[GRASS-SVN] r37711 - grass/branches/develbranch_6/gui/tcltk/gis.m
svn_grass at osgeo.org
Wed Jun 3 05:12:39 EDT 2009
Author: hamish
Date: 2009-06-03 05:12:39 -0400 (Wed, 03 Jun 2009)
New Revision: 37711
grass/branches/develbranch_6/gui/tcltk/gis.m/mapcanvas.tcl
#87 : fancy DMS output for Lat/Lon (TODO: UI control for dms_format variable);
#608: cap north/south LL at 90 (still needs a lot of work)
Modified: grass/branches/develbranch_6/gui/tcltk/gis.m/mapcanvas.tcl
--- grass/branches/develbranch_6/gui/tcltk/gis.m/mapcanvas.tcl 2009-06-03 06:50:08 UTC (rev 37710)
+++ grass/branches/develbranch_6/gui/tcltk/gis.m/mapcanvas.tcl 2009-06-03 09:12:39 UTC (rev 37711)
@@ -113,8 +113,10 @@
variable zoom_attrs
set zoom_attrs {n s e w nsres ewres rows cols}
- # ll_proj is 1 for a Lat/Lon projection, 0 othervise
- variable ll_proj
+ # proj_is_ll is 1 for a Lat/Lon projection, 0 otherwise
+ global proj_is_ll
+ # DMS format: 0 is ddd.ddddd, 1 is ddd:mm.mmmmm', 2 is ddd:mm'ss.sss"
+ global dms_format
# string with region information to show in status bar
variable regionstr
@@ -155,7 +157,8 @@
variable b1east
variable b1north
variable mappid
- variable ll_proj
+ global proj_is_ll
+ global dms_format
global drawprog
global tmpdir
global env
@@ -171,7 +174,7 @@
# run get_mapunits to check projection
MapCanvas::get_mapunits
- if { $ll_proj } {
+ if { $proj_is_ll } {
# Explore mode is off by default (can't peer past 90deg)
set exploremode($mon) 0
} else {
@@ -179,6 +182,9 @@
set exploremode($mon) 1
+# FIXME: make this settable from the UI or use GRASS_DMS_FORMAT enviro var
+ set dms_format 2
# Make sure that we are using the WIND file for everything except displays
if {[info exists env(WIND_OVERRIDE)]} {unset env(WIND_OVERRIDE)}
@@ -429,7 +435,7 @@
proc MapCanvas::get_mapunits {} {
- variable ll_proj
+ global proj_is_ll
# get map units from PROJ_UNITS
if {![catch {open "|g.proj -p" r} input]} {
set key ""
@@ -437,7 +443,7 @@
while {[gets $input line] >= 0} {
if { [string equal "XY location (unprojected)" "$line"] } {
set mapunits "map units"
- set ll_proj 0
+ set proj_is_ll 0
break
regexp -nocase {^(.*):(.*)$} $line trash key value
@@ -457,9 +463,9 @@
set mapunits $prj(units)
if { [string eq "Lat/Lon" "$prj(name)"] } {
- set ll_proj 1
+ set proj_is_ll 1
} else {
- set ll_proj 0
+ set proj_is_ll 0
@@ -580,7 +586,7 @@
variable opclist
variable mapframe
variable zoom_attrs
- variable ll_proj
+ global proj_is_ll
variable exploremode
global env
global drawprog
@@ -601,7 +607,7 @@
set options {}
foreach attr $zoom_attrs value $values {
if {$attr != "rows" && $attr != "cols"} {
- if { $ll_proj } {
if {$attr == "n" && $value > 90} {
set value 90
if {$exploremode($mon)} {
@@ -983,6 +989,7 @@
variable can
variable b1east
variable b1north
+ global proj_is_ll
global coords
global pctentry
global pixelentry
@@ -1009,7 +1016,18 @@
global screenpct pctentry pixelentry geoentry geogentry llvert llhoriz
set b1east [MapCanvas::scrx2mape $mon %x]
set b1north [MapCanvas::scry2mapn $mon %y]
- set b1coords "$b1east $b1north"
+ if { $b1north < -90 } {
+ set coords($mon) "$b1east -90"
+ } elseif { $b1north > 90 } {
+ set coords($mon) "$b1east 90"
+ } else {
+ set coords($mon) "$b1east $b1north"
+ } else {
# grab coordinates at mouse click for georectification
if { [info exists geoentry] } {
$geoentry insert 0 $b1coords
@@ -1051,13 +1069,149 @@
set scrxmov %x
set scrymov %y
set eastcoord [format $outfmt_coords [eval MapCanvas::scrx2mape $mon %x] ]
- set northcoord [format $outfmt_coords [eval MapCanvas::scry2mapn $mon %y] ]
- set coords($mon) "$eastcoord $northcoord"
+ set northcoord [eval MapCanvas::scry2mapn $mon %y]
+ set coords($mon) [eval MapCanvas::fancy_ll $eastcoord $northcoord]
+ } else {
+ set northcoord [format $outfmt_coords [eval MapCanvas::scry2mapn $mon %y] ]
+ set coords($mon) "$eastcoord $northcoord"
+# procedures to make lat/lon resolution fancy
+proc MapCanvas::fancy_ll_res { res } {
+ variable res_str
+ # units are degrees
+ # _d means integer, _f means float
+ variable deg_d
+ variable min_f
+ variable min_d
+ variable sec_f
+ global proj_is_ll
+ global dms_format
+ if { !$proj_is_ll } {
+ return "$res"
+ # format easting
+ set deg_d [expr $res - fmod($res,1) ]
+ set min_f [expr fmod($res,1)*60 ]
+ set min_d [expr $min_f - fmod($min_f,1) ]
+ set sec_f [expr fmod($min_f,1)*60 ]
+ switch $dms_format {
+ 0 {
+ set res_str [format "%.6g" $res]
+ 1 {
+ set res_str [format "%.0f\xB0%02.4g'" $deg_d $min_f ]
+ 2 {
+ # 'g.region -g' doesn't report enough sig digs for LL so we get rounding errors!
+ if { [expr abs($sec_f - 60)] < 0.0001 } {
+ set min_d [expr $min_d + 1]
+ set sec_f "0"
+ set res_str [format "%.0f\xB0%02.0f'%02.3g\"" \
+ $deg_d $min_d $sec_f ]
+ return "$res_str"
+# procedures to make lat/lon coords fancy
+proc MapCanvas::fancy_ll { eastcoord northcoord } {
+ variable ncoord
+ variable ecoord
+ variable hem_str
+ variable deg_d
+ variable min_f
+ variable min_d
+ variable sec_f
+ global proj_is_ll
+ global dms_format
+ return "$eastcoord $northcoord"
+ # format easting
+ set deg_d [expr abs($eastcoord - fmod($eastcoord,1)) ]
+ set min_f [expr abs(fmod($eastcoord,1)*60) ]
+ if { fmod($eastcoord,180) == 0 } {
+ set hem_str ""
+ } elseif { $eastcoord > 0 } {
+ set hem_str "E"
+ } else {
+ set hem_str "W"
+ 0 {
+ set ecoord [format "%.6f\xB0 %s" [expr abs($eastcoord)] $hem_str ]
+ 1 {
+ set ecoord [format "%3.0f\xB0 %02.4f' %s" \
+ $deg_d $min_f $hem_str ]
+ 2 {
+ set ecoord [format "%3.0f\xB0%02.0f'%06.3f\"%s" \
+ $deg_d $min_d $sec_f $hem_str ]
+ # now northing
+ set deg_d [expr abs($northcoord - fmod($northcoord,1)) ]
+ set min_f [expr abs(fmod($northcoord,1)*60) ]
+ if { $northcoord > 0 } {
+ set hem_str "N"
+ } elseif { $northcoord == 0 } {
+ set hem_str ""
+ } else {
+ set hem_str "S"
+ if { $northcoord > 90 || $northcoord < -90} {
+ set ncoord [concat "90\xB0" $hem_str ]
+ } else {
+ 0 {
+ set ncoord [format "%.6f\xB0 %s" [expr abs($northcoord)] $hem_str ]
+ 1 {
+ set ncoord [format "%2.0f\xB0 %02.4f' %s" \
+ 2 {
+ set ncoord [format "%2.0f\xB0%02.0f'%06.3f\"%s" \
+ return "$ecoord $ncoord"
# procedures for interactive zooming in and zooming out
# Get the current zoom region
@@ -1071,7 +1225,7 @@
variable msg
variable canvas_w
variable canvas_h
- variable ll_proj
+ global proj_is_ll
set mapunits [MapCanvas::get_mapunits]
@@ -1091,7 +1245,7 @@
# In Lat/Lon N and S can not be larger than 90!
# FIXME:
#puts "-> n=$n s=$s e=$e w=$w"
- if { $ll_proj } {
if { $n > 90 } {
set n 90
tk_messageBox -type ok -icon warning -parent .mapcan($mon) \
@@ -1125,11 +1279,21 @@
set ewres [lindex $region 5]
if { $nsres == $ewres || $exploremode($mon) } {
- set MapCanvas::regionstr [format [G_msg "Display: rows=%d columns=%d resolution=%g $mapunits"] \
- $rows $cols $nsres]
+ set res_str [MapCanvas::fancy_ll_res $nsres]
+ } else {
+ set res_str [format "%g" $nsres]
+ set MapCanvas::regionstr [format [G_msg "Display: rows=%d columns=%d resolution=%s\
+ $mapunits"] $rows $cols $res_str]
} else {
- set MapCanvas::regionstr [format [G_msg "Display: rows=%d cols=%d N-S res=%g E-W res=%g"] \
- $rows $cols $nsres $ewres]
+ set MapCanvas::regionstr [format [G_msg "Display: rows=%d cols=%d N-S res=%s E-W res=%s"] \
+ $rows $cols [MapCanvas::fancy_ll_res $nsres] [MapCanvas::fancy_ll_res $ewres]]
+ } else {
+ set MapCanvas::regionstr [format [G_msg "Display: rows=%d cols=%d N-S res=%g E-W res=%g"] \
+ $rows $cols $nsres $ewres]
set MapCanvas::msg($mon) $regionstr
@@ -1299,6 +1463,7 @@
variable areaY2
variable msg
global outfmt_coords
+ global proj_is_ll
# initialize zoom rectangle corners
@@ -1324,8 +1489,14 @@
set scrxmov %x
set scrymov %y
+ } else {
MapCanvas::drawzoom $mon %x %y
@@ -1546,6 +1717,7 @@
variable can
variable msg
+ global proj_is_ll
set MapCanvas::msg($mon) [G_msg "Drag with mouse to pan"]
@@ -1558,8 +1730,15 @@
set scrxmov %x
set scrymov %y
+ set eastcoord [format $outfmt_coords [eval MapCanvas::scrx2mape $mon %x] ]
+ } else {
MapCanvas::dragpan $mon %x %y
@@ -1687,10 +1866,16 @@
set scrxmov %x
set scrymov %y
+ } else {
MapCanvas::drawmline $mon %x %y
bind $can($mon) <ButtonRelease-1> "MapCanvas::measure $mon %x %y"
set MapCanvas::msg($mon) [G_msg "Draw measure line with mouse"]
