[GRASS-SVN] r37774 -
grass/branches/develbranch_6/swig/include/python
svn_grass at osgeo.org
Sun Jun 7 11:13:55 EDT 2009
Author: neteler
Date: 2009-06-07 11:13:55 -0400 (Sun, 07 Jun 2009)
New Revision: 37774
grass/branches/develbranch_6/swig/include/python/my_typemaps.i
Add typemaps for numeric arrays (merge from trunk, r37773)
Modified: grass/branches/develbranch_6/swig/include/python/my_typemaps.i
--- grass/branches/develbranch_6/swig/include/python/my_typemaps.i 2009-06-07 11:50:17 UTC (rev 37773)
+++ grass/branches/develbranch_6/swig/include/python/my_typemaps.i 2009-06-07 15:13:55 UTC (rev 37774)
@@ -149,14 +149,16 @@
if (PyCObject_Check(input))
return PyCObject_AsVoidPtr(input);
+ if (PyString_Check(input) && strchr("cbB", data_type))
+ return (void *) PyString_AsString(input);
if (PyObject_AsWriteBuffer(input, &buffer, &len) == 0)
return buffer;
if (PyObject_AsReadBuffer(input, &cbuffer, &len) == 0)
return (void *) cbuffer;
- if (PyString_Check(input) && strchr("cbB", data_type))
- return (void *) PyString_AsString(input);
+ PyErr_Clear();
return pyseq_to_ptr(input, data_type);
@@ -175,6 +177,54 @@
$1 = (DCELL *) pyobj_to_ptr($input, 'd');
+%typemap(in) signed char * {
+ $1 = (signed char *) pyobj_to_ptr($input, 'b');
+%typemap(in) unsigned char * {
+ $1 = (unsigned char *) pyobj_to_ptr($input, 'B');
+%typemap(in) signed short * {
+ $1 = (signed short *) pyobj_to_ptr($input, 'h');
+%typemap(in) unsigned short * {
+ $1 = (unsigned short *) pyobj_to_ptr($input, 'H');
+%typemap(in) int * {
+ $1 = (int *) pyobj_to_ptr($input, 'i');
+%typemap(in) signed int * {
+%typemap(in) unsigned int * {
+ $1 = (int *) pyobj_to_ptr($input, 'I');
+%typemap(in) long * {
+ $1 = (long *) pyobj_to_ptr($input, 'l');
+%typemap(in) signed long * {
+%typemap(in) unsigned long * {
+ $1 = (long *) pyobj_to_ptr($input, 'L');
+%typemap(in) float * {
+ $1 = (float *) pyobj_to_ptr($input, 'f');
+%typemap(in) double * {
+ $1 = (double *) pyobj_to_ptr($input, 'd');
static void **pyseq_to_ptr_ptr(PyObject *input, int data_type) __attribute__ ((unused));
