[GRASS-SVN] r37809 - in grass/trunk: gui/wxpython/support
gui/wxpython/xml raster/r.support.stats raster/r.terraflow
raster/r.water.outlet
svn_grass at osgeo.org
Wed Jun 10 16:01:45 EDT 2009
Author: martinl
Date: 2009-06-10 16:01:45 -0400 (Wed, 10 Jun 2009)
New Revision: 37809
grass/trunk/gui/wxpython/support/update_menudata.py
grass/trunk/gui/wxpython/xml/menudata.xml
grass/trunk/raster/r.support.stats/main.c
grass/trunk/raster/r.terraflow/main.cc
grass/trunk/raster/r.water.outlet/main.c
Add missing keywords
Update menu (remove disabled modules)
Modified: grass/trunk/gui/wxpython/support/update_menudata.py
--- grass/trunk/gui/wxpython/support/update_menudata.py 2009-06-10 18:03:00 UTC (rev 37808)
+++ grass/trunk/gui/wxpython/support/update_menudata.py 2009-06-10 20:01:45 UTC (rev 37809)
@@ -57,16 +57,24 @@
def updateData(data, modules):
"""!Update menu data tree"""
+ # list of modules to be ignored
+ ignore = [ 'v.type_wrapper.py',
+ 'vcolors' ]
for node in data.tree.getiterator():
if node.tag != 'menuitem':
continue
item = dict()
for child in node.getchildren():
item[child.tag] = child.text
if not item.has_key('command'):
continue
+ if item['command'] in ignore:
+ continue
module = item['command'].split(' ')[0]
if not modules.has_key(module):
@@ -86,7 +94,11 @@
def writeData(data):
"""!Write updated menudata.xml"""
file = os.path.join('..', 'xml', 'menudata.xml')
- data.tree.write(file)
+ try:
+ data.tree.write(file)
+ except IOError:
+ print >> sys.stderr, "'menudata.xml' not found. Please run the script from 'gui/wxpython/support'."
def main(argv = None):
if argv is None:
@@ -113,7 +125,7 @@
print >> sys.stderr, "You must be in GRASS GIS to run this program."
sys.exit(1)
- sys.path.append('../gui_modules')
+ sys.path.append(os.path.join(os.getenv("GISBASE"), 'etc', 'wxpython', 'gui_modules'))
import menudata
import menuform
import globalvar
Modified: grass/trunk/gui/wxpython/xml/menudata.xml
--- grass/trunk/gui/wxpython/xml/menudata.xml 2009-06-10 18:03:00 UTC (rev 37808)
+++ grass/trunk/gui/wxpython/xml/menudata.xml 2009-06-10 20:01:45 UTC (rev 37809)
@@ -591,7 +591,7 @@
<separator />
<menuitem>
<label>NVIZ (requires Tcl/Tk)</label>
- <help>nviz - Visualization and animation tool for GRASS data</help>
+ <help>nviz - Visualization and animation tool for GRASS data.</help>
<handler>self.OnMenuCmd</handler>
<command>nviz</command>
</menuitem>
@@ -1133,19 +1133,6 @@
</menuitem>
<separator />
<menuitem>
- <label>SIMWE Overland flow modeling</label>
- <help>Overland flow hydrologic simulation using path sampling method (SIMWE)</help>
- <handler>self.OnMenuCmd</handler>
- <command>r.sim.water</command>
- </menuitem>
- <menuitem>
- <label>SIMWE Sediment flux modeling</label>
- <help>Sediment transport and erosion/deposition simulation using path sampling method (SIMWE)</help>
- <command>r.sim.sediment</command>
- </menuitem>
- <separator />
- <menuitem>
<label>Topographic index map</label>
<help>Creates topographic index [ln(a/tan(beta))] map from elevation map.</help>
<keywords>raster</keywords>
@@ -1198,30 +1185,6 @@
</items>
</menu>
<menu>
- <label>Landscape structure modeling</label>
- <items>
- <menuitem>
- <label>Analyze landscape</label>
- <help>Contains a set of measures for attributes, diversity, texture, juxtaposition, and edge.</help>
- <command>r.le.pixel</command>
- </menuitem>
- <menuitem>
- <label>Analyze patches</label>
- <help>Calculates attribute, patch size, core (interior) size, shape, fractal dimension, and perimeter measures for sets of patches in a landscape.</help>
- <command>r.le.patch</command>
- </menuitem>
- <menuitem>
- <label>Output</label>
- <help>Displays the boundary of each r.le patch and shows how the boundary is traced, displays the attribute, size, perimeter and shape indices for each patch and saves the data in an output file.</help>
- <command>r.le.trace</command>
- </menuitem>
- </items>
- </menu>
- <menu>
<label>Landscape patch analysis</label>
<items>
<menuitem>
@@ -1395,12 +1358,6 @@
<handler>self.RulesCmd</handler>
<command>r.recode</command>
</menuitem>
- <menuitem>
- <label>Recode using rules file</label>
- <help>r.recode.rules - Use ascii rules file to recode categories in raster map</help>
- <command>r.recode.file</command>
- </menuitem>
<separator />
<menuitem>
<label>Rescale</label>
@@ -1506,12 +1463,6 @@
<label>Interpolate surfaces</label>
<items>
<menuitem>
- <label>Bilinear from raster points</label>
- <help>Bilinear interpolation utility for raster map layers.</help>
- <command>r.bilinear</command>
- </menuitem>
- <menuitem>
<label>Bilinear and bicubic from vector points</label>
<help>Bicubic or bilinear spline interpolation with Tykhonov regularization.</help>
<keywords>vector,interpolation</keywords>
@@ -1599,12 +1550,6 @@
<command>r.describe</command>
</menuitem>
<menuitem>
- <label>Sum category values</label>
- <help>Sums up the raster cell values.</help>
- <command>r.sum</command>
- </menuitem>
- <menuitem>
<label>Sum area by raster map and category</label>
<help>Reports statistics for raster map layers.</help>
<keywords>raster,statistics</keywords>
@@ -2372,12 +2317,6 @@
<command>i.zc</command>
</menuitem>
- <menuitem>
- <label>Matrix/convolving filter</label>
- <help>Raster map matrix filter.</help>
- <command>r.mfilter.fp</command>
- </menuitem>
</items>
</menu>
<menuitem>
Modified: grass/trunk/raster/r.support.stats/main.c
--- grass/trunk/raster/r.support.stats/main.c 2009-06-10 18:03:00 UTC (rev 37808)
+++ grass/trunk/raster/r.support.stats/main.c 2009-06-10 20:01:45 UTC (rev 37809)
@@ -35,6 +35,7 @@
module = G_define_module();
module->description = _("Update raster map statistics");
+ module->keywords = _("raster, statistics");
parm.raster = G_define_standard_option(G_OPT_R_MAP);
Modified: grass/trunk/raster/r.terraflow/main.cc
--- grass/trunk/raster/r.terraflow/main.cc 2009-06-10 18:03:00 UTC (rev 37808)
+++ grass/trunk/raster/r.terraflow/main.cc 2009-06-10 20:01:45 UTC (rev 37809)
@@ -450,6 +450,7 @@
#ifdef ELEV_FLOAT
module->description = _("Flow computation for massive grids (Float version).");
#endif
+ module->keywords = _("raster");
/* read user options; fill in global <opt> */
opt = (userOptions*)malloc(sizeof(userOptions));
Modified: grass/trunk/raster/r.water.outlet/main.c
--- grass/trunk/raster/r.water.outlet/main.c 2009-06-10 18:03:00 UTC (rev 37808)
+++ grass/trunk/raster/r.water.outlet/main.c 2009-06-10 20:01:45 UTC (rev 37809)
@@ -61,7 +61,8 @@
module->description = _("Watershed basin creation program.");
opt1 = G_define_option();
opt1->key = "drainage";
opt1->type = TYPE_STRING;
@@ -138,7 +139,7 @@
for (row = 0; row < nrows; row++) {
G_get_map_row(drain_fd, cell_buf, row);
for (col = 0; col < ncols; col++) {
- if (cell_buf[col] == 0)
+ if (cell_buf[col] == 0)
total--;
drain_ptrs[SEG_INDEX(pt_seg, row, col)] = cell_buf[col];
