[GRASS-SVN] r38559 - grass/branches/develbranch_6/vector/v.surf.rst
Fri Jul 31 17:06:43 EDT 2009
Author: helena
Date: 2009-07-31 17:06:43 -0400 (Fri, 31 Jul 2009)
New Revision: 38559
   grass/branches/develbranch_6/vector/v.surf.rst/description.html
-z desc. added, time support taken out
Modified: grass/branches/develbranch_6/vector/v.surf.rst/description.html
--- grass/branches/develbranch_6/vector/v.surf.rst/description.html	2009-07-31 18:20:49 UTC (rev 38558)
+++ grass/branches/develbranch_6/vector/v.surf.rst/description.html	2009-07-31 21:06:43 UTC (rev 38559)
@@ -1,9 +1,9 @@
 <h2>DESCRIPTION</h2>
 <em>v.surf.rst</em>
-<br>This program performs spatial approximation based on z-values (<em>layer=0</em>
-parameter) or attributes (<em>zcolumn</em> parameter) of point or isoline data
-given in a vector map named <em>input</em> to grid cells in the output
+<br>This program performs spatial approximation based on z-values (<em>-z</em> flag
+or <em>layer=0</em> parameter) or attributes (<em>zcolumn</em> parameter)
+of point or isoline data given in a vector map named <em>input</em> to grid cells in the output
 raster map <em>elev</em> representing a surface. As an option, simultaneously
 with approximation, topographic parameters slope, aspect, profile curvature
 (measured in the direction of the steepest slope), tangential curvature (measured
@@ -13,8 +13,9 @@
 outputs partial derivatives f<sub>x</sub>,f<sub>y</sub>,f<sub>xx</sub>,
 f<sub>yy</sub>,f<sub>xy</sub>
 instead of slope, aspect, profile, tangential and mean curvatures respectively.
+<!-- the feature below has been lost when switch was made from sites to vector points)
 If the input data have time stamp, the program creates time stamp for all
-output files.
+output files. -->
 <p>
 User can define a raster map named <em>maskmap</em>, which will be used
