[GRASS-SVN] r37698 - grass/branches/releasebranch_6_4/lib/db/sqlp
Mon Jun 1 10:15:34 EDT 2009
Author: neteler
Date: 2009-06-01 10:15:34 -0400 (Mon, 01 Jun 2009)
New Revision: 37698
   grass/branches/releasebranch_6_4/lib/db/sqlp/description.html
+type casting
Modified: grass/branches/releasebranch_6_4/lib/db/sqlp/description.html
--- grass/branches/releasebranch_6_4/lib/db/sqlp/description.html	2009-06-01 14:15:25 UTC (rev 37697)
+++ grass/branches/releasebranch_6_4/lib/db/sqlp/description.html	2009-06-01 14:15:34 UTC (rev 37698)
@@ -82,13 +82,13 @@
 <p>
-<p>Example of subquery expressions from a list (does not work for DBF driver):
+<p><b>Example</b> of subquery expressions from a list (does not work for DBF driver):
 <div class="code"><pre>
 v.db.select mysites where="id IN ('P04', 'P05')"
 </pre></div>
-<p>Example of pattern matching:
+<p><b>Example</b> of pattern matching:
 # field contains string:
@@ -104,7 +104,7 @@
 v.db.select mysites where="id LIKE 'P%'"
 </pre></div>
-<p>Example of null handling:
+<p><b>Example</b> of null handling:
 v.db.addcol map=roads col="nulltest int"
 v.db.update map=roads col=nulltest value=1 where="cat &gt; 2"
@@ -113,7 +113,7 @@
 </pre></div>
-<p>Examples of complex expressions in updates (using v.db.* modules):
+<p><b>Examples</b> of complex expressions in updates (using v.db.* modules):
 v.db.addcol map=roads col="exprtest double precision"
 v.db.update map=roads col=exprtest value=cat/nulltest
@@ -121,7 +121,7 @@
 </pre></div>
-<p>Examples of complex expressions in updates (using db.* modules):
+<p><b>Examples</b> of complex expressions in updates (using db.* modules):
 echo "UPDATE roads SET exprtest=null"
 echo "UPDATE roads SET exprtest=cat/2" | db.execute
@@ -140,7 +140,19 @@
 </pre></div>
+<p><b>Example</b> of changing a SQL type (type casting, does not work for DBF driver):
+<div class="code"><pre>
+# North Carolina data set: convert string column to double precision
+#  copy map into current mapset
+g.copy vect=geodetic_pts,mygeodetic_pts
+v.db.addcol mygeodetic_pts col="zval double precision"
+# the 'z_value' col contains 'N/A' strings, not to be converted
+v.db.update mygeodetic_pts col=zval \
+            qcol="CAST(z_value AS double precision)" \
+            where="z_value <> 'N/A'"
+</pre></div>
 <h2>SEE ALSO</h2>
 <a href="databaseintro.html">Database management in GRASS GIS</a>,<BR>
