[GRASS-SVN] r37729 - grass/branches/releasebranch_6_4/gui/tcltk/gis.m
Wed Jun 3 23:01:07 EDT 2009
Author: hamish
Date: 2009-06-03 23:01:07 -0400 (Wed, 03 Jun 2009)
New Revision: 37729
   grass/branches/releasebranch_6_4/gui/tcltk/gis.m/mapcanvas.tcl
trim unused zeros from resolution string (merge from devbr6)
Modified: grass/branches/releasebranch_6_4/gui/tcltk/gis.m/mapcanvas.tcl
--- grass/branches/releasebranch_6_4/gui/tcltk/gis.m/mapcanvas.tcl	2009-06-04 02:59:43 UTC (rev 37728)
+++ grass/branches/releasebranch_6_4/gui/tcltk/gis.m/mapcanvas.tcl	2009-06-04 03:01:07 UTC (rev 37729)
@@ -115,7 +115,7 @@
 	# proj_is_ll is 1 for a Lat/Lon projection, 0 otherwise
 	global proj_is_ll
-	# DMS format: 0 is ddd.ddddd,  1 is ddd:mm.mmmmm', 2 is ddd:mm'ss.sss"
+	# DMS format: 0 is ddd.dddddd,  1 is ddd:mm.mmmm', 2 is ddd:mm'ss.sss"
 	global dms_format
 	# string with region information to show in status bar
@@ -183,6 +183,7 @@
 # FIXME:  make this settable from the UI or use GRASS_DMS_FORMAT enviro var
 	set dms_format 2
 	# Make sure that we are using the WIND file for everything except displays
@@ -1108,7 +1109,11 @@
 		set res_str [format "%.6g" $res]
 	    1 {
-		set res_str [format "%.0f\xB0%02.4g'" $deg_d $min_f ]
+		if { $min_f == 0 } {
+			set res_str [format "%.0f\xB0" $deg_d ]
+		} else {
+			set res_str [format "%.0f\xB0%02.4g'" $deg_d $min_f ]
 	    2 {
 		# 'g.region -g' doesn't report enough sig digs for LL so we get rounding errors!
@@ -1117,8 +1122,13 @@
 		    set sec_f "0"
-		set res_str [format "%.0f\xB0%02.0f'%02.3g\"" \
-			$deg_d $min_d $sec_f ]
+		if { $sec_f != 0 } {
+			set res_str [format "%.0f\xB0%02.0f'%02.3g\"" $deg_d $min_d $sec_f ]
+		} elseif { $min_d != 0 } {
+			set res_str [format "%.0f\xB0%02.0f'" $deg_d $min_d ]
+		} else {
