[GRASS-SVN] r37764 - grass/trunk/raster/r.out.gdal
svn_grass at osgeo.org
Sat Jun 6 12:54:52 EDT 2009
Author: mmetz
Date: 2009-06-06 12:54:52 -0400 (Sat, 06 Jun 2009)
New Revision: 37764
grass/trunk/raster/r.out.gdal/main.c
updated warning on nodata value conversion
Modified: grass/trunk/raster/r.out.gdal/main.c
--- grass/trunk/raster/r.out.gdal/main.c 2009-06-06 16:36:19 UTC (rev 37763)
+++ grass/trunk/raster/r.out.gdal/main.c 2009-06-06 16:54:52 UTC (rev 37764)
@@ -33,7 +33,7 @@
#include "local_proto.h"
int range_check(double, double, GDALDataType);
-int nodataval_check(double, GDALDataType);
+int nodataval_check(double *, GDALDataType);
double set_default_nodata_value(GDALDataType, double, double);
void supported_formats(const char **formats)
@@ -475,11 +475,8 @@
nodataval = atof(nodataopt->answer);
default_nodataval = 0;
/* Check if given nodata value can be represented by selected GDAL datatype */
- if (nodataval_check(nodataval, datatype)) {
- if (flag_f->answer)
- G_warning(_("Forcing raster export."));
- else
- G_fatal_error(_("Raster export aborted."));
+ if (nodataval_check(&nodataval, datatype)) {
+ G_warning(_("Nodata value converted to %f"), nodataval);
/* Set reasonable default nodata value */
@@ -702,31 +699,33 @@
-int nodataval_check(double nodataval, GDALDataType datatype)
+int nodataval_check(double *nodataval, GDALDataType datatype)
switch (datatype) {
case GDT_Byte:
- if (nodataval != (double)(GByte) nodataval) {
+ if (*nodataval != (double)(GByte) *nodataval) {
G_warning(_("Mismatch between metadata nodata value and actual nodata value in exported raster: "
"specified nodata value %f gets converted to %d by selected GDAL datatype."),
- nodataval, (GByte) nodataval);
+ *nodataval, (GByte) *nodataval);
G_warning(_("GDAL datatype: %s, range: %d - %d"),
GDALGetDataTypeName(datatype), TYPE_BYTE_MIN,
TYPE_BYTE_MAX);
+ *nodataval = (double)(GByte) *nodataval;
return 1;
else
return 0;
case GDT_UInt16:
- if (nodataval != (double)(GUInt16) nodataval) {
+ if (*nodataval != (double)(GUInt16) *nodataval) {
- nodataval, (GUInt16) nodataval);
+ *nodataval, (GUInt16) *nodataval);
GDALGetDataTypeName(datatype), TYPE_UINT16_MIN,
TYPE_UINT16_MAX);
+ *nodataval = (double)(GUInt16) *nodataval;
return 1;
else
@@ -734,26 +733,28 @@
case GDT_Int16:
case GDT_CInt16:
- if (nodataval != (double)(GInt16) nodataval) {
+ if (*nodataval != (double)(GInt16) *nodataval) {
- nodataval, (GInt16) nodataval);
+ *nodataval, (GInt16) *nodataval);
GDALGetDataTypeName(datatype), TYPE_INT16_MIN,
TYPE_INT16_MAX);
+ *nodataval = (double)(GInt16) *nodataval;
return 1;
else
return 0;
case GDT_UInt32:
- if (nodataval != (double)(GUInt32) nodataval) {
+ if (*nodataval != (double)(GUInt32) *nodataval) {
- nodataval, (GUInt32) nodataval);
+ *nodataval, (GUInt32) *nodataval);
G_warning(_("GDAL datatype: %s, range: %u - %u"),
GDALGetDataTypeName(datatype), TYPE_UINT32_MIN,
TYPE_UINT32_MAX);
+ *nodataval = (double)(GUInt32) *nodataval;
return 1;
else
@@ -761,13 +762,14 @@
case GDT_Int32:
case GDT_CInt32:
- if (nodataval != (double)(GInt32) nodataval) {
+ if (*nodataval != (double)(GInt32) *nodataval) {
- nodataval, (GInt32) nodataval);
+ *nodataval, (GInt32) *nodataval);
GDALGetDataTypeName(datatype), TYPE_INT32_MIN,
TYPE_INT32_MAX);
+ *nodataval = (double)(GInt32) *nodataval;
return 1;
else
@@ -775,13 +777,14 @@
case GDT_Float32:
case GDT_CFloat32:
- if (nodataval != (double)(float)nodataval) {
+ if (*nodataval != (double)(float) *nodataval) {
"specified nodata value %f gets converted to %f by selected GDAL datatype."),
- nodataval, (float)nodataval);
+ *nodataval, (float) *nodataval);
G_warning(_("GDAL datatype: %s, range: %g - %g"),
GDALGetDataTypeName(datatype), TYPE_FLOAT32_MIN,
TYPE_FLOAT32_MAX);
+ *nodataval = (double)(float) *nodataval;
return 1;
else
