[GRASS-SVN] r37822 - grass-addons/vector/v.autokrige2
svn_grass at osgeo.org
Thu Jun 11 10:30:13 EDT 2009
Author: aghisla
Date: 2009-06-11 10:30:13 -0400 (Thu, 11 Jun 2009)
New Revision: 37822
grass-addons/vector/v.autokrige2/v.autokrige2.py
added autofit variogram functionality on specific dataset -
proof-of-concept. Works!
Modified: grass-addons/vector/v.autokrige2/v.autokrige2.py
--- grass-addons/vector/v.autokrige2/v.autokrige2.py 2009-06-11 14:27:26 UTC (rev 37821)
+++ grass-addons/vector/v.autokrige2/v.autokrige2.py 2009-06-11 14:30:13 UTC (rev 37822)
@@ -26,10 +26,11 @@
except ImportError:
print "Rpy2 not found. Please install it and re-run."
-#@TODO(anne): why not check all dependencies at the beginning?
+#@TODO(anne): why not check all dependencies and data at the beginning?
# a nice splash screen like QGIS does can fit the purpose, with a log message on the bottom and
-# popup windows for missing dependencies messages.
-# For the moment, deps are checked when creating the notebook pages for each package.
+# popup windows for missing stuff messages.
+# For the moment, deps are checked when creating the notebook pages for each package, and the
+# data availability when clicking Run button. Quite late.
#global variables
gisenv = grass.gisenv()
@@ -58,29 +59,61 @@
self.RPackagesBook = RPackagesBook(parent= self)
KrigingSizer.Add(self.RPackagesBook, wx.EXPAND)
+# 3. Run Button
+ RunButton = wx.Button(self, -1, 'Run')
+ RunButton.Bind(wx.EVT_BUTTON, self.OnRunButton)
# Main Sizer. Add each child sizer as soon as it is ready.
Sizer = wx.BoxSizer(wx.VERTICAL)
Sizer.Add(InputBoxSizer, 0, wx.EXPAND, 5)
Sizer.Add(KrigingSizer, 0, wx.EXPAND, 5)
+ Sizer.Add(RunButton, 0, wx.ALIGN_RIGHT, 5)
self.SetSizerAndFit(Sizer)
def __getVectors(self, *args, **kwargs):
"""Get list of tables for given location and mapset"""
vectors = grass.list_grouped('vect')[gisenv['MAPSET']]
#@WARNING: this cycle is quite time-consuming.
# see if it is possible to postpone this filtering, and immediately show the dialog.
- for n in vectors:
- if grass.vector_info_topo(n)['points'] == 0:
- vectors.remove(n)
if vectors == []:
wx.MessageBox(parent=self,
message=("No vector maps available. Check if the location is correct."),
+ caption=("Missing Input Data"), style=wx.OK | wx.ICON_ERROR | wx.CENTRE)
+ pointVectors = []
+ for n in vectors:
+ if grass.vector_info_topo(n)['points'] > 0:
+ pointVectors.append(n)
+ if pointVectors == []:
+ wx.MessageBox(parent=self,
+ message=("No point vector maps available. Check if the location is correct."),
- return sorted(vectors)
+ return sorted(pointVectors)
+ def OnRunButton(self,event):
+ """ Execute R analysis. """
+ #0. require packages. See creation of the notebook pages and note after import directives.
+ #1. get the data in R format, i.e. SpatialPointsDataFrame
+ self.InputData = robjects.r.readVECT6(self.InputDataChoicebox.GetStringSelection(), type= 'point')
+ #2. collect options
+ #@TODO(anne): let user pick up the column name from a list.
+ self.Column = 'elev'
+ #3. Fit variogram
+ self.parent.log.write('Variogram fitting')
+ self.Formula = robjects.r['as.formula'](robjects.r.paste(self.Column, "~ 1"))
+ self.Variogram= robjects.r.autofitVariogram(self.Formula, self.InputData)
+ # print variogram somehow
+ robjects.r.plot(self.Variogram)
+ self.parent.log.write('Variogram fitted.')
+ #4. Kriging
+ #5. Format output
+ pass
class KrigingModule(wx.Frame):
Kriging module for GRASS GIS. Depends on R and its packages gstat and geoR.
@@ -139,14 +172,12 @@
self.KrigingList = ["Ordinary kriging"]
KrigingRadioBox = wx.RadioBox(self.AutomapPanel, -1, "Kriging techniques", (-1,-1), wx.DefaultSize,
self.KrigingList, 1, wx.RA_SPECIFY_COLS)
- RunButton = wx.Button(self.AutomapPanel, -1, 'Run')
- RunButton.Bind(wx.EVT_BUTTON, self.OnRunButton)
Sizer.Add(VariogramRadioBox, 0, wx.EXPAND, 5)
Sizer.Add(KrigingRadioBox, 0, wx.EXPAND, 5)
- Sizer.Add(RunButton, 0, wx.ALIGN_RIGHT, 5)
self.AutomapPanel.SetSizerAndFit(Sizer)
else:
pass
@@ -181,26 +212,8 @@
columns.append(column)
return columns
- def OnRunButton(self,event):
- """ Execute R analysis. """
- #0. require packages. See creation of the notebook pages and note after import directives.
- #1. get the data in R format, i.e. SpatialPointsDataFrame
- MapName = []
- InputDataPath = os.path.join(gisenv['GISDBASE'],gisenv['LOCATION_NAME'],gisenv['MAPSET'],
- MapName)
- InputData = robjects.r.readVECT6(InputDataPath)
- print type(InputData)
- #2. collect options
- #3. Autofit variogram
-# KrigingResult = robjects.r.autoKrige("column~1", InputData)
- #4. Autokriging
- #5. Format output
- pass
#main
def main(argv=None):
if argv is None:
