[GRASS-SVN] r37671 - in grass/trunk: include/Make lib/init locale
swig/python
svn_grass at osgeo.org
Mon Jun 1 01:29:24 EDT 2009
Author: glynn
Date: 2009-06-01 01:29:24 -0400 (Mon, 01 Jun 2009)
New Revision: 37671
grass/trunk/include/Make/Grass.make
grass/trunk/include/Make/Platform.make.in
grass/trunk/include/Make/Python.make
grass/trunk/lib/init/Makefile
grass/trunk/locale/Makefile
grass/trunk/swig/python/Makefile
Build system clean-up
Modified: grass/trunk/include/Make/Grass.make
--- grass/trunk/include/Make/Grass.make 2009-06-01 05:27:36 UTC (rev 37670)
+++ grass/trunk/include/Make/Grass.make 2009-06-01 05:29:24 UTC (rev 37671)
@@ -26,27 +26,33 @@
# platform specific dirs
ARCH_DISTDIR = $(GRASS_HOME)/dist.$(ARCH)
ARCH_BINDIR = $(GRASS_HOME)/bin.$(ARCH)
+GISBASE = $(ARCH_DISTDIR)
ERRORLOG = $(GRASS_HOME)/error.log
# include dirs
ARCH_INCDIR = $(ARCH_DISTDIR)/include/grass
-ARCH_INC = -I$(ARCH_DISTDIR)/include
-INC = $(ARCH_INC)
+INC = -I$(ARCH_DISTDIR)/include -I$(GISBASE)/include
VECT_INC =
# libraries
ARCH_LIBDIR = $(ARCH_DISTDIR)/lib
-ARCH_LIBPATH = -L$(ARCH_LIBDIR)
-LIBPATH = $(ARCH_LIBPATH)
+LIBPATH = -L$(ARCH_LIBDIR) -L$(GISBASE)/lib
# object dir
OBJDIR = OBJ.$(ARCH)
+LIB_RUNTIME_DIR = $(GISBASE)/lib
+RUN_GISRC = $(GISBASE)/demolocation/.grassrc$(GRASS_VERSION_MAJOR)$(GRASS_VERSION_MINOR)
+RUN_GISBASE = $(GISBASE)
# these define the various directories which contain GRASS programs
# or files used by GRASS programs
-GISBASE = $(ARCH_DISTDIR)
BIN = $(ARCH_DISTDIR)/bin
ETC = $(ARCH_DISTDIR)/etc
DRIVERDIR = $(ARCH_DISTDIR)/driver
@@ -54,6 +60,8 @@
DOCSDIR = $(ARCH_DISTDIR)/docs
HTMLDIR = $(ARCH_DISTDIR)/docs/html
SCRIPTDIR = $(ARCH_DISTDIR)/scripts
+MSG_DIR = $(ARCH_DISTDIR)/etc/msgs
+MO_DIR = $(ARCH_DISTDIR)/locale
FONTDIR = $(ARCH_DISTDIR)/fonts
@@ -64,6 +72,10 @@
GRASS_BUILD_FILE = $(ETC)/BUILD
##################### other #############################################
+COMPILE_FLAGS = $(CPPFLAGS) $(CFLAGS1) $(INCLUDE_DIRS)
+COMPILE_FLAGS_CXX = $(CPPFLAGS) $(CXXFLAGS1) $(INCLUDE_DIRS)
CFLAGS = $(INC) $(COMPILE_FLAGS)
CXXFLAGS = $(INC) $(COMPILE_FLAGS_CXX)
LDFLAGS = $(LIBPATH) $(LINK_FLAGS) $(LD_SEARCH_FLAGS) $(PQLIBPATH)
@@ -83,7 +95,7 @@
MANSECT = 1
MANBASEDIR = $(ARCH_DISTDIR)/man
MANDIR = $(MANBASEDIR)/man$(MANSECT)
-HTML2MAN = VERSION_NUMBER=${GRASS_VERSION_NUMBER} $(GRASS_HOME)/tools/g.html2man/g.html2man.py
+HTML2MAN = VERSION_NUMBER=$(GRASS_VERSION_NUMBER) $(GRASS_HOME)/tools/g.html2man/g.html2man.py
##################### library names #####################################
Modified: grass/trunk/include/Make/Platform.make.in
--- grass/trunk/include/Make/Platform.make.in 2009-06-01 05:27:36 UTC (rev 37670)
+++ grass/trunk/include/Make/Platform.make.in 2009-06-01 05:29:24 UTC (rev 37671)
@@ -40,6 +40,8 @@
UNIX_BIN = @BINDIR@
INST_DIR = @INSTDIR@
+GRASS_HOME = @GRASS_HOME@
GRASS_VERSION_MAJOR = @GRASS_VERSION_MAJOR@
GRASS_VERSION_MINOR = @GRASS_VERSION_MINOR@
GRASS_VERSION_RELEASE = @GRASS_VERSION_RELEASE@
@@ -50,7 +52,6 @@
CC_SEARCH_FLAGS = @CC_SEARCH_FLAGS@
LD_SEARCH_FLAGS = @LD_SEARCH_FLAGS@
LD_LIBRARY_PATH_VAR = @LD_LIBRARY_PATH_VAR@
-LIB_RUNTIME_DIR = $(ARCH_LIBDIR)
#generate static (ST) or shared (SH)
LIB_PREFIX = @GRASS_LIB_PREFIX@
@@ -72,12 +73,6 @@
SHLIB_SUFFIX = @SHLIB_SUFFIX@
EXE = @EXEEXT@
-# GRASS dirs
-GRASS_HOME = @GRASS_HOME@
-RUN_GISBASE = @GISBASE@
-RUN_GISRC = ${ARCH_DISTDIR}/demolocation/.grassrc${GRASS_VERSION_MAJOR}${GRASS_VERSION_MINOR}
DEFAULT_DATABASE =
DEFAULT_LOCATION =
@@ -85,9 +80,6 @@
CFLAGS1 = @CFLAGS@
CXXFLAGS1 = @CXXFLAGS@
INCLUDE_DIRS = @INCLUDE_DIRS@
-COMPILE_FLAGS = $(CPPFLAGS) $(CFLAGS1) $(INCLUDE_DIRS)
-COMPILE_FLAGS_CXX = $(CPPFLAGS) $(CXXFLAGS1) $(INCLUDE_DIRS)
LINK_FLAGS = @LDFLAGS@
DLLIB = @DLLIB@
Modified: grass/trunk/include/Make/Python.make
--- grass/trunk/include/Make/Python.make 2009-06-01 05:27:36 UTC (rev 37670)
+++ grass/trunk/include/Make/Python.make 2009-06-01 05:29:24 UTC (rev 37671)
@@ -13,7 +13,7 @@
$(PYTHON) -m py_compile $<
%_wrap.c %.py: %.i $(EXTRA_SWIG)
- $(SWIG) $(ARCH_INC) -python -module $* -shadow $<
+ $(SWIG) $(INC) -python -module $* -shadow $<
_%.so: $(OBJDIR)/%_wrap.o $(_%_so_FILES)
$(PYMOD_LD) -o $@ $(LDFLAGS) $(EXTRA_LDFLAGS) $(PYMOD_LDFLAGS) $(filter %.o,$^) $($*_LIBS) $(LIBES) $(EXTRA_LIBS)
Modified: grass/trunk/lib/init/Makefile
--- grass/trunk/lib/init/Makefile 2009-06-01 05:27:36 UTC (rev 37670)
+++ grass/trunk/lib/init/Makefile 2009-06-01 05:29:24 UTC (rev 37671)
@@ -61,8 +61,8 @@
default: $(FILES)
$(ARCH_BINDIR)/$(START_UP): init.sh grass.src
- @test -d $(ARCH_BINDIR) || (echo 'ARCH_DISTDIR($(ARCH_BINDIR))' not found; exit 1)
- @test -w $(ARCH_BINDIR) || (echo '($(ARCH_BINDIR))' not writeable; exit 1)
+ @test -d $(ARCH_BINDIR) || (echo 'ARCH_BINDIR($(ARCH_BINDIR))' not found; exit 1)
+ @test -w $(ARCH_BINDIR) || (echo 'ARCH_BINDIR($(ARCH_BINDIR))' not writeable; exit 1)
rm -f $(ARCH_BINDIR)/$(START_UP) ; true
$(SHELL) -c "sed \
-e \"s#GISBASE_VALUE#$(GISBASE)#\" \
@@ -70,8 +70,8 @@
chmod a+x $(ARCH_BINDIR)/$(START_UP)
$(ARCH_BINDIR)/$(START_UP).bat: init.bat grass.bat
rm -f $@ ; true
$(SHELL) -c "sed \
-e \"s#GISBASE_VALUE#$(RUN_GISBASE)#\" \
Modified: grass/trunk/locale/Makefile
--- grass/trunk/locale/Makefile 2009-06-01 05:27:36 UTC (rev 37670)
+++ grass/trunk/locale/Makefile 2009-06-01 05:29:24 UTC (rev 37671)
@@ -20,8 +20,6 @@
@echo ' make mo create the *.mo files'
# Directory for installing tcl .msg files:
-MSG_DIR = $(ARCH_DISTDIR)/etc/msgs
-MO_DIR = $(ARCH_DISTDIR)/locale
PO_DIR = po
#distinguish between library messages and modules:
Modified: grass/trunk/swig/python/Makefile
--- grass/trunk/swig/python/Makefile 2009-06-01 05:27:36 UTC (rev 37670)
+++ grass/trunk/swig/python/Makefile 2009-06-01 05:29:24 UTC (rev 37671)
@@ -33,7 +33,7 @@
proj_wrap_c_FLAGS = $(PROJINC) $(GDALCFLAGS)
EXTRA_SWIG = ../include/python/my_typemaps.i ../include/python/common.i
-SWIGFLAGS = $(ARCH_INC) -I../include/python -outdir .
+SWIGFLAGS = $(INC) -I../include/python -outdir .
EXTRA_CFLAGS = $(PYMOD_CFLAGS)
EXTRA_CLEAN_FILES := $(foreach M,$(MODULES),$(M)_wrap.o $(M)_wrap.c $(M).pyc $(M).py _$(M).so)
CLEAN_SUBDIRS = NumPtr
