[GRASS-SVN] r37788 - grass/trunk/include
svn_grass at osgeo.org
Tue Jun 9 12:59:45 EDT 2009
Author: mmetz
Date: 2009-06-09 12:59:45 -0400 (Tue, 09 Jun 2009)
New Revision: 37788
grass/trunk/include/Vect.h
new cleaning tool, header
Modified: grass/trunk/include/Vect.h
--- grass/trunk/include/Vect.h 2009-06-09 14:59:11 UTC (rev 37787)
+++ grass/trunk/include/Vect.h 2009-06-09 16:59:45 UTC (rev 37788)
@@ -317,6 +317,7 @@
void Vect_break_lines(struct Map_info *, int, struct Map_info *);
int Vect_break_lines_list(struct Map_info *, struct ilist *, struct ilist *,
+int Vect_merge_lines(struct Map_info *, int, int *, struct Map_info *);
void Vect_break_polygons(struct Map_info *, int, struct Map_info *);
void Vect_remove_duplicates(struct Map_info *, int, struct Map_info *);
int Vect_line_check_duplicate(const struct line_pnts *,
