[GRASS-SVN] r37876 - in
grass/branches/develbranch_6/gui/tcltk/gis.m: . docs
svn_grass at osgeo.org
Sat Jun 13 23:28:59 EDT 2009
Author: hamish
Date: 2009-06-13 23:28:59 -0400 (Sat, 13 Jun 2009)
New Revision: 37876
grass/branches/develbranch_6/gui/tcltk/gis.m/docs/gm_animate.html
grass/branches/develbranch_6/gui/tcltk/gis.m/docs/gm_georect.html
grass/branches/develbranch_6/gui/tcltk/gis.m/docs/gm_profile.html
grass/branches/develbranch_6/gui/tcltk/gis.m/gmmenu.tcl
grass/branches/develbranch_6/gui/tcltk/gis.m/runandoutput.tcl
(partial) fix for when $GISBASE includes a space (merge from relbr64)
Modified: grass/branches/develbranch_6/gui/tcltk/gis.m/docs/gm_animate.html
--- grass/branches/develbranch_6/gui/tcltk/gis.m/docs/gm_animate.html 2009-06-14 03:23:42 UTC (rev 37875)
+++ grass/branches/develbranch_6/gui/tcltk/gis.m/docs/gm_animate.html 2009-06-14 03:28:59 UTC (rev 37876)
@@ -8,6 +8,7 @@
<body bgcolor="white">
+<!-- meta page description: ANIMATION TOOL (gis.m) -->
<h2>ANIMATION TOOL (gis.m)</h2>
The Animation Tool is an interactive interface to display a series of
Modified: grass/branches/develbranch_6/gui/tcltk/gis.m/docs/gm_georect.html
--- grass/branches/develbranch_6/gui/tcltk/gis.m/docs/gm_georect.html 2009-06-14 03:23:42 UTC (rev 37875)
+++ grass/branches/develbranch_6/gui/tcltk/gis.m/docs/gm_georect.html 2009-06-14 03:28:59 UTC (rev 37876)
@@ -7,6 +7,7 @@
</head>
+<!-- meta page description: GEORECTIFY TOOL (gis.m) -->
<h2>GEORECTIFY TOOL (gis.m)</h2>
In order to use and overlay different forms of geospatial data in a
Modified: grass/branches/develbranch_6/gui/tcltk/gis.m/docs/gm_profile.html
--- grass/branches/develbranch_6/gui/tcltk/gis.m/docs/gm_profile.html 2009-06-14 03:23:42 UTC (rev 37875)
+++ grass/branches/develbranch_6/gui/tcltk/gis.m/docs/gm_profile.html 2009-06-14 03:28:59 UTC (rev 37876)
@@ -7,6 +7,7 @@
</head>
+<!-- meta page description: PROFILE TOOL (gis.m) -->
<h2>PROFILE TOOL (gis.m)</h2>
The Profile Tool will draw a 2-dimensional profile of the surface of
Modified: grass/branches/develbranch_6/gui/tcltk/gis.m/gmmenu.tcl
--- grass/branches/develbranch_6/gui/tcltk/gis.m/gmmenu.tcl 2009-06-14 03:23:42 UTC (rev 37875)
+++ grass/branches/develbranch_6/gui/tcltk/gis.m/gmmenu.tcl 2009-06-14 03:28:59 UTC (rev 37876)
@@ -435,7 +435,7 @@
{command {[G_msg "Clean vector"]} {} "v.clean: Clean vector objects" {} -command {execute v.clean }}
{command {[G_msg "Smooth or simplify"]} {} "v.generalize: Smooth or simplify lines and boundaries (reduce vertices)" {} -command {execute v.generalize }}
{separator}
- {command {[G_msg "Convert object types"]} {} "v.type: Convert vector objects from one feature type to another" {} -command {execute $env(GISBASE)/etc/gui/scripts/v.type_wrapper.sh }}
+ {command {[G_msg "Convert object types"]} {} "v.type: Convert vector objects from one feature type to another" {} -command {execute "$env(GISBASE)/etc/gui/scripts/v.type_wrapper.sh" }}
{separator}
{command {[G_msg "Add centroids"]} {} "v.centroids: Add centroids to closed boundaries to create areas" {} -command {execute v.centroids }}
{separator}
Modified: grass/branches/develbranch_6/gui/tcltk/gis.m/runandoutput.tcl
--- grass/branches/develbranch_6/gui/tcltk/gis.m/runandoutput.tcl 2009-06-14 03:23:42 UTC (rev 37875)
+++ grass/branches/develbranch_6/gui/tcltk/gis.m/runandoutput.tcl 2009-06-14 03:28:59 UTC (rev 37876)
@@ -72,7 +72,7 @@
set program [lindex $cmd 0]
set code ""
- if {[catch {set code [exec -- $program --tcltk 2> $devnull]} error]} {
+ if {[catch {set code [exec -- "$program" --tcltk 2> $devnull]} error]} {
GmLib::errmsg $error
@@ -170,7 +170,7 @@
proc execute {cmd} {
# Use run and output
- run_ui $cmd
+ run_ui [list $cmd]
