[GRASS-SVN] r37850 - grass-addons/imagery/i.landsat.toar
svn_grass at osgeo.org
Fri Jun 12 12:28:13 EDT 2009
Author: ejtizado
Date: 2009-06-12 12:28:13 -0400 (Fri, 12 Jun 2009)
New Revision: 37850
grass-addons/imagery/i.landsat.toar/landsat_set.c
NLAPS product after 2004/04/04 change qcalmin of TM5
Modified: grass-addons/imagery/i.landsat.toar/landsat_set.c
--- grass-addons/imagery/i.landsat.toar/landsat_set.c 2009-06-12 15:43:51 UTC (rev 37849)
+++ grass-addons/imagery/i.landsat.toar/landsat_set.c 2009-06-12 16:28:13 UTC (rev 37850)
@@ -54,7 +54,7 @@
lsat->band[i].wavemax = *(wmax + i);
lsat->band[i].wavemin = *(wmin + i);
lsat->band[i].qcalmax = 255.;
- lsat->band[i].qcalmin = 0.;
+ lsat->band[i].qcalmin = 0.; /* modified in set_TM5 by date */
lsat->band[i].thermal = (lsat->band[i].number == 6 ? 1 : 0);
return;
@@ -338,7 +338,7 @@
void set_TM5(lsat_data * lsat)
int i, j;
- double julian, *lmax, *lmin;
+ double julian, *lmax, *lmin, jbuf;
/** Gyanesh Chander and Brian Markham.
IEEE Transactions On Geoscience And Remote Sensing, Vol. 41, No. 11, November 2003 */
@@ -362,8 +362,8 @@
lmax = Lmax[i];
lmin = Lmin[i];
if ( i == 2 ) { /* in Chander, Markham and Barsi 2007 */
- julian = julian_char(lsat->date); /* Yes, here acquisition date */
- if (julian >= julian_char("1992-01-01")) {
+ jbuf = julian_char(lsat->date); /* Yes, here acquisition date */
+ if (jbuf >= julian_char("1992-01-01")) {
lmax[0] = 193.0;
lmax[1] = 365.0;
@@ -371,15 +371,22 @@
lsat->number = 5;
sensor_TM( lsat );
+ jbuf = julian_char("2004-04-04");
+ if (julian >= jbuf) {
+ G_warning("Using QCalMin=1.0 as NLAPS products processed after 4/4/2004");
lsat->dist_es = earth_sun(lsat->date);
- for (i = 0; i < lsat->bands; i++) {
+ for (i = 0; i < lsat->bands; i++)
j = lsat->band[i].number - 1;
- lsat->band[i].esun = *(esun + j);
- lsat->band[i].lmax = *(lmax + j);
- lsat->band[i].lmin = *(lmin + j);
- if (lsat->band[i].thermal ) {
+ lsat->band[i].qcalmin = 1.;
+ lsat->band[i].esun = *(esun + j);
+ lsat->band[i].lmax = *(lmax + j);
+ lsat->band[i].lmin = *(lmin + j);
+ if (lsat->band[i].thermal ) {
lsat->band[i].K1 = 607.76;
lsat->band[i].K2 = 1260.56;
