[GRASS-SVN] r37746 -
grass/branches/releasebranch_6_4/swig/include/python
svn_grass at osgeo.org
Sat Jun 6 01:18:41 EDT 2009
Author: neteler
Date: 2009-06-06 01:18:40 -0400 (Sat, 06 Jun 2009)
New Revision: 37746
grass/branches/releasebranch_6_4/swig/include/python/my_typemaps.i
Add typemaps for char** and void** (merge from trunk, r37741)
Modified: grass/branches/releasebranch_6_4/swig/include/python/my_typemaps.i
--- grass/branches/releasebranch_6_4/swig/include/python/my_typemaps.i 2009-06-06 05:15:37 UTC (rev 37745)
+++ grass/branches/releasebranch_6_4/swig/include/python/my_typemaps.i 2009-06-06 05:18:40 UTC (rev 37746)
@@ -143,6 +143,9 @@
void *buffer;
Py_ssize_t len;
+ if (input == Py_None)
+ return NULL;
if (PyCObject_Check(input))
return PyCObject_AsVoidPtr(input);
@@ -152,6 +155,9 @@
if (PyObject_AsReadBuffer(input, &cbuffer, &len) == 0)
return (void *) cbuffer;
+ if (PyString_Check(input) && strchr("cbB", data_type))
+ return (void *) PyString_AsString(input);
return pyseq_to_ptr(input, data_type);
@@ -169,4 +175,70 @@
$1 = (DCELL *) pyobj_to_ptr($input, 'd');
+static void **pyseq_to_ptr_ptr(PyObject *input, int data_type) __attribute__ ((unused));
+static void **pyobj_to_ptr_ptr(PyObject *input, int data_type) __attribute__ ((unused));
+ Py_ssize_t len;
+ void **array;
+ int i;
+ if (!PySequence_Check(input)) {
+ PyErr_SetString(PyExc_ValueError,"Expected a CObject, buffer or sequence");
+ return NULL;
+ len = PySequence_Length(input);
+ array = malloc((len + 1) * sizeof(void *));
+ for (i = 0; i < len; i++) {
+ PyObject *val = PySequence_GetItem(input, i);
+ void *p = pyobj_to_ptr(val, data_type);
+ Py_DECREF(val);
+ if (val != Py_None && p == NULL) {
+ PyErr_SetString(PyExc_ValueError,"Unable to convert element to pointer");
+ free(array);
+ return NULL;
+ array[i] = p;
+ array[i] = NULL;
+ return array;
+ const void *cbuffer;
+ void *buffer;
+ Py_ssize_t len;
+ if (PyCObject_Check(input))
+ return (void **) PyCObject_AsVoidPtr(input);
+ if (PyObject_AsWriteBuffer(input, &buffer, &len) == 0)
+ return (void **) buffer;
+ if (PyObject_AsReadBuffer(input, &cbuffer, &len) == 0)
+ return (void **) cbuffer;
+ return pyseq_to_ptr_ptr(input, data_type);
+%typemap(in) void ** {
+ $1 = pyobj_to_ptr_ptr($input, 'c');
+%typemap(in) char ** {
+ $1 = (char **) pyobj_to_ptr_ptr($input, 'c');
#endif
