[GRASS-SVN] r37820 - grass/trunk/scripts/v.colors
svn_grass at osgeo.org
Thu Jun 11 09:59:35 EDT 2009
Author: glynn
Date: 2009-06-11 09:59:34 -0400 (Thu, 11 Jun 2009)
New Revision: 37820
grass/trunk/scripts/v.colors/v.colors.py
Use temporary file to avoid deadlock
Modified: grass/trunk/scripts/v.colors/v.colors.py
--- grass/trunk/scripts/v.colors/v.colors.py 2009-06-11 13:07:54 UTC (rev 37819)
+++ grass/trunk/scripts/v.colors/v.colors.py 2009-06-11 13:59:34 UTC (rev 37820)
@@ -252,8 +252,8 @@
# calculate colors and write SQL command file
grass.message("Looking up colors ...")
- p = grass.start_command('r.what.color', flags = 'i', input = tmp_colr,
- stdin = grass.PIPE, stdout = grass.PIPE)
+ f = open(tmp, 'w')
+ p = grass.feed_command('r.what.color', flags = 'i', input = tmp_colr, stdout = f)
lastval = None
for v in sorted(cvals):
if v == lastval:
@@ -261,20 +261,23 @@
p.stdin.write('%f\n' % v)
p.stdin.close()
p.wait()
+ f.close()
tmp_vcol = "%s_vcol.sql" % tmp
- f = open(tmp_vcol, 'w')
+ fi = open(tmp, 'r')
+ fo = open(tmp_vcol, 'w')
t = string.Template("UPDATE $table SET $rgb_column = '$colr' WHERE $column = $value;\n")
found = 0
- for line in p.stdout:
+ for line in fi:
[value, colr] = line.split(':')
colr = colr.strip()
if len(colr.split(':')) != 3:
continue
#g.message message="LINE=[$LINE]"
- f.write(t.substitute(table = table, rgb_column = rgb_column, colr = colr, value = value))
+ fo.write(t.substitute(table = table, rgb_column = rgb_column, colr = colr, value = value))
found += 1
- f.close()
+ fi.close()
+ fo.close()
if not found:
grass.fatal("No values found in color range")
