proto_dbmi.h
--- grass/trunk/include/proto_dbmi.h	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/include/proto_dbmi.h	2009-07-31 11:46:59 UTC (rev 38552)
@@ -53,7 +53,7 @@
 int db_convert_value_to_string(dbValue * value, int sqltype,
 			       dbString * string);
 void db_copy_dbmscap_entry(dbDbmscap * dst, dbDbmscap * src);
-int db_copy_string(dbString * dst, dbString * src);
+int db_copy_string(dbString * dst, const dbString * src);
 int db_table_to_sql(dbTable *, dbString *);
 int db_copy_table(const char *, const char *, const char *, const char *,
 		  const char *, const char *);
@@ -173,7 +173,7 @@
 int db_get_index_number_of_columns(dbIndex * index);
 const char *db_get_index_table_name(dbIndex * index);
 int db_get_num_rows(dbCursor * cursor);
-char *db_get_string(dbString * x);
+char *db_get_string(const dbString * x);
 dbColumn *db_get_table_column(dbTable * table, int n);
 int db_get_table_delete_priv(dbTable * table);
 const char *db_get_table_description(dbTable * table);
@@ -398,7 +398,7 @@
 const char *db_whoami(void);
 void db_zero(void *s, int n);
 void db_zero_string(dbString * x);
-unsigned int db_sizeof_string(dbString * x);
+unsigned int db_sizeof_string(const dbString * x);
 int db_set_login(const char *, const char *, const char *, const char *);
 int db_get_login(const char *, const char *, const char **, const char **);
Modified: grass/trunk/include/std_incs.h
--- grass/trunk/include/std_incs.h	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/include/std_incs.h	2009-07-31 11:46:59 UTC (rev 38552)
@@ -16,7 +16,7 @@
 #include <stdio.h>
 #include <signal.h>
 #include <sys/stat.h>
-#if defined(sparc) || defined (uts) || defined(SVR4) || defined(IGRAPH)
+#if defined(sparc) || defined (uts) || defined(SVR4) || defined(IdglGraph_s)
 #include <dirent.h>
 #else
 #include <sys/dir.h>
Modified: grass/trunk/include/vect/dig_defines.h
--- grass/trunk/include/vect/dig_defines.h	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/include/vect/dig_defines.h	2009-07-31 11:46:59 UTC (rev 38552)
@@ -1,26 +1,58 @@
-#define GRASS_OK    0
-#define GRASS_ERR (-1)
+  \file include/vect/dig_defines.h
+  Defines for diglib (part of vector library)
+/*! \brief Exit/print/return on error
+  \todo To be moved to gislib
 #define GV_FATAL_EXIT    0
 #define GV_FATAL_PRINT   1
 #define GV_FATAL_RETURN  2
-#define GRASS_VECT_DIRECTORY    "vector"	/* name of vector directory */
-#define GRASS_VECT_FRMT_ELEMENT "frmt"	/* format description, data location */
-#define GRASS_VECT_COOR_ELEMENT "coor"	/* coordinates */
-#define GRASS_VECT_HEAD_ELEMENT "head"	/* header information */
-#define GRASS_VECT_DBLN_ELEMENT "dbln"	/* link to database */
-#define GRASS_VECT_HIST_ELEMENT "hist"	/* history file */
-#define GV_TOPO_ELEMENT "topo"	/* topology */
-#define GV_SIDX_ELEMENT "sidx"	/* spatial index */
-#define GV_CIDX_ELEMENT "cidx"	/* category index */
+/*! \brief Vector directory layout, element names */
+/*! \brief Name of vector directory */
+#define GV_DIRECTORY    "vector"
+/*! \brief Format description, data location (OGR) */
+#define GV_FRMT_ELEMENT "frmt"
+/*! \brief Native format, coordinates */
+#define GV_COOR_ELEMENT "coor"
+/*! \brief Native format, header information */
+#define GV_HEAD_ELEMENT "head"
+/*! \brief Native format, link to database */
+#define GV_DBLN_ELEMENT "dbln"
+/*! \brief Native format, history file */
+#define GV_HIST_ELEMENT "hist"
+/*! \brief Native format, topology file */
+#define GV_TOPO_ELEMENT "topo"
+/*! \brief Native format, spatial index */
+#define GV_SIDX_ELEMENT "sidx"
+/*! \brief Native format, category index */
+#define GV_CIDX_ELEMENT "cidx"
+/*! \brief External format (OGR), feature index */
+#define GV_FIDX_ELEMENT "fidx"
+/*! \brief Endian check
+  \todo To be moved to gislib?
 #define ENDIAN_LITTLE 0
 #define ENDIAN_BIG    1
 #define ENDIAN_OTHER  2
-/* sizes of types used in portable format (different names used in
- * Vlib/ and diglib/ for the same thing) */
+/*! \brief Sizes of types used in portable format (different names used in
+  Vlib/ and diglib/ for the same thing)
+  Assumptions:
+   - double =    8 byte IEEE
+   -  float =    4 byte IEEE
+   -   long =    4 byte int
+   -  short =    2 byte int
 #define PORT_DOUBLE 8
 #define PORT_FLOAT  4
 #define PORT_LONG   4
@@ -29,22 +61,19 @@
 #define PORT_CHAR   1
 #define PORT_OFF_T  8
-/* replace by PORT_* in Vlib later and remove : */
+/*! \brief replace by PORT_* in Vlib later and remove :
+  \todo To be removed ?
 #define DBL_SIZ  8
 #define FLT_SIZ  4
 #define LNG_SIZ  4
 #define SHRT_SIZ 2
- ** assumptions:
- **    double =    8 byte IEEE
- **    float  =    4 byte IEEE
- **    long   =    4 byte int
- **    short  =    2 byte int
+/*! \brief Limits for portable types
-/* Limits for portable types - I am not sure if OK */
 #define PORT_DOUBLE_MAX 1.7976931348623157e+308
 #define PORT_DOUBLE_MIN 2.2250738585072014e-308
 #define PORT_FLOAT_MAX  3.40282347e+38F
@@ -58,48 +87,70 @@
 #define PORT_CHAR_MAX   127
 #define PORT_CHAR_MIN   (-128)
-/* Geometry data formats supported by lib */
-/* Don't change GV_FORMAT_* values, this order is hardcoded in lib */
-#define GV_FORMAT_NATIVE   0	/* grass native format */
-#define GV_FORMAT_OGR      1	/* OGR format */
+/*! \brief Geometry data formats supported by lib
+  Don't change GV_FORMAT_* values, this order is hardcoded in lib
+/*! \brief GRASS native format */
+#define GV_FORMAT_NATIVE   0
+/*! \brief OGR format */
+#define GV_FORMAT_OGR      1
-/* How may tables linked to map */
-#define GV_1TABLE  0		/* One table */
-#define GV_MTABLE  1		/* More, many, multi */
+/*! \brief One table linked to vector map */
+#define GV_1TABLE  0
+/*! \brief More tables linked to vector map */
+#define GV_MTABLE  1
+/*! \brief Read-only vector map open mode */
 #define GV_MODE_READ  0
+/*! \brief Write vector map open mode */
 #define GV_MODE_WRITE 1
+/*! \brief Read-write vector map open mode */
 #define GV_MODE_RW    2
+/*! \brief Vector map open code */
 #define VECT_OPEN_CODE   0x5522AA22
+/*! \brief Vector map close code */
 #define VECT_CLOSED_CODE 0x22AA2255
+/*! \brief Vector level
+  - 1 without topology
+  - 2 topology
+  - 3 ?
 #define LEVEL_1  1
 #define LEVEL_2  2
 #define LEVEL_3  3
-/* Topology level details */
-#define GV_BUILD_NONE  0
-#define GV_BUILD_BASE  1
-#define GV_BUILD_AREAS  2
-#define GV_BUILD_ATTACH_ISLES 3	/* Attach islands to areas */
-#define GV_BUILD_CENTROIDS 4	/* Assign centroids to areas */
-#define GV_BUILD_ALL GV_BUILD_CENTROIDS
+/*! \brief Topology level details */
+/*! \brief Nothing to build */
+#define GV_BUILD_NONE         0
+/*! \brief Basic level */
+#define GV_BUILD_BASE         1
+/*! \brief Build areas */
+#define GV_BUILD_AREAS        2
+/*! \brief Attach islands to areas */
+#define GV_BUILD_ATTACH_ISLES 3
+/*! \brief Assign centroids to areas */
+#define GV_BUILD_CENTROIDS    4
+#define GV_BUILD_ALL          GV_BUILD_CENTROIDS
+/*! \brief Check if vector map is open */
 #define VECT_OPEN(Map)   (Map->open == VECT_OPEN_CODE)
-/* Memory mode */
+/*! \brief Memory mode */
 #define GV_MEMORY_ALWAYS 1
 #define GV_MEMORY_NEVER  2
 #define GV_MEMORY_AUTO   3
+/*! \brief Coordinates file head size */
 #define GV_COOR_HEAD_SIZE 14
 #define GRASS_V_VERSION       "5.0"
-/* The latest versions of files known by current version of the library. Used for new files */
+/*! \brief The latest versions of files known by current version of
+    the library. Used for new files */
 #define GV_COOR_VER_MAJOR  5
 #define GV_COOR_VER_MINOR  1
 #define GV_TOPO_VER_MAJOR  5
 #define GV_TOPO_VER_MINOR  0
 #define GV_SIDX_VER_MAJOR  5
@@ -107,10 +158,10 @@
 #define GV_CIDX_VER_MAJOR  5
 #define GV_CIDX_VER_MINOR  0
-/* The oldest versions of the library, which are capable to read the files created by the current version */
+/*! \brief The oldest versions of the library, which are capable to
+    read the files created by the current version */
 #define GV_COOR_EARLIEST_MAJOR  5
 #define GV_COOR_EARLIEST_MINOR	1
 #define GV_TOPO_EARLIEST_MAJOR  5
 #define GV_TOPO_EARLIEST_MINOR	0
 #define GV_SIDX_EARLIEST_MAJOR  5
@@ -118,25 +169,19 @@
 #define GV_CIDX_EARLIEST_MAJOR  5
 #define GV_CIDX_EARLIEST_MINOR	0
+/*! \brief 2D/3D vector data */
 #define WITHOUT_Z	0
 #define WITH_Z		1
-#define DIGITIZER	0
-#define MOUSE		1
-#define ON	1
-#define OFF	0
-/* note this is changed from  3.0  which had 0.04   -dpg */
-#define THRESH_FUDGE   0.03
+/*! \brief Side indicator left/right */
 #define GV_LEFT	 1
 #define GV_RIGHT 2
-#define GV_FORWARD 1
+/*! \brief Direction indicator forward/backward */
+#define GV_FORWARD  1
 #define GV_BACKWARD 2
-/* types used in memory on run time - may change */
+/*! \brief Types used in memory on run time (may change) */
 #define GV_POINT      0x01
 #define GV_LINE	      0x02
 #define GV_BOUNDARY   0x04
@@ -149,7 +194,7 @@
 #define GV_POINTS (GV_POINT | GV_CENTROID )
 #define GV_LINES (GV_LINE | GV_BOUNDARY )
-/* types used in store like 'coor' file or postgis type column - must not change */
+/*! \types Used in store like 'coor' file or postgis type column (must not change) */
 #define GV_STORE_POINT    1
 #define GV_STORE_LINE     2
 #define GV_STORE_BOUNDARY 3
@@ -159,7 +204,7 @@
 #define GV_STORE_AREA     7	/* used in category index file */
 #define GV_STORE_VOLUME   8	/* used in category index file */
-/* Overlay operators */
+/*! \brief Overlay operators */
 #define GV_ON_AND     "AND"	/* intersect */
 #define GV_ON_OVERLAP "OVERLAP"
@@ -171,36 +216,11 @@
 typedef enum overlay_operator OVERLAY_OPERATOR;
-#define ESC	033
+/*! \brief Maximum number of categories for one element */
+#define GV_NCATS_MAX PORT_INT_MAX
+/*! \brief Maximum field */
+#define GV_FIELD_MAX PORT_INT_MAX
+/*! \brief Maximum category value */
+#define GV_CAT_MAX   PORT_INT_MAX
-#ifdef FOO
-/* these have all turned into global ints.  in digit/globals.h */
-/* colors of unique items on screen */
-#define CLR_LINE	BLUE
-#define CLR_AREA	GREY
-#define CLR_DOT		GREEN
-#define CLR_SITE	GREEN
-#define CLR_LLINE	MAGENTA
-#define CLR_LSITE	AQUA
-#define CLR_LAREA	ORANGE
-#define CLR_AMARK	AQUA
-#define CLR_ALABEL	ORANGE
-#define CLR_LLABEL	MAGENTA
-#define CLR_HIGHLIGHT	YELLOW
-#define CLR_ERASE	BLACK
-#define CLR_UNKNOWN	WHITE
-#define CLR_OVERLAY	WHITE
-#define CLR_0_NODE	GREEN
-#define CLR_1_NODE	ORANGE
-#define CLR_2_NODE	RED
-#endif
-#define GV_NCATS_MAX PORT_INT_MAX	/* maximum number of categories for one element */
-#define GV_FIELD_MAX PORT_INT_MAX	/* maximum field */
-#define GV_CAT_MAX   PORT_INT_MAX	/* maximum category value */
-#define BUILD_PROG "v.build"
+#define HEADSTR	50
Modified: grass/trunk/include/vect/dig_externs.h
--- grass/trunk/include/vect/dig_externs.h	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/include/vect/dig_externs.h	2009-07-31 11:46:59 UTC (rev 38552)
@@ -1,3 +1,9 @@
+  \file include/vect/dig_externs.h
+  \brief Function prototypes for diglib (part of vector library)
 void *dig_alloc_space(int, int *, int, void *, int);	/* exits on error, calls _alloc_space () */
 void *dig__alloc_space(int, int *, int, void *, int);	/* returns NULL on error, calls calloc(), _frealloc() */
 void *dig_falloc(int, int);	/* exits on error, calls _falloc () */
Modified: grass/trunk/include/vect/dig_macros.h
--- grass/trunk/include/vect/dig_macros.h	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/include/vect/dig_macros.h	2009-07-31 11:46:59 UTC (rev 38552)
@@ -1,14 +1,8 @@
-/* convert UTM to screen */
-#define XADJ(x)		(int)((x - U_west ) * U_to_D_xconv + D_west)
-#define YADJ(y)		(int)((y - U_south) * U_to_D_yconv + D_south)
+  \file include/vect/dig_macros.h
-#define _TOGGLE(x) ((x) ? 0 : 1)
-#define TOGGLE(x)  ((x) = _TOGGLE (x))
-#define BEEP	   putchar ('\007')
-#define ON_OFF(x)  ((x) ? "        ON" : "       OFF")
-   #define ABS(x)          ((x) < 0 ? -(x) : (x))
+  \brief Macros for diglib (part of vector library
 /* ALIVE MACROS take a pointer the the structure in question */
 /*  and return 0 or non-zero */
@@ -22,7 +16,3 @@
 #define LESSER(x,y)  ((x) < (y) ? (x) : (y))
 #define GREATER(x,y) ((x) > (y) ? (x) : (y))
-/* temporary till 3.0 */
-/*#define R_standard_color(x) R_color (x) */
Modified: grass/trunk/include/vect/dig_structs.h
--- grass/trunk/include/vect/dig_structs.h	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/include/vect/dig_structs.h	2009-07-31 11:46:59 UTC (rev 38552)
@@ -1,13 +1,17 @@
- **  Written by Dave Gerdes  5/1988
- **  US Army Construction Engineering Research Lab
+  \file include/vect/dig_structs.h
+  \brief Structures for diglib (vector library)
+  \author Written by Dave Gerdes (CERL)  5/1988
+  \author Updated to GRASS 5.7 by Radim Blazek (2001)
 #include <grass/config.h>
 #ifndef  DIG___STRUCTS___
 #define DIG___STRUCTS___
-/*  this file depends on  <stdio.h> */
+/*  this file depends on <stdio.h> */
 #ifndef _STDIO_H
 #include <stdio.h>
 #endif
@@ -19,32 +23,20 @@
 #include <grass/btree.h>
 #include <grass/rtree.h>
 #ifdef HAVE_OGR
 #include "ogr_api.h"
 #endif
-#define HEADSTR	50
+/*! \brief plus_t size
- **  NOTE: 3.10 changes plus_t to  ints.
- **    This assumes that any reasonable machine will use 4 bytes to
- **    store an int.  The mapdev code is not guaranteed to work if
- **    plus_t is changed to a type that is larger than an int.
-   typedef short plus_t;
+  3.10 changes plus_t to  ints.
+  This assumes that any reasonable machine will use 4 bytes to
+  store an int. The mapdev code is not guaranteed to work if
+  plus_t is changed to a type that is larger than an int.
 typedef int plus_t;
-typedef struct bound_box BOUND_BOX;
-typedef struct P_node P_NODE;
-typedef struct P_area P_AREA;
-typedef struct P_line P_LINE;
-typedef struct P_isle P_ISLE;
-/* Used by sites lib */
+/*! \brief Used by sites lib */
 struct site_att
     int cat;			/* category */
@@ -52,9 +44,8 @@
     char **str;			/* string attributes */
-typedef struct site_att SITE_ATT;
-struct bound_box		/* Bounding Box */
+/*! \brief Bounding box */
+struct bound_box
     double N;			/* north */
     double S;			/* south */
@@ -64,43 +55,42 @@
     double B;			/* bottom */
+/*! \brief File definition */
 struct gvfile
     FILE *file;
     char *start;		/* pointer to beginnig of the file in the memory */
-    char *current;		/* current position set by dig_seek */
+    char *current;		/* current position set by dig_seek() */
     char *end;			/* end of file in the memory (pointer to first byte after) */
     off_t size;			/* size of the file loaded to memory */
     off_t alloc;		/* allocated space */
     int loaded;			/* 0 - not loaded, 1 - loaded */
-typedef struct gvfile GVFILE;
-/* category field information */
+/*! \brief Field information */
 struct field_info
     int number;			/* field number */
     char *name;			/* field name */
-    char *driver;
-    char *database;
-    char *table;
-    char *key;
+    char *driver;               /* db driver */
+    char *database;             /* db database */
+    char *table;                /* db table */
+    char *key;                  /* table key */
+/*! \brief Database links */
 struct dblinks
-    struct field_info *field;
-    int alloc_fields, n_fields;
+    struct field_info *field;   /* pointer to the first field_info structure */
+    int alloc_fields;           /* number of allocated slots */
+    int n_fields;               /* number of available fields */
-/* Portability info */
+/*! \brief Portability info - set in V1_open_new/old() */
 struct Port_info
-    /* portability stuff, set in V1_open_new/old() */
-    /* file byte order */
-    int byte_order;
-    int off_t_size;
+    int byte_order;             /* file byte order */
+    int off_t_size;             /* off_t size */
     /* conversion matrices between file and native byte order */
     unsigned char dbl_cnvrt[PORT_DOUBLE];
@@ -110,9 +100,8 @@
     unsigned char shrt_cnvrt[PORT_SHORT];
     unsigned char off_t_cnvrt[PORT_OFF_T];
-    /* *_quick specify if native byte order of that type
-     * is the same as byte order of vector file (TRUE)
-     * or not (FALSE);*/
+    /* *_quick specify if native byte order of that type is the same
+      as byte order of vector file (TRUE) or not (FALSE) */
     int dbl_quick;
     int flt_quick;
     int lng_quick;
@@ -121,68 +110,70 @@
     int off_t_quick;
-/* List of dead lines in the file, the space can be reused, not yet used */
+/*! \brief List of dead lines in the file, the space can be reused,
+  not yet used
+  \todo Implement it
 struct recycle
-    /* TODO */
     char dummy;
+/*! \brief Vector map head */
 struct dig_head
+    /* elements */
+    char *organization;         /* orgranization name */
+    char *date;                 /* map date */
+    char *your_name;            /* user name */
+    char *map_name;             /* map name */
+    char *source_date;          /* source date */
+    long orig_scale;            /* original scale */
+    char *line_3;               /* comments */
+    int plani_zone;             /* zone */
+    double digit_thresh;        /* threshold for digitization */
-    /*** HEAD_ELEMENT ***/
-    char *organization;
-    char *date;
-    char *your_name;
-    char *map_name;
-    char *source_date;
-    long orig_scale;
-    char *line_3;
-    int plani_zone;
-    /* double W, E, S, N; */
-    double digit_thresh;
-    /* double map_thresh; *//* not used in g57 */
     /* Programmers should NOT touch any thing below here */
     /* Library takes care of everything for you          */
-    /*** COOR_ELEMENT ***/
-    int Version_Major;
+    /* coor elements */
+    int Version_Major;          /* backward compatibility info */
     int Version_Minor;
     int Back_Major;
     int Back_Minor;
-    int with_z;
+    int with_z;                 /* 2D/3D vector data */
     off_t size;			/* coor file size */
     long head_size;		/* coor header size */
-    struct Port_info port;	/* Portability information */
+    struct Port_info port;	/* portability information */
     off_t last_offset;		/* offset of last read line */
-    struct recycle *recycle;
+    struct recycle *recycle;    /* recycle dead line, not implemented yet */
-    struct Map_info *Map;	/* X-ref to Map_info struct ?? */
+    struct Map_info *Map;	/* X-ref to Map_info struct (needed?) */
-/* Coor info */
+/*! \brief Coor file info */
 struct Coor_info
     off_t size;			/* total size, in bytes */
     long mtime;			/* time of last modification */
-/* Non-native format inforamtion */
-/* TODO: structure size should not change depending on compilation I think, do it better */
-/* OGR */
+/*! \brief Non-native format info (OGR)
+  \todo Structure size should not change depending on compilation I think, do it better
 struct Format_info_ogr
-    char *dsn;
-    char *layer_name;
+    char *dsn;                  /* OGR datasource name */
+    char *layer_name;           /* OGR layer name */
 #ifdef HAVE_OGR
-    OGRDataSourceH ds;
-    OGRLayerH layer;
+    OGRDataSourceH ds;          /* pointer to OGRDataSourceH */
+    OGRLayerH layer;            /* pointer to OGRLayerH */
 #else
     void *ds;
     void *layer;
@@ -190,8 +181,8 @@
     /* Level 1 (used by V*_read_next_line_ogr) */
     struct line_pnts **lines;	/* points cache */
-    int *lines_types;
-    int lines_alloc;
+    int *lines_types;           /* list of line types */
+    int lines_alloc;            /* number of allocated lines */
     int lines_num;		/* number of lines in cache */
     int lines_next;		/* next line to be read from cache */
@@ -203,139 +194,155 @@
 #endif
     int feature_cache_id;	/* id of feature read in feature_cache */
-    /* Array where OGR feature/part info is stored for each line in GRASS.
-     * This is not used for GV_CENTROID.
-     * Because one feature may contain more elements (geometry collection also recursively),
-     * offset for one line may be stored in more records.
-     * First record is FID, next records are part indexes if necessary.
-     * Example:
-     * 5. ring in 3. polygon in 7. feature (multipolygon) of geometry collection which has FID = 123
-     * 123 (feature 123: geometry colletion)
-     *   6 (7. feature in geometry collection: multiPolygon)
-     *   2 (3. polygon)
-     *   4 (5. ring in the polygon)
+    /* Array where OGR feature/part info is stored for each line in
+     * GRASS.  This is not used for GV_CENTROID.  Because one feature
+     * may contain more elements (geometry collection also
+     * recursively), offset for one line may be stored in more
+     * records.  First record is FID, next records are part indexes if
+     * necessary.  Example: 5. ring in 3. polygon in 7. feature
+     * (multipolygon) of geometry collection which has FID = 123 123
+     * (feature 123: geometry colletion) 6 (7. feature in geometry
+     * collection: multiPolygon) 2 (3. polygon) 4 (5. ring in the
+     * polygon)
-    int *offset;
+    int *offset;                /* offset list */
     int offset_num;		/* number of items in offset */
     int offset_alloc;		/* space allocated for offset */
     int next_line;		/* used by V2_read_next_line_ogr */
+/*! \brief Non-native format info */
 struct Format_info
-    int i;
-    struct Format_info_ogr ogr;
+    int i;                      /* id? */
+    struct Format_info_ogr ogr; /* OGR info */
-/* Category index */
+/*! \brief Category index */
 struct Cat_index
     int field;			/* field number */
     int n_cats;			/* number of items in cat array */
     int a_cats;			/* allocated space in cat array */
-    int (*cat)[3];		/* array of cats (cat,type, lines/area) */
+    int (*cat)[3];		/* array of cats (cat, type, lines/area) */
     int n_ucats;		/* number of unique cats (not updated) */
     int n_types;		/* number of types in type */
-    int type[7][2];		/* number of elements for each type (point, line, boundary, centroid, area, face, kernel) */
-    off_t offset;		/* offset of the beginning of this index in cidx file */
+    int type[7][2];		/* number of elements for each type
+				 * (point, line, boundary, centroid,
+				 * area, face, kernel) */
+    off_t offset;		/* offset of the beginning of this
+				 * index in cidx file */
+/*! \brief Plus head info */
 struct Plus_head
-    int Version_Major;		/* version codes */
+    /*** version info ***/
+    int Version_Major;		 /* version codes */
     int Version_Minor;
-    int Back_Major;		/* earliest version that can use this data format */
+    int Back_Major;		 /* earliest version that can use this data format */
     int Back_Minor;
-    int spidx_Version_Major;	/* version codes for spatial index */
+    int spidx_Version_Major;	 /* version codes for spatial index */
     int spidx_Version_Minor;
-    int spidx_Back_Major;	/* earliest version that can use this data format */
+    int spidx_Back_Major;	 /* earliest version that can use this data format */
     int spidx_Back_Minor;
-    int cidx_Version_Major;	/* version codes for category index */
+    int cidx_Version_Major;	 /* version codes for category index */
     int cidx_Version_Minor;
-    int cidx_Back_Major;	/* earliest version that can use this data format */
+    int cidx_Back_Major;	 /* earliest version that can use this data format */
     int cidx_Back_Minor;
-    int with_z;
-    int spidx_with_z;
+    int spidx_with_z;            /* 2D/3D spatial index */
-    int off_t_size;        /* offset size here because Plus_head is available to all releveant functions */
+    int off_t_size;              /* offset size here because Plus_head
+				    is available to all releveant
+				    functions */
-    long head_size;		/* topo header size */
-    long spidx_head_size;	/* spatial index header size */
-    long cidx_head_size;	/* category index header size */
+    /*** file header size ***/
+    long head_size;		 /* topo header size */
+    long spidx_head_size;	 /* spatial index header size */
+    long cidx_head_size;	 /* category index header size */
-    int release_support;	/* release memory occupied by support (topo, spatial, category) */
+    int release_support;	 /* release memory occupied by support
+				    (topo, spatial, category) */
-    struct Port_info spidx_port;	/* Portability information for spatial index */
-    struct Port_info cidx_port;	/* Portability information for category index */
-    int mode;			/* Read, Write, RW */
+    /*** portability info */
+    struct Port_info spidx_port; /* portability information for
+				    spatial index */
+    struct Port_info cidx_port;	 /* portability information for
+				    category index */
+    int mode;			 /* read, write, RW */
-    int built;			/* the highest level of topology currently available (GV_BUILD_*) */
+    int built;			 /* the highest level of topology
+				    currently available
+				    (GV_BUILD_*) */
-    struct bound_box box;	/* box */
+    struct bound_box box;	 /* vector map bounding box */
-    P_NODE **Node;		/* P_NODE array of pointers *//* 1st item is 1 for  */
-    P_LINE **Line;		/* P_LINE array of pointers *//* all these (not 0) */
-    P_AREA **Area;
-    P_ISLE **Isle;
-    /* add here P_FACE, P_VOLUME, P_HOLE */
+    /*** topology ***/
+    struct P_node **Node;	 /* struct P_node array of pointers
+				    1st item is 1 for  */
+    struct P_line **Line;	 /* struct P_line array of pointers
+				    all these (not 0) */
+    struct P_area **Area;
+    struct P_isle **Isle;
+                                 /* add here P_FACE, P_VOLUME, P_HOLE */
-    plus_t n_nodes;		/* current Number of nodes */
-    plus_t n_edges;		/* current Number of edges */
-    plus_t n_lines;		/* current Number of lines */
-    plus_t n_areas;		/* current Number of areas */
-    plus_t n_isles;		/* current Number of isles */
-    plus_t n_faces;		/* current Number of faces */
-    plus_t n_volumes;	/* current Number of volumes */
-    plus_t n_holes;		/* current Number of holes */
+    plus_t n_nodes;		 /* current number of nodes */
+    plus_t n_edges;		 /* current number of edges */
+    plus_t n_lines;	 	 /* current number of lines */
+    plus_t n_areas;		 /* current number of areas */
+    plus_t n_isles;		 /* current number of isles */
+    plus_t n_faces;		 /* current number of faces */
+    plus_t n_volumes;	         /* current number of volumes */
+    plus_t n_holes;		 /* current number of holes */
-    plus_t n_plines;		/* Current Number of point    lines */
-    plus_t n_llines;		/* Current Number of line     lines */
-    plus_t n_blines;		/* Current Number of boundary lines */
-    plus_t n_clines;		/* Current Number of centroid lines */
-    plus_t n_flines;		/* Current Number of face lines */
-    plus_t n_klines;		/* Current Number of kernel lines */
-    plus_t n_vfaces;		/* Current Number of volume faces */
-    plus_t n_hfaces;		/* Current Number of hole faces */
+    plus_t n_plines;		 /* current number of points */
+    plus_t n_llines;		 /* current number of lines */
+    plus_t n_blines;		 /* current number of boundaries */
+    plus_t n_clines;		 /* current number of centroids */
+    plus_t n_flines;		 /* current number of faces */
+    plus_t n_klines;		 /* current number of kernels*/
+    plus_t n_vfaces;		 /* current number of volumes */
+    plus_t n_hfaces;		 /* current number of hole faces */
-    plus_t alloc_nodes;		/* # of nodes we have alloc'ed space for
-				   i.e. array size - 1 */
-    plus_t alloc_edges;
-    plus_t alloc_lines;		/* # of lines we have alloc'ed space for */
-    plus_t alloc_areas;		/* # of areas we have alloc'ed space for */
-    plus_t alloc_isles;		/* # of isles we have alloc'ed space for */
-    plus_t alloc_faces;		/* # of faces we have alloc'ed space for */
-    plus_t alloc_volumes;	/* # of volumes we have alloc'ed space for */
-    plus_t alloc_holes;		/* # of holes we have alloc'ed space for */
+    plus_t alloc_nodes;		 /* number of nodes we have alloc'ed
+				    space for i.e. array size - 1 */
+    plus_t alloc_edges;          /* number of edges we have alloc'ed space for */
+    plus_t alloc_lines;		 /* number of lines we have alloc'ed space for */
+    plus_t alloc_areas;		 /* number of areas we have alloc'ed space for */
+    plus_t alloc_isles;		 /* number of isles we have alloc'ed space for */
+    plus_t alloc_faces;		 /* number of faces we have alloc'ed space for */
+    plus_t alloc_volumes;	 /* number of volumes we have alloc'ed space for */
+    plus_t alloc_holes;		 /* number of holes we have alloc'ed space for */
-    off_t Node_offset;		/* offset of array of nodes in topo file */
-    off_t Edge_offset;
-    off_t Line_offset;
-    off_t Area_offset;
-    off_t Isle_offset;
-    off_t Volume_offset;
-    off_t Hole_offset;
+    off_t Node_offset;		 /* offset of array of nodes in topo file */
+    off_t Edge_offset;           /* offset of array of edges in topo file */
+    off_t Line_offset;           /* offset of array of lines in topo file */
+    off_t Area_offset;           /* offset of array of areas in topo file */
+    off_t Isle_offset;           /* offset of array of isles in topo file */
+    off_t Volume_offset;         /* offset of array of volumes in topo file */
+    off_t Hole_offset;           /* offset of array of holes in topo file */
-    /* Spatial index is always saved */
+    /*** spatial index ***/
+    int Spidx_built;		 /* set to 1 if spatial index is available */
+    int Spidx_new;               /* set to 1 if new spatial index will be generated */
-    int Spidx_built;		/* set to 1 if spatial index is available */
-    int Spidx_new;          /* set to 1 if new spatial index will be generated */
-    GVFILE spidx_fp;		    /* spatial index file pointer */
+    struct gvfile spidx_fp;	 /* spatial index file pointer */
-    char *spidx_node_fname;     /* node spatial index file name */
+    char *spidx_node_fname;      /* node spatial index file name */
-    off_t Node_spidx_offset;	/* offset of spatial index in sidx file */
-    off_t Line_spidx_offset;
-    off_t Area_spidx_offset;
-    off_t Isle_spidx_offset;
-    off_t Face_spidx_offset;
-    off_t Volume_spidx_offset;
-    off_t Hole_spidx_offset;
+    off_t Node_spidx_offset;	 /* offset of nodes in sidx file */
+    off_t Line_spidx_offset;     /* offset of lines in sidx file */
+    off_t Area_spidx_offset;     /* offset of areas in sidx file */
+    off_t Isle_spidx_offset;     /* offset of isles in sidx file */
+    off_t Face_spidx_offset;     /* offset of faces in sidx file */
+    off_t Volume_spidx_offset;   /* offset of volumes in sidx file */
+    off_t Hole_spidx_offset;     /* offset of holes in sidx file */
     struct RTree *Node_spidx;     /* node spatial index */
     struct RTree *Line_spidx;     /* line spatial index */
@@ -345,70 +352,75 @@
     struct RTree *Volume_spidx;   /* volume spatial index */
     struct RTree *Hole_spidx;     /* hole spatial index */
-    /* Category index */
+    /*** category index ***/
     /* By default, category index is not updated */
-    int update_cidx;		/* update category index if vector is modified */
+    int update_cidx;		  /* update category index if vector is modified */
-    int n_cidx;			/* number of cat indexes (one for each field) */
-    int a_cidx;			/* allocated space for cat indexes */
-    struct Cat_index *cidx;	/* Array of category indexes */
-    int cidx_up_to_date;	/* set to 1 when cidx is created and reset to 0 whenever any line is changed */
+    int n_cidx;			  /* number of cat indexes (one for each field) */
+    int a_cidx;			  /* allocated space for cat indexes */
+    struct Cat_index *cidx;	  /* array of category indexes */
+    int cidx_up_to_date;	  /* set to 1 when cidx is created and reset to 0 whenever any line is changed */
-    off_t coor_size;		/* size of coor file */
-    long coor_mtime;		/* time of last coor modification */
+    off_t coor_size;		  /* size of coor file */
+    long coor_mtime;		  /* time of last coor modification */
-    /* Level2 update: list of lines and nodes updated (topo info for the line was changed)
-     *                 by last write/rewrite/delete operation.
-     *                 Lines/nodes in the list may be deleted (e.g. delete boundary: first added for
-     *                 delete area and then delete */
-    int do_uplist;		/* used internaly in diglib to know if list is maintained */
+    /*** level 2 ***/
+    /* update: list of lines and nodes updated (topo info for the line
+       was changed) by last write/rewrite/delete operation.
+       Lines/nodes in the list may be deleted (e.g. delete boundary:
+       first added for delete area and then delete */
+    int do_uplist;		  /* used internaly in diglib to know if list is maintained */
-    int *uplines;		/* array of updated lines */
-    int alloc_uplines;		/* allocated array */
-    int n_uplines;		/* number of updated lines */
-    int *upnodes;		/* array of updated nodes */
-    int alloc_upnodes;		/* allocated array */
-    int n_upnodes;		/* number of updated nodes */
+    int *uplines;		  /* array of updated lines */
+    int alloc_uplines;		  /* allocated array */
+    int n_uplines;		  /* number of updated lines */
+    int *upnodes;		  /* array of updated nodes */
+    int alloc_upnodes;		  /* allocated array */
+    int n_upnodes;		  /* number of updated nodes */
+/*! \brief Vector map info */
 struct Map_info
-    /* Common info for all formats */
-    int format;			/* format */
+    /* common info for all formats */
+    int format;			/* format (native, ogr) */
     int temporary;		/* temporary file flag, not yet used */
-    struct dblinks *dblnk;	/* info about tables */
+    struct dblinks *dblnk;	/* info about db links */
-    struct Plus_head plus;	/* topo file *head; */
+    struct Plus_head plus;	/* topo file head info */
+    /* graph-related section */
     int graph_line_type;	/* line type used to build the graph */
     dglGraph_s graph;		/* graph structure */
-    dglSPCache_s spCache;	/* Shortest path cache */
-    double *edge_fcosts;	/* costs used for graph, (dglGetEdge() is not supported for _DGL_V1) */
+    dglSPCache_s spCache;	/* shortest path cache */
+    double *edge_fcosts;	/* costs used for graph, (dglGetEdge()
+				   is not supported for _DGL_V1) */
     double *edge_bcosts;
     double *node_costs;		/* node costs */
-    int cost_multip;		/* edge and node costs multiplicator */
+    int cost_multip;		/* edge and node costs
+				   multiplicator */
+    int open;			/* should be 0x5522AA22 (VECT_OPEN_CODE) if opened correctly
+				   or        0x22AA2255 (VECT_CLOSED_CODE) if closed
+				   anything else implies that structure has
+				   never been initialized
+    int mode;			/* Open mode - read (GV_MODE_READ),
+				   write (GV_MODE_WRITE),
+				   rw (GV_MODE_RW) */
+    int level;			/* Topology level - 1, 2, (3) */
+    int head_only;		/* only header is opened */
+    int support_updated;	/* support files were updated */
+    plus_t next_line;		/* for level 2 sequential reads */
-    /*  All of these apply only to runtime, and none get written out
-     **  to the dig_plus file
-    int open;			/* should be 0x5522AA22 if opened correctly */
-    /* or        0x22AA2255 if closed           */
-    /* anything else implies that structure has */
-    /* never been initialized                   */
-    int level;			/*  1, 2, (3)                               */
-    int head_only;		/* Only header is opened */
-    int support_updated;	/* Support files were updated */
-    plus_t next_line;		/* for Level II sequential reads */
     char *name;			/* for 4.0  just name, and mapset */
-    char *mapset;
+    char *mapset;               /* mapset name */
     /* location and gisdbase is usefull if changed (v.proj or external apps) */
     char *location;		/* location name */
     char *gisdbase;		/* gisdbase path */
-    /* Constraints for reading in lines  (not polys yet) */
+    /* constraints for reading in lines  (not polys yet) */
     int Constraint_region_flag;
     int Constraint_type_flag;
     double Constraint_N;
@@ -422,7 +434,7 @@
     /* format specific */
     /* native */
-    GVFILE dig_fp;		/* Dig file pointer */
+    struct gvfile dig_fp;	/* dig file pointer */
     struct dig_head head;	/* coor file head */
     /* non native */
@@ -431,37 +443,46 @@
     /* history file */
     FILE *hist_fp;
-    /* Temporary solution for sites */
-    SITE_ATT *site_att;		/* array of attributes loaded from db */
+    /* temporary solution for sites - to be removed ?*/
+    struct site_att *site_att;	/* array of attributes loaded from db */
     int n_site_att;		/* number of attributes in site_att array */
     int n_site_dbl;		/* number of double attributes for one site */
     int n_site_str;		/* number of string attributes for one site */
+/*! \brief Node (topology) info */
 struct P_node
     double x;			/* X coordinate */
     double y;			/* Y coordinate */
     double z;			/* Z coordinate */
-    plus_t n_lines;		/* Number of attached lines (size of lines, angle) */
-    /*  If 0, then is degenerate node, for snappingi ??? */
-    plus_t *lines;		/* Connected lines */
-    float *angles;		/* Respected angles. Angles for lines/boundaries are in radians between
-				 * -PI and PI. Value for points or lines with identical points (degenerated)
-				 * is set to -9. */
+    plus_t alloc_lines;         /* allocated space for lines */
+    plus_t n_lines;		/* number of attached lines (size of
+				   lines, angle). If 0, then is
+				   degenerate node, for snappingi ???
+    plus_t *lines;		/* list of connected lines */
+    float *angles;		/* respected angles; angles for
+				   lines/boundaries are in radians
+				   between -PI and PI. Value for
+				   points or lines with identical
+				   points (degenerated) is set to
+				   -9. */
+/*! \brief Line (topology) info */
 struct P_line
     plus_t N1;			/* start node */
     plus_t N2;			/* end node   */
-    plus_t left;		/* area/isle number to left, negative for isle  */
-    /* !!! area number for centroid, negative for   */
-    /* duplicate centroid                           */
-    plus_t right;		/* area/isle number to right, negative for isle */
+    plus_t left;		/* area/isle number to left, negative
+				   for isle area number for centroid,
+				   negative for duplicate centroid
+    plus_t right;		/* area/isle number to right, negative
+				 * for isle */
-    double N;			/* Bounding Box */
+    double N;			/* line bounding Box */
     double S;
     double E;
     double W;
@@ -469,58 +490,62 @@
     off_t offset;		/* offset in coor file for line */
-    int type;
+    int type;                   /* line type */
+/*! \brief Area (topology) info */
 struct P_area
+    double N;			/* area bounding Box */
     double S;
     double E;
     double W;
     double T;			/* top */
-    plus_t n_lines;		/* Number of boundary lines */
-    plus_t *lines;		/* Boundary Lines, negative means direction N2 to N1,
-				   lines are in  clockwise order */
+    plus_t n_lines;		/* number of boundary lines */
+    plus_t alloc_lines;         /* allocated space */
+    plus_t *lines;		/* list of boundary lines, negative
+				   means direction N2 to N1, lines are
+				   in clockwise order */
     /*********  Above this line is compatible with P_isle **********/
+    plus_t centroid;		/* number of first centroid within area */
-    plus_t centroid;		/* Number of first centroid within area */
-    plus_t n_isles;		/* Number of islands inside */
+    plus_t n_isles;		/* number of islands inside */
     plus_t alloc_isles;
     plus_t *isles;		/* 1st generation interior islands */
+/*! \brief Isle (topology) info */
 struct P_isle
+    double N;			/* isle bounding Box */
     double S;
     double E;
     double W;
     double T;			/* top */
     plus_t alloc_lines;
-				   lines are in counter clockwise order */
+				   in counter clockwise order */
     /*********  Above this line is compatible with P_area **********/
     plus_t area;		/* area it exists w/in, if any */
+/*! \brief Line points (feature geometry info */
 struct line_pnts
-    double *x;
-    double *y;
-    double *z;
-    int n_points;
-    int alloc_points;
+    double *x;                  /* pointer to 1st x coordinate */
+    double *y;                  /* pointer to 1st y coordinate */
+    double *z;                  /* pointer to 1st z coordinate */
+    int n_points;               /* number of points */
+    int alloc_points;           /* allocated space */
+/*! \brief Line categories (feature category info */
 struct line_cats
     int *field;			/* pointer to array of fields */
@@ -529,6 +554,7 @@
     int alloc_cats;		/* allocated space */
+/*! \brief Category list */
 struct cat_list
     int field;			/* category field */
@@ -538,7 +564,10 @@
     int alloc_ranges;		/* allocated space */
-/* list of integers */
+/*! \brief List of integers
 struct ilist
     int *value;			/* items */
@@ -546,24 +575,19 @@
     int alloc_values;		/* allocated space */
-/* Vector array. Space allocated is size + 1. */
+/*! \brief Vector array. Space allocated is size + 1. */
 struct varray
     int size;			/* array size */
-    int *c;			/* array where 'class' or new category or something like that is stored */
+    int *c;			/* array where 'class' or new category
+				   or something like that is stored */
-typedef struct varray VARRAY;
-/* Spatial index for use in modules. */
+/*! \brief Spatial index for use in modules. */
 struct spatial_index
-    struct RTree *si_tree;
-    char *name;
+    struct RTree *si_tree;      /* pointer to the tree */
+    char *name;                 /* sidx name */
-typedef struct spatial_index SPATIAL_INDEX;
-typedef dglGraph_s GRAPH;	/* graph structure */
 #endif /* DIG___STRUCTS___ */
Modified: grass/trunk/include/vector.h
--- grass/trunk/include/vector.h	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/include/vector.h	2009-07-31 11:46:59 UTC (rev 38552)
@@ -36,7 +36,7 @@
 int Vect_line_distance(const struct line_pnts *, double, double, double, int,
 		       double *, double *, double *, double *, double *,
 		       double *);
-int Vect_line_box(const struct line_pnts *, BOUND_BOX *);
+int Vect_line_box(const struct line_pnts *, struct bound_box *);
 void Vect_line_parallel(struct line_pnts *, double, double, int,
 			struct line_pnts *);
 void Vect_line_parallel2(struct line_pnts *, double, double,
@@ -78,13 +78,13 @@
 int Vect_destroy_cat_list(struct cat_list *);
 /* Vector array */
-VARRAY *Vect_new_varray(int);
+struct varray *Vect_new_varray(int);
 int Vect_set_varray_from_cat_string(const struct Map_info *, int, const char *, int,
-				    int, VARRAY *);
+				    int, struct varray *);
 int Vect_set_varray_from_cat_list(const struct Map_info *, int, struct cat_list *,
-				  int, int, VARRAY *);
+				  int, int, struct varray *);
 int Vect_set_varray_from_db(const struct Map_info *, int, const char *, int, int,
-			    VARRAY *);
+			    struct varray *);
 /* DB connection - field info */
 struct dblinks *Vect_new_dblinks_struct(void);
@@ -103,6 +103,7 @@
 					   const char *, int);
 struct field_info *Vect_get_dblink(const struct Map_info *, int);
 struct field_info *Vect_get_field(const struct Map_info *, int);
+struct field_info *Vect_get_field_by_name(const struct Map_info *, const char *);
 void Vect_set_db_updated(struct Map_info *);
 const char *Vect_get_column_names(const struct Map_info *, int);
 const char *Vect_get_column_types(const struct Map_info *, int);
@@ -119,12 +120,12 @@
 int Vect_destroy_list(struct ilist *);
 /* Bounding box (MBR) */
-int Vect_point_in_box(double, double, double, const BOUND_BOX *);
-int Vect_box_overlap(const BOUND_BOX *, const BOUND_BOX *);
-int Vect_box_copy(BOUND_BOX *, const BOUND_BOX *);
-int Vect_box_extend(BOUND_BOX *, const BOUND_BOX *);
-int Vect_box_clip(double *, double *, double *, double *, const BOUND_BOX *);
-int Vect_region_box(const struct Cell_head *, BOUND_BOX *);
+int Vect_point_in_box(double, double, double, const struct bound_box *);
+int Vect_box_overlap(const struct bound_box *, const struct bound_box *);
+int Vect_box_copy(struct bound_box *, const struct bound_box *);
+int Vect_box_extend(struct bound_box *, const struct bound_box *);
+int Vect_box_clip(double *, double *, double *, double *, const struct bound_box *);
+int Vect_region_box(const struct Cell_head *, struct bound_box *);
 int Vect_cidx_get_num_fields(const struct Map_info *);
@@ -172,7 +173,7 @@
 const char *Vect_get_proj_name(const struct Map_info *);
 int Vect_set_thresh(struct Map_info *, double);
 double Vect_get_thresh(const struct Map_info *);
-int Vect_get_constraint_box(const struct Map_info *, BOUND_BOX *);
+int Vect_get_constraint_box(const struct Map_info *, struct bound_box *);
 /* Get map level 2 informations */
@@ -183,10 +184,10 @@
 int Vect_get_num_areas(const struct Map_info *);
 int Vect_get_num_faces(const struct Map_info *);
 int Vect_get_num_islands(const struct Map_info *);
-int Vect_get_line_box(const struct Map_info *, int, BOUND_BOX *);
-int Vect_get_area_box(const struct Map_info *, int, BOUND_BOX *);
-int Vect_get_isle_box(const struct Map_info *, int, BOUND_BOX *);
-int Vect_get_map_box(const struct Map_info *, BOUND_BOX *);
+int Vect_get_line_box(const struct Map_info *, int, struct bound_box *);
+int Vect_get_area_box(const struct Map_info *, int, struct bound_box *);
+int Vect_get_isle_box(const struct Map_info *, int, struct bound_box *);
+int Vect_get_map_box(const struct Map_info *, struct bound_box *);
 int V__map_overlap(struct Map_info *, double, double, double, double);
 void Vect_set_release_support(struct Map_info *);
 void Vect_set_category_index_update(struct Map_info *);
@@ -272,11 +273,11 @@
 char *Vect_hist_read(char *, int, const struct Map_info *);
 /* Selecting features */
-int Vect_select_lines_by_box(struct Map_info *, const BOUND_BOX *, int,
+int Vect_select_lines_by_box(struct Map_info *, const struct bound_box *, int,
 			     struct ilist *);
-int Vect_select_areas_by_box(struct Map_info *, const BOUND_BOX *, struct ilist *);
-int Vect_select_isles_by_box(struct Map_info *, const BOUND_BOX *, struct ilist *);
-int Vect_select_nodes_by_box(struct Map_info *, const BOUND_BOX *, struct ilist *);
+int Vect_select_areas_by_box(struct Map_info *, const struct bound_box *, struct ilist *);
+int Vect_select_isles_by_box(struct Map_info *, const struct bound_box *, struct ilist *);
+int Vect_select_nodes_by_box(struct Map_info *, const struct bound_box *, struct ilist *);
 int Vect_find_node(struct Map_info *, double, double, double, double, int);
 int Vect_find_line(struct Map_info *, double, double, double, int, double,
 		   int, int);
@@ -338,11 +339,11 @@
 		     struct ilist *, struct ilist *, struct Map_info *);
 /* Graph */
-void Vect_graph_init(GRAPH *, int);
-void Vect_graph_build(GRAPH *);
-void Vect_graph_add_edge(GRAPH *, int, int, double, int);
-void Vect_graph_set_node_costs(GRAPH *, int, double);
-int Vect_graph_shortest_path(GRAPH *, int, int, struct ilist *, double *);
+void Vect_graph_init(dglGraph_s *, int);
+void Vect_graph_build(dglGraph_s *);
+void Vect_graph_add_edge(dglGraph_s *, int, int, double, int);
+void Vect_graph_set_node_costs(dglGraph_s *, int, double);
+int Vect_graph_shortest_path(dglGraph_s *, int, int, struct ilist *, double *);
 /* Network (graph) */
 int Vect_net_build_graph(struct Map_info *, int, int, int, const char *,
@@ -387,17 +388,17 @@
 char *Vect_subst_var(const char *, const struct Map_info *);
 /* Custom spatial index */
-void Vect_spatial_index_init(SPATIAL_INDEX *, int);
-void Vect_spatial_index_destroy(SPATIAL_INDEX *);
-void Vect_spatial_index_add_item(SPATIAL_INDEX *, int, const BOUND_BOX *);
-void Vect_spatial_index_del_item(SPATIAL_INDEX *, int, const BOUND_BOX *);
-int Vect_spatial_index_select(const SPATIAL_INDEX *, const BOUND_BOX *, struct ilist *);
+void Vect_spatial_index_init(struct spatial_index *, int);
+void Vect_spatial_index_destroy(struct spatial_index *);
+void Vect_spatial_index_add_item(struct spatial_index *, int, const struct bound_box *);
+void Vect_spatial_index_del_item(struct spatial_index *, int, const struct bound_box *);
+int Vect_spatial_index_select(const struct spatial_index *, const struct bound_box *, struct ilist *);
  * Internal functions, MUST NOT be used in modules
 int Vect_print_header(const struct Map_info *);
-int Vect__init_head(struct Map_info *);
+void Vect__init_head(struct Map_info *);
 /* Open/close/rewind map */
 int Vect_coor_info(const struct Map_info *, struct Coor_info *);
@@ -466,8 +467,8 @@
 int Vect_build_line_area(struct Map_info *, int, int);
 int Vect_isle_find_area(struct Map_info *, int);
 int Vect_attach_isle(struct Map_info *, int);
-int Vect_attach_isles(struct Map_info *, const BOUND_BOX *);
-int Vect_attach_centroids(struct Map_info *, const BOUND_BOX *);
+int Vect_attach_isles(struct Map_info *, const struct bound_box *);
+int Vect_attach_centroids(struct Map_info *, const struct bound_box *);
     /* GEOS support */
 #ifdef HAVE_GEOS
Modified: grass/trunk/lib/gis/Makefile
--- grass/trunk/lib/gis/Makefile	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/lib/gis/Makefile	2009-07-31 11:46:59 UTC (rev 38552)
@@ -3,7 +3,7 @@
 LIB_NAME = $(GIS_LIBNAME)
 EXTRA_LIBS = $(DATETIMELIB) $(PTHREADLIBPATH) $(PTHREADLIB) \
-	$(INTLLIB) $(MATHLIB) $(ZLIBLIBPATH) $(ZLIB)
+	$(INTLLIB) $(MATHLIB) $(ZLIBLIBPATH) $(ZLIB) $(GDALLIBS)
 EXTRA_INC = $(ZLIBINCPATH) $(PTHREADINCPATH)
 DATASRC = ellipse.table datum.table datumtransform.table FIPS.code state27 state83 projections
Modified: grass/trunk/lib/gis/find_file.c
--- grass/trunk/lib/gis/find_file.c	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/lib/gis/find_file.c	2009-07-31 11:46:59 UTC (rev 38552)
@@ -16,6 +16,7 @@
 #include <string.h>
 #include <unistd.h>
 #include <grass/gis.h>
+#include <grass/vect/dig_defines.h>
 #include <grass/glocale.h>
 static const char *find_file(
@@ -50,7 +51,7 @@
     if (G_legal_filename(pname) == -1)
 	return NULL;
     if (pmapset && *pmapset && G_legal_filename(pmapset) == -1)
 	return NULL;
Modified: grass/trunk/lib/gis/find_vect.c
--- grass/trunk/lib/gis/find_vect.c	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/lib/gis/find_vect.c	2009-07-31 11:46:59 UTC (rev 38552)
@@ -1,78 +1,116 @@
- *  char *
- *  G_find_vector (name, mapset)
- *        char *name       file name to look for
- *        char *mapset     mapset to search. if mapset is ""
- *                         will search in mapset search list
- *      searches for a vector map from the mapset search list
- *      or in a specified mapset.
- *      returns the mapset name where the vector map was found.
- * NOTE: If the user specifies a fully qualified vector map which exists,
- *       then <i>G_find_vector()</i> modifies <b>name</b> by removing the
- *      "@<i>mapset</i>" part.
- *  returns:
- *      char *  pointer to a string with name of mapset
- *              where vector map was found, or NULL if not found
- *  note:
- *      rejects all names that begin with .
- *      if name is of the form nnn in ppp then
- *      name = nnn and mapset = ppp
+  \file gis/find_vect.c
+  \brief GIS library - Find a vector map
+  (C) 2001-2009 by the GRASS Development Team
+  This program is free software under the GNU General Public License
+  (>=v2). Read the file COPYING that comes with GRASS for details.
+  \author Original author CERL
+#include <string.h>
+#include <grass/config.h>
+#include <grass/glocale.h>
+#ifdef HAVE_OGR
+#include <ogr_api.h>
+#endif
-/* \brief searches for a vector map
- *  returns:
- *  NOTES:
- *      If the user specifies a fully qualified vector map which exists,
- *      Rejects all names that begin with "."
- *      If name is of the form nnn in ppp then
- *  \param name
- *  \param mapset
- *  \return char *
+static const char *find_ogr(const char *, const char *);
+  \brief Finds a vector map
+  Searches for a vector map from the mapset search list or in a
+  specified mapset. Returns the mapset name where the vector map was
+  found.
+  NOTES:
+  If the user specifies a fully qualified vector map which exists,
+  then G_find_vector() modifies <i>name</i> by removing the
+  "@<i>mapset</i>" part.
+  Rejects all names that begin with "."
+  \param name vector map name
+  \param mapset mapset name or "" for search path
+  \return pointer to a string with name of mapset where vector map was found
+  \return NULL if not found
 const char *G_find_vector(char *name, const char *mapset)
-    return G_find_file(GRASS_VECT_DIRECTORY, name, mapset);
+    return G_find_file(GV_DIRECTORY, name, mapset);
- * \brief find a vector map (look but don't touch)
+ * \brief Find a vector map (look but don't touch)
  * The same as G_find_vector() but doesn't remove the "@<i>mapset</i>"
- * qualification from <b>name</b>, if present.
+ * qualification from <i>name</i>, if present.
  * Returns NULL if the map wasn't found, or the mapset the vector was
  * found in if it was.
- *  \param name
- *  \param mapset
- *  \return char *
+ * \param name vector map name
+ * \param mapset mapset name where to search
+ * \return pointer to buffer containing mapset name
+ * \return NULL when vector map not found
 const char *G_find_vector2(const char *name, const char *mapset)
-    return G_find_file2(GRASS_VECT_DIRECTORY, name, mapset);
+    const char *ogr_mapset;
+    /* check OGR mapset first */
+    ogr_mapset = find_ogr(name, mapset);
+    if (ogr_mapset)
+	return ogr_mapset;
+    return G_find_file2(GV_DIRECTORY, name, mapset);
+const char *find_ogr(const char *name, const char *mapset)
+    const char *pname, *pmapset;
+    char xname[GNAME_MAX], xmapset[GMAPSET_MAX];
+    if(G__name_is_fully_qualified(name, xname, xmapset)) {
+	pname = xname;
+	pmapset = xmapset;
+    else {
+	pname = name;
+	pmapset = mapset;
+    if(pmapset && strcmp(pmapset, "OGR") == 0) {
+	/* unique mapset "OGR", check OGR datasource instead */
+#ifdef HAVE_OGR
+	OGRDataSourceH Ogr_ds;
+	G_debug(1, "OGR mapset detected");
+	OGRRegisterAll();
+	/* datasource handle */
+	Ogr_ds = OGROpen(pname, FALSE, NULL);
+	if (Ogr_ds == NULL)
+	    G_fatal_error(_("Unable to open OGR data source '%s'"),
+			  pname);
+	return "OGR";
+#else
+	G_fatal_error(_("Unique OGR mapset detected, OGR support is missing"));
+#endif
+    /* OGR mapset not detected */
+    return NULL;
Modified: grass/trunk/lib/gis/legal_name.c
--- grass/trunk/lib/gis/legal_name.c	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/lib/gis/legal_name.c	2009-07-31 11:46:59 UTC (rev 38552)
@@ -1,17 +1,14 @@
- * \file legal_name.c
+ * \file gis/legal_name.c
  * \brief GIS Library - Functions to handle file name legality.
- * (C) 2001-2008 by the GRASS Development Team
+ * (C) 2001-2009 by the GRASS Development Team
  * This program is free software under the GNU General Public License
  * (>=v2). Read the file COPYING that comes with GRASS for details.
- * \author GRASS GIS Development Team
- * \date 1999-2006
+ * \author Original author CERL
 #include <stdio.h>
@@ -20,51 +17,51 @@
  * \brief Check for legal database file name.
- * Legal file names will <b>not</b> begin with '.' or NULL and must
- * not contain the characters, ' ' (space), '/', '"'. '\'' (single
+ * Legal file names will <b>not</b> begin with '.' or NULL and must
+ * not contain the characters, ' ' (space), '/', '"'. '\'' (single
  * quote), '@', ',', '=', '*', and all other non-alphanumeric
  * characters within.
- * \param[in] s file name to check
+ * \param s file name to check
  * \return 1 success
  * \return -1 failure
 int G_legal_filename(const char *s)
+    const char *name = s;
     if (*s == '.' || *s == 0) {
-	fprintf(stderr, _("Illegal filename.  Cannot be '.' or 'NULL'\n"));
+	G_warning(_("Illegal filename <%s>. Cannot be '.' or 'NULL'."), name);
 	return -1;
     for (; *s; s++)
 	if (*s == '/' || *s == '"' || *s == '\'' || *s <= ' ' ||
 	    *s == '@' || *s == ',' || *s == '=' || *s == '*' || *s > 0176) {
-	    fprintf(stderr,
-		    _("Illegal filename. Character <%c> not allowed.\n"), *s);
+	    G_warning(_("Illegal filename <%s>. Character <%c> not allowed.\n"), name, *s);
 	    return -1;
     return 1;
  * \brief Check input and output file names.
- * Check: 1) output is legal map name, 2) if can find input map, and 3)
- * if input was found in current mapset, check if input != output.
+ * Check: 1) output is legal map name, 2) if can find input map, and
+ * 3) if input was found in current mapset, check if input != output.
- * \param[in] input name
- * \param[out] output name
- * \param[in] error error type: GR_FATAL_EXIT, GR_FATAL_PRINT, GR_FATAL_RETURN
+ * \param input input map name
+ * \param output output map name
+ * \param error error type: GR_FATAL_EXIT, GR_FATAL_PRINT, GR_FATAL_RETURN
  * \return 0 OK
  * \return 1 error
 int G_check_input_output_name(const char *input, const char *output,
 			      int error)
Modified: grass/trunk/lib/gis/open.c
--- grass/trunk/lib/gis/open.c	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/lib/gis/open.c	2009-07-31 11:46:59 UTC (rev 38552)
@@ -229,7 +229,7 @@
     fd = G__open(element, name, mapset, 0);
     if (fd < 0)
-	return (FILE *) 0;
+	return (FILE *) NULL;
     return fdopen(fd, "r");
Modified: grass/trunk/lib/gis/zero.c
--- grass/trunk/lib/gis/zero.c	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/lib/gis/zero.c	2009-07-31 11:46:59 UTC (rev 38552)
@@ -1,31 +1,25 @@
- * \file zero.c
+ * \file gis/zero.c
  * \brief GIS Library - Zeroing functions.
- * \date 1999-2008
 #include <string.h>
  * \brief Zero out a buffer, <b>buf</b>, of length <b>i</b>.
- * \param[in,out] buf
- * \param[in] i number of bytes to be zeroed
- * \return
+ * \param[out] buf
+ * \param i number of bytes to be zeroed
 void G_zero(void *buf, int i)
     memset(buf, 0, i);
Modified: grass/trunk/lib/nviz/nvizlib.dox
--- grass/trunk/lib/nviz/nvizlib.dox	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/lib/nviz/nvizlib.dox	2009-07-31 11:46:59 UTC (rev 38552)
@@ -1,9 +1,7 @@
 /*! \page nvizlib GRASS Nviz Library
-by GRASS Development Team
+by GRASS Development Team (http://grass.osgeo.org)
-http://grass.osgeo.org
 \section nvizintro Introduction to Nviz Library
 This library is build on \ref ogsflib and serves as the interface for
@@ -101,4 +99,8 @@
  - Nviz_new_render_window()
+\section authors Authors
+ Martin Landa <landa.martin gmail.com>
Modified: grass/trunk/lib/sites/sites.c
--- grass/trunk/lib/sites/sites.c	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/lib/sites/sites.c	2009-07-31 11:46:59 UTC (rev 38552)
@@ -40,7 +40,7 @@
 static int site_att_cmp(const void *pa, const void *pb)
-    const SITE_ATT *a = pa, *b = pb;
+    const struct site_att *a = pa, *b = pb;
     return a->cat - b->cat;
@@ -57,7 +57,7 @@
     int i, type, cat;
     static struct line_pnts *Points = NULL;
     static struct line_cats *Cats = NULL;
-    SITE_ATT *sa;
+    struct site_att *sa;
     if (Points == NULL)
 	Points = Vect_new_line_struct();
@@ -89,8 +89,8 @@
 	/* find att */
 	if (Map->n_site_att > 0) {
-	    sa = (SITE_ATT *) bsearch((void *)&cat, (void *)Map->site_att,
-				      Map->n_site_att, sizeof(SITE_ATT),
+	    sa = (struct site_att *) bsearch((void *)&cat, (void *)Map->site_att,
+				      Map->n_site_att, sizeof(struct site_att),
 				      site_att_cmp);
 	    if (sa == NULL) {
@@ -283,7 +283,7 @@
     struct field_info *fi;
     int more, nrows, row, ncols, col, ndbl, nstr, adbl, astr, ctype;
-    SITE_ATT *sa;
     dbDriver *driver;
     dbString stmt;
@@ -332,7 +332,7 @@
     nrows = db_get_num_rows(&cursor);
     G_debug(1, "%d rows selected from vector attribute table", nrows);
-    Map->site_att = (SITE_ATT *) malloc(nrows * sizeof(SITE_ATT));
+    Map->site_att = (struct site_att *) malloc(nrows * sizeof(struct site_att));
     Map->n_site_att = nrows;
     table = db_get_cursor_table(&cursor);
@@ -411,7 +411,7 @@
     db_close_database_shutdown_driver(driver);
     /* sort attributes */
-    qsort((void *)Map->site_att, Map->n_site_att, sizeof(SITE_ATT),
+    qsort((void *)Map->site_att, Map->n_site_att, sizeof(struct site_att),
 	  site_att_cmp);
     return Map;
@@ -1149,12 +1149,12 @@
-   Returns a pointer to the SITE_ATT in Map_info *ptr and with category cat
+   Returns a pointer to the struct site_att in Map_info *ptr and with category cat
-SITE_ATT *G_sites_get_atts(struct Map_info * Map, int *cat)
+struct site_att *G_sites_get_atts(struct Map_info * Map, int *cat)
-    return (SITE_ATT *) bsearch((void *)cat, (void *)Map->site_att,
+    return (struct site_att *) bsearch((void *)cat, (void *)Map->site_att,
 				site_att_cmp);
Modified: grass/trunk/lib/vector/Vlib/area.c
--- grass/trunk/lib/vector/Vlib/area.c	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/lib/vector/Vlib/area.c	2009-07-31 11:46:59 UTC (rev 38552)
@@ -38,7 +38,7 @@
     int i, line, aline, dir;
     const struct Plus_head *Plus;
-    P_AREA *Area;
+    struct P_area *Area;
     static int first_time = 1;
     static struct line_pnts *Points;
@@ -100,7 +100,7 @@
-    P_ISLE *Isle;
+    struct P_isle *Isle;
@@ -153,7 +153,7 @@
 int Vect_get_area_centroid(const struct Map_info *Map, int area)
-    P_AREA *Area;
     G_debug(3, "Vect_get_area_centroid(): area = %d", area);
@@ -180,7 +180,7 @@
     int i, line;
-    P_AREA *Area;
     G_debug(3, "Vect_get_area_boundaries(): area = %d", area);
@@ -214,7 +214,7 @@
     int i, line;
-    P_ISLE *Isle;
     G_debug(3, "Vect_get_isle_boundaries(): isle = %d", isle);
@@ -246,7 +246,7 @@
 int Vect_get_area_num_isles(const struct Map_info *Map, int area)
-    P_AREA *Area;
     G_debug(3, "Vect_get_area_num_isles(): area = %d", area);
@@ -275,7 +275,7 @@
 int Vect_get_area_isle(const struct Map_info *Map, int area, int isle)
-    P_AREA *Area;
     G_debug(3, "Vect_get_area_isle(): area = %d isle = %d", area, isle);
@@ -302,7 +302,7 @@
 int Vect_get_isle_area(const struct Map_info *Map, int isle)
-    P_ISLE *Isle;
     G_debug(3, "Vect_get_isle_area(): isle = %d", isle);
@@ -345,7 +345,7 @@
     int i, isle;
-    P_AREA *Area;
     int poly;
     Plus = &(Map->plus);
@@ -379,7 +379,7 @@
 double Vect_get_area_area(const struct Map_info *Map, int area)
-    P_AREA *Area;
     double size;
     int i;
Modified: grass/trunk/lib/vector/Vlib/array.c
--- grass/trunk/lib/vector/Vlib/array.c	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/lib/vector/Vlib/array.c	2009-07-31 11:46:59 UTC (rev 38552)
@@ -29,22 +29,22 @@
-   \brief Create new VARRAY and allocate space for given number of items.
+   \brief Create new struct varray and allocate space for given number of items.
    Space allocated is 'size + 1' so that lines are accessed by line id.
    Array values are set to 0.
    \param size size of array
-   \return pointer to new VARRAY
+   \return pointer to new struct varray
    \return NULL if failed
-VARRAY *Vect_new_varray(int size)
+struct varray *Vect_new_varray(int size)
-    VARRAY *p;
+    struct varray *p;
-    p = (VARRAY *) G_malloc(sizeof(VARRAY));
+    p = (struct varray *) G_malloc(sizeof(struct varray));
     if (p == NULL)
 	return NULL;
@@ -83,7 +83,7 @@
 int
 Vect_set_varray_from_cat_string(const struct Map_info *Map, int field,
 				const char *cstring, int type, int value,
-				VARRAY * varray)
+				struct varray * varray)
     int ret;
     struct cat_list *Clist;
@@ -130,7 +130,7 @@
 int
 Vect_set_varray_from_cat_list(const struct Map_info *Map, int field,
 			      struct cat_list *clist, int type, int value,
-			      VARRAY * varray)
     int i, n, centr, cat;
     int ni = 0;			/* number of items set */
@@ -249,7 +249,7 @@
 int
 Vect_set_varray_from_db(const struct Map_info *Map, int field, const char *where,
-			int type, int value, VARRAY * varray)
+			int type, int value, struct varray * varray)
     int i, n, c, centr, cat, *cats;
     int ncats;
Modified: grass/trunk/lib/vector/Vlib/box.c
--- grass/trunk/lib/vector/Vlib/box.c	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/lib/vector/Vlib/box.c	2009-07-31 11:46:59 UTC (rev 38552)
@@ -29,7 +29,7 @@
    \return 1 point is in box
    \return 0 point is not in box
-int Vect_point_in_box(double x, double y, double z, const BOUND_BOX * Box)
+int Vect_point_in_box(double x, double y, double z, const struct bound_box * Box)
     if (x >= Box->W && x <= Box->E &&
@@ -49,7 +49,7 @@
    \return 1 boxes overlap
    \return 0 boxes do not overlap
-int Vect_box_overlap(const BOUND_BOX * A, const BOUND_BOX * B)
+int Vect_box_overlap(const struct bound_box * A, const struct bound_box * B)
     if (A->E < B->W || A->W > B->E ||
@@ -68,7 +68,7 @@
    \return 1
-int Vect_box_copy(BOUND_BOX * A, const BOUND_BOX * B)
+int Vect_box_copy(struct bound_box * A, const struct bound_box * B)
     A->N = B->N;
@@ -89,7 +89,7 @@
    \return 1
-int Vect_box_extend(BOUND_BOX * A, const BOUND_BOX * B)
+int Vect_box_extend(struct bound_box * A, const struct bound_box * B)
     if (B->N > A->N)
@@ -134,7 +134,7 @@
 int
-Vect_box_clip(double *x, double *y, double *c_x, double *c_y, const BOUND_BOX * Box)
+Vect_box_clip(double *x, double *y, double *c_x, double *c_y, const struct bound_box * Box)
     int mod;
@@ -204,10 +204,10 @@
    \return 1 on success
    \return 0 line is dead
-int Vect_get_line_box(const struct Map_info *Map, int line, BOUND_BOX * Box)
+int Vect_get_line_box(const struct Map_info *Map, int line, struct bound_box * Box)
-    P_LINE *Line;
+    struct P_line *Line;
     Line = Plus->Line[line];
@@ -243,10 +243,10 @@
    \return 0 area is dead
-int Vect_get_area_box(const struct Map_info *Map, int area, BOUND_BOX * Box)
+int Vect_get_area_box(const struct Map_info *Map, int area, struct bound_box * Box)
-    P_AREA *Area;
     Area = Plus->Area[area];
@@ -282,10 +282,10 @@
    \return 0 isle is dead
-int Vect_get_isle_box(const struct Map_info *Map, int isle, BOUND_BOX * Box)
+int Vect_get_isle_box(const struct Map_info *Map, int isle, struct bound_box * Box)
-    P_ISLE *Isle;
     Isle = Plus->Isle[isle];
@@ -320,7 +320,7 @@
    \return 0 on error
-int Vect_get_map_box(const struct Map_info *Map, BOUND_BOX * Box)
+int Vect_get_map_box(const struct Map_info *Map, struct bound_box * Box)
@@ -346,7 +346,7 @@
    \return 0 on error
-int Vect_region_box(const struct Cell_head *Window, BOUND_BOX * Box)
+int Vect_region_box(const struct Cell_head *Window, struct bound_box * Box)
     Box->N = Window->north;
Modified: grass/trunk/lib/vector/Vlib/break_lines.c
--- grass/trunk/lib/vector/Vlib/break_lines.c	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/lib/vector/Vlib/break_lines.c	2009-07-31 11:46:59 UTC (rev 38552)
@@ -71,7 +71,7 @@
     int j, k, l, ret, atype, btype, aline, bline, found, iline, nlines;
     int naxlines, nbxlines, nx;
     double *xx = NULL, *yx = NULL, *zx = NULL;
-    BOUND_BOX ABox, BBox;
+    struct bound_box ABox, BBox;
     struct ilist *List;
     int nbreaks;
     int touch1_n = 0, touch1_s = 0, touch1_e = 0, touch1_w = 0;	/* other vertices except node1 touching box */
Modified: grass/trunk/lib/vector/Vlib/build.c
--- grass/trunk/lib/vector/Vlib/build.c	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/lib/vector/Vlib/build.c	2009-07-31 11:46:59 UTC (rev 38552)
@@ -171,7 +171,7 @@
     if (plus->built >= GV_BUILD_AREAS) {
 	int line, nlines, area, nareas, err_boundaries, err_centr_out,
 	    err_centr_dupl, err_nocentr;
-	P_LINE *Line;
 	/* Count errors (it does not take much time comparing to build process) */
@@ -243,14 +243,14 @@
     struct Plus_head *plus;
     char fname[GPATH_MAX], buf[GPATH_MAX];
-    GVFILE fp;
+    struct gvfile fp;
     G_debug(1, "Vect_save_topo()");
     plus = &(Map->plus);
     /*  write out all the accumulated info to the plus file  */
-    sprintf(buf, "%s/%s", GRASS_VECT_DIRECTORY, Map->name);
+    sprintf(buf, "%s/%s", GV_DIRECTORY, Map->name);
     G__file_name(fname, buf, GV_TOPO_ELEMENT, Map->mapset);
     G_debug(1, "Open topo: %s", fname);
     dig_file_init(&fp);
@@ -285,11 +285,11 @@
 int Vect_topo_dump(const struct Map_info *Map, FILE * out)
     int i, j, line, isle;
-    P_NODE *Node;
-    P_LINE *Line;
-    P_AREA *Area;
-    P_ISLE *Isle;
-    BOUND_BOX box;
+    struct P_node *Node;
     const struct Plus_head *plus;
@@ -417,11 +417,11 @@
     int i, total, done;
-    BOUND_BOX box;
-    P_LINE *Line;
-    P_NODE *Node;
-    P_AREA *Area;
-    P_ISLE *Isle;
     G_debug(3, "Vect_build_sidx_from_topo()");
@@ -532,7 +532,7 @@
     if (Map->plus.Spidx_new == 1) {
 	/*  write out rtrees to sidx file  */
 	G__file_name(fname, buf, GV_SIDX_ELEMENT, Map->mapset);
 	G_debug(1, "Open sidx: %s", fname);
 	dig_file_init(&(Map->plus.spidx_fp));
Modified: grass/trunk/lib/vector/Vlib/build_nat.c
--- grass/trunk/lib/vector/Vlib/build_nat.c	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/lib/vector/Vlib/build_nat.c	2009-07-31 11:46:59 UTC (rev 38552)
@@ -40,7 +40,7 @@
     static int first = 1;
     off_t offset;
-    P_LINE *BLine;
+    struct P_line *BLine;
     static struct line_pnts *Points, *APoints;
     plus_t *lines;
     double area_size;
@@ -135,12 +135,12 @@
     int j, line, node, sel_area, first, area, poly;
     static int first_call = 1;
-    P_LINE *Line;
-    P_NODE *Node;
-    P_ISLE *Isle;
-    P_AREA *Area;
     double size, cur_size;
-    BOUND_BOX box, abox;
+    struct bound_box box, abox;
     static struct ilist *List;
     static struct line_pnts *APoints;
@@ -269,7 +269,7 @@
 int Vect_attach_isle(struct Map_info *Map, int isle)
     int sel_area;
-    P_ISLE *Isle;
     /* Note!: If topology is not clean and areas overlap, one island may fall to more areas
@@ -303,7 +303,7 @@
    \return 0
-int Vect_attach_isles(struct Map_info *Map, const BOUND_BOX * box)
+int Vect_attach_isles(struct Map_info *Map, const struct bound_box * box)
     int i, isle;
@@ -337,13 +337,13 @@
    \return 0
-int Vect_attach_centroids(struct Map_info *Map, const BOUND_BOX * box)
+int Vect_attach_centroids(struct Map_info *Map, const struct bound_box * box)
     int i, sel_area, centr;
-    P_AREA *Area;
-    P_LINE *Line;
     G_debug(3, "Vect_attach_centroids ()");
@@ -443,9 +443,9 @@
     int side, line, area;
     struct line_cats *Cats;
-    P_LINE *Line;
-    P_AREA *Area;
-    BOUND_BOX box;
     struct ilist *List;
     G_debug(3, "Vect_build_nat() build = %d", build);
Modified: grass/trunk/lib/vector/Vlib/build_ogr.c
--- grass/trunk/lib/vector/Vlib/build_ogr.c	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/lib/vector/Vlib/build_ogr.c	2009-07-31 11:46:59 UTC (rev 38552)
@@ -113,7 +113,7 @@
     int line;
     long offset;
-    BOUND_BOX box;
@@ -159,8 +159,8 @@
     int lines[1];
     static struct line_pnts **Points = NULL;
     static int alloc_points = 0;
-    BOUND_BOX box;
-    P_LINE *Line;
     double area_size, x, y;
     int eType, nRings, iPart, nParts, nPoints;
     OGRGeometryH hGeom2, hRing;
@@ -254,7 +254,7 @@
 		outer_area = area;
 	    else {		/* inner ring */
-		P_ISLE *Isle;
 		Isle = plus->Isle[isle];
 		Isle->area = outer_area;
@@ -273,7 +273,7 @@
 		      outer_area);
 	else {
-	    P_AREA *Area;
 	    G_debug(4, "  Centroid: %f, %f", x, y);
 	    Vect_reset_line(Points[0]);
Modified: grass/trunk/lib/vector/Vlib/cindex.c
--- grass/trunk/lib/vector/Vlib/cindex.c	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/lib/vector/Vlib/cindex.c	2009-07-31 11:46:59 UTC (rev 38552)
@@ -444,14 +444,14 @@
     char fname[1024], buf[1024];
-    GVFILE fp;
+    struct gvfile fp;
     G_debug(2, "Vect_cidx_save()");
     check_status(Map);
     G__file_name(fname, buf, GV_CIDX_ELEMENT, Map->mapset);
     G_debug(2, "Open cidx: %s", fname);
     dig_file_init(&fp);
@@ -477,8 +477,8 @@
    \brief Read category index from file if exists
-   \param Map vector map
-   \param head_only Read only header
+   \param Map pointer to Map_info structure
+   \param head_only read only header
    \return 0 on success
    \return 1 if file does not exist
@@ -488,7 +488,7 @@
     int ret;
     char buf[500], file_path[2000];
-    GVFILE fp;
+    struct gvfile fp;
     struct stat info;
@@ -497,7 +497,7 @@
     G__file_name(file_path, buf, GV_CIDX_ELEMENT, Map->mapset);
     if (stat(file_path, &info) != 0)	/* does not exist */
Modified: grass/trunk/lib/vector/Vlib/clean_nodes.c
--- grass/trunk/lib/vector/Vlib/clean_nodes.c	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/lib/vector/Vlib/clean_nodes.c	2009-07-31 11:46:59 UTC (rev 38552)
@@ -66,7 +66,7 @@
 	    G_debug(3, "nlines = %d", nlines);
 	    for (i = 0; i < nlines; i++) {
-		P_LINE *Line;
 		int line2;
 		float angle2;
Modified: grass/trunk/lib/vector/Vlib/close.c
--- grass/trunk/lib/vector/Vlib/close.c	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/lib/vector/Vlib/close.c	2009-07-31 11:46:59 UTC (rev 38552)
@@ -74,7 +74,7 @@
 	struct stat info;
 	/* Delete old support files if available */
 	G__file_name(file_path, buf, GV_TOPO_ELEMENT, G_mapset());
 	if (stat(file_path, &info) == 0)	/* file exists? */
Modified: grass/trunk/lib/vector/Vlib/close_ogr.c
--- grass/trunk/lib/vector/Vlib/close_ogr.c	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/lib/vector/Vlib/close_ogr.c	2009-07-31 11:46:59 UTC (rev 38552)
@@ -71,7 +71,7 @@
     char fname[1000], elem[1000];
     char buf[5];
     long length = 9;
-    GVFILE fp;
+    struct gvfile fp;
     G_debug(3, "V2_close_ogr()");
@@ -81,7 +81,7 @@
     if (strcmp(Map->mapset, G_mapset()) == 0 && Map->support_updated &&
 	Map->plus.built == GV_BUILD_ALL) {
-	sprintf(elem, "%s/%s", GRASS_VECT_DIRECTORY, Map->name);
+	sprintf(elem, "%s/%s", GV_DIRECTORY, Map->name);
 	G__file_name(fname, elem, "fidx", Map->mapset);
 	G_debug(4, "Open fidx: %s", fname);
 	dig_file_init(&fp);
Modified: grass/trunk/lib/vector/Vlib/constraint.c
--- grass/trunk/lib/vector/Vlib/constraint.c	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/lib/vector/Vlib/constraint.c	2009-07-31 11:46:59 UTC (rev 38552)
@@ -75,7 +75,7 @@
    \return 0
-int Vect_get_constraint_box(const struct Map_info *Map, BOUND_BOX * Box)
+int Vect_get_constraint_box(const struct Map_info *Map, struct bound_box * Box)
     Box->N = Map->Constraint_N;
     Box->S = Map->Constraint_S;
Modified: grass/trunk/lib/vector/Vlib/dgraph.h
--- grass/trunk/lib/vector/Vlib/dgraph.h	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/lib/vector/Vlib/dgraph.h	2009-07-31 11:46:59 UTC (rev 38552)
@@ -1,5 +1,5 @@
-#ifndef GRASS_DGRAPH_H
-#define GRASS_DGRAPH_H
+#ifndef GRASS_DdglGraph_s_H
+#define GRASS_DdglGraph_s_H
 /* pg comes from "planar graph" */
 /* every edge is directed. Nevertheless, we can visit it on both sides */
Modified: grass/trunk/lib/vector/Vlib/error.c
--- grass/trunk/lib/vector/Vlib/error.c	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/lib/vector/Vlib/error.c	2009-07-31 11:46:59 UTC (rev 38552)
@@ -41,7 +41,7 @@
    \brief Get behaviour for fatal error
-   \param
+   \todo Remove or move to GIS Library?
    \return GV_FATAL_EXIT(default): print error message and exit,
    \return GV_FATAL_PRINT: print error message and return error,
Modified: grass/trunk/lib/vector/Vlib/find.c
--- grass/trunk/lib/vector/Vlib/find.c	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/lib/vector/Vlib/find.c	2009-07-31 11:46:59 UTC (rev 38552)
@@ -40,7 +40,7 @@
 	       double ux, double uy, double uz, double maxdist, int with_z)
     int i, nnodes, node;
-    BOUND_BOX box;
     struct ilist *NList;
     double x, y, z;
     double cur_dist, dist;
@@ -155,7 +155,7 @@
-    BOUND_BOX box;
     struct ilist *List;
     G_debug(3, "Vect_find_line_list() for %f %f %f type = %d maxdist = %f",
@@ -248,7 +248,7 @@
     int i, ret, area;
-    BOUND_BOX box;
     G_debug(3, "Vect_find_area() x = %f y = %f", x, y);
@@ -294,7 +294,7 @@
     int i, ret, island, current, current_size, size;
-    BOUND_BOX box;
Modified: grass/trunk/lib/vector/Vlib/geos.c
--- grass/trunk/lib/vector/Vlib/geos.c	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/lib/vector/Vlib/geos.c	2009-07-31 11:46:59 UTC (rev 38552)
@@ -1,5 +1,5 @@
-  \file geos.c
+  \file lib/vector/Vlib/geos.c
   \brief Vector library - GEOS support
@@ -46,7 +46,7 @@
 GEOSGeometry *Vect_read_line_geos(struct Map_info *Map, int line, int *type)
-    P_LINE *Line;
     G_debug(3, "Vect_read_line_geos(): line = %d", line);
@@ -246,7 +246,7 @@
 GEOSCoordSequence *V2_read_line_geos(struct Map_info *Map, int line)
     int ftype;
-    P_LINE *Line;
     G_debug(3, "V2_read_line_geos(): line = %d", line);
@@ -373,7 +373,7 @@
 	    GEOSCoordSeq_setZ(pseq, i, z[i]);
-    G_debug(3, "    off = %ld", dig_ftell(&(Map->dig_fp)));
+    G_debug(3, "    off = %ld", (long) dig_ftell(&(Map->dig_fp)));
     G_free((void *) x);
     G_free((void *) y);
@@ -400,7 +400,7 @@
 GEOSCoordSequence *Vect_get_area_points_geos(struct Map_info *Map, int area)
-    P_AREA *Area;
     G_debug(3, "Vect_get_area_points_geos(): area = %d", area);
@@ -431,7 +431,7 @@
 GEOSCoordSequence *Vect_get_isle_points_geos(struct Map_info *Map, int isle)
-    P_ISLE *Isle;
     G_debug(3, "Vect_get_isle_points_geos(): isle = %d", isle);
Modified: grass/trunk/lib/vector/Vlib/graph.c
--- grass/trunk/lib/vector/Vlib/graph.c	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/lib/vector/Vlib/graph.c	2009-07-31 11:46:59 UTC (rev 38552)
@@ -5,7 +5,7 @@
    Higher level functions for reading/writing/manipulating vectors.
-   \todo Vect_graph_free ( GRAPH *graph )
+   \todo Vect_graph_free ( dglGraph_s *graph )
@@ -70,7 +70,7 @@
    \return void
-void Vect_graph_init(GRAPH * graph, int nodes_costs)
+void Vect_graph_init(dglGraph_s * graph, int nodes_costs)
     dglInt32_t opaqueset[16] =
 	{ 360000, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0 };
@@ -96,7 +96,7 @@
    \return void
-void Vect_graph_build(GRAPH * graph)
+void Vect_graph_build(dglGraph_s * graph)
     int ret;
@@ -123,7 +123,7 @@
    \return void
 void
-Vect_graph_add_edge(GRAPH * graph, int from, int to, double costs, int id)
+Vect_graph_add_edge(dglGraph_s * graph, int from, int to, double costs, int id)
     int ret;
     dglInt32_t dglcosts;
@@ -153,7 +153,7 @@
    \return void
-void Vect_graph_set_node_costs(GRAPH * graph, int node, double costs)
+void Vect_graph_set_node_costs(dglGraph_s * graph, int node, double costs)
@@ -183,7 +183,7 @@
    \return -1 destination unreachable
 int
-Vect_graph_shortest_path(GRAPH * graph, int from, int to, struct ilist *List,
+Vect_graph_shortest_path(dglGraph_s * graph, int from, int to, struct ilist *List,
 			 double *cost)
     int i, line, *pclip, cArc, nRet;
Modified: grass/trunk/lib/vector/Vlib/header.c
--- grass/trunk/lib/vector/Vlib/header.c	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/lib/vector/Vlib/header.c	2009-07-31 11:46:59 UTC (rev 38552)
@@ -77,21 +77,21 @@
-   \return GRASS_OK on success
-   \return GRASS_ERR on error
+   \return 0 on success
+   \return -1 on error
 int Vect__write_head(const struct Map_info *Map)
     char buf[GPATH_MAX];
     FILE *head_fp;
-    head_fp = G_fopen_new(buf, GRASS_VECT_HEAD_ELEMENT);
+    head_fp = G_fopen_new(buf, GV_HEAD_ELEMENT);
     if (head_fp == NULL) {
 	G_warning(_("Unable to open header file of vector <%s>"),
 		  Vect_get_full_name(Map));
-	return (GRASS_ERR);
+	return (-1);
     fprintf(head_fp, "ORGANIZATION: %s\n", Vect_get_organization(Map));
@@ -105,16 +105,16 @@
     fprintf(head_fp, "MAP THRESH:   %f\n", Vect_get_thresh(Map));
     fclose(head_fp);
-    return (GRASS_OK);
+    return (0);
-   \brief Reads head information from text file (GRASS_VECT_HEAD_ELEMENT).
+   \brief Reads head information from text file (GV_HEAD_ELEMENT).
 int Vect__read_head(struct Map_info *Map)
@@ -134,12 +134,12 @@
     Vect_set_thresh(Map, 0.);
     G_debug(1, "Vect__read_head(): vector = %s@%s", Map->name, Map->mapset);
-    sprintf(buff, "%s/%s", GRASS_VECT_DIRECTORY, Map->name);
-    head_fp = G_fopen_old(buff, GRASS_VECT_HEAD_ELEMENT, Map->mapset);
+    sprintf(buff, "%s/%s", GV_DIRECTORY, Map->name);
+    head_fp = G_fopen_old(buff, GV_HEAD_ELEMENT, Map->mapset);
+	return (-1);
     while (G_getl2(buff, 2000, head_fp)) {
@@ -185,7 +185,7 @@
     fclose(head_fp);
+    return (0);
Modified: grass/trunk/lib/vector/Vlib/hist.c
--- grass/trunk/lib/vector/Vlib/hist.c	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/lib/vector/Vlib/hist.c	2009-07-31 11:46:59 UTC (rev 38552)
@@ -22,7 +22,7 @@
    \brief Write command info to history file
    \return -1 error
@@ -52,7 +52,7 @@
    \brief Write string to history file
    \param str string to write
    \return the number of characters printed
Modified: grass/trunk/lib/vector/Vlib/init_head.c
--- grass/trunk/lib/vector/Vlib/init_head.c	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/lib/vector/Vlib/init_head.c	2009-07-31 11:46:59 UTC (rev 38552)
@@ -1,8 +1,8 @@
-   \file init_head.c
+   \file vector/Vlib/init_head.c
-   \brief Vector library - init header of vector map
+   \brief Vector library - init header of vector maps
    Initialize Head structure. To make sure that we are not writing out
@@ -15,6 +15,7 @@
    \author Original author CERL, probably Dave Gerdes or Mike Higgins.
    \author Update to GRASS 5.7 Radim Blazek and David D. Gray.
+   \author Various updates by Martin Landa <landa.martin gmail.com>, 2009
@@ -23,40 +24,49 @@
 #include <grass/vector.h>
-   \brief Initialize head structure
+   \brief Initialize Map_info head structure (dig_head)
-   \return 0
+   \param[in,out] Map pointer to Map_info structure
-int Vect__init_head(struct Map_info *Map)
+void Vect__init_head(struct Map_info *Map)
     char buf[64];
+    /* organization */
     Map->head.organization = NULL;
     Vect_set_organization(Map, "");
+    /* date */
     Map->head.date = NULL;
     Vect_set_date(Map, "");
+    /* user name */
     Map->head.your_name = NULL;
     sprintf(buf, "%s", G_whoami());
     Vect_set_person(Map, buf);
+    /* map name */
     Map->head.map_name = NULL;
     Vect_set_map_name(Map, "");
+    /* source date */
     Map->head.source_date = NULL;
     sprintf(buf, "%s", G_date());
     Vect_set_map_date(Map, buf);
+    /* comments */
     Map->head.line_3 = NULL;
     Vect_set_comment(Map, "");
+    /* scale, zone, threshold */
     Vect_set_scale(Map, 1);
     Vect_set_zone(Map, 0);
     Vect_set_thresh(Map, 0.0);
+    /* support variables */
     Map->plus.Spidx_built = 0;
     Map->plus.release_support = 0;
     Map->plus.update_cidx = 0;
-    return 0;
Modified: grass/trunk/lib/vector/Vlib/level_two.c
--- grass/trunk/lib/vector/Vlib/level_two.c	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/lib/vector/Vlib/level_two.c	2009-07-31 11:46:59 UTC (rev 38552)
@@ -181,7 +181,7 @@
 Vect_get_node_coor(const struct Map_info *map, int num, double *x, double *y,
 		   double *z)
-    P_NODE *Node;
     Node = map->plus.Node[num];
     *x = Node->x;
Modified: grass/trunk/lib/vector/Vlib/line.c
--- grass/trunk/lib/vector/Vlib/line.c	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/lib/vector/Vlib/line.c	2009-07-31 11:46:59 UTC (rev 38552)
@@ -762,7 +762,7 @@
    \return 0
-int Vect_line_box(const struct line_pnts *Points, BOUND_BOX * Box)
+int Vect_line_box(const struct line_pnts *Points, struct bound_box * Box)
     dig_line_box(Points, Box);
     return 0;
Modified: grass/trunk/lib/vector/Vlib/map.c
--- grass/trunk/lib/vector/Vlib/map.c	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/lib/vector/Vlib/map.c	2009-07-31 11:46:59 UTC (rev 38552)
@@ -161,8 +161,8 @@
     struct field_info *Fi, *Fin;
     char old_path[GPATH_MAX], new_path[GPATH_MAX], buf[GPATH_MAX];
     struct stat info;
-    const char *files[] = { GRASS_VECT_FRMT_ELEMENT, GRASS_VECT_COOR_ELEMENT,
-	GRASS_VECT_HEAD_ELEMENT, GRASS_VECT_HIST_ELEMENT,
+    const char *files[] = { GV_FRMT_ELEMENT, GV_COOR_ELEMENT,
+	GV_HEAD_ELEMENT, GV_HIST_ELEMENT,
 	GV_TOPO_ELEMENT, GV_SIDX_ELEMENT, GV_CIDX_ELEMENT,
 	NULL
@@ -200,16 +200,16 @@
     /* Copy the directory */
-    G__make_mapset_element(GRASS_VECT_DIRECTORY);
-    sprintf(buf, "%s/%s", GRASS_VECT_DIRECTORY, out);
+    G__make_mapset_element(GV_DIRECTORY);
+    sprintf(buf, "%s/%s", GV_DIRECTORY, out);
     G__make_mapset_element(buf);
     i = 0;
     while (files[i]) {
 	sprintf(buf, "%s/%s", in, files[i]);
-	G__file_name(old_path, GRASS_VECT_DIRECTORY, buf, mapset);
+	G__file_name(old_path, GV_DIRECTORY, buf, mapset);
 	sprintf(buf, "%s/%s", out, files[i]);
-	G__file_name(new_path, GRASS_VECT_DIRECTORY, buf, G_mapset());
+	G__file_name(new_path, GV_DIRECTORY, buf, G_mapset());
 	if (stat(old_path, &info) == 0) {	/* file exists? */
 	    G_debug(2, "copy %s to %s", old_path, new_path);
@@ -221,8 +221,8 @@
 	i++;
-    G__file_name(old_path, GRASS_VECT_DIRECTORY, in, mapset);
-    G__file_name(new_path, GRASS_VECT_DIRECTORY, out, G_mapset());
+    G__file_name(old_path, GV_DIRECTORY, in, mapset);
+    G__file_name(new_path, GV_DIRECTORY, out, G_mapset());
     /* Open input */
     Vect_set_open_level(1);
@@ -331,7 +331,7 @@
     /* Move the directory */
-    ret = G_rename(GRASS_VECT_DIRECTORY, in, out);
+    ret = G_rename(GV_DIRECTORY, in, out);
     if (ret == 0) {
 	G_warning(_("Vector map <%s> not found"), in);
@@ -462,7 +462,7 @@
     sprintf(buf, "%s/%s/%s/%s/%s/%s", G_gisdbase(), G_location(),
-	    G_mapset(), GRASS_VECT_DIRECTORY, map, GRASS_VECT_DBLN_ELEMENT);
+	    G_mapset(), GV_DIRECTORY, map, GV_DBLN_ELEMENT);
     G_debug(1, "dbln file: %s", buf);
Modified: grass/trunk/lib/vector/Vlib/merge_lines.c
--- grass/trunk/lib/vector/Vlib/merge_lines.c	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/lib/vector/Vlib/merge_lines.c	2009-07-31 11:46:59 UTC (rev 38552)
@@ -51,7 +51,7 @@
     struct ilist *List;
     struct line_pnts *MPoints, *Points;
     struct line_cats *MCats, *Cats;
-    P_LINE *Line;
     if ((type & GV_BOUNDARY) && (type & GV_LINE)) {
 	G_warning
Modified: grass/trunk/lib/vector/Vlib/open.c
--- grass/trunk/lib/vector/Vlib/open.c	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/lib/vector/Vlib/open.c	2009-07-31 11:46:59 UTC (rev 38552)
@@ -1,5 +1,5 @@
- * \file open.c
+ * \file vector/Vlib/open.c
  * \brief Vector library - Open vector map
@@ -70,20 +70,20 @@
- * \brief Predetermine level at which a map will be opened for
+ * \brief Predetermine level at which a vector map will be opened for
  * reading.
  * If it can't open that level, the open will fail. The specified
- * level must be set before any call to open.  The default is to try
- * to open the highest level possible, and keep stepping down until
+ * level must be set before any call to open. The default is to try to
+ * open the highest level possible, and keep stepping down until
  * success.
- * NOTE!!  This should only be used to set when you wish to force
- * a lower level open.  If you require a higher level, then just
- * check the return to verify the level instead of forcing it.
- * This is because future releases will have higher levels which
- * will be downward compatible and which your programs should
- * support by default.
+ * NOTE: This should only be used to set when you wish to force a
+ * lower level open. If you require a higher level, then just check
+ * the return to verify the level instead of forcing it.  This is
+ * because future releases will have higher levels which will be
+ * downward compatible and which your programs should support by
+ * default.
  * \param level vector (topo) level
@@ -104,7 +104,6 @@
     return 0;
  * \brief Open old vector for reading.
@@ -128,11 +127,15 @@
     FILE *fp;
     int level, level_request, ferror;
     int format, ret;
+    int ogr_mapset;
     const char *fmapset;
-    G_debug(1, "Vect_open_old(): name = %s mapset= %s update = %d", name,
+    G_debug(1, "Vect__open_old(): name = %s mapset= %s update = %d", name,
 	    mapset, update);
+    /* zero Map_info structure */
+    G_zero(Map, sizeof(struct Map_info));
     /* TODO: Open header for update ('dbln') */
     ferror = Vect_get_fatal_error();
@@ -140,19 +143,31 @@
     level_request = Open_level;
     Open_level = 0;
+    /* initialize Map->head */
     Vect__init_head(Map);
+    /* initialize Map->plus */
     dig_init_plus(&(Map->plus));
+    ogr_mapset = 0;
     if (G__name_is_fully_qualified(name, xname, xmapset)) {
-	sprintf(buf, "%s/%s", GRASS_VECT_DIRECTORY, xname);
-	sprintf(buf2, "%s@%s", GRASS_VECT_COOR_ELEMENT, xmapset);
+	if (strcmp(xmapset, "OGR") == 0) {
+	    /* unique OGR mapset detected */
+	    ogr_mapset = 1;
+	    Map->fInfo.ogr.dsn = xname;
+	    Map->fInfo.ogr.layer_name = NULL; /* no layer to be open */
+	else {
+	    sprintf(buf, "%s/%s", GV_DIRECTORY, xname);
+	    sprintf(buf2, "%s@%s", GV_COOR_ELEMENT, xmapset);
 	Map->name = G_store(xname);
 	Map->mapset = G_store(xmapset);
     else {
-	sprintf(buf, "%s/%s", GRASS_VECT_DIRECTORY, name);
-	sprintf(buf2, "%s", GRASS_VECT_COOR_ELEMENT);
+	sprintf(buf, "%s/%s", GV_DIRECTORY, name);
+	sprintf(buf2, "%s", GV_COOR_ELEMENT);
 	Map->name = G_store(name);
 	if (mapset)
@@ -172,7 +187,7 @@
     Map->location = G_store(G_location());
     Map->gisdbase = G_store(G_gisdbase());
     if (update && (0 != strcmp(Map->mapset, G_mapset()))) {
 	G_warning(_("Vector map which is not in the current mapset cannot be opened for update"));
 	return -1;
@@ -182,32 +197,36 @@
     G_debug(1, "Map mapset: %s", Map->mapset);
     /* Read vector format information */
-    format = 0;
-    G_debug(1, "open format file: '%s/%s/%s'", Map->mapset, buf,
-	    GRASS_VECT_FRMT_ELEMENT);
-    fp = G_fopen_old(buf, GRASS_VECT_FRMT_ELEMENT, Map->mapset);
-    if (fp == NULL) {
-	G_debug(1, "Vector format: %d (native)", format);
-	format = GV_FORMAT_NATIVE;
+    if (ogr_mapset) {
+	format = GV_FORMAT_OGR;
     else {
-	format = dig_read_frmt_ascii(fp, &(Map->fInfo));
-	fclose(fp);
-	G_debug(1, "Vector format: %d (non-native)", format);
-	if (format < 0) {
-	    sprintf(errmsg, _("Unable to open vector map <%s>"),
-		    Vect_get_full_name(Map));
-	    fatal_error(ferror, errmsg);
-	    return -1;
+	format = 0;
+	G_debug(1, "open format file: '%s/%s/%s'", Map->mapset, buf,
+		GV_FRMT_ELEMENT);
+	fp = G_fopen_old(buf, GV_FRMT_ELEMENT, Map->mapset);
+	if (fp == NULL) {
+	    G_debug(1, "Vector format: %d (native)", format);
+	    format = GV_FORMAT_NATIVE;
+	else {
+	    format = dig_read_frmt_ascii(fp, &(Map->fInfo));
+	    fclose(fp);
+	    G_debug(1, "Vector format: %d (non-native)", format);
+	    if (format < 0) {
+		sprintf(errmsg, _("Unable to open vector map <%s>"),
+			Vect_get_full_name(Map));
+		fatal_error(ferror, errmsg);
+		return -1;
     Map->format = format;
     /* Read vector head */
-    if (Vect__read_head(Map) != GRASS_OK) {
+    if (!ogr_mapset && Vect__read_head(Map) != 0) {
 	sprintf(errmsg,
 		_("Unable to open vector map <%s> on level %d. "
 		  "Try to rebuild vector topology by v.build."),
@@ -215,7 +234,7 @@
 	G_warning(_("Unable to read head file of vector <%s>"),
     G_debug(1, "Level request = %d", level_request);
     /* There are only 2 possible open levels, 1 and 2. Try first to open 'support' files
@@ -279,12 +298,19 @@
 #endif
 	if (level_request == 2 && level < 2) {
-	    sprintf(errmsg,
-		    _("Unable to open vector map <%s> on level %d. "
-		      "Try to rebuild vector topology by v.build."),
-		    Vect_get_full_name(Map), level_request);
-	    return -1;
+	    if (ogr_mapset) {
+		G_warning(_("Topology level (2) is not supported when reading "
+			    "OGR layers directly. For topology level "
+			    "is required link to OGR layer via v.external command."));
+	    else {
+		sprintf(errmsg,
+			_("Unable to open vector map <%s> on level %d. "
+			  "Try to rebuild vector topology by v.build."),
+			Vect_get_full_name(Map), level_request);
+		return -1;
     else {
@@ -348,10 +374,10 @@
     Vect_read_dblinks(Map);
     /* Open history file */
     if (update) {		/* native only */
-	Map->hist_fp = G_fopen_modify(buf, GRASS_VECT_HIST_ELEMENT);
+	Map->hist_fp = G_fopen_modify(buf, GV_HIST_ELEMENT);
 	if (Map->hist_fp == NULL) {
 	    sprintf(errmsg,
 		    _("Unable to open history file for vector map <%s>"),
@@ -367,7 +393,7 @@
     else {
 	if (Map->format == GV_FORMAT_NATIVE || Map->format == GV_FORMAT_OGR) {
 	    Map->hist_fp =
-		G_fopen_old(buf, GRASS_VECT_HIST_ELEMENT, Map->mapset);
+		G_fopen_old(buf, GV_HIST_ELEMENT, Map->mapset);
 	    /* If NULL (does not exist) then Vect_hist_read() handle that */
 	else {
@@ -384,7 +410,7 @@
 	char file_path[2000];
 	struct stat info;
@@ -458,20 +484,19 @@
- * \brief Reads only info about vector from headers of 'head', 'dbln',
- * 'topo' and 'cidx' file.
+ * \brief Reads only info about vector map from headers of 'head',
+ * 'dbln', 'topo' and 'cidx' file.
  * In case of error, the functions respect fatal error settings.
- * \param[out] Map vector map
+ * \param[out] Map pointer to Map_info structure
  * \param name name of vector map to read
  * \return level of openness [1, 2, (3)]
  * \return -1 on error
-int
-Vect_open_old_head(struct Map_info *Map, const char *name, const char *mapset)
+int Vect_open_old_head(struct Map_info *Map, const char *name, const char *mapset)
     return (Vect__open_old(Map, name, mapset, 0, 1));
@@ -513,9 +538,9 @@
  * \brief Open new vector for reading/writing
+ * \param[in,out] Map pointer to Map_info structure
- * \param with_z 2D/3D vector map
+ * \param with_z non-zero value for 3D vector data
  * \return 1 on success
@@ -576,8 +601,8 @@
-    Map->hist_fp = G_fopen_new(buf, GRASS_VECT_HIST_ELEMENT);
+    Map->hist_fp = G_fopen_new(buf, GV_HIST_ELEMENT);
 	sprintf(errmsg, _("Unable to open history file for vector map <%s>"),
@@ -612,8 +637,8 @@
  * \brief Update Coor_info structure
- * \param Map vector map
- * \param[out] Info Coor_info structure
+ * \param Map pointer to Map_info structure
+ * \param[out] Info pointer to Coor_info structure
  * \return 0 on error
@@ -625,8 +650,8 @@
     switch (Map->format) {
     case GV_FORMAT_NATIVE:
-	G__file_name(path, buf, GRASS_VECT_COOR_ELEMENT, Map->mapset);
+	G__file_name(path, buf, GV_COOR_ELEMENT, Map->mapset);
 	G_debug(1, "get coor info: %s", path);
 	if (0 != stat(path, &stat_buf)) {
 	    G_warning(_("Unable to stat file <%s>"), path);
@@ -692,7 +717,7 @@
  * \brief Open topo file
- * \param[in,out] Map vector map
  * \param head_only open only head
  * \return 0 on success
@@ -703,7 +728,7 @@
     int err, ret;
-    GVFILE fp;
+    struct gvfile fp;
     struct Coor_info CInfo;
     struct stat info;
@@ -713,7 +738,7 @@
     G__file_name(file_path, buf, GV_TOPO_ELEMENT, Map->mapset);
@@ -773,9 +798,9 @@
- * \brief Open spatial index file
+ * \brief Open spatial index file ('sidx')
  * \param mode 0 old, 1 update, 2 new
@@ -783,7 +808,7 @@
 int Vect_open_sidx(struct Map_info *Map, int mode)
-    char buf[500], spidxbuf[500], file_path[2000];
+    char buf[500], file_path[2000];
     int err;
@@ -793,7 +818,7 @@
 	    Map->mapset, mode == 0 ? "old" : (mode == 1 ? "update" : "new"));
     if (Map->plus.Spidx_built == 1) {
-	G_warning("spatial index already opened");
+	G_warning("Spatial index already opened");
 	return 0;
@@ -802,7 +827,7 @@
     if (mode < 2) {
 	G__file_name(file_path, buf, GV_SIDX_ELEMENT, Map->mapset);
Modified: grass/trunk/lib/vector/Vlib/open_nat.c
--- grass/trunk/lib/vector/Vlib/open_nat.c	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/lib/vector/Vlib/open_nat.c	2009-07-31 11:46:59 UTC (rev 38552)
@@ -26,7 +26,7 @@
 static char name_buf[GPATH_MAX];
 static int check_coor(struct Map_info *Map);
    \brief Open existing vector map
    Map->name and Map->mapset must be set before.
@@ -45,13 +45,13 @@
     G_debug(1, "V1_open_old_nat(): name = %s mapset = %s", Map->name,
 	    Map->mapset);
     dig_file_init(&(Map->dig_fp));
     if (update)
-	Map->dig_fp.file = G_fopen_modify(buf, GRASS_VECT_COOR_ELEMENT);
+	Map->dig_fp.file = G_fopen_modify(buf, GV_COOR_ELEMENT);
     else
 	Map->dig_fp.file =
-	    G_fopen_old(buf, GRASS_VECT_COOR_ELEMENT, Map->mapset);
+	    G_fopen_old(buf, GV_COOR_ELEMENT, Map->mapset);
     if (Map->dig_fp.file == NULL) {
         G_warning(_("Unable to open coor file for vector map <%s>"), Map->name);
@@ -77,14 +77,13 @@
     return 0;
-   \brief Open/Create new vector map.
+   \brief Open/Create new vector map (level 1)
-   \param[out] Map pointer to vector map
+   \param[out] Map pointer to Map_info structure
    \param name map name
    \param with_z 2D or 3D (unused?)
    \return 0 success
    \return -1 error
@@ -95,7 +94,7 @@
     G_debug(1, "V1_open_new_nat(): name = %s", name);
     /* Set the 'coor' file version */
     Map->head.Version_Major = GV_COOR_VER_MAJOR;
@@ -105,13 +104,13 @@
     /* TODO open better */
-    Map->dig_fp.file = G_fopen_new(buf, GRASS_VECT_COOR_ELEMENT);
+    Map->dig_fp.file = G_fopen_new(buf, GV_COOR_ELEMENT);
 	return (-1);
     fclose(Map->dig_fp.file);
 	return (-1);
@@ -120,7 +119,7 @@
     if (stat(name_buf, &info) == 0)	/* file exists? */
 	unlink(name_buf);
-    G__file_name(name_buf, buf, GRASS_VECT_COOR_ELEMENT, G_mapset());
+    G__file_name(name_buf, buf, GV_COOR_ELEMENT, G_mapset());
     Map->head.size = 0;
     Map->head.head_size = GV_COOR_HEAD_SIZE + 4;
Modified: grass/trunk/lib/vector/Vlib/open_ogr.c
--- grass/trunk/lib/vector/Vlib/open_ogr.c	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/lib/vector/Vlib/open_ogr.c	2009-07-31 11:46:59 UTC (rev 38552)
@@ -27,7 +27,7 @@
 #ifdef HAVE_OGR
@@ -100,10 +100,10 @@
     return (0);
    \brief Open OGR specific level 2 files (feature index)
    \return 0 success
    \return -1 error
@@ -113,15 +113,15 @@
     char elem[GPATH_MAX];
     char buf[5];		/* used for format version */
     long length;
-    GVFILE fp;
+    struct gvfile fp;
     struct Port_info port;
     int Version_Major, Version_Minor, Back_Major, Back_Minor, byte_order;
     G_debug(3, "V2_open_old_ogr()");
     dig_file_init(&fp);
-    fp.file = G_fopen_old(elem, "fidx", Map->mapset);
+    fp.file = G_fopen_old(elem, GV_FIDX_ELEMENT, Map->mapset);
     if (fp.file == NULL) {
 	G_warning(_("Unable to open fidx file for vector map <%s@%s>"),
Modified: grass/trunk/lib/vector/Vlib/poly.c
--- grass/trunk/lib/vector/Vlib/poly.c	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/lib/vector/Vlib/poly.c	2009-07-31 11:46:59 UTC (rev 38552)
@@ -370,7 +370,7 @@
    int area,
    double cent_x, double cent_y)
-   P_AREA *Area;
    static struct line_pnts *TPoints;
    int isle;
@@ -698,8 +698,8 @@
     int i, line;
-    P_LINE *Line;
-    P_AREA *Area;
     G_debug(3, "Vect_point_in_area_outer_ring(): x = %f y = %f area = %d", X,
 	    Y, area);
@@ -762,8 +762,8 @@
     int i, line;
-    P_LINE *Line;
-    P_ISLE *Isle;
     G_debug(3, "Vect_point_in_island(): x = %f y = %f isle = %d", X, Y, isle);
Modified: grass/trunk/lib/vector/Vlib/read_nat.c
--- grass/trunk/lib/vector/Vlib/read_nat.c	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/lib/vector/Vlib/read_nat.c	2009-07-31 11:46:59 UTC (rev 38552)
@@ -68,7 +68,7 @@
     int itype;
     off_t offset;
-    BOUND_BOX lbox, mbox;
+    struct bound_box lbox, mbox;
     G_debug(3, "V1_read_next_line_nat()");
@@ -122,7 +122,7 @@
 V2_read_line_nat(struct Map_info *Map,
 		 struct line_pnts *line_p, struct line_cats *line_c, int line)
-    P_LINE *Line;
     G_debug(3, "V2_read_line_nat(): line = %d", line);
@@ -153,8 +153,8 @@
 		      struct line_pnts *line_p, struct line_cats *line_c)
     register int line;
-    register P_LINE *Line;
+    register struct P_line *Line;
     G_debug(3, "V2_read_next_line_nat()");
Modified: grass/trunk/lib/vector/Vlib/read_ogr.c
--- grass/trunk/lib/vector/Vlib/read_ogr.c	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/lib/vector/Vlib/read_ogr.c	2009-07-31 11:46:59 UTC (rev 38552)
@@ -141,7 +141,7 @@
     int itype;
     OGRFeatureH hFeature;
     OGRGeometryH hGeom;
@@ -325,8 +325,8 @@
     int node;
     int offset;
     long FID;
-    P_LINE *Line;
-    P_NODE *Node;
     OGRGeometryH hGeom;
     G_debug(4, "V2_read_line_ogr() line = %d", line);
Modified: grass/trunk/lib/vector/Vlib/remove_duplicates.c
--- grass/trunk/lib/vector/Vlib/remove_duplicates.c	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/lib/vector/Vlib/remove_duplicates.c	2009-07-31 11:46:59 UTC (rev 38552)
@@ -39,7 +39,7 @@
     struct line_cats *ACats, *BCats, *Cats;
     int i, j, c, atype, btype, bline;
     int nlines, nbcats_orig;
-    BOUND_BOX ABox;
+    struct bound_box ABox;
     struct ilist *List;
     int ndupl;
Modified: grass/trunk/lib/vector/Vlib/select.c
--- grass/trunk/lib/vector/Vlib/select.c	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/lib/vector/Vlib/select.c	2009-07-31 11:46:59 UTC (rev 38552)
@@ -30,7 +30,7 @@
    \return void
-void Vect_spatial_index_init(SPATIAL_INDEX * si, int with_z)
+void Vect_spatial_index_init(struct spatial_index * si, int with_z)
     G_debug(1, "Vect_spatial_index_init()");
@@ -46,7 +46,7 @@
    \return void
-void Vect_spatial_index_destroy(SPATIAL_INDEX * si)
+void Vect_spatial_index_destroy(struct spatial_index * si)
     G_debug(1, "Vect_spatial_index_destroy()");
@@ -62,8 +62,8 @@
    \return void
-void Vect_spatial_index_add_item(SPATIAL_INDEX * si, int id,
-				 const BOUND_BOX * box)
+void Vect_spatial_index_add_item(struct spatial_index * si, int id,
+				 const struct bound_box * box)
     struct Rect rect;
@@ -86,8 +86,8 @@
    \return void
-void Vect_spatial_index_del_item(SPATIAL_INDEX * si, int id,
+void Vect_spatial_index_del_item(struct spatial_index * si, int id,
     int ret;
     struct Rect rect;
@@ -125,7 +125,7 @@
    \return number of selected items
 int
-Vect_spatial_index_select(const SPATIAL_INDEX * si, const BOUND_BOX * box,
+Vect_spatial_index_select(const struct spatial_index * si, const struct bound_box * box,
 			  struct ilist *list)
     struct Rect rect;
Modified: grass/trunk/lib/vector/Vlib/sindex.c
--- grass/trunk/lib/vector/Vlib/sindex.c	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/lib/vector/Vlib/sindex.c	2009-07-31 11:46:59 UTC (rev 38552)
@@ -32,12 +32,12 @@
    \return number of lines
 int
-Vect_select_lines_by_box(struct Map_info *Map, const BOUND_BOX * Box,
+Vect_select_lines_by_box(struct Map_info *Map, const struct bound_box * Box,
 			 int type, struct ilist *list)
     int i, line, nlines;
-    P_LINE *Line;
     static struct ilist *LocList = NULL;
     G_debug(3, "Vect_select_lines_by_box()");
@@ -86,7 +86,7 @@
    \return number of areas
 int
-Vect_select_areas_by_box(struct Map_info *Map, const BOUND_BOX * Box,
+Vect_select_areas_by_box(struct Map_info *Map, const struct bound_box * Box,
 			 struct ilist *list)
     int i;
@@ -137,7 +137,7 @@
    \return number of isles
 int
-Vect_select_isles_by_box(struct Map_info *Map, const BOUND_BOX * Box,
+Vect_select_isles_by_box(struct Map_info *Map, const struct bound_box * Box,
 			 struct ilist *list)
     G_debug(3, "Vect_select_isles_by_box()");
@@ -165,7 +165,7 @@
    \return number of nodes
 int
-Vect_select_nodes_by_box(struct Map_info *Map, const BOUND_BOX * Box,
+Vect_select_nodes_by_box(struct Map_info *Map, const struct bound_box * Box,
 			 struct ilist *list)
@@ -209,7 +209,7 @@
 			     struct ilist *List)
     int i;
-    BOUND_BOX box;
+    struct bound_box box;
     static struct line_pnts *LPoints = NULL;
Modified: grass/trunk/lib/vector/Vlib/tin.c
--- grass/trunk/lib/vector/Vlib/tin.c	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/lib/vector/Vlib/tin.c	2009-07-31 11:46:59 UTC (rev 38552)
@@ -34,7 +34,7 @@
     int i, area, n_points;
-    P_AREA *Area;
     double *x, *y, *z;
Modified: grass/trunk/lib/vector/Vlib/write_nat.c
--- grass/trunk/lib/vector/Vlib/write_nat.c	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/lib/vector/Vlib/write_nat.c	2009-07-31 11:46:59 UTC (rev 38552)
@@ -39,7 +39,7 @@
 static void delete_area_cats_from_cidx(struct Map_info *Map, int area)
     int i;
-    P_AREA *Area;
     G_debug(3, "delete_area_cats_from_cidx() area = %d", area);
@@ -72,7 +72,7 @@
 static void add_area_cats_to_cidx(struct Map_info *Map, int area)
     int i;
-    P_AREA *Area;
     G_debug(3, "add_area_cats_to_cidx() area = %d", area);
@@ -134,11 +134,11 @@
     int type, node, next_line, area, side, sel_area, new_area[2];
-    P_LINE *Line, *NLine;
-    P_NODE *Node;
-    P_AREA *Area;
+    struct P_line *Line, *NLine;
     Line = plus->Line[line];
@@ -342,7 +342,7 @@
     int line;
     off_t offset;
-    BOUND_BOX box;
     line = 0;
@@ -491,7 +491,7 @@
     int i, n_points;
     char rhead, nc;
     short field;
-    GVFILE *dig_fp;
+    struct gvfile *dig_fp;
     dig_set_cur_port(&(Map->head.port));
     dig_fp = &(Map->dig_fp);
@@ -583,7 +583,7 @@
 int V1_delete_line_nat(struct Map_info *Map, off_t offset)
     char rhead;
-    GVFILE *dig_fp;
     G_debug(3, "V1_delete_line_nat(), offset = %lu", (unsigned long) offset);
@@ -623,10 +623,10 @@
 int V2_delete_line_nat(struct Map_info *Map, int line)
     int ret, i, side, type = 0, first = 0, next_line, area;
-    P_LINE *Line = NULL;
-    P_AREA *Area;
+    struct P_line *Line = NULL;
     int adjacent[4], n_adjacent = 0;
@@ -822,7 +822,7 @@
 int V1_restore_line_nat(struct Map_info *Map, off_t offset)
     char rhead;
-    GVFILE *dig_fp;
     G_debug(3, "V1_restore_line_nat(), offset = %lu", (unsigned long) offset);
@@ -865,9 +865,9 @@
 int V2_restore_line_nat(struct Map_info *Map, int line, off_t offset)
     int i, ret, type;
-    P_LINE *Line;
-    BOUND_BOX box;
     static struct line_pnts *points = NULL;
     static struct line_cats *cats = NULL;
Modified: grass/trunk/lib/vector/dglib/graph.h
--- grass/trunk/lib/vector/dglib/graph.h	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/lib/vector/dglib/graph.h	2009-07-31 11:46:59 UTC (rev 38552)
@@ -20,8 +20,8 @@
  * best view tabstop=4
-#ifndef _DGL_GRAPH_H_
-#define _DGL_GRAPH_H_
+#ifndef _DGL_dglGraph_s_H_
+#define _DGL_dglGraph_s_H_
 #ifdef DGL_STATS
 #include <time.h>
Modified: grass/trunk/lib/vector/dglib/graph_v1.h
--- grass/trunk/lib/vector/dglib/graph_v1.h	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/lib/vector/dglib/graph_v1.h	2009-07-31 11:46:59 UTC (rev 38552)
@@ -20,8 +20,8 @@
-#ifndef _DGL_GRAPH_V1_H_
-#define _DGL_GRAPH_V1_H_
+#ifndef _DGL_dglGraph_s_V1_H_
+#define _DGL_dglGraph_s_V1_H_
 #ifdef DGL_STATS
 #include <time.h>
Modified: grass/trunk/lib/vector/dglib/graph_v2.h
--- grass/trunk/lib/vector/dglib/graph_v2.h	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/lib/vector/dglib/graph_v2.h	2009-07-31 11:46:59 UTC (rev 38552)
@@ -20,8 +20,8 @@
-#ifndef _DGL_GRAPH_V2_H_
-#define _DGL_GRAPH_V2_H_
+#ifndef _DGL_dglGraph_s_V2_H_
+#define _DGL_dglGraph_s_V2_H_
 #ifdef DGL_STATS
 #include <time.h>
Modified: grass/trunk/lib/vector/diglib/box.c
--- grass/trunk/lib/vector/diglib/box.c	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/lib/vector/diglib/box.c	2009-07-31 11:46:59 UTC (rev 38552)
@@ -22,7 +22,7 @@
  *  dig_line_box ()
  *  set box to points extent
-int dig_line_box(const struct line_pnts *Points, BOUND_BOX * Box)
+int dig_line_box(const struct line_pnts *Points, struct bound_box * Box)
     int i;
@@ -67,7 +67,7 @@
  *  dig_box_copy ()
  *  Copy B to A.
-int dig_box_copy(BOUND_BOX * A, BOUND_BOX * B)
+int dig_box_copy(struct bound_box * A, struct bound_box * B)
     A->N = B->N;
@@ -84,7 +84,7 @@
  * dig_box_extend ()
  * Extend A by B.
-int dig_box_extend(BOUND_BOX * A, BOUND_BOX * B)
+int dig_box_extend(struct bound_box * A, struct bound_box * B)
     if (B->N > A->N)
Modified: grass/trunk/lib/vector/diglib/cindex.c
--- grass/trunk/lib/vector/diglib/cindex.c	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/lib/vector/diglib/cindex.c	2009-07-31 11:46:59 UTC (rev 38552)
@@ -20,12 +20,13 @@
- *  dig_cidx_init ()
- *  initit cat index
+ * \brief Initialize Plus_head structure (cidx)
- *  returns 1 OK
- *          0 on error
+ * \param Plus pointer to Plus_head structure
+ * \return 1 OK
+ * \return 0 on error
 int dig_cidx_init(struct Plus_head *Plus)
Modified: grass/trunk/lib/vector/diglib/cindex_rw.c
--- grass/trunk/lib/vector/diglib/cindex_rw.c	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/lib/vector/diglib/cindex_rw.c	2009-07-31 11:46:59 UTC (rev 38552)
@@ -21,7 +21,7 @@
-int dig_write_cidx_head(GVFILE * fp, struct Plus_head *plus)
+int dig_write_cidx_head(struct gvfile * fp, struct Plus_head *plus)
     int i;
     unsigned char buf[5];
@@ -110,8 +110,16 @@
     return (0);
-/* return: 0 OK, -1 error */
-int dig_read_cidx_head(GVFILE * fp, struct Plus_head *plus)
+  \brief Read header of cidx file
+  \param fp pointer to gvfile structure
+  \param plus pointer to Plus_head strcuture
+  \return 0 OK
+  \return -1 error
+int dig_read_cidx_head(struct gvfile * fp, struct Plus_head *plus)
     int i, byte_order;
@@ -232,7 +240,7 @@
 /* Write spatial index */
-int dig_write_cidx(GVFILE * fp, struct Plus_head *plus)
+int dig_write_cidx(struct gvfile * fp, struct Plus_head *plus)
     int i;
@@ -266,11 +274,17 @@
     return 0;
-/* Read spatial index file
- * returns 0 - OK
- *         1 - error
-int dig_read_cidx(GVFILE * fp, struct Plus_head *plus, int head_only)
+  \brief Read spatial index file
+  \param[in,out] plus pointer to Plus_head structure
+  \param head_only non-zero to read only head
+  \return 0 OK
+  \return 1 error
+int dig_read_cidx(struct gvfile * fp, struct Plus_head *plus, int head_only)
     int i;
Modified: grass/trunk/lib/vector/diglib/file.c
--- grass/trunk/lib/vector/diglib/file.c	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/lib/vector/diglib/file.c	2009-07-31 11:46:59 UTC (rev 38552)
@@ -29,13 +29,13 @@
-  \brief Get GVFILE position.
+  \brief Get struct gvfile position.
-  \param file pointer to GVFILE structure
+  \param file pointer to struct gvfile structure
   \return current file position
-off_t dig_ftell(GVFILE *file)
+off_t dig_ftell(struct gvfile *file)
     if (file->loaded) /* using memory */
 	return (file->current - file->start);
@@ -44,7 +44,7 @@
-  \brief Set GVFILE position.
+  \brief Set struct gvfile position.
   Start positions:
@@ -52,14 +52,14 @@
    - SEEK_CUR (current position)
    - SEEK_END (end)
   \param offset offset position
   \param whence start position
   \return 0 OK
   \return -1 error
-int dig_fseek(GVFILE * file, off_t offset, int whence)
+int dig_fseek(struct gvfile * file, off_t offset, int whence)
     if (file->loaded) {	 /* using memory */
 	switch (whence) {
@@ -82,11 +82,11 @@
-  \brief Rewind GVFILE position.
+  \brief Rewind file position.
+  \param file pointer to gvfile structure
-void dig_rewind(GVFILE * file)
+void dig_rewind(struct gvfile * file)
 	file->current = file->start;
@@ -97,13 +97,13 @@
-  \brief Flush GVFILE.
+  \brief Flush struct gvfile.
   \return 0
-int dig_fflush(GVFILE * file)
+int dig_fflush(struct gvfile * file)
 	return 0;
@@ -114,16 +114,16 @@
-  \brief Read GVFILE.
+  \brief Read struct gvfile.
   \param[out] ptr data buffer
   \param size buffer size
   \param nmemb number of members
   \return number of read members
-size_t dig_fread(void *ptr, size_t size, size_t nmemb, GVFILE *file)
+size_t dig_fread(void *ptr, size_t size, size_t nmemb, struct gvfile *file)
     long tot;
     size_t cnt;
@@ -146,16 +146,16 @@
-  \brief Write GVFILE.
+  \brief Write struct gvfile.
   \param ptr data buffer
-  \param[out] file pointer to GVFILE structure
+  \param[out] file pointer to struct gvfile structure
   \return number of items written
-size_t dig_fwrite(const void *ptr, size_t size, size_t nmemb, GVFILE *file)
+size_t dig_fwrite(const void *ptr, size_t size, size_t nmemb, struct gvfile *file)
 	G_fatal_error(_("Writing to file loaded to memory not supported"));
@@ -165,11 +165,11 @@
-  \brief Initialize GVFILE.
+  \brief Initialize gvfile strcuture
+  \param[in,out] file pointer to gvfile structure
-void dig_file_init(GVFILE *file)
+void dig_file_init(struct gvfile *file)
     file->file = NULL;
     file->start = NULL;
@@ -181,17 +181,17 @@
-  \brief Load opened GVFILE to memory.
+  \brief Load opened struct gvfile to memory.
   Warning: position in file is set to the beginning.
   \return 1 loaded
   \return 0 not loaded
   \return -1 error
-int dig_file_load(GVFILE * file)
+int dig_file_load(struct gvfile * file)
     int ret, mode, load;
     const char *cmode;
@@ -266,11 +266,11 @@
-  \brief Free GVFILE.
+  \brief Free struct gvfile.
-void dig_file_free(GVFILE * file)
+void dig_file_free(struct gvfile * file)
     if (file->loaded) {
 	G_free(file->start);
Modified: grass/trunk/lib/vector/diglib/frmt.c
--- grass/trunk/lib/vector/diglib/frmt.c	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/lib/vector/diglib/frmt.c	2009-07-31 11:46:59 UTC (rev 38552)
@@ -20,11 +20,15 @@
-/* Read vector format.
- *  Returns: format number
- *           -1 on error
+  \brief Read external vector format file
+  \param dascii format file (frmt)
+  \param[out] finfo pointer to Format_info structure
+  \return format code
 int dig_read_frmt_ascii(FILE * dascii, struct Format_info *finfo)
     char buff[20001], buf1[1024];
Modified: grass/trunk/lib/vector/diglib/inside.c
--- grass/trunk/lib/vector/diglib/inside.c	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/lib/vector/diglib/inside.c	2009-07-31 11:46:59 UTC (rev 38552)
@@ -30,7 +30,7 @@
     return (a + b * Y);
-int dig_in_area_bbox(P_AREA * Area, double x, double y)
+int dig_in_area_bbox(struct P_area * Area, double x, double y)
 #ifdef GDEBUG
     G_debug(3, "BBOX: (x,y) (%lf, %lf)\n", x, y);
Modified: grass/trunk/lib/vector/diglib/plus.c
--- grass/trunk/lib/vector/diglib/plus.c	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/lib/vector/diglib/plus.c	2009-07-31 11:46:59 UTC (rev 38552)
@@ -24,7 +24,7 @@
- * \brief Init head structure
  * \param[in,out] Plus pointer to Plus_head structure
@@ -109,7 +109,7 @@
 void dig_free_plus_nodes(struct Plus_head *Plus)
     int i;
-    P_NODE *Node;
     G_debug(2, "dig_free_plus_nodes()");
@@ -137,7 +137,7 @@
 void dig_free_plus_lines(struct Plus_head *Plus)
     int i;
-    P_LINE *Line;
     G_debug(2, "dig_free_plus_lines()");
@@ -173,7 +173,7 @@
 void dig_free_plus_areas(struct Plus_head *Plus)
     int i;
-    P_AREA *Area;
     G_debug(2, "dig_free_plus_areas()");
@@ -201,7 +201,7 @@
 void dig_free_plus_isles(struct Plus_head *Plus)
     int i;
-    P_ISLE *Isle;
     G_debug(2, "dig_free_plus_isles()");
@@ -250,7 +250,7 @@
-int dig_load_plus(struct Plus_head *Plus, GVFILE * plus, int head_only)
+int dig_load_plus(struct Plus_head *Plus, struct gvfile * plus, int head_only)
     int i;
@@ -325,7 +325,7 @@
-int dig_write_plus_file(GVFILE * fp_plus, struct Plus_head *Plus)
+int dig_write_plus_file(struct gvfile * fp_plus, struct Plus_head *Plus)
     dig_set_cur_port(&(Plus->port));
@@ -375,7 +375,7 @@
-int dig_write_nodes(GVFILE * plus, struct Plus_head *Plus)
+int dig_write_nodes(struct gvfile * plus, struct Plus_head *Plus)
     int i;
@@ -399,7 +399,7 @@
-int dig_write_lines(GVFILE * plus, struct Plus_head *Plus)
+int dig_write_lines(struct gvfile * plus, struct Plus_head *Plus)
     int i;
@@ -424,7 +424,7 @@
-int dig_write_areas(GVFILE * plus, struct Plus_head *Plus)
+int dig_write_areas(struct gvfile * plus, struct Plus_head *Plus)
     int i;
@@ -449,7 +449,7 @@
-int dig_write_isles(GVFILE * plus, struct Plus_head *Plus)
+int dig_write_isles(struct gvfile * plus, struct Plus_head *Plus)
     int i;
Modified: grass/trunk/lib/vector/diglib/plus_area.c
--- grass/trunk/lib/vector/diglib/plus_area.c	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/lib/vector/diglib/plus_area.c	2009-07-31 11:46:59 UTC (rev 38552)
@@ -56,7 +56,7 @@
     char *p;
     static int array_size;	/* 0 on startup */
     int n_lines;
-    P_LINE *Line;
     int node;
     const char *dstr;
     int debug_level;
@@ -175,9 +175,9 @@
     register int i;
     register int area, line;
-    P_AREA *Area;
-    P_LINE *Line;
     G_debug(3, "dig_add_area():");
     /* First look if we have space in array of pointers to areas
@@ -254,7 +254,7 @@
 int dig_area_add_isle(struct Plus_head *plus, int area, int isle)
     int i;
-    P_AREA *Area;
     G_debug(3, "dig_area_add_isle(): area = %d isle = %d", area, isle);
@@ -291,7 +291,7 @@
 int dig_area_del_isle(struct Plus_head *plus, int area, int isle)
     int i, mv;
-    P_AREA *Area;
     G_debug(3, "dig_area_del_isle(): area = %d isle = %d", area, isle);
@@ -344,9 +344,9 @@
     int i, line;
     /* int    isle, area_out; */
-    P_AREA *Area;
-    P_LINE *Line;
-    P_ISLE *Isle;
     G_debug(3, "dig_del_area() area =  %d", area);
     Area = plus->Area[area];
@@ -440,9 +440,9 @@
  * \return 1
-int dig_area_set_box(struct Plus_head *plus, plus_t area, BOUND_BOX * Box)
+int dig_area_set_box(struct Plus_head *plus, plus_t area, struct bound_box * Box)
-    P_AREA *Area;
@@ -480,8 +480,8 @@
     int current;
     int line;
     plus_t node;
-    P_NODE *Node;
-    P_LINE *Line;
     const char *dstr;
     int debug_level;
@@ -582,7 +582,7 @@
     int next, prev;
     float angle1, angle2;
     plus_t node;
-    P_LINE *Line;
     G_debug(3, "dig_node_angle_check: line = %d, type = %d", line, type);
@@ -637,9 +637,9 @@
     register int i;
     register int isle, line;
-    P_ISLE *Isle;
-    P_LINE *Line;
     G_debug(3, "dig_add_isle():");
     /* First look if we have space in array of pointers to isles
@@ -719,9 +719,9 @@
  * \return 1
-int dig_isle_set_box(struct Plus_head *plus, plus_t isle, BOUND_BOX * Box)
+int dig_isle_set_box(struct Plus_head *plus, plus_t isle, struct bound_box * Box)
-    P_ISLE *Isle;
@@ -748,8 +748,8 @@
 int dig_del_isle(struct Plus_head *plus, int isle)
     int i, line;
-    P_LINE *Line;
-    P_ISLE *Isle;
     G_debug(3, "dig_del_isle() isle =  %d", isle);
Modified: grass/trunk/lib/vector/diglib/plus_line.c
--- grass/trunk/lib/vector/diglib/plus_line.c	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/lib/vector/diglib/plus_line.c	2009-07-31 11:46:59 UTC (rev 38552)
@@ -23,8 +23,8 @@
 		    off_t offset)
     int node, lp;
-    P_LINE *line;
-    BOUND_BOX box;
+    struct P_line *line;
     plus->Line[lineid] = dig_alloc_line();
     line = plus->Line[lineid];
@@ -185,8 +185,8 @@
 int dig_del_line(struct Plus_head *plus, int line)
     int i, mv;
-    P_LINE *Line;
-    P_NODE *Node;
     G_debug(3, "dig_del_line() line =  %d", line);
@@ -266,7 +266,7 @@
 plus_t dig_line_get_area(struct Plus_head * plus, plus_t line, int side)
-    P_LINE *Line;
     if (side == GV_LEFT) {
@@ -299,7 +299,7 @@
 int
 dig_line_set_area(struct Plus_head *plus, plus_t line, int side, plus_t area)
-    P_LINE *Line;
@@ -321,9 +321,9 @@
  * \return 1
-int dig_line_set_box(struct Plus_head *plus, plus_t line, BOUND_BOX * Box)
+int dig_line_set_box(struct Plus_head *plus, plus_t line, struct bound_box * Box)
-    P_LINE *Line;
@@ -346,9 +346,9 @@
  * \return 1
-int dig_line_get_box(struct Plus_head *plus, plus_t line, BOUND_BOX * Box)
+int dig_line_get_box(struct Plus_head *plus, plus_t line, struct bound_box * Box)
-    P_LINE *Line;
Modified: grass/trunk/lib/vector/diglib/plus_node.c
--- grass/trunk/lib/vector/diglib/plus_node.c	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/lib/vector/diglib/plus_node.c	2009-07-31 11:46:59 UTC (rev 38552)
@@ -46,7 +46,7 @@
     register int i, j, nlines;
     float angle;
     int ret;
-    P_NODE *node;
+    struct P_node *node;
     G_debug(3, "dig_node_add_line(): node = %d line = %d", nodeid, lineid);
@@ -107,7 +107,7 @@
 int dig_add_node(struct Plus_head *plus, double x, double y, double z)
     int nnum;
-    P_NODE *node;
     /* First look if we have space in array of pointers to nodes
      *  and reallocate if necessary */
@@ -155,7 +155,7 @@
     register int have_match;
     int winner;
     double least_dist, dist;
-    P_NODE *node;
     first_time = 1;
     have_match = 0;
@@ -203,7 +203,7 @@
 float dig_node_line_angle(struct Plus_head *plus, int nodeid, int lineid)
     int i, nlines;
-    P_NODE *node;
     G_debug(3, "dig_node_line_angle: node = %d line = %d", nodeid, lineid);
Modified: grass/trunk/lib/vector/diglib/plus_struct.c
--- grass/trunk/lib/vector/diglib/plus_struct.c	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/lib/vector/diglib/plus_struct.c	2009-07-31 11:46:59 UTC (rev 38552)
@@ -48,10 +48,10 @@
  *    plus_t is changed to a type that is larger than an int.
-int dig_Rd_P_node(struct Plus_head *Plus, int n, GVFILE * fp)
+int dig_Rd_P_node(struct Plus_head *Plus, int n, struct gvfile * fp)
     int cnt, n_edges;
-    P_NODE *ptr;
+    struct P_node *ptr;
     G_debug(3, "dig_Rd_P_node()");
@@ -102,10 +102,10 @@
     return (0);
-int dig_Wr_P_node(struct Plus_head *Plus, int n, GVFILE * fp)
+int dig_Wr_P_node(struct Plus_head *Plus, int n, struct gvfile * fp)
     int i, n_edges = 0;
-    P_NODE *ptr;
     G_debug(3, "dig_Wr_P_node()");
     ptr = Plus->Node[n];
@@ -147,12 +147,12 @@
     return (0);
-int dig_Rd_P_line(struct Plus_head *Plus, int n, GVFILE * fp)
+int dig_Rd_P_line(struct Plus_head *Plus, int n, struct gvfile * fp)
     int n_edges, vol;
     char tp;
-    P_LINE *ptr;
-    P_NODE *Node;
+    struct P_line *ptr;
     G_debug(3, "dig_Rd_P_line()");
@@ -251,11 +251,11 @@
     return (0);
-int dig_Wr_P_line(struct Plus_head *Plus, int n, GVFILE * fp)
+int dig_Wr_P_line(struct Plus_head *Plus, int n, struct gvfile * fp)
     int n_edges = 0, vol = 0;
     char ch;
-    P_LINE *ptr;
     G_debug(4, "dig_Wr_P_line() line = %d", n);
@@ -339,10 +339,10 @@
     return (0);
-int dig_Rd_P_area(struct Plus_head *Plus, int n, GVFILE * fp)
+int dig_Rd_P_area(struct Plus_head *Plus, int n, struct gvfile * fp)
     int cnt;
-    P_AREA *ptr;
+    struct P_area *ptr;
 #ifdef GDEBUG
     G_debug(3, "dig_Rd_P_area(): n = %d", n);
@@ -408,10 +408,10 @@
     return (0);
-int dig_Wr_P_area(struct Plus_head *Plus, int n, GVFILE * fp)
+int dig_Wr_P_area(struct Plus_head *Plus, int n, struct gvfile * fp)
     int i;
-    P_AREA *ptr;
     ptr = Plus->Area[n];
@@ -462,10 +462,10 @@
     return (0);
-int dig_Rd_P_isle(struct Plus_head *Plus, int n, GVFILE * fp)
+int dig_Rd_P_isle(struct Plus_head *Plus, int n, struct gvfile * fp)
     int cnt;
-    P_ISLE *ptr;
+    struct P_isle *ptr;
 #ifdef GDEBUG
     G_debug(3, "dig_Rd_P_isle()");
@@ -520,10 +520,10 @@
     return (0);
-int dig_Wr_P_isle(struct Plus_head *Plus, int n, GVFILE * fp)
+int dig_Wr_P_isle(struct Plus_head *Plus, int n, struct gvfile * fp)
     int i;
-    P_ISLE *ptr;
     ptr = Plus->Isle[n];
@@ -566,11 +566,16 @@
     return (0);
-   \return -1 error
-   \return  0 OK
-int dig_Rd_Plus_head(GVFILE * fp, struct Plus_head *ptr)
+  \brief Read Plus_head from file
+  \param[in,out] ptr pointer to Plus_head structure
+  \return -1 error
+  \return  0 OK
+int dig_Rd_Plus_head(struct gvfile * fp, struct Plus_head *ptr)
     int byte_order;
@@ -614,6 +619,7 @@
 	     ptr->Version_Major, ptr->Version_Minor);
+    /* init Port_info structure and set as default */
     dig_init_portable(&(ptr->port), byte_order);
     dig_set_cur_port(&(ptr->port));
@@ -714,7 +720,7 @@
     return (0);
-int dig_Wr_Plus_head(GVFILE * fp, struct Plus_head *ptr)
+int dig_Wr_Plus_head(struct gvfile * fp, struct Plus_head *ptr)
     unsigned char buf[10];
     long length = 142;
Modified: grass/trunk/lib/vector/diglib/port_init.c
--- grass/trunk/lib/vector/diglib/port_init.c	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/lib/vector/diglib/port_init.c	2009-07-31 11:46:59 UTC (rev 38552)
@@ -178,7 +178,7 @@
-  \brief Initialize structures
+  \brief Initialize Port_info structures
 void port_init(void)
Modified: grass/trunk/lib/vector/diglib/portable.c
--- grass/trunk/lib/vector/diglib/portable.c	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/lib/vector/diglib/portable.c	2009-07-31 11:46:59 UTC (rev 38552)
@@ -73,12 +73,12 @@
    \param[out] buf data buffer
    \param cnt number of members
-   \param fp pointer to GVFILE
+   \param fp pointer to struct gvfile
    \return 0 error
    \return 1 OK
-int dig__fread_port_D(double *buf, size_t cnt, GVFILE * fp)
+int dig__fread_port_D(double *buf, size_t cnt, struct gvfile * fp)
     unsigned int i, j;
     int ret;
@@ -117,12 +117,12 @@
    \return 0 error
    \return 1 OK
-int dig__fread_port_F(float *buf, size_t cnt, GVFILE * fp)
+int dig__fread_port_F(float *buf, size_t cnt, struct gvfile * fp)
     unsigned int i, j;
     int ret;
@@ -161,12 +161,12 @@
    \param port_off_t_size offset
    \return 0 error
    \return 1 OK
-int dig__fread_port_O(off_t *buf, size_t cnt, GVFILE * fp, size_t port_off_t_size)
+int dig__fread_port_O(off_t *buf, size_t cnt, struct gvfile * fp, size_t port_off_t_size)
     unsigned int i, j;
     int ret;
@@ -256,12 +256,12 @@
    \return 0 error
    \return 1 OK
-int dig__fread_port_L(long *buf, size_t cnt, GVFILE * fp)
+int dig__fread_port_L(long *buf, size_t cnt, struct gvfile * fp)
     unsigned int i, j;
     int ret;
@@ -341,12 +341,12 @@
    \return 0 error
    \return 1 OK
-int dig__fread_port_I(int *buf, size_t cnt, GVFILE * fp)
+int dig__fread_port_I(int *buf, size_t cnt, struct gvfile * fp)
     unsigned int i, j;
     int ret;
@@ -426,12 +426,12 @@
    \return 0 error
    \return 1 OK
-int dig__fread_port_S(short *buf, size_t cnt, GVFILE * fp)
+int dig__fread_port_S(short *buf, size_t cnt, struct gvfile * fp)
     unsigned int i, j;
     int ret;
@@ -511,12 +511,12 @@
    \return 0 error
    \return 1 OK
-int dig__fread_port_C(char *buf, size_t cnt, GVFILE * fp)
+int dig__fread_port_C(char *buf, size_t cnt, struct gvfile * fp)
     int ret;
@@ -537,12 +537,12 @@
    \return 0 error
    \return 1 OK
-int dig__fread_port_P(plus_t * buf, size_t cnt, GVFILE * fp)
+int dig__fread_port_P(plus_t * buf, size_t cnt, struct gvfile * fp)
     int *ibuf;
@@ -559,13 +559,13 @@
    \param buf data buffer
-   \param[in,out] fp pointer to GVFILE
+   \param[in,out] fp pointer to struct gvfile
    \return 0 error
    \return 1 OK
 int dig__fwrite_port_D(const double *buf,
-		       size_t cnt, GVFILE * fp)
+		       size_t cnt, struct gvfile * fp)
     unsigned int i, j;
     unsigned char *c1, *c2;
@@ -598,13 +598,13 @@
    \return 0 error
    \return 1 OK
 int dig__fwrite_port_F(const float *buf,
     unsigned int i, j;
@@ -637,13 +637,13 @@
    \return 0 error
    \return 1 OK
 int dig__fwrite_port_O(const off_t *buf,
-		       size_t cnt, GVFILE * fp, size_t port_off_t_size)
+		       size_t cnt, struct gvfile * fp, size_t port_off_t_size)
     unsigned int i, j;
@@ -703,13 +703,13 @@
    \return 0 error
    \return 1 OK
 int dig__fwrite_port_L(const long *buf,
     unsigned int i, j;
@@ -759,13 +759,13 @@
    \return 0 error
    \return 1 OK
 int dig__fwrite_port_I(const int *buf,
     unsigned int i, j;
@@ -815,13 +815,13 @@
    \return 0 error
    \return 1 OK
 int dig__fwrite_port_S(const short *buf,
     unsigned int i, j;
@@ -872,13 +872,13 @@
    \return 0 error
    \return 1 OK
 int dig__fwrite_port_P(const plus_t * buf,
     return (dig__fwrite_port_I((int *)buf, cnt, fp));
@@ -891,13 +891,13 @@
    \return 0 error
    \return 1 OK
 int dig__fwrite_port_C(const char *buf,
     if (dig_fwrite(buf, PORT_CHAR, cnt, fp) == cnt)
 	return 1;
@@ -906,9 +906,9 @@
-  \brief Set portable info structure to byte order of file
+  \brief Set Port_info structure to byte order of file
-  \param port pointer to Port_info
+  \param port pointer to Port_info structure
   \param byte_order ENDIAN_BIG or ENDIAN_LITTLE
 void dig_init_portable(struct Port_info *port, int byte_order)
@@ -1001,9 +1001,9 @@
-  \brief set current portable info
+  \brief Set current Port_info structure
   \return 0
Modified: grass/trunk/lib/vector/diglib/spindex.c
--- grass/trunk/lib/vector/diglib/spindex.c	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/lib/vector/diglib/spindex.c	2009-07-31 11:46:59 UTC (rev 38552)
@@ -182,7 +182,7 @@
    \return 0
-int dig_spidx_add_line(struct Plus_head *Plus, int line, BOUND_BOX * box)
+int dig_spidx_add_line(struct Plus_head *Plus, int line, struct bound_box * box)
     struct Rect rect;
@@ -208,7 +208,7 @@
    \return 0
-int dig_spidx_add_area(struct Plus_head *Plus, int area, BOUND_BOX * box)
+int dig_spidx_add_area(struct Plus_head *Plus, int area, struct bound_box * box)
     struct Rect rect;
@@ -235,7 +235,7 @@
    \return 0
-int dig_spidx_add_isle(struct Plus_head *Plus, int isle, BOUND_BOX * box)
+int dig_spidx_add_isle(struct Plus_head *Plus, int isle, struct bound_box * box)
     struct Rect rect;
@@ -265,7 +265,7 @@
 int dig_spidx_del_node(struct Plus_head *Plus, int node)
     int ret;
-    P_NODE *Node;
     struct Rect rect;
     G_debug(3, "dig_spidx_del_node(): node = %d", node);
@@ -299,7 +299,7 @@
 int dig_spidx_del_line(struct Plus_head *Plus, int line)
-    P_LINE *Line;
     struct Rect rect;
     int ret;
@@ -340,7 +340,7 @@
 int dig_spidx_del_area(struct Plus_head *Plus, int area)
     int ret;
-    P_AREA *Area;
+    struct P_area *Area;
     struct Rect rect;
     G_debug(3, "dig_spidx_del_area(): area = %d", area);
@@ -379,7 +379,7 @@
 int dig_spidx_del_isle(struct Plus_head *Plus, int isle)
     int ret;
-    P_ISLE *Isle;
+    struct P_isle *Isle;
     struct Rect rect;
     G_debug(3, "dig_spidx_del_isle(): isle = %d", isle);
@@ -419,7 +419,7 @@
    \return -1 on error
 int
-dig_select_nodes(struct Plus_head *Plus, const BOUND_BOX * box,
+dig_select_nodes(struct Plus_head *Plus, const struct bound_box * box,
 		 struct ilist *list)
     struct Rect rect;
@@ -495,7 +495,7 @@
    \return number of selected lines
 int
-dig_select_lines(struct Plus_head *Plus, const BOUND_BOX * box,
+dig_select_lines(struct Plus_head *Plus, const struct bound_box * box,
 		 struct ilist *list)
     struct Rect rect;
@@ -529,7 +529,7 @@
    \return number of selected areas
 int
-dig_select_areas(struct Plus_head *Plus, const BOUND_BOX * box,
+dig_select_areas(struct Plus_head *Plus, const struct bound_box * box,
 		 struct ilist *list)
     struct Rect rect;
@@ -563,7 +563,7 @@
    \return number of selected isles
 int
-dig_select_isles(struct Plus_head *Plus, const BOUND_BOX * box,
+dig_select_isles(struct Plus_head *Plus, const struct bound_box * box,
 		 struct ilist *list)
     struct Rect rect;
Modified: grass/trunk/lib/vector/diglib/spindex_rw.c
--- grass/trunk/lib/vector/diglib/spindex_rw.c	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/lib/vector/diglib/spindex_rw.c	2009-07-31 11:46:59 UTC (rev 38552)
@@ -42,13 +42,13 @@
    \brief Write spatial index to the file
    \param ptr pointer to Plus_head structure
    \return -1 on error
-int dig_Wr_spidx_head(GVFILE * fp, struct Plus_head *ptr)
+int dig_Wr_spidx_head(struct gvfile * fp, struct Plus_head *ptr)
     unsigned char buf[6];
     long length = 81;		/* header length in bytes */
@@ -252,13 +252,13 @@
    \brief Read spatial index to the file
    \return -1 on error
-int dig_Rd_spidx_head(GVFILE * fp, struct Plus_head *ptr)
+int dig_Rd_spidx_head(struct gvfile * fp, struct Plus_head *ptr)
     int byte_order;
@@ -574,16 +574,16 @@
    \brief Write RTree body from memory to sidx file
    Must be called when new or updated vector is closed
-   \param[out] fp pointer to GVFILE
-   \param startpos offset to GVFILE where to start writing out
+   \param[out] fp pointer to struct gvfile
+   \param startpos offset to struct gvfile where to start writing out
    \param t pointer to RTree
-   \param off_t_size size of off_t used to write GVFILE
+   \param off_t_size size of off_t used to write struct gvfile
    \return -1 on error
    \return offset to root node on success
-static off_t rtree_write_to_sidx(GVFILE * fp, off_t startpos,
+static off_t rtree_write_to_sidx(struct gvfile * fp, off_t startpos,
 				 struct RTree *t, int off_t_size)
     off_t nextfreepos = startpos;
@@ -666,16 +666,16 @@
    \brief Load RTree body from sidx file to memory
    Must be called when old vector is opened in update mode
    \param rootpos position of root node in file
-   \param off_t_size size of off_t used to read GVFILE
+   \param off_t_size size of off_t used to read struct gvfile
    \return -1 on error
    \return pointer to root node on success
-struct Node *rtree_load_from_sidx(GVFILE * fp, off_t rootpos,
+struct Node *rtree_load_from_sidx(struct gvfile * fp, off_t rootpos,
     struct Node *newnode = NULL;
@@ -773,12 +773,12 @@
    \return 0
-int dig_Wr_spidx(GVFILE * fp, struct Plus_head *Plus)
+int dig_Wr_spidx(struct gvfile * fp, struct Plus_head *Plus)
     G_debug(1, "dig_Wr_spidx()");
@@ -823,12 +823,12 @@
    \brief Read spatial index from spidx file
    Only needed when old vector is opened in update mode
    \return 0
-int dig_Rd_spidx(GVFILE * fp, struct Plus_head *Plus)
+int dig_Rd_spidx(struct gvfile * fp, struct Plus_head *Plus)
     G_debug(1, "dig_read_spindx()");
Modified: grass/trunk/lib/vector/diglib/struct_alloc.c
--- grass/trunk/lib/vector/diglib/struct_alloc.c	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/lib/vector/diglib/struct_alloc.c	2009-07-31 11:46:59 UTC (rev 38552)
@@ -37,11 +37,11 @@
 /* allocate new node structure */
-P_NODE *dig_alloc_node()
+struct P_node *dig_alloc_node()
-    P_NODE *Node;
+    struct P_node *Node;
-    Node = (P_NODE *) G_malloc(sizeof(P_NODE));
+    Node = (struct P_node *) G_malloc(sizeof(struct P_node));
     if (Node == NULL)
         return NULL;
@@ -54,7 +54,7 @@
 /* free node structure */
-void dig_free_node(P_NODE *Node)
+void dig_free_node(struct P_node *Node)
     if (Node->alloc_lines > 0) {
         G_free(Node->lines);
@@ -71,7 +71,7 @@
  **  Returns   0 ok    or    -1 on error
-int dig_node_alloc_line(P_NODE * node, int add)
+int dig_node_alloc_line(struct P_node * node, int add)
     int num;
     char *p;
@@ -107,22 +107,22 @@
     char *p;
     size = Plus->alloc_nodes + 1 + add;
-    p = G_realloc(Plus->Node, size * sizeof(P_NODE *));
+    p = G_realloc(Plus->Node, size * sizeof(struct P_node *));
     if (p == NULL)
         return -1;
-    Plus->Node = (P_NODE **) p;
+    Plus->Node = (struct P_node **) p;
     Plus->alloc_nodes = size - 1;
     return (0);
 /* allocate new line structure */
-P_LINE *dig_alloc_line()
+struct P_line *dig_alloc_line()
-    P_LINE *Line;
+    struct P_line *Line;
-    Line = (P_LINE *) G_malloc(sizeof(P_LINE));
+    Line = (struct P_line *) G_malloc(sizeof(struct P_line));
     if (Line == NULL)
         return NULL;
@@ -130,7 +130,7 @@
 /* free line structure */
-void dig_free_line(P_LINE *Line)
+void dig_free_line(struct P_line *Line)
     G_free(Line);
@@ -147,11 +147,11 @@
     char *p;
     size = Plus->alloc_lines + 1 + add;
-    p = G_realloc(Plus->Line, size * sizeof(P_LINE *));
+    p = G_realloc(Plus->Line, size * sizeof(struct P_line *));
     if (p == NULL)
         return -1;
-    Plus->Line = (P_LINE **) p;
+    Plus->Line = (struct P_line **) p;
     Plus->alloc_lines = size - 1;
     return (0);
@@ -169,11 +169,11 @@
     char *p;
     size = Plus->alloc_areas + 1 + add;
-    p = G_realloc(Plus->Area, size * sizeof(P_AREA *));
+    p = G_realloc(Plus->Area, size * sizeof(struct P_area *));
     if (p == NULL)
         return -1;
-    Plus->Area = (P_AREA **) p;
+    Plus->Area = (struct P_area **) p;
     Plus->alloc_areas = size - 1;
     return (0);
@@ -192,22 +192,22 @@
     G_debug(3, "dig_alloc_isle():");
     size = Plus->alloc_isles + 1 + add;
-    p = G_realloc(Plus->Isle, size * sizeof(P_ISLE *));
+    p = G_realloc(Plus->Isle, size * sizeof(struct P_isle *));
     if (p == NULL)
         return -1;
-    Plus->Isle = (P_ISLE **) p;
+    Plus->Isle = (struct P_isle **) p;
     Plus->alloc_isles = size - 1;
     return (0);
 /* allocate new area structure */
-P_AREA *dig_alloc_area()
+struct P_area *dig_alloc_area()
-    P_AREA *Area;
-    Area = (P_AREA *) G_malloc(sizeof(P_AREA));
+    Area = (struct P_area *) G_malloc(sizeof(struct P_area));
     if (Area == NULL)
         return NULL;
@@ -225,7 +225,7 @@
 /* free area structure */
-void dig_free_area(P_AREA *Area)
+void dig_free_area(struct P_area *Area)
     if (Area->alloc_lines > 0)
         free(Area->lines);
@@ -237,11 +237,11 @@
 /* alloc new isle structure */
-P_ISLE *dig_alloc_isle()
+struct P_isle *dig_alloc_isle()
-    P_ISLE *Isle;
-    Isle = (P_ISLE *) G_malloc(sizeof(P_ISLE));
+    Isle = (struct P_isle *) G_malloc(sizeof(struct P_isle));
     if (Isle == NULL)
         return NULL;
@@ -255,7 +255,7 @@
 /* free isle structure */
-void dig_free_isle(P_ISLE *Isle)
+void dig_free_isle(struct P_isle *Isle)
     if (Isle->alloc_lines > 0)
         G_free(Isle->lines);
@@ -337,7 +337,7 @@
-int dig_area_alloc_line(P_AREA * area, int add)
+int dig_area_alloc_line(struct P_area * area, int add)
     int num;
     char *p;
@@ -359,7 +359,7 @@
-int dig_area_alloc_isle(P_AREA * area, int add)
+int dig_area_alloc_isle(struct P_area * area, int add)
     int num;
     char *p;
@@ -382,7 +382,7 @@
-int dig_isle_alloc_line(P_ISLE * isle, int add)
+int dig_isle_alloc_line(struct P_isle * isle, int add)
     int num;
     char *p;
Modified: grass/trunk/lib/vector/diglib/test.c
--- grass/trunk/lib/vector/diglib/test.c	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/lib/vector/diglib/test.c	2009-07-31 11:46:59 UTC (rev 38552)
@@ -34,7 +34,7 @@
     int err;
     int byte_order;
-    GVFILE fp;
+    struct gvfile fp;
     int port_off_t;
     double db, td[] = { -(PORT_DOUBLE_MAX), -(D_TEST), -(PORT_DOUBLE_MIN),
Modified: grass/trunk/ps/ps.map/ps_vareas.c
--- grass/trunk/ps/ps.map/ps_vareas.c	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/ps/ps.map/ps_vareas.c	2009-07-31 11:46:59 UTC (rev 38552)
@@ -133,8 +133,8 @@
     double llx, lly, urx, ury, sc;
     char pat[50];
     struct line_cats *Cats;
-    BOUND_BOX box;
-    VARRAY *Varray = NULL;
+    struct varray *Varray = NULL;
     PSCOLOR color;
     int centroid;
Modified: grass/trunk/ps/ps.map/ps_vlines.c
--- grass/trunk/ps/ps.map/ps_vlines.c	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/ps/ps.map/ps_vlines.c	2009-07-31 11:46:59 UTC (rev 38552)
@@ -23,7 +23,7 @@
     int i, k, np, line, cat, nlines, ret;
     double *xarray, *yarray, tol = 0.1, width;
     /* rgbcol */
     dbCatValArray cvarr_rgb;
Modified: grass/trunk/ps/ps.map/ps_vpoints.c
--- grass/trunk/ps/ps.map/ps_vpoints.c	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/ps/ps.map/ps_vpoints.c	2009-07-31 11:46:59 UTC (rev 38552)
@@ -29,7 +29,7 @@
     double llx, lly, urx, ury;
     int x_int, y_int, eps_exist;
     SYMBOL *Symb;
     /* Attributes if sizecol is used */
     dbCatValArray cvarr_size;
Modified: grass/trunk/raster/r.region/main.c
--- grass/trunk/raster/r.region/main.c	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/raster/r.region/main.c	2009-07-31 11:46:59 UTC (rev 38552)
@@ -203,7 +203,7 @@
     if ((name = parm.vect->answer)) {	/* vect= */
 	struct Map_info Map;
-	BOUND_BOX box;
 	if (Vect_open_old(&Map, name, "") != 1)
Modified: grass/trunk/vector/lidar/lidarlib/PolimiFunct.h
--- grass/trunk/vector/lidar/lidarlib/PolimiFunct.h	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/vector/lidar/lidarlib/PolimiFunct.h	2009-07-31 11:46:59 UTC (rev 38552)
@@ -98,8 +98,8 @@
 void P_zero_dim(struct Reg_dimens * /**/);
 int P_set_regions(struct Cell_head *, /**/
-		  BOUND_BOX *, /**/
-		  BOUND_BOX *, /**/ struct Reg_dimens, /**/ int /**/);
+		  struct bound_box *, /**/
+		  struct bound_box *, /**/ struct Reg_dimens, /**/ int /**/);
 int P_get_orlo(int, /**/ struct Reg_dimens *, /**/ double, /**/ double /**/);
@@ -115,8 +115,8 @@
 void
 P_Sparse_Points(struct Map_info *, /**/
-		BOUND_BOX, /**/
-		BOUND_BOX, /**/
+		struct bound_box, /**/
 		double **, /**/
 		double *, /**/
 		int *, /**/
@@ -131,8 +131,8 @@
 		dbDriver *, /**/ double, /**/ char * /**/);
 double **P_Regular_Points(struct Cell_head *, /**/
-			  BOUND_BOX, /**/
-			  BOUND_BOX, /**/
 			  double **, /**/
 			  double *, /**/
 			  double, /**/
Modified: grass/trunk/vector/lidar/lidarlib/raster.c
--- grass/trunk/vector/lidar/lidarlib/raster.c	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/vector/lidar/lidarlib/raster.c	2009-07-31 11:46:59 UTC (rev 38552)
@@ -13,7 +13,7 @@
 void
 P_Sparse_Points(struct Map_info *Out, struct Cell_head *Elaboration,
-		BOUND_BOX General, BOUND_BOX Overlap, double **obs,
+		struct bound_box General, struct bound_box Overlap, double **obs,
 		double *param, int *line_num, double pe, double pn,
 		double overlap, int nsplx, int nsply, int num_points,
 		int bilin, struct line_cats *categories, dbDriver * driver,
@@ -200,8 +200,8 @@
-double **P_Regular_Points(struct Cell_head *Elaboration, BOUND_BOX General,
-			  BOUND_BOX Overlap, double **matrix, double *param,
+double **P_Regular_Points(struct Cell_head *Elaboration, struct bound_box General,
+			  struct bound_box Overlap, double **matrix, double *param,
 			  double passoN, double passoE, double overlap,
 			  double mean, int nsplx, int nsply, int nrows,
 			  int ncols, int bilin)
Modified: grass/trunk/vector/lidar/lidarlib/zones.c
--- grass/trunk/vector/lidar/lidarlib/zones.c	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/vector/lidar/lidarlib/zones.c	2009-07-31 11:46:59 UTC (rev 38552)
@@ -24,8 +24,8 @@
 int
-P_set_regions(struct Cell_head *Elaboration, BOUND_BOX * General,
-	      BOUND_BOX * Overlap, struct Reg_dimens dim, int type)
+P_set_regions(struct Cell_head *Elaboration, struct bound_box * General,
+	      struct bound_box * Overlap, struct Reg_dimens dim, int type)
     /* Set the Elaborationoration region limits-> Also set the limits of the orlo and overlapping regions->
      * Returns 0 on success; -1 on failure*/
@@ -126,7 +126,7 @@
     int i, mean_count = 0;
     double mean = 0.0;
-    BOUND_BOX mean_box;
+    struct bound_box mean_box;
     Vect_region_box(Elaboration, &mean_box);
     mean_box.W -= CONTOUR;
@@ -158,7 +158,7 @@
     struct Point *obs;
     struct line_pnts *points;
     struct line_cats *categories;
-    BOUND_BOX elaboration_box;
+    struct bound_box elaboration_box;
     pippo = dim_vect;
     obs = (struct Point *)G_calloc(pippo, sizeof(struct Point));
Modified: grass/trunk/vector/lidar/v.lidar.correction/correction.c
--- grass/trunk/vector/lidar/v.lidar.correction/correction.c	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/vector/lidar/v.lidar.correction/correction.c	2009-07-31 11:46:59 UTC (rev 38552)
@@ -30,7 +30,7 @@
 void
 P_Sparse_Correction(struct Map_info *In, struct Map_info *Out,
 		    struct Map_info *Terrain, struct Cell_head *Elaboration,
 		    double *param, int *line_num, double passoN,
 		    double passoE, double overlap, double HighThresh,
 		    double LowThresh, int nsplx, int nsply, int num_points,
@@ -302,7 +302,7 @@
     struct Point *obs;
     pippo = dim_vect;
Modified: grass/trunk/vector/lidar/v.lidar.correction/correction.h
--- grass/trunk/vector/lidar/v.lidar.correction/correction.h	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/vector/lidar/v.lidar.correction/correction.h	2009-07-31 11:46:59 UTC (rev 38552)
@@ -12,8 +12,8 @@
-		    BOUND_BOX, /**/
-		    BOUND_BOX, /**/
 		    double **, /**/
 		    double *, /**/
 		    int *, /**/
Modified: grass/trunk/vector/lidar/v.lidar.correction/main.c
--- grass/trunk/vector/lidar/v.lidar.correction/main.c	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/vector/lidar/v.lidar.correction/main.c	2009-07-31 11:46:59 UTC (rev 38552)
@@ -54,7 +54,7 @@
     struct Cell_head elaboration_reg, original_reg;
     struct Reg_dimens dims;
-    BOUND_BOX general_box, overlap_box;
+    struct bound_box general_box, overlap_box;
     struct Point *observ;
Modified: grass/trunk/vector/lidar/v.lidar.edgedetection/edgedetection.c
--- grass/trunk/vector/lidar/v.lidar.edgedetection/edgedetection.c	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/vector/lidar/v.lidar.edgedetection/edgedetection.c	2009-07-31 11:46:59 UTC (rev 38552)
@@ -33,7 +33,7 @@
 #include <grass/dbmi.h>
     /* #include <grass/PolimiFunct.h> */
 #include "edgedetection.h"
-int edge_detection(struct Cell_head elaboration_reg, BOUND_BOX Overlap_Box,
+int edge_detection(struct Cell_head elaboration_reg, struct bound_box Overlap_Box,
 		   double *parBilin, double obsX, double obsY,
 		   double *partial, double alpha, double residual,
 		   double gradHigh, double gradLow)
@@ -171,7 +171,7 @@
 void classification(struct Map_info *Out, struct Cell_head Elaboration,
 		    double *parBilin, double *parBicub, double mean,
 		    double alpha, double gradHigh, double gradLow,
 		    double overlap, int *line_num, int num_points,
Modified: grass/trunk/vector/lidar/v.lidar.edgedetection/edgedetection.h
--- grass/trunk/vector/lidar/v.lidar.edgedetection/edgedetection.h	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/vector/lidar/v.lidar.edgedetection/edgedetection.h	2009-07-31 11:46:59 UTC (rev 38552)
@@ -31,7 +31,7 @@
 int edge_detection(struct Cell_head, /**/
-		   BOUND_BOX, /**/
 		   double *, /**/
 		   double, /**/
 		   double, /**/
@@ -43,8 +43,8 @@
 void classification(struct Map_info *, /**/
-		    BOUND_BOX, /**/
-		    BOUND_BOX, /**/
 		    double **, /**/
 		    double *, /**/
 		    double *, /**/
Modified: grass/trunk/vector/lidar/v.lidar.edgedetection/main.c
--- grass/trunk/vector/lidar/v.lidar.edgedetection/main.c	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/vector/lidar/v.lidar.edgedetection/main.c	2009-07-31 11:46:59 UTC (rev 38552)
@@ -62,7 +62,7 @@
Modified: grass/trunk/vector/lidar/v.lidar.growing/main.c
--- grass/trunk/vector/lidar/v.lidar.growing/main.c	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/vector/lidar/v.lidar.growing/main.c	2009-07-31 11:46:59 UTC (rev 38552)
@@ -206,7 +206,7 @@
 	last_column = FALSE;
 	while (last_column == FALSE) {	/* For each strip of LATO columns */
 	    elaboration_reg.west = elaboration_reg.east;
 	    if (elaboration_reg.west < original_reg.west)	/* First column */
Modified: grass/trunk/vector/lidar/v.outlier/main.c
--- grass/trunk/vector/lidar/v.outlier/main.c	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/vector/lidar/v.outlier/main.c	2009-07-31 11:46:59 UTC (rev 38552)
@@ -56,7 +56,7 @@
Modified: grass/trunk/vector/lidar/v.outlier/outlier.c
--- grass/trunk/vector/lidar/v.outlier/outlier.c	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/vector/lidar/v.outlier/outlier.c	2009-07-31 11:46:59 UTC (rev 38552)
@@ -10,7 +10,7 @@
 void P_Outlier(struct Map_info *Out, struct Map_info *Outlier,
 	       struct Map_info *Qgis, struct Cell_head Elaboration,
 	       double *parBilin, double mean, double overlap, int *line_num,
 	       int num_points, dbDriver * driver)
Modified: grass/trunk/vector/lidar/v.outlier/outlier.h
--- grass/trunk/vector/lidar/v.outlier/outlier.h	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/vector/lidar/v.outlier/outlier.h	2009-07-31 11:46:59 UTC (rev 38552)
@@ -12,8 +12,8 @@
-	  BOUND_BOX, /**/
-	  BOUND_BOX, /**/
 	  double **, /**/
 	  double *, /**/
 	  double, /**/ double, /**/ int *, /**/ int, /**/ dbDriver * /**/);
Modified: grass/trunk/vector/lidar/v.surf.bspline/main.c
--- grass/trunk/vector/lidar/v.surf.bspline/main.c	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/vector/lidar/v.surf.bspline/main.c	2009-07-31 11:46:59 UTC (rev 38552)
@@ -65,7 +65,7 @@
Modified: grass/trunk/vector/v.clean/prune.c
--- grass/trunk/vector/v.clean/prune.c	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/vector/v.clean/prune.c	2009-07-31 11:46:59 UTC (rev 38552)
@@ -41,7 +41,7 @@
     int norig;
     struct line_pnts *Points, *TPoints, *BPoints, *Points_orig;
-    BOUND_BOX box;
     struct ilist *List;
     Points = Vect_new_line_struct();
Modified: grass/trunk/vector/v.convert/read.c
--- grass/trunk/vector/v.convert/read.c	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/vector/v.convert/read.c	2009-07-31 11:46:59 UTC (rev 38552)
@@ -7,7 +7,7 @@
 #include "conv.h"
 #include "local_proto.h"
-int read_line(GVFILE *, struct line_pnts *);
+int read_line(struct gvfile *, struct line_pnts *);
 /* read old 3.0 or 4.0 dig file into array
    returns number of elements read into array
@@ -26,7 +26,7 @@
     double dbuf;
     int ibuf;
     long lbuf;
-    GVFILE gvf;
+    struct gvfile gvf;
     dig_file_init(&gvf);
     gvf.file = Digin;
@@ -204,7 +204,7 @@
 /* read_line() reads element from file
    returns element type
-int read_line(GVFILE * Gvf, struct line_pnts *nline)
+int read_line(struct gvfile * Gvf, struct line_pnts *nline)
     int n_points;
     long itype;
Modified: grass/trunk/vector/v.db.select/main.c
--- grass/trunk/vector/v.db.select/main.c	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/vector/v.db.select/main.c	2009-07-31 11:46:59 UTC (rev 38552)
@@ -44,7 +44,7 @@
     char query[1024];
     struct ilist *list_lines;
-    BOUND_BOX *min_box, *line_box;
+    struct bound_box *min_box, *line_box;
     int i, line, area, init_box, cat;
     module = G_define_module();
@@ -101,10 +101,10 @@
     field = atoi(field_opt->answer);
     if (r_flag->answer) {
-	min_box = (BOUND_BOX *) G_malloc(sizeof(BOUND_BOX));
-	G_zero((void *)min_box, sizeof(BOUND_BOX));
+	min_box = (struct bound_box *) G_malloc(sizeof(struct bound_box));
+	G_zero((void *)min_box, sizeof(struct bound_box));
-	line_box = (BOUND_BOX *) G_malloc(sizeof(BOUND_BOX));
+	line_box = (struct bound_box *) G_malloc(sizeof(struct bound_box));
 	list_lines = Vect_new_list();
     else {
Modified: grass/trunk/vector/v.delaunay/defs.h
--- grass/trunk/vector/v.delaunay/defs.h	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/vector/v.delaunay/defs.h	2009-07-31 11:46:59 UTC (rev 38552)
@@ -4,8 +4,8 @@
 #ifdef MAIN
 struct Cell_head Window;
-BOUND_BOX Box;
+struct bound_box Box;
 #else
 extern struct Cell_head Window;
-extern BOUND_BOX Box;
+extern struct bound_box Box;
 #endif
Modified: grass/trunk/vector/v.delaunay/in_out.c
--- grass/trunk/vector/v.delaunay/in_out.c	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/vector/v.delaunay/in_out.c	2009-07-31 11:46:59 UTC (rev 38552)
@@ -161,7 +161,7 @@
 /* returns number of sites read */
 int read_sites(int mode3d, int complete_map, struct Map_info map_in,
-	       BOUND_BOX Box)
+	       struct bound_box Box)
     int nlines, line, allocated, nsites;
     struct line_pnts *Points;
Modified: grass/trunk/vector/v.delaunay/in_out.h
--- grass/trunk/vector/v.delaunay/in_out.h	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/vector/v.delaunay/in_out.h	2009-07-31 11:46:59 UTC (rev 38552)
@@ -2,7 +2,7 @@
 #define IN_OUT_H
-	       BOUND_BOX Box);
+	       struct bound_box Box);
 void output_edges(struct vertex *sites_sorted[], unsigned int n, int mode3d,
 		  int Type, struct Map_info map_out);
 void output_triangles(struct vertex *sites_sorted[], unsigned int n,
Modified: grass/trunk/vector/v.delaunay/main.c
--- grass/trunk/vector/v.delaunay/main.c	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/vector/v.delaunay/main.c	2009-07-31 11:46:59 UTC (rev 38552)
@@ -36,7 +36,7 @@
     const char *mapset;
     struct Map_info map_in, map_out;
-    BOUND_BOX Box;
+    struct bound_box Box;
     struct GModule *module;
     struct Flag *reg_flag, *line_flag;
     struct Option *in_opt, *out_opt;
Modified: grass/trunk/vector/v.distance/main.c
--- grass/trunk/vector/v.distance/main.c	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/vector/v.distance/main.c	2009-07-31 11:46:59 UTC (rev 38552)
@@ -100,7 +100,7 @@
     int update_ok, update_err, update_exist, update_notexist, update_dupl,
 	update_notfound;
     struct ilist *List;
-    BOUND_BOX box;
     dbCatValArray cvarr;
     dbColumn *column;
@@ -322,7 +322,7 @@
     /* TODO: add maxdist = -1 to Vect_select_ !!! */
     /* Calc maxdist */
     if (max < 0) {
-	BOUND_BOX fbox, tbox;
+	struct bound_box fbox, tbox;
 	double dx, dy, dz;
 	Vect_get_map_box(&From, &fbox);
Modified: grass/trunk/vector/v.edit/select.c
--- grass/trunk/vector/v.edit/select.c	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/vector/v.edit/select.c	2009-07-31 11:46:59 UTC (rev 38552)
@@ -340,7 +340,7 @@
 		int type, double x1, double y1, double x2, double y2,
 		struct ilist *List)
-    BOUND_BOX bbox;
+    struct bound_box bbox;
     struct ilist *List_tmp;
Modified: grass/trunk/vector/v.external/main.c
--- grass/trunk/vector/v.external/main.c	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/vector/v.external/main.c	2009-07-31 11:46:59 UTC (rev 38552)
@@ -140,8 +140,8 @@
     /* Create frmt */
-    sprintf(buf, "%s/%s", GRASS_VECT_DIRECTORY, options.output->answer);
-    fd = G_fopen_new(buf, GRASS_VECT_FRMT_ELEMENT);
+    sprintf(buf, "%s/%s", GV_DIRECTORY, options.output->answer);
+    fd = G_fopen_new(buf, GV_FRMT_ELEMENT);
     if (fd == NULL) {
 	Vect_delete(options.output->answer);
 	G_fatal_error("Unable to open file '%s'", buf);
Modified: grass/trunk/vector/v.generalize/displacement.c
--- grass/trunk/vector/v.generalize/displacement.c	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/vector/v.generalize/displacement.c	2009-07-31 11:46:59 UTC (rev 38552)
@@ -32,7 +32,7 @@
 int snakes_displacement(struct Map_info *In, struct Map_info *Out,
 			double threshold, double alpha, double beta,
 			double gama, double delta, int iterations,
-			VARRAY * varray)
+			struct varray * varray)
     int n_points;
Modified: grass/trunk/vector/v.generalize/main.c
--- grass/trunk/vector/v.generalize/main.c	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/vector/v.generalize/main.c	2009-07-31 11:46:59 UTC (rev 38552)
@@ -66,7 +66,7 @@
     int n_areas, n_lines;
     double x, y;
     int simplification, mask_type;
-    VARRAY *varray;
+    struct varray *varray;
     char *s;
     int left, right;
Modified: grass/trunk/vector/v.generalize/network.c
--- grass/trunk/vector/v.generalize/network.c	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/vector/v.generalize/network.c	2009-07-31 11:46:59 UTC (rev 38552)
@@ -28,9 +28,9 @@
     int **edge;			/* edge for each vertex */
     int *degree;		/* degree of vertices */
     int vertices;
-} NGRAPH;
+} NdglGraph_s;
-void graph_free(NGRAPH * g)
+void graph_free(NdglGraph_s * g)
     int i;
@@ -44,7 +44,7 @@
     return;
-int graph_init(NGRAPH * g, int vertices)
+int graph_init(NdglGraph_s * g, int vertices)
     g->edge = NULL;
     g->degree = NULL;
@@ -76,7 +76,7 @@
     int i;
     int output = 0;
     dglGraph_s *gr;
-    NGRAPH g;
+    NdglGraph_s g;
     int nnodes;
Modified: grass/trunk/vector/v.generalize/operators.h
--- grass/trunk/vector/v.generalize/operators.h	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/vector/v.generalize/operators.h	2009-07-31 11:46:59 UTC (rev 38552)
@@ -29,4 +29,4 @@
-			VARRAY * varray);
+			struct varray * varray);
Modified: grass/trunk/vector/v.hull/main.c
--- grass/trunk/vector/v.hull/main.c	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/vector/v.hull/main.c	2009-07-31 11:46:59 UTC (rev 38552)
@@ -167,7 +167,7 @@
     int pointIdx = 0;
     struct line_pnts *sites;
     struct line_cats *cats;
-    BOUND_BOX box;
     int cat, type;
     sites = Vect_new_line_struct();
Modified: grass/trunk/vector/v.in.dxf/dxf_to_vect.c
--- grass/trunk/vector/v.in.dxf/dxf_to_vect.c	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/vector/v.in.dxf/dxf_to_vect.c	2009-07-31 11:46:59 UTC (rev 38552)
@@ -10,7 +10,7 @@
 static void make_head(struct Map_info *);
-static BOUND_BOX ext, dxf_ext;
+static struct bound_box ext, dxf_ext;
 /* returns 1 on success, otherwise 0 */
 int dxf_to_vect(struct dxf_file *dxf, struct Map_info *Map)
Modified: grass/trunk/vector/v.in.ogr/geom.c
--- grass/trunk/vector/v.in.ogr/geom.c	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/vector/v.in.ogr/geom.c	2009-07-31 11:46:59 UTC (rev 38552)
@@ -29,7 +29,7 @@
 /* Add categories to centroids inside polygon */
 int
-centroid(OGRGeometryH hGeom, CENTR * Centr, SPATIAL_INDEX * Sindex, int field,
+centroid(OGRGeometryH hGeom, CENTR * Centr, struct spatial_index * Sindex, int field,
 	 int cat, double min_area, int type)
     int i, valid_isles, j, np, nr, ret;
@@ -41,7 +41,7 @@
     OGRGeometryH hRing;
     double size;
     static struct ilist *List;
-    BOUND_BOX box;
     G_debug(3, "centroid() cat = %d", cat);
Modified: grass/trunk/vector/v.in.ogr/main.c
--- grass/trunk/vector/v.in.ogr/main.c	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/vector/v.in.ogr/main.c	2009-07-31 11:46:59 UTC (rev 38552)
@@ -42,7 +42,7 @@
 int geom(OGRGeometryH hGeom, struct Map_info *Map, int field, int cat,
 	 double min_area, int type, int mk_centr);
-int centroid(OGRGeometryH hGeom, CENTR * Centr, SPATIAL_INDEX * Sindex,
+int centroid(OGRGeometryH hGeom, CENTR * Centr, struct spatial_index * Sindex,
 	     int field, int cat, double min_area, int type);
 int main(int argc, char *argv[])
@@ -928,9 +928,9 @@
 	Vect_get_num_primitives(&Tmp, GV_BOUNDARY) > 0) {
 	int ret, centr, ncentr, otype, n_overlaps, n_nocat;
 	CENTR *Centr;
-	SPATIAL_INDEX si;
+	struct spatial_index si;
 	double x, y, total_area, overlap_area, nocat_area;
-	BOUND_BOX box;
 	int nmodif;
Modified: grass/trunk/vector/v.info/main.c
--- grass/trunk/vector/v.info/main.c	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/vector/v.info/main.c	2009-07-31 11:46:59 UTC (rev 38552)
@@ -45,8 +45,7 @@
     struct Option *in_opt, *fieldopt;
     struct Flag *histf, *columns, *gflag, *tflag, *mflag;
-    BOUND_BOX box;
-    const char *mapset;
     char line[200], buf[1001];
     int i;
     int with_z;
@@ -101,12 +100,7 @@
     if (G_parser(argc, argv))
 	exit(EXIT_FAILURE);
-    /* open input vector */
-    if ((mapset = G_find_vector2(in_opt->answer, "")) == NULL) {
-	G_fatal_error(_("Vector map <%s> not found"), in_opt->answer);
-    Vect_set_open_level(2);
+    Vect_set_open_level(2); /* topology required */
     Vect_open_old_head(&Map, in_opt->answer, "");
     with_z = Vect_is_3d(&Map);
@@ -230,9 +224,9 @@
 	else {
 	    divider('+');
-	    sprintf(line, _("Layer:           %s"), in_opt->answer);
+	    sprintf(line, _("Layer:           %s"), Vect_get_name(&Map));
 	    printline(line);
-	    sprintf(line, _("Mapset:          %s"), mapset);
+	    sprintf(line, _("Mapset:          %s"), Vect_get_mapset(&Map));
 	    printline(line);
 	    sprintf(line, _("Location:        %s"), G_location());
 	    printline(line);
Modified: grass/trunk/vector/v.kcv/main.c
--- grass/trunk/vector/v.kcv/main.c	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/vector/v.kcv/main.c	2009-07-31 11:46:59 UTC (rev 38552)
@@ -62,7 +62,7 @@
     struct Option *in_opt, *out_opt, *col_opt, *npart_opt;
     struct Flag *drand48_flag, *q_flag;
-    BOUND_BOX box;
     double maxdist;
     /* Attributes */
Modified: grass/trunk/vector/v.kernel/main.c
--- grass/trunk/vector/v.kernel/main.c	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/vector/v.kernel/main.c	2009-07-31 11:46:59 UTC (rev 38552)
@@ -503,7 +503,7 @@
     int nn, kk, nalines, aline;
     double dist;
     struct line_pnts *APoints, *BPoints;
-    BOUND_BOX box;
     struct ilist *List;
     APoints = Vect_new_line_struct();
@@ -582,7 +582,7 @@
     int i;
     double dist;
     static struct line_pnts *Points = NULL;
-    BOUND_BOX box;
     static struct ilist *List = NULL;
     if (!Points)
@@ -639,7 +639,7 @@
     double dist;
     /* spatial index handling, borrowed from lib/vector/Vlib/find.c */
-    BOUND_BOX box;
     static struct ilist *NList = NULL;
Modified: grass/trunk/vector/v.label.sa/labels.c
--- grass/trunk/vector/v.label.sa/labels.c	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/vector/v.label.sa/labels.c	2009-07-31 11:46:59 UTC (rev 38552)
@@ -5,7 +5,7 @@
 #include "labels.h"
 static int label_skyline(FT_Face face, const char *charset, label_t * label);
-static struct line_pnts *box_trans_rot(BOUND_BOX * bb, label_point_t * p,
+static struct line_pnts *box_trans_rot(struct bound_box * bb, label_point_t * p,
 				       double angle);
 static void label_point_candidates(label_t * label);
 static void label_line_candidates(label_t * label);
@@ -18,7 +18,7 @@
 static double min_dist_2_lines(struct line_pnts *skyline,
 			       struct line_pnts *swathline,
 			       label_point_t * p);
-static int box_overlap(BOUND_BOX * a, BOUND_BOX * b);
+static int box_overlap(struct bound_box * a, struct bound_box * b);
 static int box_overlap2(struct line_pnts *a, struct line_pnts *b);
@@ -805,7 +805,7 @@
  * @return A lint_pnts structure containing the rotated and translated
  * bounding box as a polygon.
 				       double angle)
@@ -1157,7 +1157,7 @@
 		    if ((labels[i].candidates[j].rotation == 0) &&
 			(labels[k].candidates[l].rotation == 0)) {
-			BOUND_BOX a, b;
+			struct bound_box a, b;
 			a.N =
 			    labels[i].bb.N + labels[i].candidates[j].point.y;
@@ -1230,7 +1230,7 @@
  * @param b Bounding box B
  * @return REtruns 1 if the two boxes overlap 0 if not.
     int vert = 0, hori = 0;
Modified: grass/trunk/vector/v.label.sa/labels.h
--- grass/trunk/vector/v.label.sa/labels.h	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/vector/v.label.sa/labels.h	2009-07-31 11:46:59 UTC (rev 38552)
@@ -46,7 +46,7 @@
     struct line_pnts *skyline;	/**< The skyline of the text, as an offest
 				  *  from the label point */
-    BOUND_BOX bb;
+    struct bound_box bb;
     double size;
     double current_score;	  /**< The current score of the label. */
Modified: grass/trunk/vector/v.neighbors/main.c
--- grass/trunk/vector/v.neighbors/main.c	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/vector/v.neighbors/main.c	2009-07-31 11:46:59 UTC (rev 38552)
@@ -38,7 +38,7 @@
     double radius;
     struct ilist *List;
     struct Cell_head region;
-    BOUND_BOX box;
Modified: grass/trunk/vector/v.normal/main.c
--- grass/trunk/vector/v.normal/main.c	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/vector/v.normal/main.c	2009-07-31 11:46:59 UTC (rev 38552)
@@ -63,7 +63,7 @@
     int line, nlines, npoints;
-    BOUND_BOX box;
     /* Attributes */
     int nrecords;
Modified: grass/trunk/vector/v.out.dxf/main.c
--- grass/trunk/vector/v.out.dxf/main.c	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/vector/v.out.dxf/main.c	2009-07-31 11:46:59 UTC (rev 38552)
@@ -93,7 +93,7 @@
 double do_limits(struct Map_info *Map)
     double textsize;
-    BOUND_BOX box;
     Vect_get_map_box(Map, &box);
Modified: grass/trunk/vector/v.out.svg/main.c
--- grass/trunk/vector/v.out.svg/main.c	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/vector/v.out.svg/main.c	2009-07-31 11:46:59 UTC (rev 38552)
@@ -50,7 +50,7 @@
 	*field_opt;
     struct Map_info In;
-    BOUND_BOX box;
     /* vector */
Modified: grass/trunk/vector/v.patch/main.c
--- grass/trunk/vector/v.patch/main.c	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/vector/v.patch/main.c	2009-07-31 11:46:59 UTC (rev 38552)
@@ -506,7 +506,7 @@
     if (BBoxMap) {		/* inspired by v.in.region */
-	BOUND_BOX box;
 	double diff_long, mid_long;
 	static int cat;
Modified: grass/trunk/vector/v.select/main.c
--- grass/trunk/vector/v.select/main.c	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/vector/v.select/main.c	2009-07-31 11:46:59 UTC (rev 38552)
@@ -141,7 +141,7 @@
 	G_message(_("Processing features..."));
 	for (aline = 1; aline <= nalines; aline++) {
-	    BOUND_BOX abox;
+	    struct bound_box abox;
 	    G_debug(3, "aline = %d", aline);
 	    G_percent(aline, nalines, 2);	/* must be before any continue */
@@ -272,7 +272,7 @@
 	naareas = Vect_get_num_areas(&(In[0]));
 	for (aarea = 1; aarea <= naareas; aarea++) {
-	    BOUND_BOX abox;
 	    G_percent(aarea, naareas, 2);	/* must be before any continue */
Modified: grass/trunk/vector/v.support/main.c
--- grass/trunk/vector/v.support/main.c	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/vector/v.support/main.c	2009-07-31 11:46:59 UTC (rev 38552)
@@ -177,8 +177,8 @@
 	char buf[2000];		/* derived from Vect_hist_command() */
 	/* Open history file for modification */
-	sprintf(buf, "%s/%s", GRASS_VECT_DIRECTORY, Map.name);
-	Map.hist_fp = G_fopen_modify(buf, GRASS_VECT_HIST_ELEMENT);
+	sprintf(buf, "%s/%s", GV_DIRECTORY, Map.name);
+	Map.hist_fp = G_fopen_modify(buf, GV_HIST_ELEMENT);
 	if (Map.hist_fp == NULL) {
 	    G_warning(_("Unable to open history file for vector map <%s>"),
 		      Vect_get_full_name(&Map));
Modified: grass/trunk/vector/v.to.3d/main.c
--- grass/trunk/vector/v.to.3d/main.c	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/vector/v.to.3d/main.c	2009-07-31 11:46:59 UTC (rev 38552)
@@ -27,7 +27,7 @@
     struct opts opt;
     struct Map_info In, Out;
-    BOUND_BOX box;
     int field, type;
     int ret;
Modified: grass/trunk/vector/v.transform/main.c
--- grass/trunk/vector/v.transform/main.c	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/vector/v.transform/main.c	2009-07-31 11:46:59 UTC (rev 38552)
@@ -66,7 +66,7 @@
     char mon[4], date[40], buf[1000];
     struct Map_info Old, New;
     int day, yr;
-    BOUND_BOX box;
     double ztozero;
     double trans_params[7];	// xshift, ..., xscale, ..., zrot
Modified: grass/trunk/vector/v.voronoi/defs.h
--- grass/trunk/vector/v.voronoi/defs.h	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/vector/v.voronoi/defs.h	2009-07-31 11:46:59 UTC (rev 38552)
@@ -1,6 +1,6 @@
 extern struct Map_info In, Out;
 extern int Type;
 extern int All;
Modified: grass/trunk/vector/v.voronoi/sw_main.c
--- grass/trunk/vector/v.voronoi/sw_main.c	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/vector/v.voronoi/sw_main.c	2009-07-31 11:46:59 UTC (rev 38552)
@@ -27,7 +27,7 @@
 int PQmin;
-BOUND_BOX Box;
 int Type;
 int All;
Modified: grass/trunk/vector/v.what.rast/main.c
--- grass/trunk/vector/v.what.rast/main.c	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/vector/v.what.rast/main.c	2009-07-31 11:46:59 UTC (rev 38552)
@@ -66,7 +66,7 @@
     int outside_cnt;		/* points outside region */
     int nocat_cnt;		/* points inside region but without category */
     int dupl_cnt;		/* duplicate categories */
-    BOUND_BOX box;
     int *catexst, *cex;
     struct field_info *Fi;
Modified: grass/trunk/visualization/nviz/src/site_attr_commands.c
--- grass/trunk/visualization/nviz/src/site_attr_commands.c	2009-07-31 11:43:54 UTC (rev 38551)
+++ grass/trunk/visualization/nviz/src/site_attr_commands.c	2009-07-31 11:46:59 UTC (rev 38552)
@@ -244,7 +244,7 @@
 		    float *mr, float *mg, float *mb);
 /* better move to ../../../include/P_site.h */
-SITE_ATT *G_sites_get_atts(struct Map_info *ptr, int *cat);
+struct site_att *G_sites_get_atts(struct Map_info *ptr, int *cat);
@@ -395,7 +395,7 @@
     int *ndx;
     int ncols, i, index;
     char buf[9182];
-    SITE_ATT *sa;
+    struct site_att *sa;
     if (argc != 3)
 	return (TCL_ERROR);
@@ -447,7 +447,7 @@
     int *ndx;
     char buf[9182];
-    SITE_ATT *sa;
     if (argc != 3)
 	return (TCL_ERROR);
@@ -500,7 +500,7 @@
     int *ndx;
     int ncols, i, cat;
     char buf[9182];
-    SITE_ATT *sa;
     if (argc != 3)
 	return (TCL_ERROR);
@@ -511,7 +511,7 @@
     ncols = G_sites_get_fields(Map, &cnames, &ctypes, &ndx);
-    if ((sa = (SITE_ATT *) G_sites_get_atts(Map, &cat)) == NULL)
+    if ((sa = (struct site_att *) G_sites_get_atts(Map, &cat)) == NULL)
 	return (TCL_ERROR);
     for (i = 0; i < ncols; i++) {
@@ -740,7 +740,7 @@
     struct Map_info *Map;
     geopoint *gpt;
-    SITE_ATT *sa;
     int *ctypes;
     char **cnames;
     int *ndx;
@@ -769,7 +769,7 @@
 	else if (ctypes[index] == 'd') {
 	    if ((sa =
-		 (SITE_ATT *) G_sites_get_atts(Map, &(gpt->cat))) == NULL)
+		 (struct site_att *) G_sites_get_atts(Map, &(gpt->cat))) == NULL)
 		continue;
 	    else
 		gpt->color[nattr] =
@@ -778,7 +778,7 @@
 	else {
 	    if ((sa =
 		continue;
 	    else
 		gpt->color[nattr] =
@@ -811,7 +811,7 @@
     geopoint *gpt;
-    SITE_ATT *sa;
     int *ctypes;
     char **cnames;
     int *ndx;
@@ -837,7 +837,7 @@
 	    if ((sa =
 		continue;
 	    else
 		gpt->size[nattr] =
@@ -845,7 +845,7 @@
 	else {
 	    if ((sa =
 		continue;
 	    else
 		gpt->size[nattr] =
