[GRASS-SVN] r37889 - in grass/branches/develbranch_6/gui/wxpython: . gui_modules
Mon Jun 15 14:10:42 EDT 2009
Author: martinl
Date: 2009-06-15 14:10:42 -0400 (Mon, 15 Jun 2009)
New Revision: 37889
   grass/branches/develbranch_6/gui/wxpython/gui_modules/dbm.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/gselect.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp_window.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/vdigit.py
   grass/branches/develbranch_6/gui/wxpython/wxgui.py
Refresh button / auto refresh button for Attribute Table viewer while using wxvdigit (trac #642)
TODO: use AddDataRow() instead, reloading data is very expensive task
      (merge from trunk, r37888)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/dbm.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/dbm.py	2009-06-15 18:06:59 UTC (rev 37888)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/dbm.py	2009-06-15 18:10:42 UTC (rev 37889)
@@ -245,58 +245,14 @@
             record = outFile.readline().replace('\n', '')
             if not record:
                 break
-            self.itemDataMap[i] = []
-            j = 0
-            for value in record.split('|'):
-                if self.columns[columns[j]]['ctype'] != type(''):
-                    try:
-                        ### casting disabled (2009/03)
-                        ### self.itemDataMap[i].append(self.columns[columns[j]]['ctype'](value))
-                        self.itemDataMap[i].append(value)
-                    except ValueError:
-                        self.itemDataMap[i].append(_('Unknown value'))
-                else:
-                    # encode string values
-                    try:
-                        self.itemDataMap[i].append(unicodeValue(value))
-                    except UnicodeDecodeError:
-                        self.itemDataMap[i].append(_("Unable to decode value. "
-                                                     "Set encoding in GUI preferences ('Attributes')."))
-                if keyId > -1 and keyId == j:
-                    try:
-                        cat = self.columns[columns[j]]['ctype'] (value)
-                    except ValueError, e:
-                        cat = -1
-                        wx.MessageBox(parent=self,
-                                      message=_("Error loading attribute data. "
-                                                "Record number: %(rec)d. Unable to convert value '%(val)s' in "
-                                                "key column (%(key)s) to integer.\n\n"
-                                                "Details: %(detail)s") % \
-                                          { 'rec' : i + 1, 'val' : value,
-                                            'key' : keyColumn, 'detail' : e},
-                                      caption=_("Error"),
-                                      style=wx.OK | wx.ICON_ERROR | wx.CENTRE)
-                j += 1
+            self.AddDataRow(i, record, columns, keyId)
-            # insert to table
-            # index = self.InsertStringItem(index=sys.maxint, label=str(self.itemDataMap[i][0]))
-            # for j in range(len(self.itemDataMap[i][1:])):
-            # self.SetStringItem(index=index, col=j+1, label=str(self.itemDataMap[i][j+1]))
-            # self.SetItemData(item=index, data=i)
-            self.itemIndexMap.append(i)
-            if keyId > -1: # load cats only when LoadData() is called first time
-                self.itemCatsMap[i] = cat
             i += 1
             if i >= 100000:
                 self.log.write(_("Limit 100000 records."))
                 break
         self.SetItemCount(i)
         i = 0
@@ -308,14 +264,62 @@
                 width = 300
             self.SetColumnWidth(col=i, width=width)
             i += 1
         self.SendSizeEvent()
         self.log.write(_("Number of loaded records: %d") % \
                            self.GetItemCount())
         return keyId
+    def AddDataRow(self, i, record, columns, keyId):
+        """!Add row to the data list"""
+        self.itemDataMap[i] = []
+        j = 0
+        for value in record.split('|'):
+            if self.columns[columns[j]]['ctype'] != type(str):
+                try:
+                    ### casting disabled (2009/03)
+                    ### self.itemDataMap[i].append(self.columns[columns[j]]['ctype'](value))
+                    self.itemDataMap[i].append(value)
+                except ValueError:
+                    self.itemDataMap[i].append(_('Unknown value'))
+            else:
+                # encode string values
+                try:
+                    self.itemDataMap[i].append(unicodeValue(value))
+                except UnicodeDecodeError:
+                    self.itemDataMap[i].append(_("Unable to decode value. "
+                                                 "Set encoding in GUI preferences ('Attributes')."))
+            if keyId > -1 and keyId == j:
+                try:
+                    cat = self.columns[columns[j]]['ctype'] (value)
+                except ValueError, e:
+                    cat = -1
+                    wx.MessageBox(parent=self,
+                                  message=_("Error loading attribute data. "
+                                            "Record number: %(rec)d. Unable to convert value '%(val)s' in "
+                                            "key column (%(key)s) to integer.\n\n"
+                                            "Details: %(detail)s") % \
+                                      { 'rec' : i + 1, 'val' : value,
+                                        'key' : keyColumn, 'detail' : e},
+                                  caption=_("Error"),
+                                  style=wx.OK | wx.ICON_ERROR | wx.CENTRE)
+            j += 1
+        # insert to table
+        # index = self.InsertStringItem(index=sys.maxint, label=str(self.itemDataMap[i][0]))
+        # for j in range(len(self.itemDataMap[i][1:])):
+        # self.SetStringItem(index=index, col=j+1, label=str(self.itemDataMap[i][j+1]))
+        # self.SetItemData(item=index, data=i)
+        self.itemIndexMap.append(i)
+        if keyId > -1: # load cats only when LoadData() is called first time
+            self.itemCatsMap[i] = cat
     def OnItemSelected(self, event):
         """!Item selected. Add item to selected cats..."""
         #         cat = int(self.GetItemText(event.m_itemIndex))
@@ -1870,6 +1874,10 @@
     def OnCloseWindow(self, event):
         """!Cancel button pressed"""
         self.Close()
+        if self.parent.GetName() == 'LayerManager':
+            # deregister ATM
+            self.parent.dialogs['atm'].remove(self)
         event.Skip()
     def OnBuilder(self,event):
@@ -2014,7 +2022,24 @@
         ### modify layer
         self.manageLayerBook.modifyLayerWidgets['layer'][1].SetItems(listOfLayers)
         self.manageLayerBook.OnChangeLayer(event=None)
+    def GetVectorName(self):
+        """!Get vector name"""
+        return self.vectorName
+    def LoadData(self, layer, columns=None, where=None):
+        """!Load data into list
+        @param layer layer number
+        @param columns list of columns for output
+        @param where where statement
+        @return id of key column
+        @return -1 if key column is not displayed
+        listWin = self.FindWindowById(self.layerPage[layer]['data'])
+        return listWin.LoadData(layer, columns, where)
 class TableListCtrl(wx.ListCtrl,
                     listmix.ListCtrlAutoWidthMixin):
                     #                    listmix.TextEditMixin):
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/gselect.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/gselect.py	2009-06-15 18:06:59 UTC (rev 37888)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/gselect.py	2009-06-15 18:10:42 UTC (rev 37889)
@@ -402,7 +402,11 @@
             for name in self.tables[table].keys():
                 self.tables[table][name]['values'] = []
                 self.tables[table][name]['ids']    = []
+    def GetName(self):
+        return self.map
 class LayerSelect(wx.Choice):
     Creates combo box for selecting data layers defined for vector.
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp_window.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp_window.py	2009-06-15 18:06:59 UTC (rev 37888)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp_window.py	2009-06-15 18:10:42 UTC (rev 37889)
@@ -160,6 +160,7 @@
         self.Map = Map
         self.tree = tree
+        self.lmgr = lmgr    # Layer Manager
         # Flags
@@ -1128,7 +1129,7 @@
                 return
             self.UpdateMap(render=False) # redraw map
             # add new record into atribute table
             if UserSettings.Get(group='vdigit', key="addRecord", subkey='enabled')  is True:
                 # select attributes based on layer and category
@@ -1144,22 +1145,43 @@
        cats=cats,
        pos=posWindow,
        action="add")
                 if addRecordDlg.mapDBInfo and \
                         addRecordDlg.ShowModal() == wx.ID_OK:
                     sqlfile = tempfile.NamedTemporaryFile(mode="w")
                     for sql in addRecordDlg.GetSQLString():
                         sqlfile.file.write(sql + ";\n")
                     sqlfile.file.flush()
                     gcmd.RunCommand('db.execute',
                                     parent = self,
                                     quiet = True,
                                     input = sqlfile.name)
+                if addRecordDlg.mapDBInfo:
+                    self.__updateATM()
         elif digitToolbar.GetAction('type') in ["line", "boundary"]:
             # add new point to the line
             self.polycoords.append(self.Pixel2Cell(event.GetPositionTuple()[:]))
             self.DrawLines(pdc=self.pdcTmp)
+    def __updateATM(self):
+        """!Update open Attribute Table Manager
+        @todo: use AddDataRow() instead
+        # update ATM
+        digitToolbar = self.parent.toolbars['vdigit']
+        digitVector = digitToolbar.GetLayer().GetName()
+        for atm in self.lmgr.dialogs['atm']:
+            atmVector = atm.GetVectorName()
+            if atmVector == digitVector:
+                layer = UserSettings.Get(group='vdigit', key="layer", subkey='value')
+                # TODO: use AddDataRow instead
+                atm.LoadData(layer)
     def OnLeftDownVDigitEditLine(self, event):
         Left mouse button down - vector digitizer edit linear feature
@@ -1942,10 +1964,14 @@
                                             quiet = True,
             elif digitToolbar.GetAction() == "deleteLine":
                 # -> delete selected vector features
                 if digitClass.DeleteSelectedLines() < 0:
                     return
             elif digitToolbar.GetAction() == "splitLine":
                 # split line
                 if digitClass.SplitLine(self.Pixel2Cell(self.mouse['begin'])) < 0:
@@ -1973,6 +1999,9 @@
                     del self.copyCatsIds
                 except AttributeError:
                     pass
             elif digitToolbar.GetAction() == "editLine" and \
                     hasattr(self, "vdigitMove"):
                 line = digitClass.driver.GetSelected()
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/vdigit.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/vdigit.py	2009-06-15 18:06:59 UTC (rev 37888)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/vdigit.py	2009-06-15 18:10:42 UTC (rev 37889)
@@ -1,15 +1,13 @@
 @package vdigit
 @brief Vector digitizer extension
-Progress:
- (1) v.edit called on the background (class VEdit) (removed in r?)
- (2) Reimplentation of v.digit (VDigit)
 Import:
+ at code
   from vdigit import VDigit as VDigit
+ at endcode
 Classes:
  - AbstractDigit
Modified: grass/branches/develbranch_6/gui/wxpython/wxgui.py
--- grass/branches/develbranch_6/gui/wxpython/wxgui.py	2009-06-15 18:06:59 UTC (rev 37888)
+++ grass/branches/develbranch_6/gui/wxpython/wxgui.py	2009-06-15 18:10:42 UTC (rev 37889)
@@ -120,8 +120,11 @@
         self.curr_pagenum  = ''           # currently selected page number for layer tree notebook
         self.encoding      = 'ISO-8859-1' # default encoding for display fonts
         self.workspaceFile = workspace    # workspace file
-        self.menucmd       = {}           # menuId / cmd
+        self.menucmd       = dict()       # menuId / cmd
         self.georectifying = None         # reference to GCP class or None
+        # list of open dialogs
+        self.dialogs        = dict()
+        self.dialogs['atm'] = list()
         # creating widgets
         # -> self.notebook, self.goutput, self.outpage
@@ -1065,19 +1068,19 @@
         if not self.curr_page:
             self.MsgNoLayerSelected()
             return
         layer = self.curr_page.maptree.layer_selected
         # no map layer selected
         if not layer:
             return
         # available only for vector map layers
         try:
             maptype = self.curr_page.maptree.GetPyData(layer)[0]['maplayer'].type
         except:
             maptype = None
         if not maptype or maptype != 'vector':
                           message=_("Attribute management is available only "
@@ -1085,7 +1088,7 @@
                           caption=_("Message"),
                           style=wx.OK | wx.ICON_INFORMATION | wx.CENTRE)
             return
         if not self.curr_page.maptree.GetPyData(layer)[0]:
             return
         dcmd = self.curr_page.maptree.GetPyData(layer)[0]['cmd']
@@ -1096,14 +1099,18 @@
                            parent=self)
         wx.Yield()
-        self.dbmanager = dbm.AttributeManager(parent=self, id=wx.ID_ANY,
-                                              size=wx.Size(500, 300),
-                                              item=layer, log=self.goutput)
+        dbmanager = dbm.AttributeManager(parent=self, id=wx.ID_ANY,
+                                         size=wx.Size(500, 300),
+                                         item=layer, log=self.goutput)
         busy.Destroy()
-        self.dbmanager.Show()
+        # register ATM dialog
+        self.dialogs['atm'].append(dbmanager)
+        # show ATM window
+        dbmanager.Show()
     def OnNewDisplay(self, event=None):
         """!Create new layer tree and map display instance"""
         self.NewDisplay()
