[GRASS-SVN] r37898 - grass/trunk/lib/init
svn_grass at osgeo.org
Mon Jun 15 16:45:14 EDT 2009
Author: martinl
Date: 2009-06-15 16:45:13 -0400 (Mon, 15 Jun 2009)
New Revision: 37898
grass/trunk/lib/init/grass.py
fix bash_startup
Modified: grass/trunk/lib/init/grass.py
--- grass/trunk/lib/init/grass.py 2009-06-15 20:13:51 UTC (rev 37897)
+++ grass/trunk/lib/init/grass.py 2009-06-15 20:45:13 UTC (rev 37898)
@@ -690,7 +690,7 @@
def bash_startup():
global exit_val
# save command history in mapset dir and remember more
os.environ['HISTFILE'] = os.path.join(location, ".bash_history")
if not os.getenv('HISTSIZE') and not os.getenv('HISTFILESIZE'):
@@ -707,16 +707,16 @@
try_remove(bashrc)
f = open(bashrc, 'w')
- f.write("test -r ~/.alias && . ~/.alias")
- f.write("PS1='GRASS %s (%s):\w > '" % (grass_version, location_name))
- f.write("PROMPT_COMMAND=%s" % gfile("etc", "prompt.sh"))
+ f.write("test -r ~/.alias && . ~/.alias\n")
+ f.write("PS1='GRASS %s (%s):\w > '\n" % (grass_version, location_name))
+ f.write("PROMPT_COMMAND=%s\n" % gfile("etc", "prompt.sh"))
path = os.path.join(userhome, ".grass.bashrc")
if os.access(path, os.R_OK):
- f.write(readfile(path))
+ f.write(readfile(path) + '\n')
- f.write("export PATH=\"%s\"" % os.getenv('PATH'))
- f.write("export HOME=\"%s\"" % userhome) # restore user home path
+ f.write("export PATH=\"%s\"\n" % os.getenv('PATH'))
+ f.write("export HOME=\"%s\"\n" % userhome) # restore user home path
f.close()
